MuleSoft-Integration-Architect-I Practice Guide & Online MuleSoft-Integratio
Posted at 1/18/2026 08:19:43
View149
Replies0
DOWNLOAD the newest Pass4Test MuleSoft-Integration-Architect-I PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=12b1tLA3cBlabM5nt4mcSo_7bl8542fLq
In order to survive better in society, we must understand the requirements of society for us. In addition to theoretical knowledge, we need more practical skills. After we use MuleSoft-Integration-Architect-I practice guide, we can get the certification faster, which will greatly improve our competitiveness. Of course, your gain is definitely not just the MuleSoft-Integration-Architect-I certificate. Our MuleSoft-Integration-Architect-I study materials will change your working style and lifestyle. You will work more efficiently than others. Our MuleSoft-Integration-Architect-I training materials can play such a big role.
Pass4Test is an excellent source of information on IT Certifications. In the Pass4Test, you can find study skills and learning materials for your exam. Pass4Test's Salesforce MuleSoft-Integration-Architect-I training materials are studied by the experienced IT experts. It has a strong accuracy and logic. To encounter Pass4Test, you will encounter the best training materials. You can rest assured that using our Salesforce MuleSoft-Integration-Architect-I Exam Training materials. With it, you have done fully prepared to meet this exam.
100% Pass Quiz Salesforce - MuleSoft-Integration-Architect-I - Useful Salesforce Certified MuleSoft Integration Architect I Practice GuideTry to have a positive mindset, keep your mind focused on what you have to do. Self- discipline is important if you want to become successful. Learn to reject temptations. As old saying goes, no pains no gains. Learning our MuleSoft-Integration-Architect-I study materials will help you calm down. What you have learned will finally pay off. It is never too late to learn. You still have the chance to obtain the MuleSoft-Integration-Architect-I certificate. What is more, many people have harvest happiness and success after passing the MuleSoft-Integration-Architect-I exam. Then you are available for various high salary jobs.
Salesforce Certified MuleSoft Integration Architect I Sample Questions (Q27-Q32):NEW QUESTION # 27
A Mule application is synchronizing customer data between two different database systems.
What is the main benefit of using XA transaction over local transactions to synchronize these two database system?
- A. Simplifies communincation
- B. Ensure consistency
- C. Reduce latency
- D. Increase throughput
* XA transaction add tremendous latency so "Reduce Latency" is incorrect option XA transactions define "All or No" commit protocol.
* Each local XA resource manager supports the A.C.I.D properties (Atomicity, Consistency, Isolation, and Durability).
--------------------------------------------------------------------------------------------------------------------- So correct choice is "Ensure consistency"
NEW QUESTION # 28
How should the developer update the logging configuration in order to enable this package specific debugging?
- A. In the Mule application's log4j2.xml file, add an AsyncLogger element with name property set to org.apache.cxf and level set to DEBUG, then redeploy the Mule application in the CloudHub production environment
- B. In the Mule application's log4j2.xmI file, change the root logger's level property to DEBUG, then redeploy the Mule application to the CloudHub production environment
- C. In Anypoint Runtime Manager, in the Deployed Application Properties tab for the Mule application, add a line item with DEBUG level for package org.apache.cxf and apply the changes
- D. In Anypoint Monitoring, define a logging search query with class property set to org.apache.cxf and level set to DEBUG
NEW QUESTION # 29
A Mule application is built to support a local transaction for a series of operations on a single database. The mule application has a Scatter-Gather scope that participates in the local transaction.
What is the behavior of the Scatter-Gather when running within this local transaction?
- A. Execution of all routes within Scatter-Gather occurs sequentially Any error that occurs inside Scatter-Gather will be handled by error handler and will not result in roll back
- B. Execution of all routes within Scatter-Gather occurs in parallel Any error that occurs inside Scatter-Gather will result in a roll back of all the database operations
- C. Execution of all routes within Scatter-Gather occurs in parallel Any error that occurs inside Scatter-Gather will be handled by error handler and will not result in roll back
- D. Execution of all routes within Scatter-Gather occurs sequentially Any error that occurs inside Scatter-Gather will result in a roll back of all the database operations
NEW QUESTION # 30
Mule applications need to be deployed to CloudHub so they can access on-premises database systems. These systems store sensitive and hence tightly protected data, so are not accessible over the internet.
What network architecture supports this requirement?
- A. An Anypoint VPC with one Dedicated Load Balancer fronting each on-premises database system, plus matching IP whitelisting in the load balancer and firewall rules in the VPC and on-premises network
- B. Static IP addresses for the Mule applications deployed to the CloudHub Shared Worker Cloud, plus matching firewall rules and IP whitelisting in the on-premises network
- C. Relocation of the database systems to a DMZ in the on-premises network, with Mule applications deployed to the CloudHub Shared Worker Cloud connecting only to the DMZ
- D. An Anypoint VPC connected to the on-premises network using an IPsec tunnel or AWS DirectConnect, plus matching firewall rules in the VPC and on-premises network
* "Relocation of the database systems to a DMZ in the on-premises network, with Mule applications deployed to the CloudHub Shared Worker Cloud connecting only to the DMZ" is not a feasible option
* "Static IP addresses for the Mule applications deployed to the CloudHub Shared Worker Cloud, plus matching firewall rules and IP whitelisting in the on-premises network" - It is risk for sensitive data. - Even if you whitelist the database IP on your app, your app wont be able to connect to the database so this is also not a feasible option
* "An Anypoint VPC with one Dedicated Load Balancer fronting each on-premises database system, plus matching IP whitelisting in the load balancer and firewall rules in the VPC and on-premises network" Adding one VPC with a DLB for each backend system also makes no sense, is way too much work. Why would you add a LB for one system.
* Correct answer: "An Anypoint VPC connected to the on-premises network using an IPsec tunnel or AWS DirectConnect, plus matching firewall rules in the VPC and on-premises network" IPsec Tunnel You can use an IPsec tunnel with network-to-network configuration to connect your on-premises data centers to your Anypoint VPC. An IPsec VPN tunnel is generally the recommended solution for VPC to on-premises connectivity, as it provides a standardized, secure way to connect. This method also integrates well with existing IT infrastructure such as routers and appliances. Reference: https://docs.mulesoft.com/runtim ... ity-methods-concept
NEW QUESTION # 31
What comparison is true about a CloudHub Dedicated Load Balancer (DLB) vs. the CloudHub Shared Load Balancer (SLB)?
- A. Both a DLB and the SLB implement load balancing by sending HTTP requests to workers with the lowest workloads
- B. Only the SLB can forward HTTP traffic to the VPC-internal ports of the CloudHub workers
- C. Only a DLB allows the configuration of a custom TLS server certificate
- D. Both a DLB and the SLB allow the configuration of access control via IP whitelists
* Shared load balancers don't allow you to configure custom SSL certificates or proxy rules
* Dedicated Load Balancer are optional but you need to purchase them additionally if needed.
* TLS is a cryptographic protocol that provides communications security for your Mule app. TLS offers many different ways of exchanging keys for authentication, encrypting data, and guaranteeing message integrity.
* The CloudHub Shared Load Balancer terminates TLS connections and uses its own server-side certificate.
* Only a DLB allows the configuration of a custom TLS server certificate
* DLB enables you to define SSL configurations to provide custom certificates and optionally enforce two- way SSL client authentication.
* To use a DLB in your environment, you must first create an Anypoint VPC. Because you can associate multiple environments with the same Anypoint VPC, you can use the same dedicated load balancer for your different environments.
* MuleSoft Reference: https://docs.mulesoft.com/runtim ... d-balancer-tutorial Additional Info on SLB Vs DLB:
Table Description automatically generated
NEW QUESTION # 32
The MuleSoft-Integration-Architect-I exam real questions are the ideal and recommended study material for quick and complete Salesforce MuleSoft-Integration-Architect-I exam preparation. As a MuleSoft-Integration-Architect-I Exam candidate you should not ignore the MuleSoft-Integration-Architect-I exam questions and must add the Salesforce MuleSoft-Integration-Architect-I exam questions in preparation.
Online MuleSoft-Integration-Architect-I Training: https://www.pass4test.com/MuleSoft-Integration-Architect-I.html
100% pass by our MuleSoft-Integration-Architect-I training pdf is our guarantee, Salesforce MuleSoft-Integration-Architect-I Practice Guide For candidates who want to enter a better company through getting the certificate, passing the exam becomes important, The contents of MuleSoft-Integration-Architect-I exam materials are carefully selected by experts, Online MuleSoft-Integration-Architect-I Training - Salesforce Certified MuleSoft Integration Architect I certification can help the candidate get a foot in the door, even without copious amounts of hands-on experience, Our MuleSoft-Integration-Architect-I exam training materials is the result of our experienced experts with constant exploration, practice and research for many years.
Creating effective workflows for Scrum and other Agile projects, Javier Barrera is a senior lead engineer, architect, and administrator at a large company, 100% pass by our MuleSoft-Integration-Architect-I Training Pdf is our guarantee.
Prepare Your Salesforce MuleSoft-Integration-Architect-I Exam with Real Salesforce MuleSoft-Integration-Architect-I Practice Guide EasilyFor candidates who want to enter a better company through getting the certificate, passing the exam becomes important, The contents of MuleSoft-Integration-Architect-I exam materials are carefully selected by experts.
Salesforce Certified MuleSoft Integration Architect I certification can help the candidate Exam MuleSoft-Integration-Architect-I Tutorials get a foot in the door, even without copious amounts of hands-on experience, Our MuleSoft-Integration-Architect-I exam training materials is the result of MuleSoft-Integration-Architect-I our experienced experts with constant exploration, practice and research for many years.
- MuleSoft-Integration-Architect-I Exam Sims 📦 MuleSoft-Integration-Architect-I Test Testking 🐫 MuleSoft-Integration-Architect-I Test Voucher 🐩 Search for { MuleSoft-Integration-Architect-I } on ▶ [url]www.examcollectionpass.com ◀ immediately to obtain a free download 🥯MuleSoft-Integration-Architect-I Test Testking[/url]
- Quiz Salesforce - MuleSoft-Integration-Architect-I - Salesforce Certified MuleSoft Integration Architect I Accurate Practice Guide 🦚 Enter ▷ [url]www.pdfvce.com ◁ and search for ➽ MuleSoft-Integration-Architect-I 🢪 to download for free 🕗Reliable MuleSoft-Integration-Architect-I Exam Test[/url]
- MuleSoft-Integration-Architect-I Exam Questions 📮 Reliable MuleSoft-Integration-Architect-I Exam Test 👈 MuleSoft-Integration-Architect-I Reliable Exam Answers 😽 Open website ➡ [url]www.validtorrent.com ️⬅️ and search for MuleSoft-Integration-Architect-I for free download 🚇MuleSoft-Integration-Architect-I Reliable Exam Answers[/url]
- MuleSoft-Integration-Architect-I Reliable Exam Answers 🎸 Latest MuleSoft-Integration-Architect-I Braindumps Pdf 🧳 MuleSoft-Integration-Architect-I Reliable Source 🥨 Search for ▛ MuleSoft-Integration-Architect-I ▟ and download exam materials for free through ➡ [url]www.pdfvce.com ️⬅️ 🤤Downloadable MuleSoft-Integration-Architect-I PDF[/url]
- New MuleSoft-Integration-Architect-I Exam Name 🛤 MuleSoft-Integration-Architect-I Exam Questions 🔲 Reliable MuleSoft-Integration-Architect-I Exam Test 😡 Easily obtain free download of ➽ MuleSoft-Integration-Architect-I 🢪 by searching on [ [url]www.prepawayete.com ] 🥇MuleSoft-Integration-Architect-I Test Testking[/url]
- New MuleSoft-Integration-Architect-I Exam Name 🥊 MuleSoft-Integration-Architect-I Test Engine 🎭 MuleSoft-Integration-Architect-I Test Voucher 🌐 Open { [url]www.pdfvce.com } and search for ▶ MuleSoft-Integration-Architect-I ◀ to download exam materials for free 📷Valid MuleSoft-Integration-Architect-I Exam Forum[/url]
- MuleSoft-Integration-Architect-I C 100% Free Practice Guide | Reliable Online Salesforce Certified MuleSoft Integration Architect I Training 💆 Open [url]www.examdiscuss.com enter MuleSoft-Integration-Architect-I and obtain a free download 🏭MuleSoft-Integration-Architect-I Test Voucher[/url]
- MuleSoft-Integration-Architect-I Test Engine 🧢 MuleSoft-Integration-Architect-I Reliable Exam Answers ☸ Reliable MuleSoft-Integration-Architect-I Exam Test 🎯 Easily obtain ▛ MuleSoft-Integration-Architect-I ▟ for free download through ➠ [url]www.pdfvce.com 🠰 🥥MuleSoft-Integration-Architect-I Guaranteed Success[/url]
- Reliable MuleSoft-Integration-Architect-I Exam Test 🥁 MuleSoft-Integration-Architect-I Exam Questions 🐭 New MuleSoft-Integration-Architect-I Test Discount 🆎 Search for ➽ MuleSoft-Integration-Architect-I 🢪 and download it for free immediately on ➡ [url]www.practicevce.com ️⬅️ 😭Latest MuleSoft-Integration-Architect-I Braindumps Pdf[/url]
- MuleSoft-Integration-Architect-I C 100% Free Practice Guide | Reliable Online Salesforce Certified MuleSoft Integration Architect I Training 🤪 Copy URL ⮆ [url]www.pdfvce.com ⮄ open and search for ▶ MuleSoft-Integration-Architect-I ◀ to download for free 🏳Reliable MuleSoft-Integration-Architect-I Exam Test[/url]
- Valid MuleSoft-Integration-Architect-I Exam Forum ◀ New MuleSoft-Integration-Architect-I Test Discount 🏓 New MuleSoft-Integration-Architect-I Exam Name 🚅 ⮆ [url]www.examcollectionpass.com ⮄ is best website to obtain MuleSoft-Integration-Architect-I for free download 📽Latest MuleSoft-Integration-Architect-I Braindumps Pdf[/url]
- www.stes.tyc.edu.tw, 40bbk.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, mpgimer.edu.in, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, lms.ait.edu.za, Disposable vapes
P.S. Free 2026 Salesforce MuleSoft-Integration-Architect-I dumps are available on Google Drive shared by Pass4Test: https://drive.google.com/open?id=12b1tLA3cBlabM5nt4mcSo_7bl8542fLq
