CISSP Mock Test & Test CISSP Sample Questions
Posted at 1/18/2026 13:24:24
View296
Replies6
BTW, DOWNLOAD part of PDFTorrent CISSP dumps from Cloud Storage: https://drive.google.com/open?id=1ryXie1qQN-liuEZAi1u8whwzqa3mtFin
For most users, access to the relevant qualifying examinations may be the first, so many of the course content related to qualifying examinations are complex and arcane. According to these ignorant beginners, the CISSP Exam Questions set up a series of basic course, by easy to read, with corresponding examples to explain at the same time, the Certified Information Systems Security Professional (CISSP) study question let the user to be able to find in real life and corresponds to the actual use of learned knowledge, deepened the understanding of the users and memory. Because many users are first taking part in the exams, so for the exam and test time distribution of the above lack certain experience, and thus prone to the confusion in the examination place, time to grasp, eventually led to not finish the exam totally.
The CISSP Certification Exam is considered one of the most challenging exams in the field of information security. CISSP exam consists of 250 multiple-choice questions that must be completed within six hours. The questions are designed to test an individual's knowledge in various areas of information security, including security concepts, access control, cryptography, and network security.
Test CISSP Sample Questions & Exam CISSP FlashcardsIf you're still learning from the traditional old ways and silently waiting for the test to come, you should be awake and ready to take the exam in a different way. Study our CISSP study materials to write "test data" is the most suitable for your choice, after recent years show that the effect of our CISSP Study Materials has become a secret weapon of the examinee through qualification examination, a lot of the users of our CISSP study materials can get unexpected results in the examination.
ISC Certified Information Systems Security Professional (CISSP) Sample Questions (Q156-Q161):NEW QUESTION # 156
Which of the following is a proximity identification device that does not require action by the user and works by responding with an access code to signals transmitted by a reader?
- A. A magnetic card
- B. A transponder
- C. A passive system sensing device
- D. A card swipe
Explanation/Reference:
System sensing access control readers, also called transponders, recognize the presence of an approaching object within a specific area. This type of system does not require the user to swipe the card through the reader. The reader sends out interrogating signals and obtains the access code from the card without the user having to do anything.
Incorrect Answers:
A: A passive system sensing device contains no battery or power on the card, but senses the electromagnetic field transmitted by the reader and transmits at different frequencies using the power field of the reader. This device does not send an access code. Therefore, this answer is incorrect.
C: A swipe card requires the action from the user; the user has to swipe the card. Therefore, this answer is incorrect.
D: A magnetic card requires the action from the user; the user has to swipe the card. Therefore, this answer is incorrect.
Harris, Shon, All In One CISSP Exam Guide, 6th Edition, McGraw-Hill, 2013, p. 484 Krutz, Ronald L. and Russell Dean Vines, The CISSP and CAP Prep Guide: Mastering CISSP and CAP, Wiley Publishing, Indianapolis, 2007, p. 471
NEW QUESTION # 157
Which of the following is a valid tool that complements IDSs?
- A. Vulnerability Analysis Systems
- B. Honey Pots
- C. Padded Cells
- D. All of the choices.
Several tools exist that complement IDSs and are often labeled as intrusion detection products by vendors since they perform similar functions. They are Vulnerability Analysis Systems, File Integrity Checkers, Honey Pots, and Padded Cells.
"IDS-Related Tools Intrusion detection systems are often deployed in concert with several other components. These IDS-related tools expand the usefulness and capabilities of IDSs and make IDSs more efficient and less prone to false positives. These tools include honey pots, padded cells, and vulenerability scanners." Pg. 46 Tittel: CISSP Study Guide
NEW QUESTION # 158
In a block cipher, diffusion can be accomplished through:
- A. XORing
- B. Permutation
- C. Nonlinear S-boxes
- D. Substitution
Diffusion is aimed at obscuring redundancy in the plaintext by spreading the effect of the transformation over the ciphertext. Permutation is also known as transposition and operates by rearranging the letters of the plaintext.
*Answer substitution is used to implement confusion in a block cipher. Confusion tries to hide the relationship between the plaintext and the ciphertext. The Caesar cipher is an example of a substitution cipher.
* XORing is incorrect since XORing, for example, as used in a stream cipher, implements confusion and not diffusion. Similarly, nonlinear S-boxes implement substitution. In DES, for example, there are eight different S-boxes that each has an input of 6 bits and an output of 4 bits. Thus, nonlinear substitution is effected.
NEW QUESTION # 159
If traveling abroad and a customs official demands to examine a personal computer, which of the following should be assumed?
- A. The hard drive has been stolen.
- B. The Media Access Control (MAC) address was stolen
- C. The hard drive has been copied.
- D. The Internet Protocol (IP) address has been copied.
NEW QUESTION # 160
Which of the following is MOST important when assigning ownership of an asset to a department?
- A. Individual accountability should be ensured
- B. Ownership of the asset should be periodically reviewed
- C. All members should be trained on their responsibilities
- D. The department should report to the business owner
NEW QUESTION # 161
The CISSP Test Guide is written by lots of past materials rigorous analyses. The language of our study materials are easy to be understood, only with strict study, we write the latest and the specialized study materials. We want to provide you with the best service and hope you can be satisfied. It boosts your confidence for real exam and will help you remember the exam questions and answers that you will take part in. You may analyze the merits of each version carefully before you purchase our Certified Information Systems Security Professional (CISSP) guide torrent and choose the best one.
Test CISSP Sample Questions: https://www.pdftorrent.com/CISSP-exam-prep-dumps.html
- Sample CISSP Questions Pdf ❎ Detail CISSP Explanation 🏔 Detail CISSP Explanation 🐡 Search for ✔ CISSP ️✔️ and download it for free immediately on ☀ [url]www.prep4away.com ️☀️ 🍬CISSP Reliable Source[/url]
- CISSP Free Learning Cram 😧 Pdf CISSP Dumps 🛣 New CISSP Exam Simulator 🚜 Search on [url]www.pdfvce.com for ➥ CISSP 🡄 to obtain exam materials for free download ⚪Test CISSP Questions Vce[/url]
- CISSP Cert 🖼 Reliable CISSP Test Tips ☘ CISSP Sample Questions Answers 🦱 Simply search for ✔ CISSP ️✔️ for free download on ➠ [url]www.exam4labs.com 🠰 🃏Valid CISSP Exam Papers[/url]
- CISSP Dumps Collection: Certified Information Systems Security Professional (CISSP) - CISSP Test Cram - CISSP Study Materials ⏩ The page for free download of ▛ CISSP ▟ on [url]www.pdfvce.com will open immediately 🤠Training CISSP For Exam[/url]
- ISC CISSP Mock Test: Certified Information Systems Security Professional (CISSP) - [url]www.examdiscuss.com Pass-leading Provider 🕰 Search for CISSP on www.examdiscuss.com immediately to obtain a free download 🚰Latest CISSP Test Pdf[/url]
- Pdf CISSP Dumps 🔀 CISSP Reliable Source 🖱 Test CISSP Questions Vce 🍗 ⏩ [url]www.pdfvce.com ⏪ is best website to obtain ☀ CISSP ️☀️ for free download 🐧Reliable CISSP Braindumps Ppt[/url]
- CISSP Mock Test Makes Passing Certified Information Systems Security Professional (CISSP) Easier 🛃 Search for ⏩ CISSP ⏪ on [ [url]www.pdfdumps.com ] immediately to obtain a free download 🦙CISSP Free Learning Cram[/url]
- Free PDF Quiz ISC - CISSP - High-quality Certified Information Systems Security Professional (CISSP) Mock Test 🩳 Go to website ▷ [url]www.pdfvce.com ◁ open and search for ▶ CISSP ◀ to download for free ☎Reliable CISSP Test Tips[/url]
- Test CISSP Questions Vce 🕺 Valid CISSP Exam Papers 💓 CISSP Intereactive Testing Engine ℹ Download { CISSP } for free by simply entering ⏩ [url]www.easy4engine.com ⏪ website 🚢Latest CISSP Exam Bootcamp[/url]
- New CISSP Test Voucher 🌔 Training CISSP For Exam 🟪 New CISSP Test Voucher 💡 Immediately open ➤ [url]www.pdfvce.com ⮘ and search for ✔ CISSP ️✔️ to obtain a free download 🍵CISSP Free Learning Cram[/url]
- Test CISSP Questions Vce 🧛 New CISSP Exam Simulator 🍊 Pdf CISSP Dumps 🕧 Search for CISSP and download exam materials for free through ➡ [url]www.testkingpass.com ️⬅️ 🧐Latest CISSP Test Pdf[/url]
- nualkale.blogspot.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
