[General] Confluent CCAAK Exam Practice, CCAAK Sample Test Online
76
【General】 Confluent CCAAK Exam Practice, CCAAK Sample Test Online
Posted at 1/17/2026 19:11:51      View:138 | Replies:2        Print      Only Author   [Copy Link] 1#
Through our investigation and analysis of the real problem over the years, our CCAAK learning materials can accurately predict the annual CCAAK exams. In the actual exam process, users will encounter almost half of the problem is similar in our products. Even if the syllabus is changing every year, the CCAAK Study Materials’ experts still have the ability to master propositional trends. Believe that such a high hit rate can better help users in the review process to build confidence, and finally help users through the qualification examination to obtain a certificate.
In rare cases, if you fail to pass the Confluent Certified Administrator for Apache Kafka CCAAK exam despite using Confluent Certified Administrator for Apache Kafka exam dumps we will return your whole payment without any deduction. Take the best decision of your professional career and start exam preparation with Confluent Certified Administrator for Apache Kafka exam practice questions and become a certified Confluent Certified Administrator for Apache Kafka CCAAK expert.
Three Formats for the Confluent CCAAK Exam QuestionsIf you require any further information about either our CCAAK preparation exam or our corporation, please do not hesitate to let us know. High quality CCAAK practice materials leave a good impression on the exam candidates and bring more business opportunities in the future. And many of our cutomers use our CCAAK Exam Questions as their exam assistant and establish a long cooperation with us.
Confluent CCAAK Exam Syllabus Topics:
  • Troubleshooting: This section of the exam measures skills of a Kafka Administrator and includes diagnosing common issues in Kafka clusters. It covers problem areas such as performance bottlenecks, message delivery failures, replication issues, and consumer lag, along with techniques to resolve them effectively.
  • Deployment Architecture: This section of the exam measures skills of a Kafka Administrator and covers different Kafka deployment topologies. It evaluates understanding of high availability, disaster recovery, multi-data center replication, and the roles of Zookeeper or KRaft in the cluster architecture.
  • Apache Kafka® Security: This section of the exam measures skills of a Site Reliability Engineer and focuses on securing Kafka environments. It includes authentication mechanisms such as TLS and SASL, authorization using ACLs, and encrypting data at rest and in transit to ensure secure communication and access control.
  • Observability: This section of the exam measures skills of a Site Reliability Engineer and focuses on monitoring Kafka clusters. It assesses knowledge of metrics, logging, and alerting tools, including how to use them to maintain cluster health and performance visibility.
Confluent Certified Administrator for Apache Kafka Sample Questions (Q11-Q16):NEW QUESTION # 11
If a broker's JVM garbage collection takes too long, what can occur?
  • A. There is backpressure to, and pausing of, Kafka clients.
  • B. There will be a trigger of the broker's log cleaner thread.
  • C. Log files written to disk are loaded into the page cache.
  • D. ZooKeeper believes the broker to be dead.
If the broker's JVM garbage collection (GC) pause is too long, it may fail to send heartbeats to ZooKeeper within the expected interval. As a result, ZooKeeper considers the broker dead, and the broker may be removed from the cluster, triggering leader elections and partition reassignments.
NEW QUESTION # 12
Which statements are correct about partitions? (Choose two.)
  • A. A partition in Kafka will be represented by a single segment on a disk.
  • B. A partition is comprised of one or more segments on a disk.
  • C. All partition segments reside in a single directory on a broker disk.
  • D. A partition size is determined after the largest segment on a disk.
NEW QUESTION # 13
What is the correct permission check sequence for Kafka ACLs?
  • A. Super Users -> Allow ACL -> Deny ACL-> Deny
  • B. Super Users -> Deny ACL -> Allow ACL -> Deny
  • C. Deny ACL -> Deny -> Allow ACL -> Super Users
  • D. Allow ACL -> Deny ACL -> Super Users -> Deny
Kafka checks permissions in the following sequence:
1. Super Users: If the user is a super user (defined via super.users), access is granted immediately.
2. Allow ACL: If there is a matching Allow ACL, Kafka proceeds to the next step.
3. Deny ACL: If there is a matching Deny ACL, access is denied (even if an Allow exists).
4. Deny: If no matching ACLs are found, access is denied by default.
This order ensures that super users bypass ACLs, denials override allows, and default is deny.
NEW QUESTION # 14
How can authentication for both internal component traffic and external client traffic be accomplished?
  • A. Configure multiple listeners on the broker.
  • B. Configure multiple security protocols on the same listener.
  • C. Configure multiple brokers.
  • D. Configure LoadBalancer.
Kafka supports multiple listeners, each with its own port, hostname, and security protocol. This allows you to:
*  Use one listener for internal communication (e.g., brokers, ZooKeeper, Connect, etc.) with one type of authentication (e.g., PLAINTEXT or SASL).
* Use a separate listener for external clients (e.g., producers and consumers) with a different protocol (e.g., SSL or SASL_SSL).
NEW QUESTION # 15
Which of the following are Kafka Connect internal topics? (Choose three.)
  • A. connect-standalone
  • B. connect-confiqs
  • C. connect-status
  • D. connect-distributed
  • E. connect-offsets
Answer: B,C,E
connect-configs stores connector configurations.
connect-status tracks the status of connectors and tasks (e.g., RUNNING, FAILED).
connect-offsets stores source connector offsets for reading from external systems.
NEW QUESTION # 16
Our CCAAK test questions are available in three versions, including PDF versions, PC versions, and APP online versions. And CCAAK test material users can choose according to their own preferences. The most popular version is the PDF version of CCAAK exam prep. The PDF version of CCAAK test questions can be printed out to facilitate your learning anytime, anywhere, as well as your own priorities. The PC version of CCAAK Exam Prep is for Windows users. If you use the APP online version, just download the application program, you can enjoy our CCAAK test material service.
CCAAK Sample Test Online: https://www.lead2passexam.com/Confluent/valid-CCAAK-exam-dumps.html
Posted at 1/20/2026 00:01:37        Only Author  2#
This article has helped me answer many questions, and it's really great. Get your hands on the C-TB120-2504 reliable study guide files questions for free—the key to your next promotion!
Posted at 2/5/2026 02:44:20        Only Author  3#
Your article is brilliant beyond words, I’m thankful for your share! Sharing Examcollection PEGACPBA24V1 dumps torrent resources for free—good luck with your studies!
