Splunk - Professional SPLK-4001 - Splunk O11y Cloud Certified Metrics User Exam
72
Posted at 1/17/2026 21:18:27      View164 | Replies4        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Splunk SPLK-4001 dumps are available on Google Drive shared by Exam4PDF: https://drive.google.com/open?id=1HLR4BfqXclb8Hax545PfA5lrJP_ZO6y5
The SPLK-4001 Practice Questions are designed and verified by experienced and renowned Splunk O11y Cloud Certified Metrics User exam trainers. They work collectively and strive hard to ensure the top quality of Exam4PDF SPLK-4001 exam practice questions all the time. The SPLK-4001 Exam Questions are real, updated, and error-free that helps you in Splunk O11y Cloud Certified Metrics User exam preparation and boost your confidence to crack the upcoming SPLK-4001 exam easily.
Research indicates that the success of our highly-praised SPLK-4001 test questions owes to our endless efforts for the easily operated practice system. Most feedback received from our candidates tell the truth that our SPLK-4001 guide torrent implement good practices, systems as well as strengthen our ability to launch newer and more competitive products. In fact, you can totally believe in our SPLK-4001 Test Questions for us 100% guarantee you pass exam. If you unfortunately fail in the exam after using our SPLK-4001 test questions, you will also get a full refund from our company by virtue of the proof certificate.
SPLK-4001 Reliable Source, SPLK-4001 Training For ExamWe have a team of rich-experienced IT experts who written the valid Splunk vce braindumps based on the actual questions and checked the updating of SPLK-4001 dumps torrent everyday to make sure the success of test preparation. Before you buy our SPLK-4001 Exam PDF, you can download the demo of free vce to check the accuracy.
Splunk O11y Cloud Certified Metrics User Sample Questions (Q18-Q23):NEW QUESTION # 18
The built-in Kubernetes Navigator includes which of the following?
  • A. Map, Nodes, Workloads, Node Detail, Workload Detail, Group Detail, Container Detail
  • B. Map, Nodes, Workloads, Node Detail, Workload Detail, Pod Detail, Container Detail
  • C. Map, Clusters, Workloads, Node Detail, Workload Detail, Pod Detail, Container Detail
  • D. Map, Nodes, Processors, Node Detail, Workload Detail, Pod Detail, Container Detail
The correct answer is D. Map, Nodes, Workloads, Node Detail, Workload Detail, Pod Detail, Container Detail.
The built-in Kubernetes Navigator is a feature of Splunk Observability Cloud that provides a comprehensive and intuitive way to monitor the performance and health of Kubernetes environments. It includes the following views:
Map: A graphical representation of the Kubernetes cluster topology, showing the relationships and dependencies among nodes, pods, containers, and services. You can use the map to quickly identify and troubleshoot issues in your cluster1 Nodes: A tabular view of all the nodes in your cluster, showing key metrics such as CPU utilization, memory usage, disk usage, and network traffic. You can use the nodes view to compare and analyze the performance of different nodes1 Workloads: A tabular view of all the workloads in your cluster, showing key metrics such as CPU utilization, memory usage, network traffic, and error rate. You can use the workloads view to compare and analyze the performance of different workloads, such as deployments, stateful sets, daemon sets, or jobs1 Node Detail: A detailed view of a specific node in your cluster, showing key metrics and charts for CPU utilization, memory usage, disk usage, network traffic, and pod count. You can also see the list of pods running on the node and their status. You can use the node detail view to drill down into the performance of a single node2 Workload Detail: A detailed view of a specific workload in your cluster, showing key metrics and charts for CPU utilization, memory usage, network traffic, error rate, and pod count. You can also see the list of pods belonging to the workload and their status. You can use the workload detail view to drill down into the performance of a single workload2 Pod Detail: A detailed view of a specific pod in your cluster, showing key metrics and charts for CPU utilization, memory usage, network traffic, error rate, and container count. You can also see the list of containers within the pod and their status. You can use the pod detail view to drill down into the performance of a single pod2 Container Detail: A detailed view of a specific container in your cluster, showing key metrics and charts for CPU utilization, memory usage, network traffic, error rate, and log events. You can use the container detail view to drill down into the performance of a single container2 To learn more about how to use Kubernetes Navigator in Splunk Observability Cloud, you can refer to this documentation3.
1: https://docs.splunk.com/observab ... ubernetes-Navigator 2:
https://docs.splunk.com/observab ... v.html#Detail-pages 3:
https://docs.splunk.com/observab ... onitor/k8s-nav.html
NEW QUESTION # 19
A customer has a very dynamic infrastructure. During every deployment, all existing instances are destroyed, and new ones are created Given this deployment model, how should a detector be created that will not send false notifications of instances being down?
  • A. Create the detector. Select Alert settings, then select Auto-Clear Alerts and enter an appropriate time period.
  • B. Check the Dynamic checkbox when creating the detector.
  • C. Check the Ephemeral checkbox when creating the detector.
  • D. Create the detector. Select Alert settings, then select Ephemeral Infrastructure and enter the expected lifetime of an instance.
According to the web search results, ephemeral infrastructure is a term that describes instances that are auto-scaled up or down, or are brought up with new code versions and discarded or recycled when the next code version is deployed1. Splunk Observability Cloud has a feature that allows you to create detectors for ephemeral infrastructure without sending false notifications of instances being down2. To use this feature, you need to do the following steps:
Create the detector as usual, by selecting the metric or dimension that you want to monitor and alert on, and choosing the alert condition and severity level.
Select Alert settings, then select Ephemeral Infrastructure. This will enable a special mode for the detector that will automatically clear alerts for instances that are expected to be terminated.
Enter the expected lifetime of an instance in minutes. This is the maximum amount of time that an instance is expected to live before being replaced by a new one. For example, if your instances are replaced every hour, you can enter 60 minutes as the expected lifetime.
Save the detector and activate it.
With this feature, the detector will only trigger alerts when an instance stops reporting a metric unexpectedly, based on its expected lifetime. If an instance stops reporting a metric within its expected lifetime, the detector will assume that it was terminated on purpose and will not trigger an alert. Therefore, option B is correct.
NEW QUESTION # 20
How is it possible to create a dashboard group that no one else can edit?
  • A. Hide the edit menu on the dashboard group.
  • B. Ask the admin to lock the dashboard group.
  • C. Restrict the write access on the dashboard group.
  • D. Link the dashboard group to the team.
According to the web search results, dashboard groups are a feature of Splunk Observability Cloud that allows you to organize and share dashboards with other users in your organization1. You can set permissions for each dashboard group, such as who can view, edit, or manage the dashboards in the group1. To create a dashboard group that no one else can edit, you need to do the following steps:
Create a dashboard group as usual, by selecting Dashboard Group from the Create menu on the navigation bar, entering a name and description, and adding dashboards to the group1.
Select Alert settings from the Dashboard actions menu () on the top right corner of the dashboard group. This will open a dialog box where you can configure the permissions for the dashboard group1.
Under Write access, select Only me. This will restrict the write access to the dashboard group to yourself only. No one else will be able to edit or delete the dashboards in the group1.
Click Save. This will create a dashboard group that no one else can edit.
NEW QUESTION # 21
What is the limit on the number of properties that an MTS can have?
  • A. No limit
  • B. 0
  • C. 1
  • D. 2
The correct answer is A. 64.
According to the web search results, the limit on the number of properties that an MTS can have is 64. A property is a key-value pair that you can assign to a dimension of an existing MTS to add more context to the metrics. For example, you can add the property use: QA to the host dimension of your metrics to indicate that the host is used for QA1 Properties are different from dimensions, which are key-value pairs that are sent along with the metrics at the time of ingest. Dimensions, along with the metric name, uniquely identify an MTS. The limit on the number of dimensions per MTS is 362 To learn more about how to use properties and dimensions in Splunk Observability Cloud, you can refer to this documentation2.
1:
https://docs.splunk.com/Observab ... l#Custom-properties
2: https://docs.splunk.com/Observab ... dimensions-mts.html
NEW QUESTION # 22
Which of the following are true about organization metrics? (select all that apply)
  • A. Organization metrics are included for free.
  • B. A user can plot and alert on them like metrics they send to Splunk Observability Cloud.
  • C. Organization metrics give insights into system usage, system limits, data ingested and token quotas.
  • D. Organization metrics count towards custom MTS limits.
Answer: A,B,C
The correct answer is A, C, and D. Organization metrics give insights into system usage, system limits, data ingested and token quotas. Organization metrics are included for free. A user can plot and alert on them like metrics they send to Splunk Observability Cloud.
Organization metrics are a set of metrics that Splunk Observability Cloud provides to help you measure your organization's usage of the platform. They include metrics such as:
Ingest metrics: Measure the data you're sending to Infrastructure Monitoring, such as the number of data points you've sent.
App usage metrics: Measure your use of application features, such as the number of dashboards in your organization.
Integration metrics: Measure your use of cloud services integrated with your organization, such as the number of calls to the AWS CloudWatch API.
Resource metrics: Measure your use of resources that you can specify limits for, such as the number of custom metric time series (MTS) you've created1 Organization metrics are not charged and do not count against any system limits. You can view them in built-in charts on the Organization Overview page or in custom charts using the Metric Finder. You can also create alerts based on organization metrics to monitor your usage and performance1 To learn more about how to use organization metrics in Splunk Observability Cloud, you can refer to this documentation1.
1: https://docs.splunk.com/observability/admin/org-metrics.html
NEW QUESTION # 23
We offer you free demo for you to have a try before buying the SPLK-4001 study guide, so that you can have a better understanding of what you are going to buy. SPLK-4001 exam dumps of us also offer you free update for one year after purchasing, and our system will send the latest version to you automatically. Besides we have the online and offline chat service stuff, and if you have any questions about the SPLK-4001 Study Guide, you can consult them, and they will offer you the suggestions.
SPLK-4001 Reliable Source: https://www.exam4pdf.com/SPLK-4001-dumps-torrent.html
So the SPLK-4001 Reliable Source - Splunk O11y Cloud Certified Metrics User training dumps written by them has high quality, has 98%-100% passing rate if you study the dumps well, Gradually, you will find that our SPLK-4001 practice test materials deserves you trust, We truly treat our customers with the best quality service and the most comprehensive SPLK-4001 exam pdf, that's why we enjoy great popularity among most IT workers, If it is not the latest version we won't sell and will remind you to wait the updated SPLK-4001 study guide.
Just from my seminars and book, Hey, how are things, So the SPLK-4001 Splunk O11y Cloud Certified Metrics User training dumps written by them has high quality, has 98%-100% passing rate if you study the dumps well.
Gradually, you will find that our SPLK-4001 Practice Test materials deserves you trust, We truly treat our customers with the best quality service and the most comprehensive SPLK-4001 exam pdf, that's why we enjoy great popularity among most IT workers.
High Pass-Rate 100% Free SPLK-4001 C 100% Free Exam Topics Pdf | SPLK-4001 Reliable SourceIf it is not the latest version we won't sell and will remind you to wait the updated SPLK-4001 study guide, You will soon get familiar with our SPLK-4001 exam braindump once you involve yourself.
BONUS!!! Download part of Exam4PDF SPLK-4001 dumps for free: https://drive.google.com/open?id=1HLR4BfqXclb8Hax545PfA5lrJP_ZO6y5
Posted at 1/22/2026 18:08:47        Only Author  2#
300-815ѧ̲Ĥˤϡ``Τ٤ƤҪĤ˜य㤬ޤԇgФȤ᰸Ϥϡ`˥ե`ɥХå򤪼Ĥ˽300-815ѧYϤϤʤ⤿餷ޤ˽ϥ``Τˤ򤹤٤Ƥޤ 300-815ȥ`˥YϤκϸʤ99〜100ǤꡢLoaylΤ͘^ƤꡢΤΥåȤäޤ 300-815եϡμӤ򤪴Ƥޤ
Posted at 1/31/2026 09:13:31        Only Author  3#
Thank you for your article; it truly broadened my horizons! The Real C_BCBTP_2502 Exams helped me secure my promotion and raise. Its free now for everyone. Best of luck with your career!
Posted at 2/21/2026 16:56:01        Only Author  4#
Your article is absolutely mind-blowing, thank you for sharing! Get free access to Reliable 1Y0-231 dumps pdf exam questionsgood luck to everyone!
Posted at 3/10/2026 16:06:39        Only Author  5#
Thank you for your brilliant article; it truly shocked me! Thanks to the PL-600 vce test simulator exam, I reached a new level in my career. Now Im sharing it for free with all of you!
