H12-725_V4.0 Testking Exam Questions | H12-725_V4.0 Latest Test Report
Posted at 1/18/2026 06:30:49
P.S. Free & New H12-725_V4.0 dumps are available on Google Drive shared by ActualPDF: https://drive.google.com/open?id=14Eao5aQm2wZ7Jqx7-R8Hz5Oo6jQpFQB0
If candidates want to obtain certifications candidates should notice studying methods. If you do not want to purchase our Huawei H12-725_V4.0 new exam bootcamp materials and just want to study yourself, willpower is the most important. Passing so many exams is really not easy. Reasonable studying methods and relative work experience make you half the work with double the results. H12-725_V4.0 New Exam Bootcamp materials will be a shortcut for you.
Huawei H12-725_V4.0 Certification Exam consists of multiple-choice questions, and it is designed to test the candidate's knowledge and skills in a variety of security domains, including firewall technology, intrusion prevention, VPN technology, and security management. H12-725_V4.0 exam is divided into two parts: a written exam and a lab exam. The written exam covers the theoretical aspects of security technologies and solutions, while the lab exam focuses on the practical skills required to implement and manage security solutions in Huawei enterprise networks.
H12-725_V4.0 Latest Test Report | Valid H12-725_V4.0 Test NotesWe present our H12-725_V4.0 real questions in PDF format. It is beneficial for those applicants who are busy in daily routines. The Huawei H12-725_V4.0 PDF QUESTIONS contains all the exam questions which will appear in the real test. You can easily get ready for the examination in a short time by just memorizing H12-725_V4.0 Actual Questions. ActualPDF PDF questions can be printed. And this document of H12-725_V4.0 questions is also usable on smartphones, laptops and tablets. These features of the Huawei H12-725_V4.0 PDF format enable you to prepare for the test anywhere, anytime.
Huawei H12-725_V4.0 Certification Exam is a highly respected credential in the ICT security industry. It demonstrates to employers that an individual has the skills and knowledge necessary to protect their organization's data and assets from cyber threats.
Huawei HCIP-Security V4.0 Sample Questions (Q18-Q23):NEW QUESTION # 18
Which of the following protocols can be encapsulated through GRE over IPsec?(Select All that Apply)
- A. IPX
- B. OSPF
- C. VRRP
- D. IPv6
Answer: A,B,C,D
* IPsec does not support non-IP traffic (e.g., multicast, routing protocols, or legacy protocols like IPX).
* GRE over IPsec allows encapsulation of:
* A. IPX# Legacy protocol supported via GRE.
* B. VRRP# Uses multicast, which GRE supports.
* C. IPv6# GRE tunnels can carry IPv6 over IPv4.
* D. OSPF# Uses multicast (224.0.0.5 & 224.0.0.6), requiring GRE.
* Why are all options correct?
* GRE over IPsec is required for non-unicast and legacy protocols.
HCIP-Security References:
* Huawei HCIP-Security Guide # GRE over IPsec Deployment
NEW QUESTION # 19
Which of the following statements is true about the outgoing traffic in the firewall virtual system?
- A. Traffic from the public network interface to the private network interface is limited by the inbound bandwidth.
- B. Traffic from the private network interface to the public network interface is limited by the outbound bandwidth.
- C. Traffic from the public network interface to the private network interface is limited by the outbound bandwidth.
- D. Traffic from the private network interface to the public network interface is limited by the inbound bandwidth.
* Inbound bandwidth= Trafficenteringthe firewall.
* Outbound bandwidth= Trafficleavingthe firewall.
* Correct answer:
* A. Private # Public traffic is controlled by outbound bandwidth.
* Why are the other options incorrect?
* Bis incorrect because public # private traffic is controlled byinbound bandwidth, not outbound.
* Cis incorrect because inbound bandwidth does not apply to private # public traffic.
* Dis incorrect because public # private traffic is controlled by inbound bandwidth.
* Huawei HCIP-Security Guide # Firewall Virtual System Bandwidth Control
NEW QUESTION # 20
Which of the following parameters is not required for an IKE proposal?
- A. Encryption algorithm
- B. Authentication algorithm
- C. Encapsulation mode
- D. Negotiation mode
* IKE (Internet Key Exchange) proposalincludes:
* Encryption algorithm# Ensures data confidentiality.
* Authentication algorithm# Verifies the identity of peers.
* Encapsulation mode# Defines whether IPsec operates intunnel mode or transport mode.
* Why is C the correct answer?
* Negotiation mode is not part of the IKE proposal; it is configured separately in the IKE policy.
* Huawei HCIP-Security Guide # IKE Configuration
NEW QUESTION # 21
Which of the following methods are used by flood attacks to cause denial of services?(Select All that Apply)
- A. Exhaust server-side resources.
- B. Exhaust available bandwidth.
- C. Control network host rights.
- D. Exhaust network device resources.
Answer: A,B,D
* Flood attacks (DoS/DDoS) overwhelm network resources, preventing normal users from accessing services.
* Correct answers:
* A. Exhaust available bandwidth# Large amounts of traffic saturate the network.
* B. Exhaust server-side resources# High CPU/memory usage causes server crashes.
* D. Exhaust network device resources# Firewalls, routers, and switches become overloaded.
* Why is C incorrect?
* Controlling host rights is related to hacking, not flooding attacks.
* Huawei HCIP-Security Guide # DoS/DDoS Attack Prevention
NEW QUESTION # 22
In the figure, if 802.1X authentication is used for wired users on the network, the network admission device and terminals must be connected through a Layer 2 network.
Options:
Understanding 802.1X Authentication in Wired Networks:
* 802.1X is a port-based network access control (PNAC) protocolthat requires aLayer 2 connection between thesupplicant (PC), the authenticator (switch), and the authentication server (e.g., RADIUS server).
* In wired networks,802.1X authentication occurs at the Ethernet switch (Layer 2 device), which enforces authenticationbefore allowing network access.
Why Must the Network Be Layer 2?
* 802.1X authentication operates at Layer 2 (Data Link Layer) before any IP-based communication (Layer 3) occurs.
* If the authentication device and user terminal were on different Layer 3 networks, the authentication packets (EAPOL - Extensible Authentication Protocol Over LAN)would not be forwarded.
* In the figure, the authentication control point is at theaggregation switch, which means thePC and switch must be in the same Layer 2 domain.
Components of 802.1X Authentication in the Figure:
* Supplicant (PC)# The device requesting network access.
* Authenticator (Aggregation Switch)# The switch controlling access to the network based on authentication results.
* Authentication Server (iMaster NCE-Campus & AD Server)# Verifies user credentials and grants or denies access.
* Layer 2 Connectivity Requirement# ThePC must be in the same Layer 2 networkas the Authenticatorto communicate via EAPOL.
Why "TRUE" is the Correct answer:
* 802.1X authentication is performed before IP addresses are assigned, meaning it can only operate in a Layer 2 network.
* EAPOL (Extensible Authentication Protocol Over LAN) messages are not routableand must stay within a single Layer 2 broadcast domain.
* In enterprise networks,VLAN-based 802.1X authentication is often used, where authenticated users are assigned to a specific VLAN.
* Huawei HCIP-Security Guide# 802.1X Authentication in Enterprise Networks
* Huawei iMaster NCE-Campus Documentation# Authentication Control and NAC Deployment
* IEEE 802.1X Standard Documentation# Layer 2 Network Authentication
NEW QUESTION # 23
H12-725_V4.0 Latest Test Report: https://www.actualpdf.com/H12-725_V4.0_exam-dumps.html
- Efficient H12-725_V4.0 Testking Exam Questions Help You to Get Acquainted with Real H12-725_V4.0 Exam Simulation 🚁 Go to website 「 [url]www.examdiscuss.com 」 open and search for 【 H12-725_V4.0 】 to download for free ✌Test H12-725_V4.0 Preparation[/url]
- Pass Guaranteed Quiz Unparalleled Huawei - H12-725_V4.0 - HCIP-Security V4.0 Testking Exam Questions 🪕 Search for ➠ H12-725_V4.0 🠰 and obtain a free download on 【 [url]www.pdfvce.com 】 🥐Exam H12-725_V4.0 Course[/url]
- Efficient H12-725_V4.0 Testking Exam Questions Help You to Get Acquainted with Real H12-725_V4.0 Exam Simulation ⛷ Simply search for ➥ H12-725_V4.0 🡄 for free download on ⮆ [url]www.vceengine.com ⮄ ⏲New H12-725_V4.0 Practice Questions[/url]
- Pass Guaranteed 2026 Huawei Unparalleled H12-725_V4.0: HCIP-Security V4.0 Testking Exam Questions 🕐 Search for ⮆ H12-725_V4.0 ⮄ and obtain a free download on ⇛ [url]www.pdfvce.com ⇚ 🕒New Soft H12-725_V4.0 Simulations[/url]
- Pass Guaranteed 2026 Huawei Unparalleled H12-725_V4.0: HCIP-Security V4.0 Testking Exam Questions 🛅 Immediately open 《 [url]www.exam4labs.com 》 and search for ▛ H12-725_V4.0 ▟ to obtain a free download 🌎Test H12-725_V4.0 Pdf[/url]
- Free PDF H12-725_V4.0 - HCIP-Security V4.0 –High-quality Testking Exam Questions ☣ Search for ➽ H12-725_V4.0 🢪 and download it for free immediately on ➠ [url]www.pdfvce.com 🠰 🐐Test H12-725_V4.0 Preparation[/url]
- Free PDF H12-725_V4.0 - High-quality HCIP-Security V4.0 Testking Exam Questions 📶 Search for ⏩ H12-725_V4.0 ⏪ and download exam materials for free through { [url]www.practicevce.com } 🧏Exam H12-725_V4.0 Experience[/url]
- Pass Guaranteed 2026 Huawei Unparalleled H12-725_V4.0: HCIP-Security V4.0 Testking Exam Questions 🦥 Open ⏩ [url]www.pdfvce.com ⏪ enter ⇛ H12-725_V4.0 ⇚ and obtain a free download 💹Exam H12-725_V4.0 Tests[/url]
- Free PDF H12-725_V4.0 - High-quality HCIP-Security V4.0 Testking Exam Questions 🐪 Open website “ [url]www.troytecdumps.com ” and search for ➠ H12-725_V4.0 🠰 for free download 🤣H12-725_V4.0 Guaranteed Passing[/url]
- Free PDF H12-725_V4.0 - HCIP-Security V4.0 –High-quality Testking Exam Questions 🏑 Go to website 【 [url]www.pdfvce.com 】 open and search for ➠ H12-725_V4.0 🠰 to download for free 💒Test H12-725_V4.0 Preparation[/url]
- Exam H12-725_V4.0 Assessment 💂 H12-725_V4.0 Valid Dumps Sheet 🍢 Exam H12-725_V4.0 Tests 🕊 Enter 「 [url]www.testkingpass.com 」 and search for { H12-725_V4.0 } to download for free 🌻H12-725_V4.0 Valid Dumps Sheet[/url]
- dl.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest ActualPDF H12-725_V4.0 PDF Dumps and H12-725_V4.0 Exam Engine Free Share: https://drive.google.com/open?id=14Eao5aQm2wZ7Jqx7-R8Hz5Oo6jQpFQB0
