[General] Latest JN0-683 Test Materials & JN0-683 Valid Test Preparation
54
General Latest JN0-683 Test Materials & JN0-683 Valid Test Preparation
Posted at 1/18/2026 09:09:15      View183 | Replies1        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Lead1Pass JN0-683 dumps from Cloud Storage: https://drive.google.com/open?id=1MjmqX11C1jQn3bXi7_MCmws5UB9w1Rio
Now we can say that Data Center, Professional (JNCIP-DC) (JN0-683) exam questions are real and top-notch JN0-683 exam questions that you can expect in the upcoming Data Center, Professional (JNCIP-DC) (JN0-683) exam. In this way, you can easily pass the JN0-683 exam with good scores. The countless JN0-683 Exam candidates have passed their dream Juniper JN0-683 certification exam and they all got help from real, valid, and updated JN0-683 practice questions, You can also trust on Lead1Pass and start preparation with confidence.
If you want to know the latest information for the exam timely, you can choose us, we can do that for you. We offer you free update for one year for JN0-683 learning materials, so that you can obtain the latest information for the exam. Our system will send you the latest version automatically, and you just need to examine your email for the latest version. In addition, JN0-683 Exam Materials are high-quality, and you can improve your efficiency by using them. We have online and offline service, and if you have any questions for JN0-683 exam braindumps, you can contact us, and we will give you reply as quickly as we can.
Latest JN0-683 Test Materials - The Best Juniper Data Center, Professional (JNCIP-DC) - JN0-683 Valid Test PreparationYou shall prepare yourself for the Data Center, Professional (JNCIP-DC) (JN0-683) exam, take the Data Center, Professional (JNCIP-DC) (JN0-683) practice exams well, and then attempt the final JN0-683 test. So, start your journey by today, get the Lead1Pass Data Center, Professional (JNCIP-DC) (JN0-683) study material, and study well. No one can keep you from rising as a star in the sky.
Juniper JN0-683 Exam Syllabus Topics:
  • Data Center Interconnect: For Data Center Engineers, this part focuses on interconnecting data centers, covering Layer 2 and Layer 3 stretching, stitching fabrics together, and using EVPN-signaled VXLAN for seamless communication between data centers.
  • Data Center Deployment and Management: This section assesses the expertise of data center networking professionals like architects and engineers, focusing on key deployment concepts. Topics include Zero-touch provisioning (ZTP), which automates device setup in data centers without manual input.
  • Data Center Multitenancy and Security: This section tests knowledge of single-tenant and multitenant data center setups. Candidates such as Data Center Professionals are evaluated on ensuring tenant traffic isolation at both Layer 2 and Layer 3 levels in shared infrastructure environments.
  • Layer 3 Fabrics: This section measures the knowledge of professionals managing IP-based networks in data centers. It covers IP fabric architecture and routing, ensuring candidates understand how the network is structured for scalability and how traffic is routed efficiently.
Topic 5
  • EVPN-VXLAN Signaling: This section assesses an understanding of Ethernet VPN (EVPN) concepts, including route types, multicast handling, and Multiprotocol BGP (MBGP). It also covers EVPN architectures like CRB and ERB, MAC learning, and symmetric routing.
Juniper Data Center, Professional (JNCIP-DC) Sample Questions (Q64-Q69):NEW QUESTION # 64
You are selling up an EVPN-VXLAN architecture (or your new data center. thisinitial deployment will be less than 50 switches: however, it could scale up to 250 switches over time supporting 1024 VLANs. You are still deciding whether to use symmetric or asymmetric routing.
In this scenario, which two statements are correct? (Choose two.)
  • A. Symmetric routing supports higher scaling numbers.
  • B. Asymmetric routing is easier lo monitor because of the transit VNI.
  • C. Asymmetric routing routes traffic on the egress switch.
  • D. Symmetric routing needs an extra VLAN with an IRB interface for each L3 VRF instance.
* Symmetric vs. Asymmetric Routing in EVPN-VXLAN:
* Symmetric Routing:Traffic enters and exits the VXLAN network through the same VTEP, regardless of the source or destination. This approach simplifies routing decisions, especially in large networks, and is generally more scalable.
* Asymmetric Routing:The routing occurs on the egress VTEP. This method can be simpler to deploy in smaller environments but becomes complex as the network scales, particularly with larger numbers of VNIs and VLANs.
* Correct Statements:
* C. Symmetric routing supports higher scaling numbers:Symmetric routing is preferred in larger EVPN-VXLAN deployments because it centralizes routing decisions, which can be more easily managed and scaled.
* D. Asymmetric routing routes traffic on the egress switch:This is accurate, as asymmetric routing means the routing decision is made at the final hop, i.e., the egress VTEP before the traffic reaches its destination.
* Incorrect Statements:
* A. Symmetric routing needs an extra VLAN with an IRB interface for each L3 VRF instance:This is not accurate. Symmetric routing does not require an extra VLAN per VRF; rather, it uses the same VLAN/VNI across the network, simplifying routing and VLAN management.
* B. Asymmetric routing is easier to monitor because of the transit VNI:Asymmetric routing is not necessarily easier to monitor; in fact, it can add complexity due to the split routing logic between ingress and egress points.
Data Center References:
* The choice between symmetric and asymmetric routing in an EVPN-VXLAN environment depends on network size, complexity, and specific operational requirements. Symmetric routing is generally more scalable and easier to manage in large-scale deployments.
NEW QUESTION # 65
Which two statements are true about IP fabrics using unnumbered BGP? (Choose two.)
  • A. Unnumbered BGP requires that family inet is configured on each interface.
  • B. Unnumbered BGP peering automatically provisions IPv6 peering.
  • C. Unnumbered BGP peering automatically provisions IPv4 peering.
  • D. Unnumbered BGP requires that family inet6 is configured on each interface.
https://www.juniper.net/document ... numbered/index.html
NEW QUESTION # 66
You are asked to configure telemetry on the OFX Series devices in your data center fabric. You want to use sensors that have a vendor-neutral data model Which type of sensor should you use in this scenario?
  • A. JTI OpenConfig sensors
  • B. JTI native sensors
  • C. Python sensors
  • D. analog sensors
* Telemetry in Data Centers:
* Telemetry allows for real-time monitoring of network devices by collecting and exporting data such as interface statistics, routing table updates, and other key metrics.
* Vendor-Neutral Data Models:
* Option A:JTI (Junos Telemetry Interface) OpenConfig sensors use a vendor-neutral data model, which is important for ensuring compatibility across different network devices and systems.
OpenConfig is an industry-standard model, which facilitates integration with various telemetry collection systems.
Conclusion:
* Option A:Correct-OpenConfig sensors provide a vendor-neutral solution for telemetry, ensuring broad compatibility and flexibility in data center environments.
NEW QUESTION # 67
Click the Exhibit button.
Referring to the configuration shown in the exhibit, assume that there is no external router present and that the configuration is fabric-only.
Which two statements are true about the example configuration? (Choose two.)
  • A. Devices in irb.400 (vlan 400) and irb.800 (vlan 800) are able to communicate over the fabric.
  • B. Devices in routing instance Customer A are able to communicate with devices in routing instance Customer B.
  • C. Devices in irb.400 (vlan 400) are not able to communicate directly with devices in routing instance Customer A.
  • D. VNI 10006 is assigned to vlan 800 (irb.800).
The exhibit shows configurations for two VRFs (Customer_A and Customer_B) with specific VLANs and VNIs assigned. Each VRF has interfaces (IRBs) associated with particular VLANs.
Option B: VLAN 400 (irb.400) is part of Customer_B, and there is no direct connection or routing between Customer_A and Customer_B in the configuration provided. Therefore, devices in irb.400 cannot communicate directly with devices in the Customer_A routing instance.
Option D: Since irb.400 (VLAN 400) and irb.800 (VLAN 800) are part of the same routing instance (Customer_B), they can communicate over the fabric using VXLAN encapsulation.
NEW QUESTION # 68
A local VTEP has two ECMP paths to a remote VTEP
Which two statements are correctwhen load balancing is enabled in this scenario? (Choose two.)
  • A. The destination port in the UDP header is used to load balance VXLAN traffic.
  • B. The inner packet fields are used in the hash for load balancing.
  • C. The source port in the UDP header is used to load balance VXLAN traffic.
  • D. The inner packet fields are not used in the hash for load balancing.
* Load Balancing in VXLAN:
* VXLAN uses UDP encapsulation to transport Layer 2 frames over an IP network. For load balancing across Equal-Cost Multi-Path (ECMP) links, various fields in the packet can be used to ensure even distribution of traffic.
* Key Load Balancing Fields:
* C. The source port in the UDP header is used to load balance VXLAN traffic:This is correct.
The source UDP port in the VXLAN packet is typically calculated based on a hash of the inner packet's fields. This makes the source port vary between packets, enabling effective load balancing across multiple paths.
* D. The inner packet fields are used in the hash for load balancing:This is also correct. Fields such as the source and destination IP addresses, source and destination MACaddresses, and possibly even higher-layer protocol information from the inner packet can be used to generate the hash that determines the ECMP path.
* A. The inner packet fields are not used in the hash for load balancing:This is incorrect as the inner packet fields are indeed critical for generating the hash used in load balancing.
* B. The destination port in the UDP header is used to load balance VXLAN traffic:This is incorrect because the destination UDP port in VXLAN packets is typically fixed (e.g., port 4789 for VXLAN), and therefore cannot be used for effective load balancing.
* Effective load balancing in VXLAN is crucial for ensuring high throughput and avoiding congestion on specific links. By using a combination of the source UDP port and inner packet fields, the network can distribute traffic evenly across available paths.
NEW QUESTION # 69
With this software, you can evaluate your Juniper JN0-683 exam preparation.The beforehand awareness of your weaknesses will help you take the Juniper certification exam successfully. Environment you encounter during the practice test is similar to the real Juniper JN0-683 Exam. This feature of software will help you kill Juniper JN0-683 Exam anxiety.
JN0-683 Valid Test Preparation: https://www.lead1pass.com/Juniper/JN0-683-practice-exam-dumps.html
P.S. Free & New JN0-683 dumps are available on Google Drive shared by Lead1Pass: https://drive.google.com/open?id=1MjmqX11C1jQn3bXi7_MCmws5UB9w1Rio
Posted at 2/14/2026 17:45:05        Only Author  2#
I felt deeply enriched by that article. The Plat-Arch-204 Cert Exam content is of great value, and it's completely free.
