[Android] FireFly 3568j built Android image fails on emulator
91
Android FireFly 3568j built Android image fails on emulator
Posted at 3/24/2023 14:17:48      View3232 | Replies5        Print      Only Author   [Copy Link] 1#
I have two questions.
1. How do I run the image AIO-3568J_Android11_HDMI_230202.img in qemu on x86-64 Ubuntu from command line? Can I integrate this VM in Android studio?
2. I am trying to build and run the  FireFly 3568 image on the emulator.
source build/envsetup.shlunch rk3568_firefly_aioj-userdebugmake installcleanmake -j8
I run
./emulator
The emulator window is being drawed OK, but the guest system doesn't seem to start: no output on the console, the device windows is black. What can be wrong?
P.S. The filename and dl address apply to the first question, the log and the picture attached - to the 2nd.
emu_run_log.tar.gz
5.47 KB, Down times: 1
Posted at 3/24/2023 15:45:10        Only Author  2#
1. How to build Android image?
----> see https://wiki.t-firefly.com/en/Core-3568J/prepare_compile_android.html,  https://wiki.t-firefly.com/en/Co ... d11.0_firmware.html
2. AIO-3568J_Android11_HDMI_230202.img do not support in qemu on x86-64 Ubuntu from command line
Posted at 3/24/2023 17:27:09        Only Author  3#
I performed the build just like it described in the manual, in Ubuntu 18.04 podman container. Have spent a lot of time...
restricted members
Posted at 1/22/2026 02:21:02        Only Author  4#
This article is fantastic, I really appreciate you sharing it. Best wishes for your exams! Heres the free Test N16599GC10 tutorials resource.
Posted at 2/11/2026 07:34:16        Only Author  5#
Thank you for the article, it was a real eye-catching read. You can enjoy the Reliable 401 exam pattern content for free, and its of high quality.
Posted at 2/20/2026 05:35:44        Only Author  6#
거침없이 발전해나가는 IT업계에서 자신만의 자리를 동요하지 않고 단단히 지킬려면Microsoft인증 MB-335시험은 무조건 패스해야 합니다. 하지만Microsoft인증 MB-335시험패스는 하늘에 별따기 만큼 어렵습니다. 시험이 영어로 출제되어 공부자료 마련도 좀 힘든편입니다. 여러분들의 고민을 덜어드리기 위해KoreaDumps에서는Microsoft인증 MB-335시험의 영어버전 실제문제를 연구하여 실제시험에 대비한 영어버전Microsoft인증 MB-335덤프를 출시하였습니다.전문적인 시험대비자료이기에 다른 공부자료는 필요없이KoreaDumps에서 제공해드리는Microsoft인증 MB-335영어버전덤프만 공부하시면 자격증을 딸수 있습니다.
