Hardware
JN0-336YƥȡJN0-336ȥ`˥
Posted at 1/18/2026 13:45:32
View294
Replies4
٤˰kչƤΤ٤ƤˤˤȤäơ¤뤳ȤޤޤҪˤʤäƤ뤳Ȥ˽֪Ƥޤ JN0-336Jȡä뤳ȤޤޤyˤʤäƤ뤳Ȥ狼äƤޤ¡U𡢤JN0-336JʈϡϤϡJN0-336ԇYȥȤǸƷ|Ά}QΤցޤoϤǥ`ɤǤޤ JN0-336ɥȥȤΥϤΥǥ⡣ JN0-336ԇY|ڤʤȤsޤ
줿JN0-336ԇY}ʹäȡJN0-336JYȡäԷϤδȤδgF뤳ȤǤޤ JN0-336ȥ`˥ɤʹäȡIJޤ JN0-336ԇYΥ֥`פϡʻעĿ^Ǥޤ ᡢ¤ȡämФФxk֫ޤ JN0-336ԇY}ԇƤߤƤϤǤJN0-336ԇY}ߤΜʂYϤǤ뤳Ȥ@뤳ȤǤ礦
JN0-336mǤԇY}JN0-336 Pdf}Security, Specialist (JNCIS-SEC)ƥȥ饤ԷITܤһؤJuniperJN0-336JԇY˺ϸJpshiken|JuniperJN0-336}ṩǤ뤷JԇY˺ϸΤ˴ۤޤ⤷Ϥ䤹뤳Ȥʤ顢ʤϤƷُ뤹ǰˡJpshikenϟoϤǥץṩ뤳ȤǤޤoϥץΤäˤäƤǡäŤ֤äJԇY˺ϸ뤳ȤǤޤ
Juniper Security, Specialist (JNCIS-SEC) J JN0-336 ԇY} (Q36-Q41):| # 36
Exhibit
When trying to set up a server protection SSL proxy, you receive the error shown.
What are two reasons for this error? (Choose two.)
- A. The SSL proxy certificate ID does not exist.
- B. The SSL proxy certificate ID is part of a blocklist.
- C. The SSL proxy certificate ID is for a forwarding proxy.
- D. The SSL proxy certificate ID does not have the correct renegotiation option set.
⣺AD
h
The error message shown in the exhibit regarding the SSL proxy setup indicates an issue with the type of server certificate being used. The error explicitly states, "Unsupported cert type of server certid." Here are two plausible reasons for this error based on the options provided:
Option B. The SSL proxy certificate ID does not have the correct renegotiation option set.
This option points to a configuration issue related to the properties or capabilities of the certificate, such as renegotiation, which if not set correctly according to the expected requirements of the SSL proxy, might lead to the certificate being unsupported. Renegotiation settings are critical in ensuring secure connections, and mismatches in configuration can result in errors.
Option D. The SSL proxy certificate ID does not exist.
If the certificate ID being referred to in the SSL proxy profile does not exist in the device's certificate store or is incorrectly referenced, the system will be unable to apply the configuration, leading to an error during the commit operation. This situation would typically result in an error indicating that the system can't find or recognize the specified certificate ID.
| # 37
Exhibit
You are asked to ensure that servers running the Ubuntu OS will not be able to update automatically by blocking their access at the SRX firewall. You have configured a unified security policy named Blockuburrtu, but it is not blocking the updates to the OS.
Referring to the exhibit which statement will block the Ubuntu OS updates?
- A. Move the Blockubuntu policy after the Allowweb policy.
- B. Change the default policy to permit-all.
- C. Configure the Allowweb policy to have a dynamic application of any.
- D. Configure the Blockubuntu policy with the junos-https application parameter.
⣺D
| # 38
Which statement regarding Juniper Identity Management Service (JIMS) domain PC probes is true?
- A. JIMS domain PC probes are triggered to map usernames to group membership information.
- B. JIMS domain PC probes analyze domain controller security event logs at60-mmute intervals by default.
- C. JIMS domain PC probes are initiated by an SRX Series device to verify authentication table information.
- D. JIMS domain PC probes are triggered if no username to IP address mapping is found in the domain security event log.
⣺D
h
Juniper Identity Management Service (JIMS) domain PC probes are used to map usernames to IP addresses in the domain security event log. This allows for the SRX Series device to verify authentication table information, such as group membership. The probes are triggered whenever a username to IP address mapping is not found in the domain security event log. By default, the probes are executed at 60-minute intervals.
| # 39
You set up the Juniper ATP Appliance solution on your network and notice that the macOS files are not being analyzed......... malware.
In this scenario, what must you do?
- A. You must obtain a Apple Mac Mini device and install the secondary core software.
- B. Under Config > System ProfilesSecondary Cores workspace, enable macOs Detection.
- C. Create a macOS virtual machine on the JATP Appliance and install the secondary core software.
- D. Under Config -> System ProfilesSecondary Cores workspace, create a macOS profile
⣺D
| # 40
Click the Exhibit button.
Which two statements describe the output shown in the exhibit? (Choose two.)
- A. Redundancy group 1 was administratively failed over.
- B. Node 1 is controlling traffic for redundancy group 1.
- C. Redundancy group 1 experienced an operational failure.
- D. Node 0 is controlling traffic for redundancy group 1.
⣺BD
h
The output indicates that node1 has a priority of 200 and is marked as "Primary," which means it is currently the active node controlling traffic for redundancy group 1. The "Primary" status designates that this node is handling the traffic for the specified redundancy group.
According to the exhibit, node0 is listed with a priority of 0 and is marked as "Secondary." This status indicates that node0 is currently not controlling traffic for redundancy group 1, serving instead in a standby role ready to take over should node1 fail or become unavailable.
| # 41
JuniperJN0-336ԇY˜ʂ䤹ˤϡmξϱҪǤYȤƤΤʤJuniperJN0-336ԇYvߤ|YϤṩޤPDF桢եȰ桢饤Ĥΰ椫顢ʤΐäxkޤθƷ|ԇY}ͨơʤJuniperJN0-336ԇYƺϸʤITܤIĤ¤ʥ٥ѺMΤҡʹǤ
JN0-336ȥ`˥: https://www.jpshiken.com/JN0-336_shiken.html
Juniper JN0-336Yƥ gȥ`˥YϤxԇY˺ϸ뤳ȤϲܤǤϤʤǤJuniper JN0-336Yƥ ΟoϤʥץh]ʤ`ɤƤJuniper JN0-336Yƥ ͤϤɤǤ⡢ĤǤʹäǤޤJuniper JN0-336Yƥ rgmФĺĤ֤뤳ȤϡɹФˤȤäƲǷҪؤǤʤJN0-336^ǤϤޤJN0-336}ߤṩϤ͘Ǥ͘˥`ӥṩ뤿ˡJN0-336ԇY^ȥݤơͨ^ʤθߤJN0-336}ߤ_kޤJuniper JN0-336Yƥ ǥṩĿĤϡ͘˥ȥԥå˽β֤⤷Ƥ餦Ȥȡ줬_줿ȤѧYϤʽϺΤǤ
ˤϤޤط佼νסԤͤ˶вOνסळȤäJN0-336ȥ`˥ޤt־ϳڤCܵߤBjȡäƤᡢ̤ȵ̤v֪Rʮ֤ǤϤʤäᡢCܤ֤ˡޤˤΤ褦ԒʤФʤޤǤ
ѥ`JN0-336Yƥ & YԇYˤ``ե` & 餷JN0-336: Security, Specialist (JNCIS-SEC)gȥ`˥YϤxԇY˺ϸ뤳ȤϲܤǤϤʤǤJN0-336oϤʥץh]ʤ`ɤƤͤϤɤǤ⡢ĤǤʹäǤޤrgmФĺĤ֤뤳ȤϡɹФˤȤäƲǷҪؤǤ
ʤJN0-336^ǤϤޤ
- JN0-336Yϵ 🤍 JN0-336ԇY 😚 JN0-336ձZYȡ 🔍 [ [url]www.passtest.jp ]_✔ JN0-336 ️✔️ơoϤǥ`ɤƤJN0-336ձZvB[/url]
- JN0-336Y㏊ 🦸 JN0-336Yϵ 🛹 JN0-336ձZvB 🆕 [url]www.goshiken.com _⏩ JN0-336 ⏪ԇYYϤoϤǥ`ɤƤJN0-336饤ԇY[/url]
- -ؔJN0-336YƥԇY-ԇYΜʂ䷽JN0-336ȥ`˥ 🍹 ǡ [url]www.passtest.jp ⏩ JN0-336 ⏪oϤǥ`JN0-336°[/url]
- -ؔJN0-336YƥԇY-ԇYΜʂ䷽JN0-336ȥ`˥ 🎅 ⏩ [url]www.goshiken.com ⏪➤ JN0-336 ⮘}`JN0-336[/url]
- JN0-336Y㏊ 🍽 JN0-336ǥ 🤸 JN0-336ԇY 🐉 ➤ [url]www.it-passports.com ⮘ϡ✔ JN0-336 ️✔️oϤǥ`ɤΤmʥȤǤJN0-336ձZvB[/url]
- ԇYΜʂ䷽-gĤJN0-336YƥԇY-100ϸʤJN0-336ȥ`˥ ☝ [url]www.goshiken.com ˤϟoϤ✔ JN0-336 ️✔️}ޤJN0-336ȫ憖}[/url]
- JN0-336ձZvB 🕗 JN0-336JYԇY} 🔖 JN0-336 😸 ➽ [url]www.it-passports.com 🢪▛ JN0-336 ▟ơoϤǺg˥`ɤǤޤJN0-336ձZvB[/url]
- JN0-336ԇYΜʂ䷽ϥѥ`ȤJN0-336YƥԇYĤSecurity, Specialist (JNCIS-SEC)ȥ`˥ 🍡 ➤ [url]www.goshiken.com ⮘ǡ JN0-336 ơoϤǥ`ɤƤJN0-336ձZvB[/url]
- JN0-336ĤJN0-336YƥԇYԇYΜʂ䷽Security, Specialist (JNCIS-SEC)ȥ`˥ 🏝 ▷ [url]www.it-passports.com ◁_ JN0-336 ƟoϤǥ`ɤƤJN0-336饤ԇY[/url]
- JN0-336Yϵ 🎰 JN0-336° 🚮 JN0-336ƥȌߕ 🍜 ✔ [url]www.goshiken.com ️✔️Ȥˤ{ JN0-336 }}`JN0-336ģM[/url]
- -ؔJN0-336YƥԇY-ԇYΜʂ䷽JN0-336ȥ`˥ 🔻 [url]www.xhs1991.com Οoϥ`✔ JN0-336 ️✔️ک`_ޤJN0-336ƥȌߕ[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, anonup.com, motionentrance.edu.np, www.stes.tyc.edu.tw, bbs.t-firefly.com, ycs.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
