[General] Arch-301 Test-king File & Arch-301 Practice Materials & Arch-301 Test Qu
98
【General】 Arch-301 Test-king File & Arch-301 Practice Materials & Arch-301 Test Qu
Posted at 1/18/2026 14:53:10      View:150 | Replies:1        Print      Only Author   [Copy Link] 1#
Do you feel anxiety about your coming Arch-301 exam test? Do you want to find the valid and latest material for the Arch-301 actual test? TorrentValid will help you and bring you to the right direction. Firstly, Arch-301 free demo is allowable for you to try before you buy. Besides, we will offer you the benefits of 365 days free update. SO, even if the Arch-301 Actual Test is changed frequently, you do not worry about it, because our Arch-301 training material is updated according to the actual test and can ensure you pass.
The Salesforce Certified B2B Solution Architect (Arch-301) actual questions we sell also come with a free demo. Spend no time, otherwise, you will pass on these fantastic opportunities. Start preparing for the Salesforce Arch-301 exam by purchasing the most recent Salesforce Arch-301 Exam Dumps. TorrentValid also guarantees that it will provide your money back if in any case, you are unable to pass the Arch-301 exam but the terms and conditions are there that you must have to follow.
Top Arch-301 Valid Test Bootcamp | Pass-Sure Online Arch-301 Lab Simulation: Salesforce Certified B2B Solution Architect 100% PassInstant answer feedback allows you to identify your vulnerabilities in a timely manner, so as to make up for your weaknesses. With our Arch-301 practice quiz, you will find that the preparation process is not only relaxed and joyful, but also greatly improves the probability of passing the Arch-301 Exam. And our pass rate of the Arch-301 training materials is high as 98% to 100%. You are bound to pass the exam if you buy our Arch-301 learning guide.
Salesforce Certified B2B Solution Architect Sample Questions (Q29-Q34):NEW QUESTION # 29
Northern Trail Outfitters (NTO) is currently using Salesforce CPQ and would like to implement B2B Commerce Classes. NTO uses a Partner Community to allow partners to build complex bundles to provide detailed quotes to clients. NTO also wants to ensure that it does not have to maintain two databases of products.
Which two considerations should a Solution Architect keep in mind about the CPQ B28 Commerce Connector when synchronizing Product and Price data?
Choose 2 answers
  • A. The connector does not support syncing complex CPQ bundles.
  • B. The connector lets you sync simple products with a flat price.
  • C. The connector is a two-way sync for product and pricing logic.
  • D. Discount schedules from CPQ will sync to discounts and promotions m B2B Commerce Classic
When synchronizing product and price data between Salesforce CPQ and B2B Commerce using the CPQ B2B Commerce Connector, it's important to understand its capabilities and limitations. The connector is designed to sync simple products with straightforward pricing structures, but it does not support the synchronization of complex CPQ bundles that involve multiple components and pricing rules. This limitation requires careful planning around product catalog management and may necessitate custom solutions or workarounds for complex product offerings, aligning with Salesforce's documentation and best practices for using the CPQ B2B Commerce Connector.
NEW QUESTION # 30
A Solution Architect is presenting a design for the Phase 1rollout of a B2B multi-cloud solution that includes CPQ and B2B Commerce using the CPQ B2B Commerce Connector. During the presentation, business stakeholders push bade on some of the key design aspects. The business is keen to have the product images and SCO data pushed back to CPQ from 828 Commerce, which is not incorporated in the current design.
Further, the business wants the Solution Architect to find a way to map discounts and promotions in 828 Commerce to CPQ pricing and add that to the Phase 1 deliverables.
Which two responses should a Solution Architect present to the stakeholder s?
Choose 2 answers
  • A. Product Images and SCO data are B2B Commerce specific metadata. It is recommended to keep them only in 828 Commerce, and not push to CPQ.
  • B. There are significant differences in the discounting models and options between B2B Commerce and CPQ, and for that reason, it is better to handle them separately. without syncing to CPQ.
  • C. Map the discounts and promotions to Additional Discounts field on the quote Int. However, we would need to ensure thatthe price rules do not run for quotes originated from B2B Commerce unless there is a specific business need.
  • D. Map the product images from B2B Commerce to CPQ, by passing the URL of theimage File from CC Product to Product2 object. SEO data sync will require additional customization and it is recommended for Phase 2.
https://help.salesforce.com/s/ar ... to_quote_connector.
htm&language=en_US&type=5
Addressing stakeholder feedback on syncing product images and SEO data from B2B Commerce to CPQ, and aligning discounts and promotions, involves a balanced approach. Mapping product images by passing the URL from B2B Commerce to CPQ ensures that product visual representation is consistent across platforms.
Considering the complexity of syncing SEO data, it is pragmatic to plan this for a subsequent phase, allowing for proper customization and integration work. For discounts and promotions, mapping them to the Additional Discounts field on the quote line in CPQ is feasible, but it's crucial to manage the execution of price rules carefully to maintain pricing integrity. This approach aligns with best practices for integrating B2B Commerce and CPQ, ensuring a cohesive and functional solution that meets business requirements while managing technical complexities and scope.
NEW QUESTION # 31
A corporate bank has decided to use a multi-cloud solution to reduce time to market, showcase a 360-degree view of the bank's business customers, and improve CSAT rating by increasing channels for customer service. The CIO has asked to run a discovery workshop with one goal: understanding existing technical dependencies within the organisation.
What should a Solution Architect recommend as the top priority to start this journey?
  • A. Plot the map of the current system landscape and identify key areas where the B2B multi-cloud solution will fit in.
  • B. Plot the process map using Universal Process Notation (UPN) through workshops involving a diverse set of stakeholders.
  • C. Plot the map or the future system landscape by making assumptions about the changes needed to improve customer satisfaction.
  • D. Plot what the customer is thinking, doing, and feeling at the varying stages of their experience, and connect them to interactions with the bank.
* Plot the map of the current system landscape and identify key areas where the B2B multi-cloud solution will fit in. This is an important step to understand the existing technical dependencies within the organisation, such as datasources, integrations, applications, and platforms. It also helps to identify the gaps and opportunities for improvement that can be addressed by the B2B multi-cloud solution.
For the corporate bank embarking on a multi-cloud solution journey, mapping the current system landscape is a critical first step. This involves documenting existing systems, applications, and their interconnections to identify integration points and potential overlaps with the new B2B multi-cloud solution. Understanding the current technical ecosystem allows for the identification of key areas where Salesforce solutions can be integrated to enhance customer service, improve visibility into business customer activities, and increase customer satisfaction. This foundational analysis is essential for informed decision-making and strategic planning, ensuring that the new solutions complement and enhance the existing technical infrastructure, in line with Salesforce's recommendations for successful multi-cloud implementations.
NEW QUESTION # 32
Universal Containers (UC) is starting to go through an inventory of capabilities in regard to its many data warehouses. UC's data warehouses are currently being provided with data from OMS, ERP, Accounting, and other inventory management systems. Data warehouses are utilized by those systems for storage or analytics purposes.
UC plans to utilize the Systems of Engagement framework to classify its systems based on how they will be utilized within the enterprise architecture. UC would like to understand which systems it should directly integrate with versus utilizing the data warehouses where that data may also be stored.
How should a Solution Architect classify the data warehouses as systems within the enterprise architecture of this scenario?
  • A. System of Reference
  • B. System of Record
  • C. System of Engagement
  • D. System of Intelligence
In an enterprise architecture, data warehouses typically serve as a System of Record (SoR). They contain the authoritative data source for a given piece of information and are used for storage and analytics purposes. The Systems of Engagement (SoE) framework would classify the data warehouses as SoR because they maintain the official copy of the data being used by various systems. This classification aids in deciding on integration strategies and data flow within the enterprise architecture.
NEW QUESTION # 33
Universal Containers (UC) is about to complete an initial planning of a complex solution involving multiple customer personas. UC wants to ensure it has a comprehensive understanding of whatkinds of business outcomes the customers want to achieve before presenting them a solution.
Which method of discovery should a Solution Architect suggest to UC?
  • A. Third-party research from well-known organizations
  • B. Jobs To Be Done Framework
  • C. User Stories Creation with End Customers
  • D. Comprehensive Surveys to End Customers
The "Jobs To Be Done Framework" is a method that focuses on understanding customer needs in specific contexts and situations. This approach is ideal for UC to gain comprehensive insights into what kinds of business outcomes the customers want to achieve. It goes beyond mere feature requests and digs into the underlying goals and challenges customers face, which can be more enlightening for solution design than surveys or user story creation alone. The framework is recognized for its effectiveness in uncovering the real jobs customers are hiring products and services to do.
NEW QUESTION # 34
TorrentValid always provides customer support for the convenience of desktop Salesforce Arch-301 practice test software users. The Salesforce Arch-301 certification provides both novices and experts with a fantastic opportunity to show off their knowledge of and proficiency in carrying out a particular task. You can benefit from a number of additional benefits after completing the Salesforce Arch-301 Certification Exam.
Online Arch-301 Lab Simulation: https://www.torrentvalid.com/Arch-301-valid-braindumps-torrent.html
Salesforce Arch-301 Valid Test Bootcamp Formatted questions just like on the real exam, Our Arch-301 practice test materials are accurate, valid and latest, Buying Arch-301 exam torrent is equivalent to purchasing three books at the same time, The TorrentValid acknowledges that Salesforce aspirants are continuously juggling a couple of responsibilities, so Arch-301 questions are ideal for short practise, To satisfy some candidates who want see the formal versions of Arch-301 dumps PDF: Salesforce Certified B2B Solution Architect, we offer free demos on trial.
Inspecting and fixing interface issues with the new View Debugger, Arch-301 intent.jpg The Intent menu lets you choose how the final color display should look, Formatted questions just like on the real exam!
100% Pass Quiz 2026 Salesforce Arch-301: Efficient Salesforce Certified B2B Solution Architect Valid Test BootcampOur Arch-301 Practice Test materials are accurate, valid and latest, Buying Arch-301 exam torrent is equivalent to purchasing three books at the same time, The TorrentValid acknowledges that Salesforce aspirants are continuously juggling a couple of responsibilities, so Arch-301 questions are ideal for short practise.
Posted at 2/11/2026 18:05:05        Only Author  2#
クライアントはCPIM-8.0試験問題を学習し、テストの準備をするのに20〜30時間しかかかりません。多くの人は、CPIM-8.0テストの準備が必要だと不満を言うかもしれませんが、一方でJpexam、仕事、学習、家族などの最も重要なことにほとんどの時間を費やさなければなりません。ただし、CPIM-8.0学習ガイドを購入すると、テストの準備に時間と労力がほとんどかからないため、最も重要なことをうまくやり、CPIM-8.0テストに簡単に合格できます。
