100% Pass Quiz 2026 Reliable Data-Architect: Real Salesforce Certified Data Arch
Posted at 1/18/2026 16:59:44
View119
Replies2
P.S. Free & New Data-Architect dumps are available on Google Drive shared by DumpsActual: https://drive.google.com/open?id=1NizyHn9OCFiVU2IRutsttrIv-r4Ig3lW
DumpsActual are supposed to help you pass the exam smoothly. Don't worry about channels to the best Data-Architect study materials because we are the exactly best vendor in this field for more than ten years. And so many exam candidates admire our generosity of the Data-Architect Practice Questions offering help for them. Up to now, no one has ever challenged our leading position of this area. With our Data-Architect training guide, you will be doomed to pass the exam successfully.
Many of the candidates like the Soft version of our Data-Architect exam questions. The software of Data-Architect guide torrent boosts varied self-learning and self-assessment functions to check the results of the learning. The software can help the learners find the weak links and deal with them. Our Data-Architect Exam Questions boost timing function and the function to stimulate the exam. Our product sets the timer to stimulate the exam to adjust the speed and keep alert. So it is worthy for you to buy our Data-Architect exam questions.
Data-Architect Exam Consultant & Detailed Data-Architect Study PlanOne of the key factors for passing the exam is practice. Candidates must use Data-Architect practice test material to be able to perform at their best on the real exam. This is why DumpsActual has developed three formats to assist candidates in their Salesforce Data-Architect Preparation. These formats include desktop-based Salesforce Data-Architect practice test software, web-based practice test, and a PDF format.
Salesforce Certified Data Architect Sample Questions (Q141-Q146):NEW QUESTION # 141
Universal Containers (UC) is implementing a formal, cross -business -unit data governance program As part of the program, UC will implement a team to make decisions on enterprise -wide data governance. Which two roles are appropriate as members of this team? Choose 2 answers
- A. Operational Data Users
- B. Data Domain Stewards
- C. Analytics/BI Owners
- D. Salesforce Administrators
Analytics/BI Owners and Data Domain Stewards are appropriate roles as members of a team that makes decisions on enterprise-wide data governance. Analytics/BI Owners are responsible for defining the business requirements and metrics for data analysis and reporting, and Data Domain Stewards are responsible for defining and enforcing the data quality standards and rules for specific data domains. Salesforce Administrators and Operational Data Users are not suitable roles for this team, as they are more focused on the operational aspects of data management, such as configuration, maintenance, and usage.
NEW QUESTION # 142
Universal Containers has more than 10 million records in the Order_c object. The query has timed out when running a bulk query. What should be considered to resolve query timeout?
- A. Streaming API
- B. Tooling API
- C. PK Chunking
- D. Metadata API
PK Chunking can resolve query timeout when running a bulk query on an object with more than 10 million records. PK Chunking is a feature of the Bulk API that splits a query into multiple batches based on the record IDs (primary keys) of the queried object. This can improve the query performance and avoid timeouts by reducing the number of records processed in each batch.
NEW QUESTION # 143
Universal Container (UC) has around 200,000 Customers (stored in Account object). They get 1 or 2 Orders every month from each Customer. Orders are stored in a custom object called "Order c"; this has about 50 fields. UC is expecting a growth of 10% year -over -year. What are two considerations an architect should consider to improve the performance of SOQL queries that retrieve data from the Order _c object? Choose 2 answers
- A. Use SOQL queries without WHERE conditions.
- B. Make the queries more selective using indexed fields.
- C. Work with Salesforce Support to enable Skinny Tables.
- D. Reduce the number of triggers on Order _c object.
To improve the performance of SOQL queries that retrieve data from the Order_c object, the data architect should work with Salesforce Support to enable Skinny Tables and make the queries more selective using indexed fields. Skinny Tables are custom tables that contain frequently used fields and are kept in sync with the base tables3. They can improve performance by reducing the number of table joins and using indexes. Making the queries more selective using indexed fields can also improve performance by reducing the query execution time and avoiding query timeouts4. The other options are not effective or recommended for improving SOQL performance.
NEW QUESTION # 144
A Customer is migrating 10 million order and 30 million order lines into Salesforce using Bulk API. The Engineer is experiencing time-out errors or long delays querying parents order IDs in Salesforce before importing related order line items. What is the recommended solution?
- A. Leverage an External ID from source system orders to import related order lines.
- B. Leverage Batch Apex to update order ID on related order lines after import.
- C. Query only indexed ID field values on the imported order to import related order lines.
- D. Leverage a sequence of numbers on the imported orders to import related order lines.
NEW QUESTION # 145
What makes Skinny tables fast? Choose three answers.
- A. They avoid resource intensive joins
- B. They can contain fields from other objects
- C. They support up to a max of 100 of columns
- D. Their tables are kept in sync with their source tables when the source tables are modified
- E. They do not include soft-deleted records
Answer: A,D,E
NEW QUESTION # 146
To deliver on the commitments of our Data-Architect test prep that we have made for the majority of candidates, we prioritize the research and development of our Data-Architect test braindumps, establishing action plans with clear goals of helping them get the Data-Architect certification. You can totally rely on our products for your future learning path. In fact, the overload of learning seems not to be a good method, once you are weary of such a studying mode, its difficult for you to regain interests and energy. Therefore, we should formulate a set of high efficient study plan to make the Data-Architect Exam Dumps easier to operate.
Data-Architect Exam Consultant: https://www.dumpsactual.com/Data-Architect-actualtests-dumps.html
And the Data-Architect certification vividly demonstrates the fact that they are better learners, The most important one, we always abide by the principle to give you the most comfortable services during and after you buying the Data-Architect exam simulation questions, All these questions and answers are prepared by the Data-Architect Exam Consultant certification professionals and experts, The 3 formats of Data-Architect study materials are PDF, Software/PC, and APP/Online.
As we all know, Data-Architect certification is becoming the one of the most popular certification people pursue, and the difficulty of the test aggravates the negative attitude and bad mood of IT candidates.
2026 High Hit-Rate Data-Architect C 100% Free Real Exams | Salesforce Certified Data Architect Exam ConsultantPrinciples of Experience Value Management, And the Data-Architect Certification vividly demonstrates the fact that they are better learners, The most important one, we always abide by the principle to give you the most comfortable services during and after you buying the Data-Architect exam simulation questions.
All these questions and answers are prepared by the Salesforce Application Architect certification professionals and experts, The 3 formats of Data-Architect study materials are PDF, Software/PC, and APP/Online.
You can also check the demo of Salesforce Data-Architect exam torrent before you decide to buy it.
- Marvelous Real Data-Architect Exams - Unparalleled Source of Data-Architect Exam 🎾 Search for { Data-Architect } and download exam materials for free through ▶ [url]www.practicevce.com ◀ 🟨Clearer Data-Architect Explanation[/url]
- Free PDF Quiz 2026 Salesforce Useful Real Data-Architect Exams 🤮 Open website ✔ [url]www.pdfvce.com ️✔️ and search for ➠ Data-Architect 🠰 for free download 🏠Clearer Data-Architect Explanation[/url]
- Data-Architect Reliable Study Materials 🥝 Data-Architect Real Torrent 🏪 Data-Architect Exam Consultant 🐓 Copy URL ▷ [url]www.prepawayexam.com ◁ open and search for ✔ Data-Architect ️✔️ to download for free 🐞Data-Architect Real Torrent[/url]
- Data-Architect Latest Exam Forum ⏲ Data-Architect Actual Exam Dumps 🕰 Data-Architect Most Reliable Questions ✅ Easily obtain free download of Data-Architect by searching on [url]www.pdfvce.com 👗Data-Architect Latest Exam Forum[/url]
- Data-Architect Actual Exam Dumps 🐮 Data-Architect Exam Consultant 😻 Reasonable Data-Architect Exam Price 🦇 Search for ▷ Data-Architect ◁ and obtain a free download on ▶ [url]www.dumpsquestion.com ◀ 💂Data-Architect Reliable Study Materials[/url]
- Real Data-Architect Exams - Realistic Quiz 2026 Salesforce Salesforce Certified Data Architect Exam Consultant 🦑 Easily obtain free download of ➤ Data-Architect ⮘ by searching on ▛ [url]www.pdfvce.com ▟ ⚔Data-Architect Most Reliable Questions[/url]
- Marvelous Real Data-Architect Exams - Unparalleled Source of Data-Architect Exam 🤓 Search on ▛ [url]www.examcollectionpass.com ▟ for Data-Architect to obtain exam materials for free download 🚕Data-Architect Reliable Study Materials[/url]
- Fantastic Data-Architect - Real Salesforce Certified Data Architect Exams 📹 Download ➡ Data-Architect ️⬅️ for free by simply entering [url]www.pdfvce.com website ⛽Data-Architect Test Cram Review[/url]
- Salesforce Data-Architect All-in-One Exam Guide Practice for Data-Architect exam success 🩳 Search for ✔ Data-Architect ️✔️ and download it for free immediately on { [url]www.verifieddumps.com } 🐏Data-Architect Test Cram Review[/url]
- Updated Salesforce Data-Architect Practice Material In 1 year 🍈 Search for ➤ Data-Architect ⮘ and download it for free immediately on ⇛ [url]www.pdfvce.com ⇚ 🌏Data-Architect Reliable Study Materials[/url]
- Data-Architect Free Brain Dumps 🦰 Data-Architect Actual Exam Dumps 💿 Data-Architect Reliable Study Materials ⚠ Search on ⏩ [url]www.exam4labs.com ⏪ for ✔ Data-Architect ️✔️ to obtain exam materials for free download 🍳Detailed Data-Architect Study Dumps[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.wcs.edu.eu, faithlife.com, 39.109.117.191:85, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BTW, DOWNLOAD part of DumpsActual Data-Architect dumps from Cloud Storage: https://drive.google.com/open?id=1NizyHn9OCFiVU2IRutsttrIv-r4Ig3lW
