[General] Identity-and-Access-Management-Architect Actualtest, Reliable Identity-and-Acces
110
【General】 Identity-and-Access-Management-Architect Actualtest, Reliable Identity-and-Acces
Posted at 1/18/2026 11:17:42      View:158 | Replies:1        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Salesforce Identity-and-Access-Management-Architect dumps are available on Google Drive shared by VCEPrep: https://drive.google.com/open?id=1y3msQK6lFTUfr98V9gY275Ni9Nx6pFV-
It is proved that if you study with our Identity-and-Access-Management-Architect exam questions for 20 to 30 hours, then you will be able to pass the Identity-and-Access-Management-Architect exam with confidence. Because users only need to spend little hours on the Identity-and-Access-Management-Architect quiz guide, our learning materials will help users to learn all the difficulties of the test site, to help users pass the qualifying examination and obtain the qualification certificate. If you think that time is important to you, try our Identity-and-Access-Management-Architect Learning Materials and it will save you a lot of time.
Salesforce Identity-and-Access-Management-Architect (Salesforce Certified Identity and Access Management Architect) Exam is a certification program designed for IT professionals who are responsible for managing and securing access to Salesforce applications. Identity-and-Access-Management-Architect exam covers a wide range of topics related to identity and access management, such as authentication, authorization, and user management. It is designed to validate the skills and knowledge of architects who can design and implement complex identity and access management solutions for Salesforce.
Salesforce Identity-and-Access-Management-Architect Certification Exam is designed to test the skills and knowledge of professionals who specialize in managing identity and access to Salesforce applications. Salesforce Certified Identity and Access Management Architect certification is ideal for individuals who have experience in designing, implementing, and maintaining complex Salesforce systems that require robust identity and access management solutions.
Reliable Salesforce Identity-and-Access-Management-Architect Test Camp & Identity-and-Access-Management-Architect 100% Correct Answerswhen you buy our Identity-and-Access-Management-Architect simulating exam, our website will use professional technology to encrypt the privacy of every user to prevent hackers from stealing. We believe that business can last only if we fully consider it for our customers, so we will never do anything that will damage our reputation. Hope you can give our Identity-and-Access-Management-Architect Exam Questions full trust, we will not disappoint you. And with our Identity-and-Access-Management-Architect study materials, you are bound to pass the exam.
Salesforce Certified Identity and Access Management Architect Sample Questions (Q30-Q35):NEW QUESTION # 30
Universal Containers (UC) is setting up delegated authentication to allow employees to log in using their corporate credentials. UC's security team is concerned about the risks of exposing the corporate login service on the internet and has asked that a reliable trust mechanism be put in place between the login service and Salesforce.
What mechanism should an Architect put in place to enable a trusted connection between the login service and Salesforce?
  • A. Include Client Id and Client Secret in the login header callout.
  • B. Require the use of Salesforce security tokens on passwords.
  • C. Set up a proxy service for the login service in the DMZ.
  • D. Enforce mutual authentication between systems using SSL.
NEW QUESTION # 31
A multinational company is looking to rollout Salesforce globally. The company has a Microsoft Active Directory Federation Services (ADFS) implementation for the Americas, Europe and APAC. The company plans to have a single org and they would like to have all of its users access Salesforce using the ADFS . The company would like to limit its investments and prefer not to procure additional applications to satisfy the requirements.
What is recommended to ensure these requirements are met ?
  • A. Configure Each ADFS system under single sign-on settings and allow users to choose the system to authenticate during sign on to Salesforce-
  • B. Implement Identity Connect to provide single sign-on to Salesforce and federated across multiple ADFS systems.
  • C. Use connected apps for each ADFS implementation and implement Salesforce site to authenticate users across the ADFS system applicable to their geo.
  • D. Add a central identity system that federates between the ADFS systems and integrate with Salesforce for single sign-on.
To have all of its user's access Salesforce using the ADFS, the multinational company should implement Identity Connect to provide single sign-on to Salesforce and federate across multiple ADFS systems. Identity Connect is a tool that synchronizes user data between Microsoft Active Directory and Salesforce. It allows single sign-on and federation between multiple Active Directory domains and a single Salesforce org. Identity Connect can also handle user provisioning and deprovisioning based on the changes made in Active Directory.
The other options are not recommended for this scenario, as they either require additional applications, do not support federation, or do not provide a seamless user experience. References: Identity Connect Implementation Guide, Identity Connect Overview
NEW QUESTION # 32
A company's external applicationis protected by Salesforce through OAuth. The identity architect for the project needs to limit the level of access to the data of the protected resource in a flexible way.
What should be done to improve security?
  • A. Select "Admin approved users arepre-authorized" and assign specific profiles.
  • B. Create custom scopes and assign to the connected app.
  • C. Define a permission set that grants access to the app and assign to authorized users.
  • D. Leverage external objects and data classification policies.
To limit the level of access to the data of the protected resource in a flexible way, the identity architect should create custom scopes and assign them to the connected app. Custom scopes are permissions that define the specific data that an external application can access or modify in Salesforce. Custom scopes can be created using Apex or Metadata API and assigned to a connected app using OAuth 2.0 or SAML protocols. Custom scopes can provide more granular control over data access than standard scopes, which are predefined by Salesforce. References: Custom Scopes, Create and Assign Custom Scopes
NEW QUESTION # 33
Northern Trail Outfitters (NTO) wants to improve its engagement with existing customers to boost customer loyalty. To get a better understanding of its customers, NTO establishes a single customer view including their buying behaviors, channel preferences and purchasing history. All of this information exists but is spread across different systems and formats.
NTO has decided to use Salesforce as the platform to build a 360 degree view. The company already uses Microsoft Active Directory (AD) to manage its users and company assets.
What should an Identity Architect do to provision, deprovision and authenticate users?
  • A. Salesforce Identity can be included but NTO will be required to build a custom integration with Microsoft AD.
  • B. Salesforce Identity is not needed since NTO uses Microsoft AD.
  • C. Salesforce Identity is included in the Salesforce licenses so it does not need to be considered separately.
  • D. A Salesforce Identity can be included but NTO will require Identity Connect.
NEW QUESTION # 34
Universal Containers (UC) wants to build a mobile application that twill be making calls to the Salesforce REST API. UC's Salesforce implementation relies heavily on custom objects and custom Apex code. UC does not want its users to have to enter credentials every time they use the app. Which two scope values should an Architect recommend to UC? Choose 2 answers.
  • A. Refresh_token
  • B. Custom_permissions
  • C. Api
  • D. Full
The two scope values that an architect should recommend to UC are api and refresh_token. The api scope allows the app to access the Salesforce REST API and use custom objects and custom Apex code. The refresh_token scope allows the app to obtain a refresh token that can be used to get new access tokens without requiring the user to re-enter credentials. Option A is not a good choice because the custom_permissions scope allows the app to access custom permissions in Salesforce, but it does not affect how the app can access the REST API or avoid user re-authentication. Option D is not a good choice because the full scope allows the app to access all data accessible by the user, including the web UI and the API, but it may be unnecessary or insecure for UC's requirement. References: OAuth 2.0 Web Server Authentication Flow, Digging Deeper into OAuth 2.0 on Force.com
NEW QUESTION # 35
Nowadays passing the Identity-and-Access-Management-Architect test certification is extremely significant for you and can bring a lot of benefits to you. Passing the Identity-and-Access-Management-Architect test certification does not only prove that you are competent in some area but also can help you enter in the big company and double your wage. And our Identity-and-Access-Management-Architect Exam Questions are in good quality. As long as you study with our Identity-and-Access-Management-Architect learning guide, you will find that the content is easily to understand and the displays are enjoyable.
Reliable Identity-and-Access-Management-Architect Test Camp: https://www.vceprep.com/Identity-and-Access-Management-Architect-latest-vce-prep.html
DOWNLOAD the newest VCEPrep Identity-and-Access-Management-Architect PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1y3msQK6lFTUfr98V9gY275Ni9Nx6pFV-
Posted at 2/14/2026 03:35:33        Only Author  2#
This article is amazing, thank you for sharing it with us! The free content in Dumps OGBA-101 Torrent is meant to help guide you through your studies.
