Test Fortinet NSE7_EFW-7.2 Questions Answers - NSE7_EFW-7.2 Pdf Braindumps
Posted at 1/18/2026 03:13:50
2026 Latest Exams-boost NSE7_EFW-7.2 PDF Dumps and NSE7_EFW-7.2 Exam Engine Free Share: https://drive.google.com/open?id=1e_peakXfve9MXb7Z2Y5zNFI9vUplKDoL
With the help of the Fortinet NSE7_EFW-7.2 brain dumps and preparation material provided by Exams-boost, you will be able to get NSE7_EFW-7.2 certified at the first attempt. Our experts have curated an amazing NSE7_EFW-7.2 exam guide for passing the NSE7_EFW-7.2 exam. You can get the desired outcome by preparing yourself from the NSE7_EFW-7.2 Exam Dumps material provided by Exams-boost. We frequently update our NSE7_EFW-7.2 exam preparation material to reflect the latest changes in the NSE7_EFW-7.2 exam syllabus.
Fortinet NSE7_EFW-7.2 Exam Syllabus Topics:| Topic | Details | | Topic 1 | - System configuration: This topic discusses Fortinet Security Fabric and hardware acceleration. Furthermore, it delves into configuring various operation modes for an HA cluster.
| | Topic 2 | - VPN: Implementing IPsec VPN IKE version 2 is discussed in this topic. Additionally, it delves into implementing auto-discovery VPN (ADVPN) to enable on-demand VPN tunnels between sites.
| | Topic 3 | - Central management: The topic of Central management covers implementing central management.
| | Topic 4 | - Security profiles: Using FortiManager as a local FortiGuard server is discussed in this topic. Moreover, it delves into configuring web filtering, application control, and the intrusion prevention system (IPS) in an enterprise network.
| | Topic 5 | - Routing: It covers implementing OSPF to route enterprise traffic and Border Gateway Protocol (BGP) to route enterprise traffic.
NSE7_EFW-7.2 Pdf Braindumps, NSE7_EFW-7.2 Examcollection Dumps TorrentFortinet NSE7_EFW-7.2 Exam provided by Exams-boost is of the highest quality, and it enables participants to pass the exam on their first try. For successful preparation, it is essential to have good Fortinet NSE7_EFW-7.2 exam dumps and to prepare questions that may come up in the exam. Exams-boost helps candidates overcome all the difficulties they may encounter in their exam preparation. To ensure the candidates' satisfaction, Exams-boost has a support team that is available 24/7 to assist with a wide range of issues.
Fortinet NSE 7 - Enterprise Firewall 7.2 Sample Questions (Q55-Q60):NEW QUESTION # 55
Refer to the exhibit, which shows a network diagram.
Which IPsec phase 2 configuration should you impalement so that only one remote site is connected at any time?
- A. Set route-overlap to either use-new or use-old
- B. Set route-overlap to allow.
- C. Set single-source to enable
- D. Set net-device to enable
To ensure that only one remote site is connected at any given time in an IPsec VPN scenario, you should use route-overlap with the option to either use-new or use-old. This setting dictates which routes are preferred and how overlaps in routes are handled, allowing for one connection to take precedence over the other (C).
NEW QUESTION # 56
Winch two statements about ADVPN are true? (Choose two)
- A. Spoke to-spoke traffic never goes through the hub
- B. Routing is configured by enabling add-advpn-route
- C. lt supports NAI for on-demand tunnels
- D. auto-discovery receiver must be set to enable on the Spokes.
ADVPN (Auto Discovery VPN) is a feature that allows to dynamically establish direct tunnels (called shortcuts) between the spokes of a traditional Hub and Spoke architecture. The auto-discovery receiver must be set to enable on the spokes to allow them to receive NHRP messages from the hub and other spokes.
NHRP (Next Hop Resolution Protocol) is used for on-demand tunnels, which are established when there is traffic between spokes. Routing is configured by enabling add-nhrp-route, not add-advpn-route. References :
= ADVPN | FortiGate / FortiOS 7.2.0 | Fortinet Document Library, Technical Tip: Fortinet Auto Discovery VPN (ADVPN)
NEW QUESTION # 57
Exhibit.
Refer to the exhibit, which contains a partial policy configuration.
Which setting must you configure to allow SSH?
- A. Configure pot 22 in the Protocol Options field.
- B. Include SSH in the Application field
- C. Specify SSH in the Service field
- D. Select an application control profile corresponding to SSH in the Security Profiles section
* Option A is correct because to allow SSH, you need to specify SSH in the Service field of the policy configuration. This is because the Service field determines which types of traffic are allowed by the policy1. By default, the Service field is set to App Default, which means that the policy will use the default ports defined by the applications. However, SSH is not one of the default applications, so you need to specify it manually or create a custom service for it2.
* Option B is incorrect because configuring port 22 in the Protocol Options field is not enough to allow
* SSH. The Protocol Options field allows you to customize the protocol inspection and anomaly protection settings for the policy3. However, this field does not override the Service field, which still needs to match the traffic type.
* Option C is incorrect because including SSH in the Application field is not enough to allow SSH. The Application field allows you to filter the traffic based on the application signatures and categories4.
* Option D is incorrect because selecting an application control profile corresponding to SSH in the Security Profiles section is not enough to allow SSH. The Security Profiles section allows you to apply various security features to the traffic, such as antivirus, web filtering, IPS, etc. However, this section does not override the Service field, which still needs to match the traffic type. References: =
* 1: Firewall policies
* 2: Services
* 3: Protocol options profiles
* 4: Application control
NEW QUESTION # 58
Exhibit.
Refer to the exhibit, which shows a partial web filter profile conjuration What can you cone udo from this configuration about access to www.facebook, com, which is categorized as Social Networking?
- A. The access is blocked based on the URL Filter configuration
- B. The access is hocked if the local or the public FortiGuard server does not reply
- C. The access is allowed based on the FortiGuard Category Based Filter configuration
- D. The access is blocked based on the Content Filter configuration
The access to www.facebook.com is blocked based on the URL Filter configuration. In the exhibit, it shows that the URL "www.facebook.com" is specifically set to "Block" under the URL Filter section1. References :
= Fortigate: How to configure Web Filter function on Fortigate, Web filter | FortiGate / FortiOS 7.0.2 | Fortinet Document Library, FortiGate HTTPS web URL filtering ... - Fortinet ... - Fortinet Community
NEW QUESTION # 59
Refer to the exhibit, which shows the output of a BGP summary.
What two conclusions can you draw from this BGP summary? (Choose two.)
- A. External BGP (EBGP) exchanges routing information.
- B. The BGP session with peer 10.127.0.75 is established.
- C. The neighbors displayed are linked to a local router with the neighbor-range set to a value of 4.
- D. The router 100.64.3.1 has the parameter bfd set to enable.
The output of the BGP (Border Gateway Protocol) summary shows details about the BGP neighbors of a router, their Autonomous System (AS) numbers, the state of the BGP session, and other metrics like messages received and sent.
From the BGP summary provided:
A). External BGP (EBGP) exchanges routing information.
This conclusion can be inferred because the AS numbers for the neighbors are different from the local AS number (65117), which suggests that these are external connections.
B). The BGP session with peer 10.127.0.75 is established. This is indicated by the state/prefix received column showing a numeric value (1), which typically means that the session is established and a number of prefixes has been received.
C). The router 100.64.3.1 has the parameter bfd set to enable. This cannot be concluded directly from the summary without additional context or commands specifically showing BFD (Bidirectional Forwarding Detection) configuration.
D). The neighbors displayed are linked to a local router with the neighbor-range set to a value of 4. The neighbor- range concept does not apply here; the value 4 in the 'V' column stands for the BGP version number, which is typically 4.
NEW QUESTION # 60
When you select to use Exams-boost's products, you have set the first foot on the peak of the IT industry and the way to your dream is one step closer. The practice questions of Exams-boost can not only help you pass Fortinet Certification NSE7_EFW-7.2 Exam and consolidate your professional knowledge, but also provide you one year free update service.
NSE7_EFW-7.2 Pdf Braindumps: https://www.exams-boost.com/NSE7_EFW-7.2-valid-materials.html
- Free PDF Fortinet - NSE7_EFW-7.2 - Professional Test Fortinet NSE 7 - Enterprise Firewall 7.2 Questions Answers 🍫 Open ( [url]www.exam4labs.com ) enter ➥ NSE7_EFW-7.2 🡄 and obtain a free download 🌼NSE7_EFW-7.2 Latest Training[/url]
- Interactive NSE7_EFW-7.2 Course 🕜 NSE7_EFW-7.2 Reliable Dumps Sheet 🤳 NSE7_EFW-7.2 Exam PDF ⚡ Enter ▷ [url]www.pdfvce.com ◁ and search for ⏩ NSE7_EFW-7.2 ⏪ to download for free 💥NSE7_EFW-7.2 Reliable Exam Cram[/url]
- High-quality Test NSE7_EFW-7.2 Questions Answers Provide Prefect Assistance in NSE7_EFW-7.2 Preparation 🕶 Search for ➥ NSE7_EFW-7.2 🡄 and download it for free on 「 [url]www.practicevce.com 」 website 🌹High NSE7_EFW-7.2 Passing Score[/url]
- Pass Guaranteed 2026 NSE7_EFW-7.2: The Best Test Fortinet NSE 7 - Enterprise Firewall 7.2 Questions Answers 💇 Open { [url]www.pdfvce.com } and search for ▶ NSE7_EFW-7.2 ◀ to download exam materials for free 🚁NSE7_EFW-7.2 Cert Exam[/url]
- Reliable NSE7_EFW-7.2 Test Sims 🥇 Exam NSE7_EFW-7.2 Registration 🧞 Exam NSE7_EFW-7.2 Dumps 🐟 Immediately open 「 [url]www.practicevce.com 」 and search for ➤ NSE7_EFW-7.2 ⮘ to obtain a free download 📗NSE7_EFW-7.2 Valid Test Duration[/url]
- High Hit-Rate Test NSE7_EFW-7.2 Questions Answers | 100% Free NSE7_EFW-7.2 Pdf Braindumps 🥵 Search on ( [url]www.pdfvce.com ) for ▛ NSE7_EFW-7.2 ▟ to obtain exam materials for free download 🐋NSE7_EFW-7.2 Pass Test[/url]
- NSE7_EFW-7.2 Latest Training 📞 NSE7_EFW-7.2 Valid Exam Syllabus 🧓 NSE7_EFW-7.2 Exam Pattern ⬇ Open ( [url]www.vce4dumps.com ) and search for ➥ NSE7_EFW-7.2 🡄 to download exam materials for free 🤔NSE7_EFW-7.2 Exam Passing Score[/url]
- High Hit-Rate Test NSE7_EFW-7.2 Questions Answers | 100% Free NSE7_EFW-7.2 Pdf Braindumps 🚆 Search for ➥ NSE7_EFW-7.2 🡄 and download exam materials for free through ⏩ [url]www.pdfvce.com ⏪ 🧪NSE7_EFW-7.2 Reliable Dumps Sheet[/url]
- Excellent Test NSE7_EFW-7.2 Questions Answers – 100% High-quality Fortinet NSE 7 - Enterprise Firewall 7.2 Pdf Braindumps 📄 Enter ( [url]www.torrentvce.com ) and search for [ NSE7_EFW-7.2 ] to download for free 🛴NSE7_EFW-7.2 Exam PDF[/url]
- High-quality Fortinet - NSE7_EFW-7.2 - Test Fortinet NSE 7 - Enterprise Firewall 7.2 Questions Answers Ⓜ Search for ✔ NSE7_EFW-7.2 ️✔️ and download it for free on ⏩ [url]www.pdfvce.com ⏪ website 🕑NSE7_EFW-7.2 Valid Exam Syllabus[/url]
- NSE7_EFW-7.2 Reliable Exam Cram 🚆 Test NSE7_EFW-7.2 Pattern 🪂 NSE7_EFW-7.2 Standard Answers 💯 Open 【 [url]www.vceengine.com 】 and search for ➤ NSE7_EFW-7.2 ⮘ to download exam materials for free 📠NSE7_EFW-7.2 Latest Training[/url]
- pct.edu.pk, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, gifyu.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of Exams-boost NSE7_EFW-7.2 dumps from Cloud Storage: https://drive.google.com/open?id=1e_peakXfve9MXb7Z2Y5zNFI9vUplKDoL
