[General] AZ-104 Braindumps, AZ-104 Practice Test, AZ-104 Real Dumps
97
【General】 AZ-104 Braindumps, AZ-104 Practice Test, AZ-104 Real Dumps
Posted at 1/18/2026 17:50:24      View:198 | Replies:3        Print      Only Author   [Copy Link] 1#
What's more, part of that SureTorrent AZ-104 dumps now are free: https://drive.google.com/open?id=1EAWh9O97IxNScGJC0Gl4nevu32TRBKaS
We have three different versions of our AZ-104 exam questions which can cater to different needs of our customers. They are the versions: PDF, Software and APP online. The PDF version of our AZ-104 exam simulation can be printed out, suitable for you who like to take notes, your unique notes may make you more profound. The Software version of our AZ-104 Study Materials can simulate the real exam. Adn the APP online version can be applied to all electronic devices.
Do you have registered for Microsoft AZ-104 exam? With the drawing near of the examination, I still lack of confidence to pass AZ-104 test. Then I have not enough time to read reference books. About the above problem, how should I do? Is there shortcut to pass the exam? Do you have such a mood like that, now? There is no need for hurry. Even if the examination time is near, you are also given the opportunity to prepare for AZ-104 Certification test. And what is the opportunity? It is SureTorrent AZ-104 dumps which is the most effective materials and can help you prepare for the exam in a short period of time. What's more, SureTorrent practice test materials have a high hit rate. 100% satisfaction guarantee! As well as you memorize these questions and answers in our dumps, you must pass Microsoft AZ-104 certification.
100% Pass 2026 Microsoft AZ-104: Microsoft Azure Administrator –Trustable Current Exam ContentWe have tens of thousands of supporters around the world eager to pass the exam with our AZ-104 learning guide which are having a steady increase on the previous years. Exam candidates around the world are longing for learning from our practice materials. If you want to have an outline and brief understanding of our AZ-104 Preparation materials we offer free demos for your reference. You can have a look of our AZ-104 exam questions for realistic testing problems in them.
Microsoft Azure Administrator Sample Questions (Q365-Q370):NEW QUESTION # 365
You have the web apps shown in the following table
You need to monitor the performance and usage of the apps by using Azure Application Insights. The solution must minimize modifications to the application code.
What should you do on each app? To answer, select the appropriate options in the answer area.
Answer in image
NEW QUESTION # 366
You need to recommend a solution for App1. The solution must meet the technical requirements. What should you include in the recommendation? To answer, select the appropriate options in the answer area.
This reference architecture shows how to deploy VMs and a virtual network configured for an N-tier application, using SQL Server on Windows for the data tier.
Scenario: You have a public-facing application named App1. App1 is comprised of the following three tiers:
A SQL database
A web front end
A processing middle tier
Each tier is comprised of five virtual machines. Users access the web front end by using HTTPS only.
Technical requirements include:
Move all the virtual machines for App1 to Azure.
Minimize the number of open ports between the App1 tiers.
References: https://docs.microsoft.com/en-us ... r/n-tier-sql-server
NEW QUESTION # 367
You have the Azure virtual machines shown in the following table.
You have a Recovery Services vault that protects VM1 and VM2.
You need to protect VM3 and VM4 by using Recovery Services.
What should you do first?
  • A. Configure the extensions for VM3 and VM4.
  • B. Create a new Recovery Services vault.
  • C. Create a new backup policy.
  • D. Create a storage account.
A Recovery Services vault is a storage entity in Azure that houses data. The data is typically copies of data, or configuration information for virtual machines (VMs), workloads, servers, or workstations. You can use Recovery Services vaults to hold backup data for various Azure services
NEW QUESTION # 368
You have an Azure subscription that contains the resources shown in the following table.
You need to assign User1 the Storage File Data SMB Share Contributor role for share1. What should you do first?
  • A. Select Default to Azure Active Directory authorization in the Azure portal for storage!.
  • B. Configure Access control (I AM) for share1.
  • C. Modify the security profile for the file shares in storage1.
  • D. Enable identity-based data access for the file shares in storage1.
NEW QUESTION # 369
You have an Azure subscription named Subscription1.
In Subscription1, you create an Azure file share named share1.
You create a shared access signature (SAS) named SAS1 as shown in the following exhibit.
Box 1: Will be prompted for credentials
Azure Storage Explorer is a standalone app that enables you to easily work with Azure Storage data on Windows, macOS, and Linux. It is used for connecting to and managing your Azure storage accounts.
Box 2: Will have read, write, and list access
The net use command is used to connect to file shares.
https://docs.microsoft.com/en-us ... ss-signature-part-1
https://docs.microsoft.com/en-us ... plorer?tabs=windows
NEW QUESTION # 370
As is known to us, a good product is not only reflected in the strict management system, complete quality guarantee system but also the fine pre-sale and after-sale service system. In order to provide the best AZ-104 test training guide for all people, our company already established the integrate quality manage system, before sell serve and promise after sale. If you buy the AZ-104 Exam Dumps from our company, we can make sure that you will have the right to enjoy the 24 hours full-time online service. In order to help the customers solve the problem at any moment, our server staff will be online all the time.
AZ-104 Dumps Download: https://www.suretorrent.com/AZ-104-exam-guide-torrent.html
That's the reason that we created latest AZ-104 pdf torrent and pass guide for our customers, For most office workers who have no enough time to practice AZ-104 Microsoft Azure Administrator exam dump, it is necessary and important to choosing right study materials for preparing their exam, Compared with products from other companies, our AZ-104 practice materials are responsible in every aspect, Our AZ-104 vce dumps constantly get updated according to the changes of exam requirement from the certification center.
Fortunately, I was able to tap my network to find AZ-104 people who were willing to take a chance on me, You can respond to its prompts to set up some essential services, such as creating or signing in to AZ-104 Guaranteed Passing a Google account and Samsung account, configuring your Wi-Fi settings, and adding an email account.
Pass Guaranteed 2026 Reliable Microsoft AZ-104: Current Microsoft Azure Administrator Exam ContentThat's the reason that we created latest AZ-104 Pdf Torrent and pass guide for our customers, For most office workers who have no enough time to practice AZ-104 Microsoft Azure Administrator exam dump, it is necessary and important to choosing right study materials for preparing their exam.
Just choose the best SureTorrent Microsoft Azure Administrator (AZ-104) exam demo questions format and download it quickly.
Posted at 2/1/2026 14:52:13        Only Author  2#
I’m deeply thankful for your article, it really stood out to me. Take advantage of Test aPHRi fee, full of valuable content, available for free.
Posted at 2/6/2026 14:14:45        Only Author  3#
This article is absolutely marvelous, thank you for sharing it with us. I used the AZ-305 new free study questions to get promoted and enjoy a salary raise. Now it’s free for everyone. Wishing you all a smooth promotion journey!
Posted at 2/17/2026 02:52:43        Only Author  4#
I sincerely appreciate your share; the content of the article is truly astounding! I’m sharing Valid C_S4CCO_2506 exam cram review resources for free. Wishing you all the best!
