New Exam NCM-MCI-6.10 Materials, New NCM-MCI-6.10 Test Guide
Posted at 1/17/2026 19:03:08
It is hard to pass without in-depth NCM-MCI-6.10 exam preparation. The Actual4Dumps understands this challenge and offers real, valid, and top-notch NCM-MCI-6.10 exam dumps in three different formats. These formats are NCM-MCI-6.10 PDF dumps files, desktop practice test software, and web-based practice test software. All these three NCM-MCI-6.10 Exam Questions formats are easy to use and compatible with all devices, operating systems, and web browsers. Just choose the best NCM-MCI-6.10 exam questions format and start NCM-MCI-6.10 exam preparation without wasting further time.
It is acknowledged that there are numerous NCM-MCI-6.10 learning questions for candidates for the NCM-MCI-6.10 exam, however, it is impossible for you to summarize all of the key points in so many materials by yourself. But since you have clicked into this website for NCM-MCI-6.10 practice materials you need not to worry about that at all because our company is especially here for you to solve this problem. We have a lot of regular customers for a long-term cooperation now since they have understood how useful and effective our NCM-MCI-6.10 Actual Exam is.
New NCM-MCI-6.10 Test Guide & Test NCM-MCI-6.10 OnlineKeep making progress is a very good thing for all people. If you try your best to improve yourself continuously, you will that you will harvest a lot, including money, happiness and a good job and so on. The NCM-MCI-6.10 preparation exam from our company will help you keep making progress. Choosing our NCM-MCI-6.10 Study Material, you will find that it will be very easy for you to overcome your shortcomings and become a persistent person. Just come and buy our NCM-MCI-6.10 learning guide!
Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Sample Questions (Q12-Q17):NEW QUESTION # 12
Use Prism Element for this question.
The Application team has a 3 tier application (App Server, Web Server, and Database Server) that is mission critical and requires as close to 0 RPO and RTO as possible with their current license level.
The organization has 2 clusters, with one cluster (Cluster 1) being production and the other cluster (Cluster 2) being remote/DR. Cluster 2 should be able to fail back to Cluster 1.
The connectivity between the two sites is >5ms and replication traffic should not use more than 10Mbps of bandwidth. The Application team requests a plan that includes the ability to go back 2 days locally, and 2 days remotely.
The team also requests that all 3 VMs be treated as a single group and backed up collectively in a snapshot.
The three VMs are:
* Web-Prod
* App-Prod
* DB-Prod
Use Task3 as part of the name for any objects created for this task.
Note: VMs do NOT need to be powered on. You will need to use the 172.30.0.x IP addresses when configuring DR.
See the Explanation below for detailed answer.
Here is the step-by-step solution to configure Disaster Recovery from the Cluster 1 Prism Element interface.
1. Add Cluster 2 as a Remote Site
First, you must register Cluster 2 as a DR target for Cluster 1.
* From the Cluster 1 Prism Element dashboard, navigate to Data Protection from the main dropdown menu.
* Click the Remote Site tab.
* Click the + Remote Site button and select Physical Cluster.
* In the "Name" field, enter Cluster2_DR_Task3.
* In the "Address" field, enter the 172.30.0.x Virtual IP address of Cluster 2.
* Click Save. The clusters will exchange credentials and connect.
2. Throttle Replication Bandwidth
Next, apply the 10 Mbps bandwidth limit for traffic going to Cluster 2.
* On the same Remote Site tab, select the newly created Cluster2_DR_Task3.
* Click the Update button.
* In the dialog, set the Bandwidth Limit to 10 Mbps.
* Click Save.
3. Create the Protection Domain
A Protection Domain (PD) is the top-level object that will manage the VMs and replication schedules.
* In the Data Protection dashboard, click the Table tab.
* Click the + Protection Domain button and select Async DR.
* For the Name, enter App_PD_Task3.
* Click Create.
4. Protect VMs in a Consistency Group
Now you will add the three application VMs to the new Protection Domain as a single Consistency Group (CG).
* You will be taken to the dashboard for the new App_PD_Task3. In the Entities panel, click the Protect Entities button.
* In the " rotect Entities" dialog, search for and select the three VMs:
* Web-Prod
* App-Prod
* DB-Prod
* Click Next.
* Select Create new consistency group and name it App_CG_Task3.
* Click Protect.
5. Create the Replication Schedule
Finally, configure the schedule to meet the RPO and retention requirements.
* In the App_PD_Task3 dashboard, click the Schedules tab.
* Click the + New Schedule button.
* Remote Site: Select Cluster2_DR_Task3.
* RPO (Repeat every): Select NearSync. Set the RPO to 1 minute.
* Note: This is the lowest possible RPO for an Async (>5ms latency) connection, fulfilling the "as close to 0" requirement.
* Local Retention: Set to 2 Days.
* Remote Retention: Set to 2 Days.
* Ensure the "Store snapshots for 2-way replication" checkbox is enabled to allow failback from Cluster 2.
* Click Create Schedule.
NEW QUESTION # 13
Due to new security requirements, an administrator has been tasked with updating the security settings for user accounts within Prism Element on Cluster 1.
An SSL Certificate Signing Request with Subject Alternative Name should be generated for submission to the security team's Certificate Authority with the following details:
countryName = US
stateOrProvinceName = North Carolina
localityName = Durham
organizationName = ACME
organizationalUnitName = Infrastructure
commonName = prism_element.ACME.org
emailAddress = administrator@ACME.org
Alternate names = cvm1.ACME.org, cvm2.ACME.org, cvm3.ACME.org
Encryption: RSA 2048, sha256
When the Certificate Signing Request is generated, place a copy of both the .cnf file and the .csr file on the desktop named 'prism_element_acme.cnf' and 'prism_element_acme.csr' Save a copy of the command(s) used for this scenario to a new file on the desktop named "Task 5.txt".
Note: You must copy and paste the command(s) and output from SSH to the "Task 5.txt" file to achieve all points available.
Here is the step-by-step solution to generate the Certificate Signing Request (CSR) on Cluster 1.
This entire process is performed from an SSH session connected to a CVM (Controller VM) on Cluster 1.
1. Access Cluster 1 CVM
* From Prism Central, navigate to Hardware > Clusters and click on Cluster 1 to open its Prism Element (PE) interface.
* In the Cluster 1 PE, navigate to Hardware > CVMs to find the IP address of any CVM in the cluster.
* Use an SSH client (like PuTTY) to connect to the CVM's IP address.
* Log in with the admin user and password.
2. Create the Configuration File (.cnf)
To include the Subject Alternative Names (SANs), you must first create a configuration file.
* In the CVM's command line, create the .cnf file using a text editor:
vi prism_element_acme.cnf
* Press i to enter "Insert" mode.
* Paste the following text exactly into the editor:
Ini, TOML
[ req ]
default_bits = 2048
distinguished_name = req_distinguished_name
req_extensions = v3_req
prompt = no
[ req_distinguished_name ]
C = US
ST = North Carolina
L = Durham
O = ACME
OU = Infrastructure
CN = prism_element.ACME.org
[ v3_req ]
subjectAltName = @alt_names
[ alt_names ]
DNS.1 = cvm1.ACME.org
DNS.2 = cvm2.ACME.org
DNS.3 = cvm3.ACME.org
* Press Esc to exit "Insert" mode, then type :wq and press Enter to save and quit vi.
3. Generate the CSR and Key
* Run the following openssl command. This command uses the .cnf file to generate the new CSR (.csr) and a corresponding private key (.key), applying the sha256 encryption as requested.
Bash
openssl req -new -nodes -out prism_element_acme.csr -keyout prism_element_acme.key -config prism_element_acme.cnf -sha256
* The command will output the following, confirming the key generation:
* Generating a 2048 bit RSA private key
* writing new private key to 'prism_element_acme.key'
4. Save Files to the Desktop
You will now copy the contents of the generated files from the CVM to your desktop.
* For Task 5.txt (Commands and Output):
* Open a new Notepad file on the desktop.
* Copy and paste all the commands you ran in the SSH session and their full output (as shown in steps 2 and 3) into this file.
* Save the file on the desktop as Task 5.txt.
* For prism_element_acme.cnf:
* In the CVM SSH session, display the file's content:
cat prism_element_acme.cnf
* Copy the entire text output (starting from [ req ]).
* Paste the content and save the file as prism_element_acme.cnf.
* For prism_element_acme.csr:
cat prism_element_acme.csr
* Copy the entire text output, including the -----BEGIN CERTIFICATE REQUEST----- and ----- END CERTIFICATE REQUEST----- lines.
* Open a new C:UsersadminDesktopNotepad file on the desktop.
* Paste the content and save the file as prism_element_acme.csr.
NEW QUESTION # 14
Following new security guidelines, it must be ensured that the storage of critical virtual machines will be encrypted in future.
The assignment is to be made by a new category called VM-Storage with a value of softwareencrypted in Prism Central. Make sure a second value of SEDencrypted is also created for future use.
Create the above-mentioned category and perform further configurations in Prism Central for VM-based storage encryption.
Assign the name Encrypted-Storage to the newly created policy.
Here is the step-by-step solution to create the category and the corresponding storage encryption policy within Prism Central.
1. Create the Category
First, you must create the category and the two values requested.
* In Prism Central, navigate to Administration > Categories.
* Click New Category.
* In the Name field, enter VM-Storage.
* In the Add a Value field, type softwareencrypted and click the Add (plus) button.
* In the Add a Value field again, type SEDencrypted and click the Add (plus) button.
* Click Save.
2. Create the Encryption Policy
Next, you will create the security policy that uses the new category.
* In Prism Central, navigate to Security > Data-at-Rest Encryption.
* Click the + Create Security Policy button.
* In the Policy Name field, enter Encrypted-Storage.
* Ensure the Encryption Type is set to Software-based.
* For Target VMs, select the radio button for VMs matching a category.
* In the Select Category dropdown, choose the VM-Storage category you just created.
* In the Select Value dropdown, choose softwareencrypted.
* Click Save.
This policy will now automatically apply software-based encryption to any new or existing VMs that are assigned the VM-Storage: softwareencrypted category.
NEW QUESTION # 15
Task 8
An administrator has environment that will soon be upgraded to 6.5. In the meantime, they need to implement log and apply a security policy named Staging_Production, such that not VM in the Staging Environment can communicate with any VM in the production Environment, Configure the environment to satisfy this requirement.
Note: All other configurations not indicated must be left at their default values.
See the Explanation for step by step solution.
To configure the environment to satisfy the requirement of implementing a security policy named Staging_Production, such that no VM in the Staging Environment can communicate with any VM in the production Environment, you need to do the following steps:
Log in to Prism Central and go to Network > Security Policies > Create Security Policy. Enter Staging_Production as the name of the security policy and select Cluster A as the cluster.
In the Scope section, select VMs as the entity type and add the VMs that belong to the Staging Environment and the Production Environment as the entities. You can use tags or categories to filter the VMs based on their environment.
In the Rules section, create a new rule with the following settings:
Direction: Bidirectional
Protocol: Any
Source: Staging Environment
Destination: Production Environment
Action: Deny
Save the security policy and apply it to the cluster.
This will create a security policy that will block any traffic between the VMs in the Staging Environment and the VMs in the Production Environment. You can verify that the security policy is working by trying to ping or access any VM in the Production Environment from any VM in the Staging Environment, or vice versa.
You should not be able to do so.
NEW QUESTION # 16
Create a VM template on Cluster 1 named Small Template that matches the small VM Configuration in NVD-2031 (see the FilesDocumentation 6.10 folder) however, you will use default storage container.
Configure SMTP Alerting and NCC reports per NVD-2031 for Cluster 1.
Settings:
* SMTP: Use Cluster 2 IP address
* Cluster email: cluster1@ACME.org
* Alert emails: primaryalerts@ACME.org, secondaryalerts@ACME.org
Here is the step-by-step solution to complete both tasks on Cluster 1.
This solution requires you to first find the IP of Cluster 2 (for the SMTP server) and then perform all configurations within the Prism Element interface for Cluster 1.
Prerequisite: Find Cluster 2 IP
* In Prism Central, navigate to Hardware > Clusters.
* Find Cluster 2 in the list and note its IP Address. You will use this in the steps below.
Task 1: Create the VM Template
* Log in to the Prism Element (PE) interface for Cluster 1. (From PC, go to Hardware > Clusters > click the name "Cluster 1").
* Navigate to the VM view from the main dashboard.
* Click the + Create VM button.
* Fill in the VM details based on the NVD-2031 "Small VM" configuration (e.g., 2 vCPUs, 1 Core per vCPU, 4 GB RAM).
* Name: Small Template
* Compute Details:
* vCPUs: 2
* Number of Cores per vCPU: 1
* Memory: 4 GB
* Scroll down to Storage and click + Add New Disk.
* Operation: Select Clone from Image Service.
* Image: Select any available guest OS image (e.g., a Windows or CentOS image).
* Storage Container: Ensure the default container is selected (as required by the task).
* Click Add.
* Scroll down to Network Adapters (NIC) and click + Add NIC.
* Select any available VLAN/Subnet (e.g., Primary).
* Click Add.
* Click Save. The VM will be created (and remain powered off).
* Find the new Small Template VM in the list. Select its checkbox.
* Click the Actions dropdown and select Convert to Template.
* Confirm the action by clicking OK.
Task 2: Configure SMTP and NCC Reports
* While still in the Cluster 1 Prism Element interface, click the gear icon (Settings) in the top-right corner.
* Select SMTP Server from the left-hand menu.
* Click the Configure button.
* In the "Server Settings" tab, fill in the following:
* Server Address: Enter the Cluster 2 IP Address (which you found in the prerequisite step).
* Port: 25 (leave as default).
* From Email Address: cluster1@ACME.org
* Click Next.
* In the "Email Recipients" tab, click + Add Email Recipient.
* Address: primaryalerts@ACME.org
* Ensure all severities (Critical, Warning, Info) are checked.
* Click Save.
* Click + Add Email Recipient again.
* Address: secondaryalerts@ACME.org
* Ensure all severities are checked.
* Click Save.
* Click Done. A test email will be sent.
* In the main Settings menu, select Alerts and Notifications.
* Scroll to the NCC Health Checks section.
* Check the box labeled Email Nutanix Cluster Check reports to recipients. (This will use the SMTP settings and recipients you just configured).
* Click Save.
NEW QUESTION # 17
If you buy the NCM-MCI-6.10 study materials of us, we ensure you to pass the exam. Since the NCM-MCI-6.10 study materials have the quality and the accuracy, and it will help you pass exam just one time. Buying NCM-MCI-6.10 exam dumps are pass guaranteed and money back guaranteed for the failure. Furthermore, we choose international confirmation third party for payment for the NCM-MCI-6.10 Exam Dumps, therefore we can ensure you the safety of your account and your money. The refund money will return to your payment account.
New NCM-MCI-6.10 Test Guide: https://www.actual4dumps.com/NCM-MCI-6.10-study-material.html
In order to give you a basic understanding NCM-MCI-6.10 our various versions, each version offers a free trial, The successful endeavor of any kind of exam not only hinges on the NCM-MCI-6.10 effort the exam candidates paid, but the quality of practice materials’ usefulness, For the details of Actual4Dumps New NCM-MCI-6.10 Test Guide's money back gurantee, please go to the left "Guarantee column, NCM-MCI-6.10 Questions | 100% Valid NCM-MCI-6.10 Dumps with Verified Answers.
Keep the room cool and dark, Using a Hidden Workbook as an Alternative to an Add-In, In order to give you a basic understanding NCM-MCI-6.10 our various versions, each version offers a free trial, The successful endeavor of any kind of exam not only hinges on the NCM-MCI-6.10 effort the exam candidates paid, but the quality of practice materials’ usefulness.
100% Pass Nutanix - New Exam NCM-MCI-6.10 MaterialsFor the details of Actual4Dumps's money back gurantee, please go to the left "Guarantee column, NCM-MCI-6.10 Questions | 100% Valid NCM-MCI-6.10 Dumps with Verified Answers.
Let along the reasonable prices which attracted New Exam NCM-MCI-6.10 Materials tens of thousands of exam candidates mesmerized by their efficiency by proficient helpers of our company, One of the striking NCM-MCI-6.10 benefits is that we provide a free demo of our product absolutely free of cost.
- NCM-MCI-6.10 Relevant Answers 🐔 Cost Effective NCM-MCI-6.10 Dumps 🌕 NCM-MCI-6.10 Valid Exam Cram 🌆 Immediately open ▛ [url]www.practicevce.com ▟ and search for ➡ NCM-MCI-6.10 ️⬅️ to obtain a free download 🦊
df NCM-MCI-6.10 Version[/url] - High Pass-Rate Nutanix New Exam NCM-MCI-6.10 Materials Offer You The Best New Test Guide | Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) 🥊 Simply search for “ NCM-MCI-6.10 ” for free download on ✔ [url]www.pdfvce.com ️✔️ 🥃Valid NCM-MCI-6.10 Test Pattern[/url]
- 100% Pass Quiz Nutanix - NCM-MCI-6.10 - Updated New Exam Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Materials 🧂 Search for ▛ NCM-MCI-6.10 ▟ and obtain a free download on ➡ [url]www.exam4labs.com ️⬅️ 😉NCM-MCI-6.10 Latest Practice Questions[/url]
- Pass Guaranteed 2026 Nutanix NCM-MCI-6.10: Reliable New Exam Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Materials 📉 Download { NCM-MCI-6.10 } for free by simply entering ⏩ [url]www.pdfvce.com ⏪ website 🚾
assing NCM-MCI-6.10 Score[/url] - 100% Pass Nutanix - NCM-MCI-6.10 Authoritative New Exam Materials 😥 ☀ [url]www.prepawaypdf.com ️☀️ is best website to obtain ▷ NCM-MCI-6.10 ◁ for free download 🤕NCM-MCI-6.10 Valid Exam Cram[/url]
- 100% Pass Quiz 2026 Nutanix High-quality New Exam NCM-MCI-6.10 Materials 👲 Open ▶ [url]www.pdfvce.com ◀ enter “ NCM-MCI-6.10 ” and obtain a free download 🧵Valid NCM-MCI-6.10 Test Pattern[/url]
- NCM-MCI-6.10 Exam Cram Questions 🤹 NCM-MCI-6.10 Exam Cram Questions 🥁 NCM-MCI-6.10 Latest Practice Questions ✊ Easily obtain ⏩ NCM-MCI-6.10 ⏪ for free download through ⮆ [url]www.validtorrent.com ⮄ 🕦Reliable NCM-MCI-6.10 Mock Test[/url]
- [url=https://gambitsphere.com/?s=100%%20Pass%20Quiz%20Nutanix%20-%20NCM-MCI-6.10%20-%20Updated%20New%20Exam%20Nutanix%20Certified%20Master%20-%20Multicloud%20Infrastructure%20(NCM-MCI)%20Materials%20%f0%9f%9a%a0%20Download%20%e2%96%b6%20NCM-MCI-6.10%20%e2%97%80%20for%20free%20by%20simply%20entering%20[%20www.pdfvce.com%20]%20website%20%f0%9f%8f%93Valid%20NCM-MCI-6.10%20Exam%20Topics]100% Pass Quiz Nutanix - NCM-MCI-6.10 - Updated New Exam Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Materials 🚠 Download ▶ NCM-MCI-6.10 ◀ for free by simply entering [ www.pdfvce.com ] website 🏓Valid NCM-MCI-6.10 Exam Topics[/url]
- Pass Guaranteed 2026 Nutanix NCM-MCI-6.10: Reliable New Exam Nutanix Certified Master - Multicloud Infrastructure (NCM-MCI) Materials ⬜ Search for ▷ NCM-MCI-6.10 ◁ and easily obtain a free download on ➡ [url]www.pass4test.com ️⬅️ ➡️NCM-MCI-6.10 Lead2pass[/url]
- NCM-MCI-6.10 Latest Practice Questions 😰 NCM-MCI-6.10 Reliable Exam Practice 🎷 Reliable NCM-MCI-6.10 Mock Test ⏸ Simply search for 「 NCM-MCI-6.10 」 for free download on ▛ [url]www.pdfvce.com ▟ 📖NCM-MCI-6.10 Reliable Exam Practice[/url]
- NCM-MCI-6.10 Valid Vce 🏥 NCM-MCI-6.10 Pdf Version 🧽 Practice NCM-MCI-6.10 Exam Online 🥒 Open ⏩ [url]www.practicevce.com ⏪ enter { NCM-MCI-6.10 } and obtain a free download 🚬NCM-MCI-6.10 Relevant Answers[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, pbzp.net, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
