1z1-076 Latest Exam Question - Reliable 1z1-076 Test Cost
138
Posted at 1/18/2026 05:35:40      View:113 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Lead1Pass 1z1-076 dumps from Cloud Storage: https://drive.google.com/open?id=1IeH-m0hIJp4Dk8F4QDDSUzXf9dNIupIy
By using Lead1Pass 1z1-076 exam questions, you will be able to understand the real exam 1z1-076 scenario. It will help you get verified 1z1-076 answers and you will be able to judge your 1z1-076 preparation level for the 1z1-076 exam. More importantly, it will help you understand the real 1z1-076 exam feel. You will be able to check the real exam scenario by using this specific 1z1-076 Exam PDF questions. Our Oracle experts are continuously working on including new 1z1-076 questions material and we provide a guarantee that you will be able to pass the 1z1-076 exam on the first attempt.
Oracle 1z1-076 Exam Syllabus Topics:
  • Backup and Recovery Considerations in an Oracle Data Guard Configuration: In this topic, Backup and recovery procedures in a Data Guard configuration are discussed, including RMAN backups, offloading to physical standby, and network-based recovery.
  • Enhanced Client Connectivity in a Data Guard Environment: This topic focuses on enhancing client connectivity in a Data Guard setup and implementing failover procedures for seamless client redirection. It also covers application continuity to ensure uninterrupted operations during role transitions.
  • Oracle Data Guard Broker Basics: An overview of the Data Guard broker, its architecture, components, benefits, and configurations, is provided here. It serves as an introduction to the tool used for managing Data Guard configurations.
  • Oracle Data Guard Basics: This topic covers the essential architecture and concepts of Oracle Data Guard. It includes sub-topics such as the physical and logical standby database comparison, benefits of Data Guard, and its integration with multi-tenant databases.
Topic 5
  • Patching and Upgrading Databases in a Data Guard Configuration: This section provides guidance on patching and upgrading databases in a Data Guard environment, along with performance optimization techniques and monitoring considerations.
Topic 7
  • Performing Role Transitions: Here, the concept of database roles is explained, along with the steps for performing switchovers, failovers, and maintaining physical standby sessions during role transitions.
Topic 8
  • Managing Physical Standby Files After Structural Changes on the Primary Database: The topic covers managing structural changes in the primary database and their impact on physical standby files.
Topic 9
  • Monitoring a Data Guard Broker Configuration: The topic covers the use of Enterprise Manager and DGMGRL to monitor Data Guard configurations and explains the various data protection modes available.
Topic 10
  • Using Flashback Database in a Data Guard Configuration: This topic covers the configuration and advantages of using Flashback Database in a Data Guard setup, as well as the process of enabling fast-start failover for seamless role changes.
Topic 11
  • Managing Oracle Net Services in a Data Guard Environment: The section focuses on Oracle Net Services and its role in Data Guard networking setup.
Topic 13
  • Using Oracle Active Data Guard: Supported Workloads in Read-Only Standby Databases: Here, the usage of physical standby databases for real-time queries is discussed.
Topic 14
  • Creating a Logical Standby Database: This topic guides users through the process of creating and managing a logical standby database, including SQL Apply filtering.
Perfect Oracle 1z1-076 Latest Exam Question - 1z1-076 Free DownloadWe value every customer who purchases our 1z1-076 test material and we hope to continue our cooperation with you. Our 1z1-076 test questions are constantly being updated and improved so that you can get the information you need and get a better experience. Our 1z1-076 test questions have been following the pace of digitalization, constantly refurbishing, and adding new things. I hope you can feel the 1z1-076 Exam Prep sincerely serve customers. We also attach great importance to the opinions of our customers. As long as you make reasonable recommendations for our 1z1-076 test material, we will give you free updates to the system's benefits. The duration of this benefit is one year, and 1z1-076 exam prep look forward to working with you.
Oracle Database 19c: Data Guard Administration Sample Questions (Q110-Q115):NEW QUESTION # 110
Which TWO observations are true about the Far Sync instance?
  • A. Includes a standby control file, password file, data files, standby redo logs, and archive logs
  • B. Receives redo synchronously from the primary database
  • C. Can only be created using a series of SQL commands
  • D. Can be created using the RMAN DUPLICATE command
  • E. Applies redo received
Answer: B,E
A Far Sync instance is a special kind of Oracle Data Guard configuration that allows synchronous redo transport from a primary database to a remote standby database with minimum impact on the primary database's performance. The Far Sync instance receives redo data synchronously from the primary database (A), then ships it asynchronously to the remote standby database, thus extending zero data loss protection over longer distances and higher network latency environments than would be practical with a synchronous standby alone. The Far Sync instance does not apply the redo data; it just receives and ships it (E). A Far Sync instance does not have data files, and it cannot apply redo to stay synchronized with the primary database.
References:Oracle Database High Availability Overview and Oracle Data Guard Concepts and Administration documentation detail the role and configuration of Far Sync instances, including how they contribute to achieving zero data loss disaster recovery over long distances.
NEW QUESTION # 111
There are currently 6 applief. and 6 pfepafef processes running and no idle applier processes on y logical standby database.
The max_SERVERS SQL apply parameter and number of archiver processes are both set to 12.
Identify two changes, each of which would allow you to increase the number of applier processes.
  • A. Increase the value for the MAX_SERVERS SQL apply parameter.
  • B. Increase the RECOVERY_PARALLEL initialization parameter.
  • C. Increase the parallel_max_server initialization parameter.
  • D. Increase the processes initialization parameter. D Decrease the number of FREPARER processes.
  • E. Decrease the number of archiver processes on the standby database.
To increase the number of applier processes on a logical standby database, the following changes can be made:
C: Increasing the value for the MAX_SERVERS SQL apply parameter would allow for more applier processes to be initiated, assuming that system resources permit.
D: Increasing the PARALLEL_MAX_SERVERS initialization parameter would allow for more parallel execution processes, which can be used by SQL apply to increase the number of applier processes.
Option A is incorrect as decreasing the number of archiver processes will not necessarily increase the number of applier processes; these are unrelated components.
Option B is incorrect because the 'FREPARER' processes do not exist, it seems to be a typographical error, and the 'REPARER' is not a valid Oracle process or parameter.
Option E is incorrect because the RECOVERY_PARALLELISM parameter controls the number of processes used for instance recovery and media recovery, not for SQL apply.
NEW QUESTION # 112
Which THREE are true about using flashback database in a Data Guard environment?
  • A. You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption.
  • B. When a flashback database operation is performed on a primary database, a logical standby database is also flashed back automatically.
  • C. It may be used to flash back a physical standby that receives redo from a far sync instance.
  • D. When a flashback database operation is performed on a primary database, a physical standby database is also flashed back automatically.
  • E. It may not be used to flash back a primary database after a failover to a physical standby.
  • F. You can use it when real-time apply is enabled in case the phylt may not be used to flash back a primary database after a failover to a logical standby.
Answer: A,C,E
Flashback Database is a feature that allows reverting a database to a previous point in time, which is extremely useful in various Data Guard configurations:
It may be used to flash back a physical standby that receives redo from a far sync instance (C): Flashback Database can be used on a physical standby database to revert it to a past point in time, even when it is receiving redo data from a far sync instance. This can be particularly useful to recover from logical corruptions or unwanted changes.
You can use it when real-time apply is enabled in case the physical standby suffers from logical corruption (D): Even when real-time apply is enabled, which allows redo data to be applied to the standby database as soon as it is received, Flashback Database can be used to revert the physical standby database to a point in time before the logical corruption occurred.
It may not be used to flash back a primary database after a failover to a physical standby (E): After a failover has occurred from a primary to a physical standby database, making the standby the new primary, Flashback Database cannot be used to revert the old primary database to a state before the failover because the failover operation makes irreversible changes to the database role and configuration.
Oracle Database Backup and Recovery User's Guide
NEW QUESTION # 113
You created a physical standby database prodsbyi from the primary database prod using SQL and RMAN.
Which THREE are prerequisites for creating a Data Guard Broker configuration to manage these databases?
  • A. The LOG_ARCHIVE_DEST_n parameters with the service attribute set must be cleared.
  • B. The primary database must have FORCE LOGGING enabled.
  • C. The primary database must have supplemental logging enabled.
  • D. The standby database must have supplemental logging enabled.
  • E. A local net service name to enable connectivity to the PRODSBYI database instance must be defined on the primary database host.
  • F. The DG_BROKER_START parameter must be set to TRUE for both database instances.
Answer: C,E,F
When setting up a Data Guard Broker configuration for a primary database and its physical standby, the following prerequisites must be met:
* A: Oracle Net connectivity must be defined on both the primary and standby hosts to enable the respective database instances to communicate with each other.
* B: Supplemental logging is required on the primary database because it provides additional logging necessary for the standby database to be able to apply changes from the primary database accurately.
* F: The DG_BROKER_START parameter must be set to TRUE for both the primary and standby
* database instances. This parameter is used to start the Data Guard Broker process which manages the configuration.
Options C and D are not prerequisites for creating a Data Guard Broker configuration. Additionally, while FORCE LOGGING mode (option E) is recommended as a best practice to prevent possible data inconsistencies during media recovery, it is not a strict prerequisite for creating a Data Guard Broker configuration.
References: This guidance is based on Oracle's best practices for setting up Data Guard configurations, as found in the Oracle Data Guard Broker documentation and the Oracle Data Guard Concepts and Administration guide.
NEW QUESTION # 114
Which THREE are among the various tasks performed by the Data Guard Monitor (DMON) process?
  • A. communicating with dkon processes in other database instances that are part of the broker configuration
  • B. performing role transitions when switchover requests are made
  • C. communicating with the DMON process of the observer to monitor a primary database in case a fast start failover is required
  • D. activating role-based services appropriately in the various database instances of the configuration, based on the database role
  • E. maintaining information about all members of the broker configuration in binary configuration files.
Answer: B,D,E
The Data Guard Monitor (DMON) process is a key component of Oracle Data Guard. It plays a crucial role in managing and monitoring the state of both the primary and standby databases in a Data Guard configuration.
* Performing role transitions when switchover requests are made (A): DMON is responsible for coordinating the switchover process between the primary and standby databases. This involves safely transitioning the roles of the databases to ensure data protection and availability.
* Maintaining information about all members of the broker configuration in binary configuration files (B): DMON maintains detailed information about the databases in the Data Guard configuration, including their roles, states, and network addresses. This information is stored in binary configuration files, which are used by the Data Guard Broker to manage the Data Guard environment.
* Activating role-based services appropriately in the various database instances of the configuration, based on the database role (C): DMON activates services that are appropriate for the role of each database in the Data Guard configuration. For example, it may activate different services on a primary database than on a standby database, based on the specific requirements of each role.
* Oracle Data Guard Concepts and Administration
* Oracle Data Guard Broker documentation
NEW QUESTION # 115
If you want to have a general review of what you have learned, you can choose us. 1z1-076 Online test engine has testing history and performance review, and it can help you have a general review of what you have learnt last time. Besides 1z1-076 Online test engine support all web browsers, and it is convenient and easy to learn, and you can have offline practice if you like. 1z1-076 Training Materials are high quality and you can pass the exam just one time if you choose us. We offer you free update for one year, and the update version for 1z1-076 exam dumps will be sent to your email automatically.
Reliable 1z1-076 Test Cost: https://www.lead1pass.com/Oracle/1z1-076-practice-exam-dumps.html
P.S. Free & New 1z1-076 dumps are available on Google Drive shared by Lead1Pass: https://drive.google.com/open?id=1IeH-m0hIJp4Dk8F4QDDSUzXf9dNIupIy
Posted at 2/23/2026 14:15:04        Only Author  2#
I’m in awe of this article, thank you for sharing it. Thanks to the Dumps H12-821_V1.0 collection exam, I got promoted and earned a higher salary. Now, I’m giving it away for free today!
Posted at 3/5/2026 06:34:16        Only Author  3#
如果你覺得你購買Fast2test IASP的SPP考試培訓資料利用它來準備考試是一場冒險,那麼整個生命就是一場冒險,走得最遠的人常常就是願意去做願意去冒險的人。更何況Fast2test IASP的SPP考試培訓資料是由眾多考生用實踐證明了,它帶給每位考生的成功也是真實有效的,成功有夢想和希望固然重要,但更重要的是去實踐和證明,Fast2test IASP的SPP考試培訓資料是被證明一定會成功的,選擇了它,你還有什麼理由不成功呢!
