[General] Valid Exam AWS-Solutions-Associate Registration, Free Sample AWS-Solutions-Assoc
94
General Valid Exam AWS-Solutions-Associate Registration, Free Sample AWS-Solutions-Assoc
Posted at 1/18/2026 17:16:11      View218 | Replies2        Print      Only Author   [Copy Link] 1#
P.S. Free & New AWS-Solutions-Associate dumps are available on Google Drive shared by ExamcollectionPass: https://drive.google.com/open?id=10REsXyhkv0FVxNgAWKazfujOoQK8E2c4
APP test engine of Amazon AWS-Solutions-Associate exam is popular with at least 60% candidates since all most certification candidates are fashion and easy to adapt to this new studying method. Someone thinks that APP test engine of AWS-Solutions-Associate exam is convenient to use any time anywhere. Also part of candidates thinks that this version can simulate the real scene with the real test. If you can open the browser you can learn. Also if you want to learn offline, you should not clear the cache after downloading and installing the APP test engine of AWS-Solutions-Associate Exam.
The AWS Certified Solutions Architect - Associate (SAA-C02) certification exam is a valuable certification for professionals in the cloud computing industry. It demonstrates an individual's expertise in designing, deploying, and managing applications on the AWS platform. If you are looking to advance your career in cloud computing, this certification is a must-have.
Free Sample AWS-Solutions-Associate Questions, Dump AWS-Solutions-Associate TorrentIf you are not sure whether our AWS-Solutions-Associate exam braindumps are suitable for you, you can request to use our trial version. Of course, AWS-Solutions-Associate learning materials produced several versions of the product to meet the requirements of different users. You can also ask to try more than one version and choose the one that suits you best. And we have three different versions Of our AWS-Solutions-Associate Study Guide: the PDF, the Software and the APP online.
The AWS Solutions Architect C Associate certification exam is designed for individuals who have experience in designing, deploying, and managing applications on AWS. AWS-Solutions-Associate Exam covers a wide range of topics, including AWS services, architecture, security, and deployment. Candidates are required to have a solid understanding of AWS services, including EC2, S3, VPC, and RDS, among others. They must also be familiar with various AWS deployment and management tools, such as CloudFormation, Elastic Beanstalk, and AWS OpsWorks.
Amazon AWS Certified Solutions Architect - Associate (SAA-C03) Sample Questions (Q280-Q285):NEW QUESTION # 280
A customer has established an AWS Direct Connect connection to AWS. The link is up and routes are being advertised from the customer's end, however the customer is unable to connect from EC2 instances inside its VPC to servers residing in its datacenter.
Which of the following options provide a viable solution to remedy this situation? (Choose 2 answers)
  • A. Modify the Instances VPC subnet route table by adding a route back to the customer's on-premises environment.
  • B. Add a route to the route table with an iPsec VPN connection as the target.
  • C. Enable route propagation to the virtual pinnate gateway (VGW).
  • D. Modify the route table of all Instances using the 'route' command.
  • E. Enable route propagation to the customer gateway (CGW).
NEW QUESTION # 281
A company has an on-premises SFTP file transfer solution. The company is migrating to the AWS Cloud to scale the file transfer solution and to optimize costs by using Amazon S3. The company's employees will use their credentials for the on-premises Microsoft Active Directory (AD) to access the new solution The company wants to keep the current authentication and file access mechanisms.
Which solution will meet these requirements with the LEAST operational overhead?
  • A. Create an AWS Transfer Family SFTP endpoint. Configure the endpoint to use the AWS Directory Service option as the identity provider to connect to the existing Active Directory.
  • B. Configure an S3 File Gateway. Create SMB file shares on the file gateway that use the existing Active Directory to authenticate
  • C. Configure an Auto Scaling group with Amazon EC2 instances to run an SFTP solution Configure the group to scale up at 60% CPU utilization.
  • D. Create an AWS Transfer Family server with SFTP endpoints Choose the AWS Directory Service option as the identity provider Use AD Connector to connect the on-premises Active Directory.
AWS Transfer Family: This service provides fully managed support for file transfers directly into and out of Amazon S3 using the SFTP, FTPS, and FTP protocols.
SFTP Endpoints:
Set up an AWS Transfer Family server and configure SFTP endpoints to handle the file transfers.
This service is scalable and managed, reducing operational overhead compared to running an SFTP solution on EC2 instances.
Integration with Active Directory:
Choose the AWS Directory Service option as the identity provider for the Transfer Family server.
Use AD Connector to link the on-premises Active Directory with AWS, allowing employees to use their existing AD credentials to access the SFTP service.
Operational Efficiency: This solution leverages managed services for both file transfer and identity management, ensuring minimal changes to the current authentication mechanisms and reducing operational overhead.
AWS Transfer Family
AWS Directory Service and AD Connector
NEW QUESTION # 282
A company has a web application that uses several web servers that run on Amazon EC2 instances. The instances use a shared Amazon RDS for MySQL database.
The company requires a secure method to store database credentials. The credentials must be automatically rotated every 30 days without affecting application availability.
Which solution will meet these requirements?
  • A. Store database credentials in an Amazon S3 bucket. Create an AWS Lambda function to automatically rotate the credentials. Use Amazon EventBridge to run the Lambda function on a schedule. Grant the necessary IAM permissions to allow the web servers to retrieve credentials from the S3 bucket.
  • B. Store the credentials in a local file on each of the web servers. Use an AWS KMS key to encrypt the credentials. Create a cron job on each server to rotate the credentials every 30 days.
  • C. Store database credentials in AWS Systems Manager OpsCenter. Grant the necessary IAM permissions to allow the web servers to access OpsCenter.
  • D. Store database credentials in AWS Secrets Manager. Create an AWS Lambda function to automatically rotate the credentials. Use Amazon EventBridge to run the Lambda function on a schedule. Grant the necessary IAM permissions to allow the web servers to access Secrets Manager.
AWS Secrets Manager is a fully managed service specifically designed to securely store and automatically rotate database credentials, API keys, and other secrets. Secrets Manager provides built-in integration with Amazon RDS for automatic credential rotation on a configurable schedule without requiring downtime. It also manages the secure distribution of the credentials to authorized services, such as your web servers, using IAM policies. Manual solutions (S3, files, cron jobs) do not provide the same level of automation, audit, or security.
Reference Extract from AWS Documentation / Study Guide:
"AWS Secrets Manager enables you to rotate, manage, and retrieve database credentials securely. It supports automatic rotation of secrets for supported AWS databases without requiring application downtime." Source: AWS Certified Solutions Architect - Official Study Guide, Security and Secrets Management section.
NEW QUESTION # 283
A company is developing an application to deliver dynamic content to users the globe. The content should to customize according to a user's device and be delivered with very low latency.
Which service should be used?
  • A. Amazon Cloud Front
  • B. Amazon S3
  • C. Amazon API Gateway
  • D. Lamba@Edge
https://aws.amazon.com/cloudfront/dynamic-content/
NEW QUESTION # 284
A company's facility has badge readers at every entrance throughout the building. When badges are scanned, the readers send a message over HTTPS to indicate who attempted to access that particular entrance.
A solutions architect must design a system to process these messages from the sensors. The solution must be highly available, and the results must be made available for the company's security team to analyze.
Which system architecture should the solutions architect recommend?
  • A. Launch an Amazon EC2 instance to serve as the HTTPS endpoint and to process the messages Configure the EC2 instance to save the results to an Amazon S3 bucket.
  • B. Use Amazon Route 53 to direct incoming sensor messages to an AWS Lambda function. Configure the Lambda function to process the messages and save the results to an Amazon DynamoDB table.
  • C. Create a gateway VPC endpoint for Amazon S3. Configure a Site-to-Site VPN connection from the facility network to the VPC so that sensor data can be written directly to an S3 bucket by way of the VPC endpoint.
  • D. Create an HTTPS endpoint in Amazon API Gateway. Configure the API Gateway endpoint to invoke an AWS Lambda function to process the messages and save the results to an Amazon DynamoDB table.
Deploy Amazon API Gateway as an HTTPS endpoint and AWS Lambda to process and save the messages to an Amazon DynamoDB table. This option provides a highly available and scalable solution that can easily handle large amounts of data. It also integrates with other AWS services, making it easier to analyze and visualize the data for the security team.
NEW QUESTION # 285
Free Sample AWS-Solutions-Associate Questions: https://www.examcollectionpass.com/Amazon/AWS-Solutions-Associate-practice-exam-dumps.html
Posted at 2/8/2026 02:15:08        Only Author  2#
Xhs1991ϳ˘I˜ʤؤƤޤ¤SC-100JgHΥפζڵĤԇY}˾ͨƤ댟TҤơˤϤʤ֪R|Ĥ򜺤ȤǤޤޤSC-100JԇYƷ|^Ƥޤꡢ͘˸Ʒ|SC-100Jg̲Ĥṩ뤳Ȥˌ뤳Ȥǡ٤ƤΥƥĤgӛ˲Ƿʲ֤Ǥ뤳Ȥ^Ǥޤ
Posted at 4/19/2026 22:52:41        Only Author  3#
IAPP인증 CIPM시험을 패스하여 자격증을 취득하여 승진이나 이직을 꿈구고 있는 분이신가요? 이 글을 읽게 된다면IAPP인증 CIPM시험패스를 위해 공부자료를 마련하고 싶은 마음이 크다는것을 알고 있어 시장에서 가장 저렴하고 가장 최신버전의 IAPP인증 CIPM덤프자료를 강추해드립니다. 높은 시험패스율을 자랑하고 있는IAPP인증 CIPM덤프는 여러분이 승진으로 향해 달리는 길에 날개를 펼쳐드립니다.자격증을 하루 빨리 취득하여 승진꿈을 이루세요.
