[General] Latest Microsoft DP-420 Dumps - Eliminate Your Risk of Failing [2026]
102
General Latest Microsoft DP-420 Dumps - Eliminate Your Risk of Failing [2026]
Posted at 1/18/2026 07:49:51      View162 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free & New DP-420 dumps are available on Google Drive shared by PracticeVCE: https://drive.google.com/open?id=1n5RXx1csmD5SmTRTRQ5atIMHIWgF2EuS
Many candidates are interested in our software test engine of DP-420. This version is software. If you download and install on your personal computer online, you can copy to any other electronic products and use offline. The software test engine of DP-420 is very practical. It can be used on Phone, Ipad and so on. You can study any time anywhere you want. Comparing to PDF version, the software test engine of Microsoft DP-420 also can simulate the real exam scene so that you can overcome your bad mood for the real exam and attend exam casually.
Microsoft DP-420 exam, also known as Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB, is an advanced-level certification exam that tests your knowledge of designing and implementing cloud-native applications using Azure Cosmos DB. DP-420 Exam is intended for professionals who want to validate their expertise in developing cloud-based applications using Azure Cosmos DB.
Exam DP-420 Duration, New DP-420 Test PapersVarious study forms are good for boosting learning interests. So our company has taken all customers requirements into account. Now we have PDF version, windows software and online engine of the DP-420 certification materials. Although all contents are the same, the learning experience is totally different. First of all, the PDF version DP-420 certification materials are easy to carry and have no restrictions. Then the windows software can simulate the real test environment, which makes you feel you are doing the real test. The online engine of the DP-420 test training can run on all kinds of browsers, which does not need to install on your computers or other electronic equipment. All in all, we hope that you can purchase our three versions of the DP-420 real exam dumps.
Microsoft Designing and Implementing Cloud-Native Applications Using Microsoft Azure Cosmos DB Sample Questions (Q69-Q74):NEW QUESTION # 69
You have an Azure Cosmos DB account named account1 that has a default consistency level of session.
You have an app named App1.
You need to ensure that the read operations of App1 can request either bounded staleness or consistent prefix consistency.
What should you modify for each consistency level? To answer, select the appropriate options in the answer area.
NEW QUESTION # 70
You provision Azure resources by using the following Azure Resource Manager (ARM) template.
NEW QUESTION # 71
The following is a sample of a document in orders.
The orders container uses customer as the partition key.
You need to provide a report of the total items ordered per month by item type. The solution must meet the following requirements:
Ensure that the report can run as quickly as possible.
Minimize the consumption of request units (RUs).
What should you do?
  • A. Configure the report to query a new aggregate container. Populate the aggregates by using SQL queries that run daily.
  • B. Configure the report to query orders by using a SQL query through a dedicated gateway.
  • C. Configure the report to query a new aggregate container. Populate the aggregates by using the change feed.
  • D. Configure the report to query orders by using a SQL query.
You can facilitate aggregate data by using Change Feed and Azure Functions, and then use it for reporting.
Reference: https://docs.microsoft.com/en-us/azure/cosmos-db/change-feed
NEW QUESTION # 72
You have an Azure Cosmos DB Core (SQL) API account that is configured for multi-region writes. The account contains a database that has two containers named container1 and container2.
The following is a sample of a document in container1:
"customerId": 1234,
"firstName": "John",
"lastName": "Smith",
"policyYear": 2021
The following is a sample of a document in container2:
"gpsId": 1234,
"latitude": 38.8951,
"longitude": -77.0364
You need to configure conflict resolution to meet the following requirements:
For container1 you must resolve conflicts by using the highest value for policyYear.
For container2 you must resolve conflicts by accepting the distance closest to latitude: 40.730610 and longitude: -73.935242.
Administrative effort must be minimized to implement the solution.
What should you configure for each container? To answer, drag the appropriate configurations to the correct containers. Each configuration may be used once, more than once, or not at all. You may need to drag the split bar between panes or scroll to view content.
Box 1: Last Write Wins (LWW) (default) mode
Last Write Wins (LWW): This resolution policy, by default, uses a system-defined timestamp property. It's based on the time-synchronization clock protocol.
Box 2: Merge Procedures (custom) mode
Custom: This resolution policy is designed for application-defined semantics for reconciliation of conflicts.
When you set this policy on your Azure Cosmos container, you also need to register a merge stored procedure.
This procedure is automatically invoked when conflicts are detected under a database transaction on the server. The system provides exactly once guarantee for the execution of a merge procedure as part of the commitment protocol.
https://docs.microsoft.com/en-us ... resolution-policies
https://docs.microsoft.com/en-us ... to-manage-conflicts
NEW QUESTION # 73
You have an Azure Cosmos DB for NoSQL container. The container contains items that have the following properties.
You need to protect the data stored in the container by using Always Encrypted. For each property, you must use the strongest type of encryption and ensure that queries execute properly.
What is the strongest type of encryption that you can apply to each property? To answer, select the appropriate options in the answer area.
Box 1 = Randomized
Box 2 = Deterministic
Always Encrypted for Azure Cosmos DB supports two types of encryption: deterministic and randomized1.
Deterministic encryption always produces the same encrypted value for any given plain text value.
Randomized encryption produces a different encrypted value for the same plain text value.
For dateOfBirth, randomized encryption is the strongest type of encryption because it provides better protection against statistical analysis and brute-force attacks. Deterministic encryption would not be suitable for dateOfBirth because it could reveal patterns or allow equality comparisons1.
For healthStatus, deterministic encryption is the strongest type of encryption because it allows queries to perform equality comparisons and filters on the encrypted property. Randomized encryption would not be suitable for healthStatus because it would prevent any queries on the encrypted property1.
NEW QUESTION # 74
No matter you are exam candidates of high caliber or newbies, our Microsoft DP-420 exam quiz will be your propulsion to gain the best results with least time and reasonable money. Not only because the outstanding content of DP-420 Real Dumps that produced by our professional expert but also for the reason that we have excellent vocational moral to improve our DP-420 learning materials quality.
Exam DP-420 Duration: https://www.practicevce.com/Microsoft/DP-420-practice-exam-dumps.html
2026 Latest PracticeVCE DP-420 PDF Dumps and DP-420 Exam Engine Free Share: https://drive.google.com/open?id=1n5RXx1csmD5SmTRTRQ5atIMHIWgF2EuS
