[Hardware] Latest AZ-104 Mock Exam & Best AZ-104 Vce
107
【Hardware】 Latest AZ-104 Mock Exam & Best AZ-104 Vce
Posted at 1/17/2026 21:01:28      View:138 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PrepPDF AZ-104 dumps for free: https://drive.google.com/open?id=17vgLQ4PmRBYDBPP1uhReYxeA1u4HksjQ
Our study materials have enough confidence to provide the best AZ-104 exam torrent for your study to pass it. With many years work experience, we have fast reaction speed to market change and need. In this way, we have the latest AZ-104 guide torrent. You don’t worry about that how to keep up with the market trend, just follow us. We can say that our AZ-104 Test Questions are the most suitable for examinee to pass the exam, you will never regret to buy it.
Even in a globalized market, the learning material of similar AZ-104 doesn't have much of a share, nor does it have a high reputation or popularity. In this dynamic and competitive market, the AZ-104 study materials can be said to be leading and have absolute advantages. In order to facilitate the user real-time detection of the learning process, we AZ-104 practice materials provided by the questions and answers are all in the past.it is closely associated, as our experts in constantly update products every day to ensure the accuracy of the problem, so all AZ-104 practice materials are high accuracy.
Most Probable Real Microsoft Exam Questions in Microsoft AZ-104 PDF FormatFor years our team has built a top-ranking brand with mighty and main which bears a high reputation both at home and abroad. The sales volume of the AZ-104 study materials we sell has far exceeded the same industry and favorable rate about our products is approximate to 100%. Why the clients speak highly of our AZ-104 Study Materials? Our dedicated service, high quality and passing rate and diversified functions contribute greatly to the high prestige of our products.
Why Take This Exam?The Microsoft AZ-104 is one of the role-based options that were introduced in 2019. Passing it will help a candidate to earn the Microsoft Certified: Azure Administrator Associate certification which is aimed at those specialists who have the relevant skills in implementing and managing a Microsoft Azure environment of an organization. These individuals are the Azure administrators who are responsible for the implementation, management, and monitoring of identity, storage, governance, virtual network, and compute in a Cloud-based environment. They are also in charge of monitoring and adjusting resources when needed. Moreover, these employees function as a part of a bigger team that is focused on implementing the Cloud infrastructure of their company. So, if you want to become such a highly competent specialist, you need to know certain things before going for the Microsoft AZ-104 test.
Microsoft Azure Administrator Sample Questions (Q304-Q309):NEW QUESTION # 304
Hotspot Question
You have an Azure subscription named Sub1 that contains the blob containers shown in the following table.
Sub1 contains two users named User1 and User2. Both users are assigned the Reader role at the Sub1 scope.
You have a condition named Condition1 as shown in the following exhibit.
You have a condition named Condition2 as shown in the following exhibit.
You assign roles to User1 and User2 as shown in the following table.
The conditions are difficult to read, but they mean (according to reference 1):
a. If the user performs a reading operation, then he may only read from "cont1" b. If the user performs a writing operation, then he may only write to blobs like "*2*" Given that, then:
1- User 1 can read Blob2 - No, because he is reading, then the condition a. applies, and he is not reading cont1
2- User 1 can read Blob3 - No, because he is reading, then the condition a. applies, and he is not reading cont1
3- User 2 can read blob 1 - Yes. He is not writing, so the condition b. does not apply. He has permissions granted by the role on the scope he is reading - Storage Blob Data Owner on storage1, which contains blob1 References:
https://learn.microsoft.com/en-u ... l/conditions-format
https://learn.microsoft.com/en-u ... trol/built-in-roles
NEW QUESTION # 305
Which blade should you instruct the finance department auditors to use?
  • A. invoices
  • B. partner information
  • C. External services
  • D. cost analysis
Cost analysis: Correct Option
In cost analysis blade of Azure, you can see all the detail for custom time span. You can use this to determine expenditure of last few day, weeks, and month. Below options are available in Cost analysis blade for filtering information by time span: last 7 days, last 30 days, and custom date range. Choosing the first option (last 7 days) auditors can view the costs by time span.
Cost analysis shows data for the current month by default. Use the date selector to switch to common date ranges quickly. Examples include the last seven days, the last month, the current year, or a custom date range. Pay-as-you-go subscriptions also include date ranges based on your billing period, which isn't bound to the calendar month, like the current billing period or last invoice. Use the <PREVIOUS and NEXT> links at the top of the menu to jump to the previous or next period, respectively. For example, <PREVIOUS will switch from the Last 7 days to 8-14 days ago or 15-21 days ago.
Invoice: Incorrect Option
Invoices can only be used for past billing periods not for current billing period, i.e. if your requirement is to know the last week's cost then that also not filled by invoices because Azure generates invoice at the end of the month. Even though Invoices have custom timespan, but when you put in dates for a week, the pane would be empty. Below is from Microsoft document:
Resource Provider: Incorrect Option
When deploying resources, you frequently need to retrieve information about the resource providers and types. For example, if you want to store keys and secrets, you work with the Microsoft.KeyVault resource provider. This resource provider offers a resource type called vaults for creating the key vault. This is not useful for reviewing all Azure costs from the past week which is required for audit.
Payment method: Incorrect Option
Payment methods is not useful for reviewing all Azure costs from the past week which is required for audit.
https://docs.microsoft.com/en-us ... k-acm-cost-analysis
https://docs.microsoft.com/en-us ... ce-daily-usage-date
NEW QUESTION # 306
You have an Azure subscription that contains virtual machine named VM1.
You need to back up VM. The solution must ensure that backups are stored across three availability zones in the primary region.
1 - Create a Recovery Services vault.
2 - For VM1, create a backup policy and configure the backup.
3 - Configure a replication policy.
NEW QUESTION # 307
You have a virtual network named VNet1 that has the configuration shown in the following exhibit.
Box 1: add an address space
Your IaaS virtual machines (VMs) and PaaS role instances in a virtual network automatically receive a private IP address from a range that you specify, based on the address space of the subnet they are connected to. We need to add the 192.168.1.0/24 address space.
Box 2: add a subnet
Address space is present but need to add subnet
https://docs.microsoft.com/en-us ... view=o365-worldwide
https://docs.microsoft.com/en-us ... vate-ip-arm-pportal
NEW QUESTION # 308
You have an Azure Storage account named storage1 that uses Azure Blob storage and Azure File storage.
You need to use AzCopy to copy data to the blob storage and file storage in storage1.
Which authentication method should you use for each type of storage? To answer, select the appropriate options in the answer area.
https://docs.microsoft.com/en-us ... rage-use-azcopy-v10
NEW QUESTION # 309
Customizable Microsoft Azure Administrator (AZ-104) exam conditions in such a way that you can create your desired AZ-104 exam with pre-determined questions and exam duration. You will be able to see instant results after going through the AZ-104 practice exam. To confirm the product license, an active internet connection is required. An active 24/7 service has been provided for customers to resolve their issues. Use the Microsoft Azure Administrator (AZ-104) practice test software to track your progress, as the software maintains track of all your efforts. The Microsoft AZ-104 demo version is provided for customer satisfaction.
Best AZ-104 Vce: https://www.preppdf.com/Microsoft/AZ-104-prepaway-exam-dumps.html
Posted at 1/26/2026 19:16:20        Only Author  2#
This article is incredible, thank you for sharing it with us! The Valid L6M3 exam guide exam played a major role in my promotion and raise—get it for free today!
