[Hardware] 312-50v13 Free Practice Exams | Latest ECCouncil 312-50v13: Certified Ethical Ha
76
Hardware 312-50v13 Free Practice Exams | Latest ECCouncil 312-50v13: Certified Ethical Ha
Posted at 1/17/2026 19:32:44      View215 | Replies2        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of ITExamSimulator 312-50v13 dumps for free: https://drive.google.com/open?id=1Yu1RlCVvkqc2LXySUnBEp5kknpTxEdYE
ITExamSimulator Certified Ethical Hacker Exam (CEHv13) (312-50v13) self-evaluation tests serve as a call to action, guiding you on how to improve your performance before the ECCouncil 312-50v13 real exam. ITExamSimulator's Certified Ethical Hacker Exam (CEHv13) (312-50v13) web-based and desktop practice dumps also provide candidates with a realistic 312-50v13 Exam scenario, allowing them to experience the 312-50v13 actual exam situation and prepare accordingly. Our 312-50v13 practice questions offer an excellent opportunity to identify and practice the strategies that work best for you.
Obtaining a certificate may be not an easy thing for some candidates, choose us, we will help you get the certificate easily. 312-50v13 learning materials are edited by experienced experts, therefore the quality and accuracy can be guaranteed. In addition, 312-50v13 exam braindumps contact most of knowledge points for the exam, and you can mater the major knowledge points well by practicing. In order to improve your confidence to 312-50v13 Exam Materials, we are pass guarantee and money back guarantee. If you fail to pass the exam by using 312-50v13 exam materials, we will give you full refund.
Online ECCouncil 312-50v13 Lab Simulation, 312-50v13 Download PdfWe consider the actual situation of the test-takers and provide them with high-quality learning materials at a reasonable price. Choose the 312-50v13 study materials absolutely excellent quality and reasonable price, because the more times the user buys the 312-50v13 study materials, the more discount he gets. In order to make the user's whole experience smoother, we also provide a thoughtful package of services. Once users have any problems related to the 312-50v13 Study Materials, our staff will help solve them as soon as possible.
ECCouncil Certified Ethical Hacker Exam (CEHv13) Sample Questions (Q453-Q458):NEW QUESTION # 453
Rebecca, a security professional, wants to authenticate employees who use web services for safe and secure communication. In this process, she employs a component of the Web Service Architecture, which is an extension of SOAP, and it can maintain the integrity and confidentiality of SOAP messages.
Which of the following components of the Web Service Architecture is used by Rebecca for securing the communication?
  • A. WSDL
  • B. WS-Security
  • C. WS Work Processes
  • D. WS-Policy
WS-Security (Web Services Security) is a protocol specification that provides a means for securing SOAP- based messages. It defines how to add authentication, encryption, and digital signatures to SOAP headers, helping ensure message integrity and confidentiality.
According to CEH v13 Official Courseware:
WS-Security is an extension of SOAP.
It supports features such as:
Authentication via tokens (e.g., username, X.509)
Message integrity via digital signatures
Message confidentiality via XML encryption
Incorrect Options:
A). WSDL (Web Services Description Language) describes the web service interface but does not provide security.
B). WS Work Processes is not a defined web service security standard.
C). WS-Policy allows expressing security requirements, but enforcement is handled by WS-Security.
Reference - CEH v13 Official Courseware:
Module 14: Hacking Web Applications
Section: "Web Services Security"
Subsection: "WS-* Standards"
NEW QUESTION # 454
A penetration tester is assessing a web application that uses dynamic SQL queries for searching users in the database. The tester suspects the search input field is vulnerable to SQL injection. What is the best approach to confirm this vulnerability?
  • A. Input DROP TABLE users; -- into the search field to test if the database query can be altered
  • B. Perform a brute-force attack on the user login page to guess weak passwords
  • C. Inject JavaScript into the search field to test for Cross-Site Scripting (XSS)
  • D. Use a directory traversal attack to access server configuration files
CEH explains that SQL injection testing should begin with controlled, intentional manipulation of SQL syntax to determine whether user input is improperly concatenated into backend queries. While destructive queries like DROP TABLE are not recommended in real-world ethical hacking engagements, CEH uses this example as a conceptual demonstration of how SQLi can influence database commands. In practice, a penetration tester would more safely use benign tautologies such as ' OR '1'='1 to test whether unauthorized data is returned. However, within CEH's theoretical framing, injecting a clearly malicious SQL command demonstrates whether the input is executed at the database level. This validates improper sanitization, the use of dynamic SQL queries, and missing parameterized input handling. CEH stresses that SQLi is among the most critical vulnerabilities because it allows attackers to bypass authentication, exfiltrate data, or manipulate the database structure. XSS, brute-forcing, and directory traversal do not test SQL query manipulation and therefore do not confirm SQL injection.
NEW QUESTION # 455
What would be the fastest way to perform content enumeration on a given web server by using the Gobuster tool?
  • A. Performing content enumeration using the bruteforce mode and random file extensions
  • B. Shipping SSL certificate verification
  • C. Performing content enumeration using a wordlist
  • D. Performing content enumeration using the bruteforce mode and 10 threads
Analyze Web Applications: Identify Files and Directories - enumerate applications, as well as hidden directories and files of the web application hosted on the web server. Tools such as #Gobuster is directory scanner that allows attackers to perform fast-paced enumeration of hidden files and directories of a target web application. # gobuster -u <target URL> -w common.txt (wordlist) (P.1849/1833)
NEW QUESTION # 456
One of your team members has asked you to analyze the following SOA record.
What is the TTL?
Rutgers.edu. SOA NS1.Rutgers.edu ipad.college.edu (200302028 3600 3600 604800 2400.)
  • A. 0
  • B. 1
  • C. 2
  • D. 3
  • E. 4
  • F. 5
The SOA (Start of Authority) record contains key DNS parameters, including TTL (Time To Live). The components of an SOA record are in this order:
(domain) IN SOA (Primary Name Server) (Responsible party) (Serial) (Refresh) (Retry) (Expire) (Minimum TTL) Given:
Rutgers.edu. SOA NS1.Rutgers.edu ipad.college.edu (200302028 3600 3600 604800 2400.) Field breakdown:
* Serial: 200302028
* Refresh: 3600 seconds
* Retry: 3600 seconds
* Expire: 604800 seconds
* Minimum TTL: 2400 seconds # This is the TTL value
From CEH v13 Courseware:
* Module 3: Scanning Networks
* Topic: DNS Enumeration and Zone Transfers
* Subsection: Understanding DNS Records
CEH v13 Study Guide states:
"In an SOA record, the last value is the Minimum TTL - the amount of time other DNS servers should cache resource records for the zone." Incorrect Options:
* A: Serial number
* B: Refresh interval
* C: Expiry interval
* E/F: Arbitrary, not part of the SOA shown
Reference:CEH v13 Study Guide - Module 3: DNS Records and Zone TransfersRFC 1035 - Domain Names
- Implementation and Specification
NEW QUESTION # 457
A penetration tester discovers malware on a system that disguises itself as legitimate software but performs malicious actions in the background. What type of malware is this?
  • A. Rootkit
  • B. Worm
  • C. Trojan
  • D. Spyware
CEH v13 defines a Trojan as malware that appears as a legitimate, trusted software application while secretly executing malicious actions behind the scenes. Trojans rely on deception rather than replication, often masquerading as tools, utilities, updates, or installers. Once executed, they may install backdoors, steal credentials, exfiltrate data, or modify system settings. The defining characteristic emphasized in CEH is the legitimate-looking facade combined with hidden malicious intent, which matches the scenario perfectly.
Spyware (Option B) focuses on monitoring and data collection but does not necessarily disguise itself as legitimate software. Worms (Option C) self-replicate across networks, which is not described here. Rootkits (Option D) hide system compromise but do not necessarily pose as legitimate software. Therefore, the malware described is a Trojan.
NEW QUESTION # 458
The aspirants will find it easy to get satisfied by our ECCouncil 312-50v13 dumps material before actually buying it. If you wish to excel in Information Technology, the ECCouncil 312-50v13 Certification will be a turning point in your career. Always remember that Certified Ethical Hacker Exam (CEHv13) 312-50v13 exam questions change.
Online 312-50v13 Lab Simulation: https://www.itexamsimulator.com/312-50v13-brain-dumps.html
Whats more, we have achieved breakthroughs in 312-50v13 certification training application as well as interactive sharing and after-sales service, ECCouncil 312-50v13 Free Practice Exams So, standing behind our products and our customer are a very important thing to us, We not only provide you with valid 312-50v13 test questions and detailed 312-50v13 test answers , but also offer the most comprehensive service to you, ECCouncil 312-50v13 Free Practice Exams Our PDF version is suitable for reading and printing requests.
First, Web buyers are confidently shopping across new product categories, 312-50v13 with the most money being spent on researched products, including travel, computer hardware, and consumer electronics.
Questions and Answers for the 312-50v13 Exam, Authentic 2026If so, have these insights inspired you to design new C++ features, Whats more, we have achieved breakthroughs in 312-50v13 Certification Training application as well as interactive sharing and after-sales service.
So, standing behind our products and our customer are a very important thing to us, We not only provide you with valid 312-50v13 test questions and detailed 312-50v13 test answers , but also offer the most comprehensive service to you.
Our PDF version is suitable for reading and printing requests, Firstly, the validity and reliability of 312-50v13 training guide are without any doubt.
2026 Latest ITExamSimulator 312-50v13 PDF Dumps and 312-50v13 Exam Engine Free Share: https://drive.google.com/open?id=1Yu1RlCVvkqc2LXySUnBEp5kknpTxEdYE
Posted at 2/7/2026 04:44:44        Only Author  2#
The perspectives presented in the article are unique, and Ive gained a lot from them. The AT-510 new exam bootcamp resource is available for free, hoping it supports your learning process.
Posted at 2/24/2026 07:12:32        Only Author  3#
Your article left me in awe, thank you for sharing! I attribute my career progress and salary increase to the C_BCFIN_2502 reliable exam cost test, and today its available to everyone for free!
