[Hardware] Real Salesforce Data-Cloud-Consultant Exam Questions with Accurate Answers
96
Hardware Real Salesforce Data-Cloud-Consultant Exam Questions with Accurate Answers
Posted at 1/17/2026 22:45:04      View220 | Replies3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of PassExamDumps Data-Cloud-Consultant dumps from Cloud Storage: https://drive.google.com/open?id=1NzSrx7WcHEVJmJAn6sAmDKZkMDiZdVFQ
Now they have become certified Salesforce Certified Data Cloud Consultant Certification Exam experts and pursue a rewarding career in the top world brands. You can also trust top-notch and easy-to-use Salesforce Data-Cloud-Consultant practice test questions. The Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) exam questions are checked and verified by experienced and qualified Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) exam trainers. They have years of experience and knowledge to collect, design, and answer the real Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) exam questions.
PassExamDumps is a trusted platform that is committed to helping Salesforce Data-Cloud-Consultant exam candidates in exam preparation. The Salesforce Data-Cloud-Consultant exam questions are real and updated and will repeat in the upcoming Salesforce Data-Cloud-Consultant Exam Dumps. By practicing again and again you will become an expert to solve all the Salesforce Data-Cloud-Consultant exam questions completely and before the exam time.
Valid Data-Cloud-Consultant Exam Cram | Practice Data-Cloud-Consultant EngineOur company has forged a group of professional experts with the excelsior craftsmanship and a mature service system. The quality of our Data-Cloud-Consultant latest question is high because our expert team organizes and compiles them according to the real exam's needs and has extracted the essence of all of the information about the test. So our Data-Cloud-Consultant Certification tool is the boutique among the same kinds of the study materials. Our assiduous pursuit for high quality of our Data-Cloud-Consultant exam prep creates our top-ranking Data-Cloud-Consultant test guide and constantly increasing sales volume.
Salesforce Certified Data Cloud Consultant Sample Questions (Q59-Q64):NEW QUESTION # 59
A consultant has an activation that is set to publish every 12 hours, but has discovered that updates to the data prior to activation are delayed by up to 24 hours.
Which two areas should a consultant review to troubleshoot this issue?
Choose 2 answers
  • A. Review calculated insights to make sure they're run before segments are refreshed.
  • B. Review calculated insights to make sure they're run after the segments are refreshed.
  • C. Review segments to ensure they're refreshed after the data is ingested.
  • D. Review data transformations to ensure they're run after calculated insights.
The correct answer is B and C because calculated insights and segments are both dependent on the data ingestion process. Calculated insights are derived from the data model objects and segments are subsets of data model objects that meet certain criteria. Therefore, both of them need to be updated after the data is ingested to reflect the latest changes. Data transformations are optional steps that can be applied to the data streams before they are mapped to the data model objects, so they are not relevant to the issue. Reviewing calculated insights to make sure they're run after the segments are refreshed (option D) is also incorrect because calculated insights are independent of segments and do not need to be refreshed after them. References: Salesforce Data Cloud Consultant Exam Guide, Data Ingestion and Modeling, Calculated Insights, Segments
NEW QUESTION # 60
A consultant at Northern Trail Outfitters is implementing Data Cloud and creating an activation target for their segment.
For activation membership, which object should the consultant choose?
  • A. Data Segmentation Object
  • B. Data Activation Object
  • C. Data Model Object
  • D. Data Lake Object
In Salesforce Data Cloud, activation membership refers to the individuals or records that qualify for a specific segment and are eligible to be activated (e.g., sent to external systems like Marketing Cloud). Here's the breakdown:
Data Segmentation Object (Option C):
Segments in Data Cloud are stored as Data Segmentation Objects, which include metadata about the segment (e.g., logic, filters) and its membership (the records/individuals that meet the criteria).
When configuring an activation target, you select the segment (and its membership) stored in the Data Segmentation Object to send to downstream systems.
Salesforce's official documentation confirms that segments and their memberships are managed through the Data Segmentation Object (Source: Salesforce Data Cloud Implementation Guide, "Segmentation and Activation").
Why Other Options Are Incorrect:
Data Model Object (A): Represents the structured data model (e.g., standard or custom objects like Individual or Account) but does not store segment membership.
Data Activation Object (B): A distractor; no such standard object exists in Data Cloud. Activation is a process that uses the Data Segmentation Object.
Data Lake Object (D): Stores raw, unprocessed data ingested into Data Cloud and is not directly used for activation.
Conclusion: For activation membership, the consultant must select the Data Segmentation Object to reference the segment's qualified members.
NEW QUESTION # 61
A customer wants to use the transactional data from their data warehouse in Data Cloud.
They are only able to export the data via an SFTP site.
How should the file be brought into Data Cloud?
  • A. Ingest the file through the Cloud Storage Connector.
  • B. Manually import the file using the Data Import Wizard.
  • C. Use Salesforce's Dataloader application to perform a bulk upload from a desktop.
  • D. Ingest the file with the SFTP Connector.
The SFTP Connector is a data source connector that allows Data Cloud to ingest data from an SFTP server.
The customer can use the SFTP Connector to create a data stream from their exported file and bring it into Data Cloud as a data lake object. The other options are not the best ways to bring the file into Data Cloud because:
* B. The Cloud Storage Connector is a data source connector that allows Data Cloud to ingest data from cloud storage services such as Amazon S3, Azure Storage, or Google Cloud Storage. The customer does not have their data in any of these services, but only on an SFTP site.
* C. The Data Import Wizard is a tool that allows users to import data for many standard Salesforce objects, such as accounts, contacts, leads, solutions, and campaign members. It is not designed to import data from an SFTP site or for custom objects in Data Cloud.
* D. The Dataloader is an application that allows users to insert, update, delete, or export Salesforce records. It is not designed to ingest data from an SFTP site or into Data Cloud. References: SFTP Connector - Salesforce, Create Data Streams with the SFTP Connector in Data Cloud - Salesforce, Data Import Wizard - Salesforce, Salesforce Data Loader
NEW QUESTION # 62
A finance company that uses Data Cloud wants to simplify how its users can view all the various channels a customer engages with Which feature should the consultant recommend to meet this requirement?
  • A. Use Data Cloud to connect with analytic tools, like Tableau.
  • B. Create segments based on the ingested data and insights to activate in Marketing Cloud.
  • C. Use Data Cloud to ingest data from various available data sources.
  • D. Use calculated insights to determine when and how to engage with various customers.
To simplify how users can view all the various channels a customer engages with, the best solution is to use Data Cloud to connect with analytic tools like Tableau . Here's why and how this works:
Understanding the Requirement
The finance company wants its users to have a consolidated view of all customer engagement channels (e.g., email, social media, website interactions, etc.). This requires:
Aggregating data from multiple sources into a unified platform.
Providing an intuitive and visual way to analyze and interpret the data.
Why Use Data Cloud with Analytic Tools like Tableau?
Data Cloud as a Centralized Data Hub :Salesforce Data Cloud aggregates data from multiple sources (e.g., CRM, Marketing Cloud, external systems) into a unified platform. This ensures that all customer engagement data is available in one place.
Tableau for Advanced Visualization :
Tableau is a powerful analytics and visualization tool that integrates seamlessly with Salesforce Data Cloud.
It allows users to create interactive dashboards and reports that provide a comprehensive view of customer engagement across all channels.
Users can drill down into specific channels, analyze trends, and gain actionable insights without needing advanced technical skills.
Simplified User Experience :By leveraging Tableau's intuitive interface, users can easily explore and understand customer engagement patterns without requiring deep knowledge of the underlying data structure.
Steps to Implement This Solution
Step 1: Ingest Data into Data Cloud
Ensure that all relevant customer engagement data (e.g., website visits, email interactions, social media activity) is ingested into Data Cloud from various sources.
Use Data Streams to bring in data from CRM, Marketing Cloud, and other external systems.
Step 2: Connect Data Cloud to Tableau
Navigate to Setup > Analytics > Tableau CRM in Salesforce.
Configure the integration between Data Cloud and Tableau to enable seamless data flow.
Step 3: Create Dashboards in Tableau
Use Tableau to build dashboards that consolidate customer engagement data from all channels.
Include visualizations such as bar charts, heatmaps, and trend lines to highlight key insights (e.g., most active channels, engagement frequency, etc.).
Step 4: Share Dashboards with Users
Publish the dashboards to Tableau Server or Tableau Online.
Provide access to the relevant users within the finance company so they can view and interact with the dashboards.
Why Not Other Options?
B). Use calculated insights to determine when and how to engage with various customers :While calculated insights are useful for understanding customer behavior, they do not provide a consolidated view of all engagement channels. This option focuses more on decision-making rather than visualization.
C). Create segments based on the ingested data and insights to activate in Marketing Cloud :Segmentation is valuable for targeting specific groups of customers, but it does not address the requirement to view all engagement channels in one place. Segments are more about grouping customers rather than providing a holistic view.
D). Use Data Cloud to ingest data from various available data sources :While ingesting data is a critical first step, it does not solve the problem of simplifying how users view engagement channels. The focus here is on data ingestion, not visualization or analysis.
Conclusion
By connecting Data Cloud with Tableau , the finance company can provide its users with a simplified and visually intuitive way to view all customer engagement channels. This approach lever
NEW QUESTION # 63
A customer has a requirement to be able to view the last time each segment was published within their Data Cloud org.
Which two features should the consultant recommend to best address this requirement?
Choose 2 answers
  • A. Calculated insight
  • B. Report
  • C. Profile Explorer
  • D. Dashboard
A customer who wants to view the last time each segment was published within their Data Cloud org can use the dashboard and report features to achieve this requirement. A dashboard is a visual representation of data that can show key metrics, trends, and comparisons. A report is a tabular or matrix view of data that can show details, summaries, and calculations. Both dashboard and report features allow the user to create, customize, and share data views based on their needs and preferences. To view the last time each segment was published, the user can create a dashboard or a report that shows the segment name, the publish date, and the publish status fields from the segment object. The user can also filter, sort, group, or chart the data by these fields to get more insights and analysis. The user can also schedule, refresh, or export the dashboard or report data as needed. Reference: Dashboards, Reports
NEW QUESTION # 64
In the modern world, obtaining Data-Cloud-Consultant certification is essential. With the growing popularity of Salesforce, the demand for professionals holding this Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) certification holders has increased significantly. Unfortunately, many candidates fail to pass the Data-Cloud-Consultant Exam due to outdated Salesforce Certified Data Cloud Consultant (Data-Cloud-Consultant) exam study material. Such failure can lead to the loss of time, money, and confidence.
Valid Data-Cloud-Consultant Exam Cram: https://www.passexamdumps.com/Data-Cloud-Consultant-valid-exam-dumps.html
PassExamDumps has come up with real Data-Cloud-Consultant Questions that are according to the current content of the Data-Cloud-Consultant exam, On the one hand, by the free trial services you can get close contact with our products, learn about the detailed information of our Data-Cloud-Consultant study materials, and know how to choose the different versions before you buy our products, Free Demo Download of Data-Cloud-Consultant Dumps PDF.
Avoid parameter ambiguity in the cases where Data-Cloud-Consultant it might exist, Ad-hoc connections cannot connect you directly to the Internet, PassExamDumps has come up with real Data-Cloud-Consultant Questions that are according to the current content of the Data-Cloud-Consultant Exam.
Salesforce Data-Cloud-Consultant Exam Prep SolutionsOn the one hand, by the free trial services you can get close contact with our products, learn about the detailed information of our Data-Cloud-Consultant study materials, and know how to choose the different versions before you buy our products.
Free Demo Download of Data-Cloud-Consultant Dumps PDF, These include the Data-Cloud-Consultant exam practice material in PDF format and the practice test software, The good news for you is that during the whole year, our operation system will Data-Cloud-Consultant Exam Dumps Demo automatically sent the latest version of our study materials to your e-mail which you used for payment.
What's more, part of that PassExamDumps Data-Cloud-Consultant dumps now are free: https://drive.google.com/open?id=1NzSrx7WcHEVJmJAn6sAmDKZkMDiZdVFQ
Posted at 2/17/2026 20:50:59        Only Author  2#
Your article is truly amazing; I appreciate your sharing! Get the Study Guide FCSS_NST_SE-7.6 exam questions for freewishing you all the best in your exams!
Posted at 2/18/2026 18:51:22        Only Author  3#
Your article really made an impact, Im very appreciative. Study guide MSP-Practitioner pdf contains comprehensive material, available at no cost to support your learning.
Posted at 3/6/2026 20:10:09        Only Author  4#
Your article has left me in awe, thank you for sharing such a gem! Thanks to the latest Comm-Dev-101 exam book exam, I got promoted and earned a higher salary. Now, Im giving it away for free today!
