[General] 2026 ARA-C01 Braindumps Pdf 100% Pass | Latest ARA-C01: SnowPro Advanced Archite
114
【General】 2026 ARA-C01 Braindumps Pdf 100% Pass | Latest ARA-C01: SnowPro Advanced Archite
Posted at 1/17/2026 23:36:32      View:114 | Replies:1        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PracticeTorrent ARA-C01 dumps for free: https://drive.google.com/open?id=13uNh1gtXUbSrUSNqqmKtYGv_NKFS26sW
We strongly recommend using our ARA-C01 exam dumps to prepare for the SnowPro Advanced Architect Certification. It is the best way to ensure success. With our ARA-C01 practice questions, you can get the most out of your studying and maximize your chances of passing your ARA-C01 Exam. PracticeTorrent SnowPro Advanced Architect Certification is the answer if you want to score higher in the ARA-C01 exam and achieve your academic goals.
Snowflake ARA-C01 certification is a valuable credential for architects and consultants who work with Snowflake. It demonstrates a deep understanding of Snowflake's architecture, data modeling, and performance tuning, which are essential skills for designing and implementing scalable data warehousing solutions. Employers also recognize the value of this certification, as it validates an individual's expertise and can help them stand out in a competitive job market.
Obtaining the Snowflake ARA-C01 certification demonstrates that an individual has the skills and expertise to design, implement, and manage complex data solutions on the Snowflake platform. SnowPro Advanced Architect Certification certification is highly valued in the IT industry and can lead to better job opportunities and higher salaries. Additionally, Snowflake ARA-C01 Certified professionals can help their organizations to optimize their data solutions and achieve better business outcomes.
Snowflake ARA-C01 (SnowPro Advanced Architect Certification) Exam is a certification exam designed to test the advanced architectural skills of professionals in the field of data warehousing and cloud computing. ARA-C01 exam is conducted by Snowflake Inc., a cloud-based data warehousing company that offers secure and scalable solutions to businesses worldwide.
100% Pass Quiz 2026 Snowflake Fantastic ARA-C01 Braindumps PdfSince the cost of signing up for the SnowPro Advanced Architect Certification ARA-C01 exam dumps is considerable, your main focus should be clearing the SnowPro Advanced Architect Certification ARA-C01 exam on your first try. Utilizing quality Snowflake ARA-C01 Exam Questions is the key to achieving this. Buy the SnowPro Advanced Architect Certification ARA-C01 Exam Dumps created to avoid the stress of searching for tried-and-true Snowflake ARA-C01 certification exam preparation.
Snowflake SnowPro Advanced Architect Certification Sample Questions (Q10-Q15):NEW QUESTION # 10
What considerations need to be taken when using database cloning as a tool for data lifecycle management in a development environment? (Select TWO).
  • A. Any pipes in the source referring to internal stages are not cloned.
  • B. Any pipes in the source are not cloned.
  • C. Any pipes in the source referring to external stages are not cloned.
  • D. The clone inherits all granted privileges of all child objects in the source object, including the database.
  • E. The clone inherits all granted privileges of all child objects in the source object, excluding the database.
Database cloning is a feature of Snowflake that allows creating a copy of a database, schema, table, or view without consuming any additional storage space. Database cloning can be used as a tool for data lifecycle management in a development environment, where developers and testers can work on isolated copies of production data without affecting the original data or each other1.
However, there are some considerations that need to be taken when using database cloning in a development environment, such as:
Any pipes in the source are not cloned. Pipes are objects that load data from a stage into a table continuously. Pipes are not cloned because they are associated with a specific stage and table, and cloning them would create duplicate data loading and potential conflicts2.
The clone inherits all granted privileges of all child objects in the source object, including the database. Privileges are the permissions that control the access and actions that can be performed on an object. When a database is cloned, the clone inherits all the privileges that were granted on the source database and its child objects, such as schemas, tables, and views. This means that the same roles that can access and modify the source database can also access and modify the clone, unless the privileges are explicitly revoked or modified3.
The other options are not correct because:
B) Any pipes in the source referring to internal stages are not cloned. This is a subset of option A, which states that any pipes in the source are not cloned, regardless of the type of stage they refer to.
C) Any pipes in the source referring to external stages are not cloned. This is also a subset of option A, which states that any pipes in the source are not cloned, regardless of the type of stage they refer to.
E) The clone inherits all granted privileges of all child objects in the source object, excluding the database. This is incorrect, as the clone inherits all granted privileges of the source object, including the database.
1: Database Cloning | Snowflake Documentation
2: Pipes | Snowflake Documentation
3: Access Control Privileges | Snowflake Documentation
NEW QUESTION # 11
A large manufacturing company runs a dozen individual Snowflake accounts across its business divisions. The company wants to increase the level of data sharing to support supply chain optimizations and increase its purchasing leverage with multiple vendors.
The company's Snowflake Architects need to design a solution that would allow the business divisions to decide what to share, while minimizing the level of effort spent on configuration and management. Most of the company divisions use Snowflake accounts in the same cloud deployments with a few exceptions for European-based divisions.
According to Snowflake recommended best practice, how should these requirements be met?
  • A. Deploy a Private Data Exchange and use replication to allow European data shares in the Exchange.
  • B. Deploy to the Snowflake Marketplace making sure that invoker_share() is used in all secure views.
  • C. Deploy a Private Data Exchange in combination with data shares for the European accounts.
  • D. Migrate the European accounts in the global region and manage shares in a connected graph architecture. Deploy a Data Exchange.
According to Snowflake recommended best practice, the requirements of the large manufacturing company should be met by deploying a Private Data Exchange in combination with data shares for the European accounts. A Private Data Exchange is a feature of the Snowflake Data Cloud platform that enables secure and governed sharing of data between organizations. It allows Snowflake customers to create their own data hub and invite other parts of their organization or external partners to access and contribute data sets. A Private Data Exchange provides centralized management, granular access control, and data usage metrics for the data shared in the exchange1. A data share is a secure and direct way of sharing data between Snowflake accounts without having to copy or move the data. A data share allows the data provider to grant privileges on selected objects in their account to one or more data consumers in other accounts2. By using a Private Data Exchange in combination with data shares, the company can achieve the following benefits:
The business divisions can decide what data to share and publish it to the Private Data Exchange, where it can be discovered and accessed by other members of the exchange. This reduces the effort and complexity of managing multiple data sharing relationships and configurations.
The company can leverage the existing Snowflake accounts in the same cloud deployments to create the Private Data Exchange and invite the members to join. This minimizes the migration and setup costs and leverages the existing Snowflake features and security.
The company can use data shares to share data with the European accounts that are in different regions or cloud platforms. This allows the company to comply with the regional and regulatory requirements for data sovereignty and privacy, while still enabling data collaboration across the organization.
The company can use the Snowflake Data Cloud platform to perform data analysis and transformation on the shared data, as well as integrate with other data sources and applications. This enables the company to optimize its supply chain and increase its purchasing leverage with multiple vendors.
NEW QUESTION # 12
Which organization-related tasks can be performed by the ORGADMIN role? (Choose three.)
  • A. Creating an account
  • B. Deleting an account
  • C. Viewing a list of organization accounts
  • D. Changing the name of an account
  • E. Enabling the replication of a database
  • F. Changing the name of the organization
Answer: A,C,E
According to the SnowPro Advanced: Architect documents and learning resources, the organization-related tasks that can be performed by the ORGADMIN role are:
* Creating an account in the organization. A user with the ORGADMIN role can use the CREATE ACCOUNT command to create a new account that belongs to the same organization as the current account1.
* Viewing a list of organization accounts. A user with the ORGADMIN role can use the SHOW ORGANIZATION ACCOUNTS command to view the names and properties of all accounts in the organization2. Alternatively, the user can use the Admin a Accounts page in the web interface to view the organization name and account names3.
* Enabling the replication of a database. A user with the ORGADMIN role can use the SYSTEM$GLOBAL_ACCOUNT_SET_PARAMETER function to enable database replication for an account in the organization. This allows the user to replicate databases across accounts in different regions and cloud platforms for data availability and durability4.
The other options are incorrect because they are not organization-related tasks that can be performed by the ORGADMIN role. Option A is incorrect because changing the name of the organization is not a task that can be performed by the ORGADMIN role. To change the name of an organization, the user must contact Snowflake Support3. Option D is incorrect because changing the name of an account is not a task that can be performed by the ORGADMIN role. To change the name of an account, the user must contact Snowflake Support5. Option E is incorrect because deleting an account is not a task that can be performed by the ORGADMIN role. To delete an account, the user must contact Snowflake Support. References: CREATE ACCOUNT | Snowflake Documentation, SHOW ORGANIZATION ACCOUNTS | Snowflake Documentation, Getting Started with Organizations | Snowflake Documentation, SYSTEM$GLOBAL_ACCOUNT_SET_PARAMETER | Snowflake Documentation, ALTER ACCOUNT | Snowflake Documentation, [DROP ACCOUNT | Snowflake Documentation]
NEW QUESTION # 13
Two queries are run on the customer_address table:
create or replace TABLE CUSTOMER_ADDRESS ( CA_ADDRESS_SK NUMBER(38,0), CA_ADDRESS_ID VARCHAR(16), CA_STREET_NUMBER VARCHAR(IO) CA_STREET_NAME VARCHAR(60), CA_STREET_TYPE VARCHAR(15), CA_SUITE_NUMBER VARCHAR(10), CA_CITY VARCHAR(60), CA_COUNTY VARCHAR(30), CA_STATE VARCHAR(2), CA_ZIP VARCHAR(10), CA_COUNTRY VARCHAR(20), CA_GMT_OFFSET NUMBER(5,2), CA_LOCATION_TYPE VARCHAR(20) ); ALTER TABLE DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS ADD SEARCH OPTIMIZATION ON SUBSTRING(CA_ADDRESS_ID); Which queries will benefit from the use of the search optimization service? (Select TWO).
  • A. select * from DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS Where substring(CA_ADDRESS_ID,1,8)= substring('AAAAAAAAPHPPLBAAASKDJHASLKDJHASKJD',1,8);
  • B. select        *        from        DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS        Where        CA_ADDRESS_ID        LIKE '%PHPP%';
  • C. select        *        from        DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS        Where        CA_ADDRESS_ID        NOT LIKE '%AAAAAAAAPHPPL%';
  • D. select * from DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS Where CA_ADDRESS_ID= substring('AAAAAAAAPHPPLBAAASKDJHASLKDJHASKJD',1,16);
  • E. select        *        from        DEMO_DB.DEMO_SCH.CUSTOMER_ADDRESS        Where        CA_ADDRESS_ID        LIKE '%BAAASKD%';
The use of the search optimization service in Snowflake is particularly effective when queries involve operations that match exact substrings or start from the beginning of a string. The ALTER TABLE command adding search optimization specifically for substrings on the CA_ADDRESS_ID field allows the service to create an optimized search path for queries using substring matches.
Option A benefits because it directly matches a substring from the start of the CA_ADDRESS_ID, aligning with the optimization's capability to quickly locate records based on the beginning segments of strings.
Option B also benefits, despite performing a full equality check, because it essentially compares the full length of CA_ADDRESS_ID to a substring, which can leverage the substring index for efficient retrieval.
Options C, D, and E involve patterns that do not start from the beginning of the string or use negations, which are not optimized by the search optimization service configured for starting substring matches.
Reference: Snowflake's documentation on the use of search optimization for substring matching in SQL queries.
NEW QUESTION # 14
An Architect with the ORGADMIN role wants to change a Snowflake account from an Enterprise edition to a Business Critical edition.
How should this be accomplished?
  • A. Failover to a new account in the same region and specify the new account's edition upon creation.
  • B. Use the account's ACCOUNTADMIN role to change the edition.
  • C. Contact Snowflake Support and request that the account's edition be changed.
  • D. Run an ALTER ACCOUNT command and create a tag of EDITION and set the tag to Business Critical.
To change the edition of a Snowflake account, an organization administrator (ORGADMIN) cannot directly alter the account settings through SQL commands or the Snowflake interface. The proper procedure is to contact Snowflake Support to request an edition change for the account. This ensures that the change is managed correctly and aligns with Snowflake's operational protocols.
References: This process is outlined in the Snowflake documentation, which specifies that changes to an account's edition should be facilitated through Snowflake Support1.
NEW QUESTION # 15
If the user fails in the ARA-C01 exam questions for any reason, we will refund the money after this process. In addition, we provide free updates to users for one year long. If the user finds anything unclear in the ARA-C01 practice materials exam, we will send email to fix it, and our team will answer all of your questions related to the ARA-C01 Guide prep. What is more, we provide the free demows of our ARA-C01 study prep for our customers to download before purchase.
Exam ARA-C01 Discount: https://www.practicetorrent.com/ARA-C01-practice-exam-torrent.html
P.S. Free & New ARA-C01 dumps are available on Google Drive shared by PracticeTorrent: https://drive.google.com/open?id=13uNh1gtXUbSrUSNqqmKtYGv_NKFS26sW
Posted at 2/20/2026 03:37:09        Only Author  2#
Sorgen Sie noch um die Vorbereitung der CompTIA CV0-004 Prüfung? Aber solange Sie diesen Blog sehen, können Sie sich doch beruhigen, weil Sie der professionellste und der autoritativste Lieferant gefunden haben. Unsere Produkte haben viele Angestellten geholfen, die in IT-Firmen arbeiten, die CompTIA CV0-004 Zertifizierungsprüfung zu bestehen. Die Gründe sind einfach. Da unsere Prüfungsunterlagen sind am neusten und am umfassendsten! Außerdem bieten wir einjährige kostenlose Aktualisierung nach Ihrem Kauf der Prüfungsunterlagen der CompTIA CV0-004 . Keine Sorge bei der Vorbereitung!
