[General] New Microsoft DP-100 Practice Questions - DP-100 Downloadable PDF
79
General New Microsoft DP-100 Practice Questions - DP-100 Downloadable PDF
Posted at 1/18/2026 00:58:54      View185 | Replies1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Microsoft DP-100 dumps are available on Google Drive shared by Exams4sures: https://drive.google.com/open?id=1yaYp85X2R9P6OqZ8RbTvWo4c3WUPrLQl
For candidates who are preparing for the DP-100 exam, passing the DP-100 exam is a long-cherished wish. So if you want to pass the DP-100 exam, you should choose the product of our company. Since our company is a leading team of the business, we have lots of experienced experts to complie the practice materials of the DP-100 exam, and the practice materials also provide the detailed answers. And the pass rate of the DP-100 Exam is 98%. If you failure to pass the DP-100 exam after purchasing the product, money back is guaranteed. What's more, our product is quite cheaper compared with other product, you just need to spent some money to buy and practiceit, then a certificate of the DP-100 will be gotten, which can add your competitive ablity in the job market.
We provide updated and real Microsoft DP-100 exam questions that are sufficient to clear the Designing and Implementing a Data Science Solution on Azure (DP-100) exam in one go. The product of Exams4sures is created by seasoned professionals and is frequently updated to reflect changes in the content of the DP-100 Exam Questions.
DP-100 Downloadable PDF, DP-100 Latest Exam BookUp to now, we have business connection with tens of thousands of exam candidates who adore the quality of our DP-100 exam questions. Besides, we try to keep our services brief, specific and courteous with reasonable prices of DP-100 Study Guide. All your questions will be treated and answered fully and promptly. So as long as you contact us to ask for the questions on the DP-100 learning guide, you will get the guidance immediately.
Microsoft Designing and Implementing a Data Science Solution on Azure Sample Questions (Q143-Q148):NEW QUESTION # 143
You manage an Azure Machine Learning workspace. You configure an automated machine learning regression training job by using the Azure Machine Learning Python SDK v2. You configure the regression job by using the following script:
NEW QUESTION # 144
You are retrieving data from a large datastore by using Azure Machine Learning Studio.
You must create a subset of the data for testing purposes using a random sampling seed based on the system clock.
You add the Partition and Sample module to your experiment.
You need to select the properties for the module.
Which values should you select? To answer, select the appropriate options in the answer area.
Box 1: Sampling
Create a sample of data
This option supports simple random sampling or stratified random sampling. This is useful if you want to create a smaller representative sample dataset for testing.
1. Add the Partition and Sample module to your experiment in Studio, and connect the dataset.
2. Partition or sample mode: Set this to Sampling.
3. Rate of sampling. See box 2 below.
Box 2: 0
3. Rate of sampling. Random seed for sampling: Optionally, type an integer to use as a seed value.
This option is important if you want the rows to be divided the same way every time. The default value is 0, meaning that a starting seed is generated based on the system clock. This can lead to slightly different results each time you run the experiment.
https://docs.microsoft.com/en-us ... artition-and-sample
NEW QUESTION # 145
You create an Azure Machine Learning workspace and set up a development environment. You plan to train a deep neural network (DNN) by using the Tensorflow framework and by using estimators to submit training scripts.
You must optimize computation speed for training runs.
You need to choose the appropriate estimator to use as well as the appropriate training compute target configuration.
Which values should you use? To answer, select the appropriate options in the answer area.
Box 1: Tensorflow
TensorFlow represents an estimator for training in TensorFlow experiments.
Box 2: 12 vCPU, 112 GB memory..,2 GPU,..
Use GPUs for the deep neural network.
https://docs.microsoft.com/en-us ... e/azureml.train.dnn
NEW QUESTION # 146
Hotspot Question
Your Azure Machine Learning workspace has a dataset named real_estate_data. A sample of the data in the dataset follows.
You want to use automated machine learning to find the best regression model for predicting the price column.
You need to configure an automated machine learning experiment using the Azure Machine Learning SDK.
How should you complete the code? To answer, select the appropriate options in the answer area.
Box 1: training_data
The training data to be used within the experiment. It should contain both training features and a label column (optionally a sample weights column). If training_data is specified, then the label_column_name parameter must also be specified.
Box 2: validation_data
Provide validation data: In this case, you can either start with a single data file and split it into training and validation sets or you can provide a separate data file for the validation set. Either way, the validation_data parameter in your AutoMLConfig object assigns which data to use as your validation set.
Example, the following code example explicitly defines which portion of the provided data in dataset to use for training and validation.
dataset = Dataset.Tabular.from_delimited_files(data)
training_data, validation_data = dataset.random_split(percentage=0.8, seed=1) automl_config = AutoMLConfig(compute_target = aml_remote_compute, task = 'classification', primary_metric = 'AUC_weighted', training_data = training_data, validation_data = validation_data, label_column_name = 'Class' ) Box 3: label_column_name label_column_name:
The name of the label column. If the input data is from a pandas.DataFrame which doesn't have column names, column indices can be used instead, expressed as integers.
This parameter is applicable to training_data and validation_data parameters.
Incorrect Answers:
X: The training features to use when fitting pipelines during an experiment. This setting is being deprecated. Please use training_data and label_column_name instead.
Y: The training labels to use when fitting pipelines during an experiment. This is the value your model will predict. This setting is being deprecated. Please use training_data and label_column_name instead.
X_valid: Validation features to use when fitting pipelines during an experiment. If specified, then y_valid or sample_weight_valid must also be specified.
Y_valid: Validation labels to use when fitting pipelines during an experiment.
Both X_valid and y_valid must be specified together.
exclude_nan_labels: Whether to exclude rows with NaN values in the label. The default is True.
y_max: y_max (float)
Maximum value of y for a regression experiment. The combination of y_min and y_max are used to normalize test set metrics based on the input data range. If not specified, the maximum value is inferred from the data.
https://docs.microsoft.com/en-us/python/api/azureml-train-automl-
client/azureml.train.automl.automlconfig.automlconfig?view=azure-ml-py
NEW QUESTION # 147
You are analyzing a numerical dataset which contains missing values in several columns.
You must clean the missing values using an appropriate operation without affecting the dimensionality of the feature set.
You need to analyze a full dataset to include all values.
Solution: Replace each missing value using the Multiple Imputation by Chained Equations (MICE) method.
Does the solution meet the goal?
  • A. NO
  • B. Yes
Replace using MICE: For each missing value, this option assigns a new value, which is calculated by using a method described in the statistical literature as "Multivariate Imputation using Chained Equations" or
"Multiple Imputation by Chained Equations". With a multiple imputation method, each variable with missing data is modeled conditionally using the other variables in the data before filling in the missing values.
Note: Multivariate imputation by chained equations (MICE), sometimes called "fully conditional specification" or "sequential regression multiple imputation" has emerged in the statistical literature as one principled method of addressing missing data. Creating multiple imputations, as opposed to single imputations, accounts for the statistical uncertainty in the imputations. In addition, the chained equations approach is very flexible and can handle variables of varying types (e.g., continuous or binary) as well as complexities such as bounds or survey skip patterns.
https://www.ncbi.nlm.nih.gov/pmc/articles/PMC3074241/
https://docs.microsoft.com/en-us ... /clean-missing-data
NEW QUESTION # 148
Many students did not perform well before they use Designing and Implementing a Data Science Solution on Azure actual test. They did not like to study, and they disliked the feeling of being watched by the teacher. They even felt a headache when they read a book. There are also some students who studied hard, but their performance was always poor. Basically, these students have problems in their learning methods. DP-100 prep torrent provides students with a new set of learning modes which free them from the rigid learning methods.
DP-100 Downloadable PDF: https://www.exams4sures.com/Microsoft/DP-100-practice-exam-dumps.html
Microsoft New DP-100 Practice Questions The second part of the syllabus makes the candidates looks into the PSTN technology and its components, Completely not, Microsoft New DP-100 Practice Questions it provides the most comprehensive certification standard industry training methods, Luckily, our company masters the core technology of developing the DP-100 Downloadable PDF - Designing and Implementing a Data Science Solution on Azure study materials, Microsoft New DP-100 Practice Questions The software is useable on Windows-based computers and laptops.
It is time to get started, To see these, simply type convert  in New DP-100 Practice Questions the Command Prompt, The second part of the syllabus makes the candidates looks into the PSTN technology and its components.
New DP-100 Practice Questions 100% Pass | Latest Microsoft Designing and Implementing a Data Science Solution on Azure Downloadable PDF Pass for sureCompletely not, it provides the most comprehensive certification standard DP-100 industry training methods, Luckily, our company masters the core technology of developing the Designing and Implementing a Data Science Solution on Azure study materials.
2026 Latest Exams4sures DP-100 PDF Dumps and DP-100 Exam Engine Free Share: https://drive.google.com/open?id=1yaYp85X2R9P6OqZ8RbTvWo4c3WUPrLQl
Posted at 2/24/2026 03:02:03        Only Author  2#
Im in awe of the insight in your article, thank you for sharing! Im sharing the COG170 latest exam pass4sure test that helped me achieve a promotion and raise. It's free for you todaybest of luck in reaching your career goals!
