Actual Oracle 1z0-1104-25 Exam Questions in PDF
94
Posted at 1/18/2026 11:37:14      View:104 | Replies:2        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of ValidVCE 1z0-1104-25 dumps from Cloud Storage: https://drive.google.com/open?id=1Mfo8RSXfeB1gTB0RiT7ZTil4LqxX0TzI
1z0-1104-25 study engine is very attentive to provide a demo for all customers who concerned about our products, whose purpose is to allow customers to understand our product content before purchase. Many students suspect that if 1z0-1104-25 learning material is really so magical? Does it really take only 20-30 hours to pass such a difficult certification exam successfully? It is no exaggeration to say that you will be able to successfully pass the exam with our 1z0-1104-25 Exam Questions.
Now, our 1z0-1104-25 learning prep can meet your demands. You will absorb the most useful knowledge with the assistance of our study materials. The 1z0-1104-25 certificate is valuable in the job market. But you need professional guidance to pass the exam. For instance, our 1z0-1104-25 exam questions fully accords with your requirements. Professional guidance is indispensable for a candidate. As a leader in the field, our 1z0-1104-25 learning prep has owned more than ten years’ development experience. Thousands of candidates have become excellent talents after obtaining the 1z0-1104-25 certificate. If you want to survive in the exam, our 1z0-1104-25 actual test guide is the best selection. Firstly, our study materials can aid you study, review and improvement of all the knowledge.
Exam Sample Oracle 1z0-1104-25 Questions, 1z0-1104-25 Reliable Braindumps EbookOur 1z0-1104-25 learning materials provide multiple functions and considerate services to help the learners have no inconveniences to use our product. We guarantee to the clients if only they buy our 1z0-1104-25 study materials and learn patiently for some time they will be sure to pass the 1z0-1104-25 test with few failure odds. The price of our product is among the range which you can afford and after you use our study materials you will certainly feel that the value of the product far exceed the amount of the money you pay. Choosing our 1z0-1104-25 Study Guide equals choosing the success and the perfect service.
Oracle Cloud Infrastructure 2025 Security Professional Sample Questions (Q12-Q17):NEW QUESTION # 12
Challenge 2 -Task 1
In deploying a new application, a cloud customer needs to reflect different security postures. If a security zone is enabled with the Maximum Security Zone recipe, the customer will be unable to create or update a resource in the security zone if the action violates the attached Maximum Security Zone policy.
As an application requirement, the customer requires a compute instance in the public subnet. You therefore, need to configure Custom Security Zones that allow the creation of compute instances in the public subnet.
Review the architecture diagram, which outlines the resoures you'll need to address the requirement:
Preconfigured
To complete this requirement, you are provided with the following:
Access to an OCI tenancy, an assigned compartment, and OCI credentials
Required IAM policies
Task3: Create and configure a Virtual Cloud Network and Private Subnet
Createand configure virtual cloud Network (VCN) named IAD SP-PBT-VCN-01, with an internet Gateway and configure appropriate route rules to allow external connectivity.
Enter the OCID of the created VCN in the text box below.
See the solution below in Explanation.
To create and configure a Virtual Cloud Network (VCN) named IAD-SP-PBT-VCN-01 with an Internet Gateway and appropriate route rules for external connectivity, follow these steps based on the Oracle Cloud Infrastructure (OCI) Networking documentation.
Step-by-Step Solution for Task 3: Create and Configure a VCN and Private Subnet
* Log in to the OCI Console:
* Use your OCI credentials to log in to the OCI Console (https://console.us-ashburn-1.oraclecloud.
com).
* Ensure you have access to the assigned compartment.
* Navigate to Virtual Cloud Networks:
* From the OCI Console, click the navigation menu (hamburger icon) on the top left.
* UnderNetworking, selectVirtual Cloud Networks.
* Create a New VCN:
* ClickStart VCN Wizardand selectCreate VCN with Internet Connectivity.
* VCN Name:Enter IAD-SP-PBT-VCN-01.
* Compartment:Select the assigned compartment.
* VCN CIDR Block:Enter 10.0.0.0/16 (matches the diagram's VCN CIDR).
* Public Subnet CIDR Block:Enter 10.0.10.0/24 (matches the diagram's public subnet).
* Accept the default settingsfor the public subnet and Internet Gateway creation.
* ClickCreateto provision the VCN, Internet Gateway, and public subnet.
* Verify the Internet Gateway:
* After creation, go to the VCN details page for IAD-SP-PBT-VCN-01.
* UnderResources, selectInternet Gateways.
* Ensure the Internet Gateway is attached and enabled.
* Configure Route Rules:
* In the VCN details page, underResources, selectRoute Tables.
* Select the default route table associated with the public subnet (10.0.10.0/24).
* ClickAdd Route Rules.
* Target Type:SelectInternet Gateway.
* Destination CIDR Block:Enter 0.0.0.0/0.
* Target Internet Gateway:Select the Internet Gateway created with the VCN.
* ClickAdd Route Ruleto save.
* Update Security List (if needed):
* UnderResources, selectSecurity Lists.
* Edit the default security list for the public subnet.
* Add an ingress rule:
* Source CIDR:0.0.0.0/0
* IP Protocol:TCP
* Source Port Range:All
* Destination Port Range:22 (for SSH) or as required by your application.
* Add an egress rule:
* Destination CIDR:0.0.0.0/0
* IP Protocol:All
* Save the changes.
* Note the VCN OCID:
* Return to the VCN details page for IAD-SP-PBT-VCN-01.
* Copy theOCIDdisplayed (e.g., ocid1.vcn.oc1..<unique_string>).
OCID of the Created VCN
* Enter the OCID of the created VCN (IAD-SP-PBT-VCN-01) into the text box. The exact OCID will be available after Step 3 (e.g., ocid1.vcn.oc1..<unique_string>).
NEW QUESTION # 13
According to the Oracle Cloud Infrastructure (OCI) Shared Responsibility Model, which statement accurately reflects OCI's responsibility for security?
  • A. OCI is responsible for securing the underlying infrastructure but not customer data.
  • B. Customers are responsible for securing both infrastructure and data.
  • C. OCI has no security responsibilities; customers need to secure their resources.
  • D. OCI provides security only for free-tier services; customers secure everything else.
NEW QUESTION # 14
Task 2: Create a Compute Instance and Install the Web Server
Create a compute instance, where:
Image: Oracle Linux 8
Shape: VM.Standard.A1.Flex
Subnet: Compute-Subnet-PBT-CERT
Install and configure Apache web server:
a.
Install Apache
sudo yum -y install httpd
b.
Enable and start Apache
sudo systemctl enable httpd
sudo systemctl restart httpd
2. Install and configure Apache web server:
a. Install Apache
b. Enable and start Apache
c. Configure firewall to allow HTTP traffic (port 80)
sudo firewall-cmd --permanent --add-port=80/tcp
sudo firewall-cmd --reload
d. Create an index.html file
sudo bash -c 'echo You are visiting Web Server 1 >> /var/www/html/index.html' Enter the OCID of the created compute instance PBT-CERT-VM-01 in the text box below.
Step 1: Create the Compute Instance
* Log in to the OCI Console.
* Navigate toCompute>Instances.
* ClickCreate Instance.
* Enter the following details:
* Name: PBT-CERT-VM-01
* Compartment: Select your assigned compartment.
* Placement: Leave as default or select an availability domain (e.g., Availability Domain 1).
* Image: ClickChange Image, selectOracle Linux 8, and confirm.
* Shape: ClickChange Shape, selectVM.Standard.A1.Flex, and configure:
* OCPUs: 1 (or adjust as needed)
* Memory: 6 GB (or adjust as needed)
* Networking:
* Virtual Cloud Network: Select PBT-CERT-VCN-01.
* Subnet: Select Compute-Subnet-PBT-CERT.
* Leave public IP assignment enabled for internet access.
* SSH Key: Provide your public SSH key (upload or paste) for secure access.
* ClickCreateand wait for the instance to be provisioned.
Step 2: Connect to the Compute Instance
* Once the instance is created, note thePublic IP Addressfrom the instance details page.
* Use an SSH client to connect:
* Command: ssh -i <private-key-file> opc@<public-ip-address>
* Replace <private-key-file> with your private key path and <public-ip-address> with the instance' s public IP.
Step 3: Install and Configure Apache Web Server
* Install Apache:
* Run: sudo yum -y install httpd
* Enable and Start Apache:
* Run: sudo systemctl enable httpd
* Run: sudo systemctl restart httpd
* Configure Firewall to Allow HTTP Traffic (Port 80):
* Run: sudo firewall-cmd --permanent --add-port=80/tcp
* Run: sudo firewall-cmd --reload
* Create an index.html File:
* Run: sudo bash -c 'echo "You are visiting Web Server 1" >> /var/www/html/index.html' Step 4: Verify the Configuration
* Open
a web browser and enter http://
<public-ip-address> to ensure the page displays "You are visiting Web Server 1".
* If needed, troubleshoot by checking Apache status: sudo systemctl status httpd.
Step 5: Retrieve and Enter the OCID
* Go to the instance details page for PBT-CERT-VM-01 underCompute>Instances.
* Copy theOCID(a long string starting with ocid1.instance., unique to your tenancy).
* Enter the copied OCID exactly as it appears into the text box provided.
Notes
* These steps are based on OCI Compute documentation and Oracle Linux 8 setup guides.
* Ensure the security list PBT-CERT-CS-SL-01 allows inbound traffic on port 22 (SSH) and port 80 (HTTP) if not already configured.
* The OCID will be unique to your instance; obtain it from the OCI Console after creation
NEW QUESTION # 15
Task 4: Create a Certificate Authority (CA)
Create a certificate authority, where:
CA name: PBT-CERT-CA-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate authority name should be PBT- CERT-CA-01990086771abuser01 Ensure you eliminate special characters from the user name.
Common name: PBT-CERT-OCICA-01
Master Encryption Key: PBT-CERT-MEK-01 (created in the previous task)
Step 1: Access the OCI Vault
* Navigate toIdentity & Security>Vault.
* Select the root compartment.
* Locate and click on the vault named PBI_Vault_SP.
Step 2: Create the Certificate Authority
* In the PBI_Vault_SP vault details page, underResources, clickCertificate Authorities.
* ClickCreate Certificate Authority.
* Name: Replace <username> with your username (e.g., if your username is 99008677-lab.user01, remove special characters like - and . to get 99008677labuser01, then use PBT-CERT-CA-
0199008677labuser01).
* Common Name: Enter PBT-CERT-OCICA-01.
* Master Encryption Key: Select the PBT-CERT-MEK-01<username> key created in Task 3 (e.
g., PBT-CERT-MEK-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required by your setup.
* Validity Period: Set as needed (e.g., 10 years), or use the default.
* Compartment: Ensure it's set to the root compartment.
* ClickCreate Certificate Authorityand wait for the CA to be provisioned.
Step 3: Verify the Certificate Authority
* After creation, go to theCertificate Authoritiessection under PBI_Vault_SP.
* Confirm the CA PBT-CERT-CA-01<username> (e.g., PBT-CERT-CA-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 16
Task 5: Create a Certificate
Create a certificate, where:
Certificate name: PBT-CERT-01-<username>
For example, if your username is 99008677-lab.user01, then the certificate name should be PBT-CERT-
01990086771abuser01
Common name: PBT-CERT-OCICERT-01
Certificate Authority: PBT-CERT-CA-01 (created in the previous task)
Since I can't create resources or retrieve OCIDs directly in your OCI environment, I'll provide a step-by-step solution based on verified OCI documentation and best practices as of 02:30 PM BST on Thursday, June 12,
2025. Follow these instructions precisely in the OCI Console or CLI, using the preconfigured PBI_Vault_SP vault and the PBT-CERT-CA-01<username> Certificate Authority created in the previous task. Replace
<username> with your actual username (e.g., 99008677-lab.user01), ensuring special characters are removed.
* In the PBI_Vault_SP vault details page, underResources, clickCertificates.
* ClickCreate Certificate.
* Common Name: Enter PBT-CERT-OCICERT-01.
* Certificate Authority: Select the PBT-CERT-CA-01<username> CA created in Task 4 (e.g., PBT-CERT-CA-0199008677labuser01).
* Subject: Leave as default or adjust (e.g., Organization, Country) if required.
* Validity Period: Set as needed (e.g., 1 year), or use the default.
* ClickCreate Certificateand wait for the certificate to be issued.
* After creation, go to theCertificatessection under PBI_Vault_SP.
* Confirm the certificate PBT-CERT-01<username> (e.g., PBT-CERT-0199008677labuser01) is listed and its status is active.
NEW QUESTION # 17
Under the tremendous stress of fast pace in modern life, this version of our 1z0-1104-25 test prep suits office workers perfectly. It can match your office software and as well as help you spare time practicing the 1z0-1104-25 exam. As for its shining points, the PDF version can be readily downloaded and printed out so as to be read by you. It’s really a convenient way for those who are fond of paper learning. With this kind of version, you can flip through the pages at liberty and quickly finish the check-up 1z0-1104-25 Test Prep. What’s more, a sticky note can be used on your paper materials, which help your further understanding the knowledge and review what you have grasped from the notes.
Exam Sample 1z0-1104-25 Questions: https://www.validvce.com/1z0-1104-25-exam-collection.html
Secondly, all we sell are the accurate and valid practice material, if you have doubt about 1z0-1104-25 practice material pdf or practice exam online please email us, Oracle Certification 1z0-1104-25 Torrent Three different versions are available, The latest and valid 1z0-1104-25 pdf dumps in ValidVCE, You have no need to worry about unnecessary exam failure with our 1z0-1104-25 test braindumps, Our 1z0-1104-25 free dumps are applied to all level of candidates and ensure you get high passing score in their first try.
But model and design choices clarify or confuse communication, 1z0-1104-25 Note that synonyms and antonyms do not have to come from the same parts of speech, Secondly, all we sell are the accurate and valid practice material, if you have doubt about 1z0-1104-25 practice material pdf or practice exam online please email us.
Oracle 1z0-1104-25 Exam Questions For Greatest Achievement [Updated 2026]Three different versions are available, The latest and valid 1z0-1104-25 pdf dumps in ValidVCE, You have no need to worry about unnecessary exam failure with our 1z0-1104-25 test braindumps.
What's more, part of that ValidVCE 1z0-1104-25 dumps now are free: https://drive.google.com/open?id=1Mfo8RSXfeB1gTB0RiT7ZTil4LqxX0TzI
Posted at 1/31/2026 17:00:05        Only Author  2#
言與行的距離到底有多遠?關鍵看人心,倘使心神明淨,意志堅強,則近在咫尺,垂手可及 。我想你應該就是這樣的人吧。既然選擇了要通過VMware的3V0-25.25認證考試,當然就得必須通過,VCESoft VMware的3V0-25.25考試培訓資料是幫助通過考試的最佳選擇,也是表現你意志堅強的一種方式,VCESoft網站提供的培訓資料在互聯網上那是獨一無二的品質好,如果你想要通過VMware的3V0-25.25考試認證,就購買VCESoft VMware的3V0-25.25考試培訓資料。
Posted at 3/8/2026 12:46:50        Only Author  3#
I’m truly grateful for your article, it made an unforgettable impact. The Latest test 300-445 discount exam is almost here. Hope I ace it!
