Perfect EAEP2201 Exam Brain Dumps give you pass-guaranteed Study Materials - Act
Posted at 1/18/2026 19:03:06
P.S. Free 2026 Esri EAEP2201 dumps are available on Google Drive shared by Actual4Dumps: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
We don't just want to make profitable deals, but also to help our users pass the EAEP2201 exams with the least amount of time to get a certificate. Choosing our EAEP2201 exam practice, you only need to spend 20-30 hours to prepare for the exam. Maybe you will ask whether such a short time can finish all the content, we want to tell you that you can rest assured ,because our EAEP2201 Learning Materials are closely related to the exam outline.
Passing the Esri EAEP2201 Exam is a significant achievement that demonstrates a candidate's expertise in managing ArcGIS Enterprise deployments. It is a valuable certification for GIS professionals who wish to advance their careers and take on more challenging roles. Certified professionals can also differentiate themselves in the job market and increase their earning potential. Enterprise Administration Professional 2201 certification is valid for two years, after which candidates must pass a renewal exam to maintain their certification.
Quiz High Hit-Rate EAEP2201 - New Enterprise Administration Professional 2201 Exam ObjectivesHere, the Actual4Dumps empathizes with them for the extreme frustration they undergo due to not finding updated and actual Esri EAEP2201 exam dumps. It helps them by providing the exceptional Esri EAEP2201 Questions to get the prestigious Esri EAEP2201 certificate.
Esri is a leading geospatial technology company that provides innovative solutions to help businesses and organizations make better decisions based on location-based data. One of the ways that Esri ensures that their users have the necessary skills and knowledge to effectively use their software is by offering certification exams. The Esri EAEP2201 (Enterprise Administration Professional 2201) Certification Exam is one such exam that is designed to test the skills and knowledge of individuals responsible for managing and administering ArcGIS Enterprise systems.
Esri Enterprise Administration Professional 2201 Sample Questions (Q53-Q58):NEW QUESTION # 53
A GIS administrator must share an imagery service with another ArcGIS Enterprise. The administrator sets up a distributed collaboration with the other ArcGIS Enterprise and shares the service as a reference. The users in the other organization keep being prompted for credentials.
Which action should the administrator perform?
- A. Save viewer credentials in the collaboration
- B. Set the collaboration workspace to send and receive
- C. Configure the service with anonymous access
- D. Share the image service as a copy
When sharing areferenced servicethrough adistributed collaboration, users accessing the service from the guest organization need valid credentialsunlesscredentials are stored with the item. To prevent repeated credential prompts, the administrator shouldsave credentials with the item when it is shared, particularly for read-only access like viewing imagery.
From the ArcGIS Enterprise documentation on collaborations:
"When sharing services as references across ArcGIS Enterprise organizations, credentials must be stored with the item to ensure seamless access unless the service is public."
* OptionA(sharing as a copy) is an alternative, but it'snot what was asked forand might not be ideal for large imagery.
* OptionC(workspace direction) affects sync behavior, not access control.
* OptionDwould only work if the service is made public, which often isn't acceptable for internal data.
Reference:ArcGIS Enterprise -Distributed Collaborations and Shared Credential Requirements
NEW QUESTION # 54
A client has an internet-accessible ArcGIS Enterprise deployment with the Web Adaptors in the DMZ, and the remaining components are on an internal network behind a firewall. A user on the internet must access a web map in that environment.
Which ports must be open in the firewall between the DMZ and the internal network?
- A. 443 and 6443
- B. 2443 and 6443
- C. 80 and 443
- D. 6443 and 7443
NEW QUESTION # 55
ArcGIS Server is installed with its Web Adaptor on the same server. The configuration is as follows:
* ArcGIS Server is federated with Portal for ArcGIS
* Portal is set up to use Integrated Windows Authentication
* The environment was set up using a domain certificate
* The attempted login account is a Windows account with admin privileges A GIS administrator tries to connect to ArcGIS Server Manager through ArcGIS Web Adaptor but the connection fails. Why did the connection fail?
- A. The Web Adaptor was not set to allow administrative access to the server
- B. The certificate must come from a valid Certificate Authority and not a Domain Certificate Authority
- C. The connection must be made with an internal admin account and not a Windows account
When using aWeb Adaptorto accessArcGIS Server Manager,administrative access must be explicitly enabled during Web Adaptor configuration. If this setting is not enabled, even valid administrator accounts (including Windows accounts with elevated privileges) will be unable to access ArcGIS Server Manager via the Web Adaptor.
This is a common configuration oversight. The federation, IWA setup, and domain certificate are not the causes here. A domain certificate is valid within trusted enterprise networks, and Windows accounts can access services through IWA once configured correctly.
Reference Source:ArcGIS Enterprise documentation - Enabling administrative access for Web Adaptor
NEW QUESTION # 56
A client wants to performincremental webgisdr backupsdaily and full backups weekly. They store all data in therelational ArcGIS Data Store, withno tile or map caches.
Which action is required to enable incremental backups?
- A. Enable point-in-time recovery on ArcGIS Data Store
- B. Increase the heap size of ArcGIS Data Store
- C. Decrease the max connections during backups
To performincremental backupsusing thewebgisdr tool,point-in-time recoverymust be enabled on the relational data store. This creates transaction logs needed for differential backups and aligns with best practices for enterprise-level backup strategies.
From Esri documentation:
"Incremental backups can only be used with a relational data store when point-in-time recovery is enabled.
This enables transaction log capture needed for delta backups."
* OptionAis unrelated to backup functionality.
* OptionCis not required unless performance tuning is needed.
Reference:ArcGIS Enterprise -Enabling Point-in-Time Recovery in ArcGIS Data Store for Incremental Backups
NEW QUESTION # 57
A GIS analyst is running raster analysis in the ArcGIS Enterprise portal Map Viewer. The input data is an image layer, but the output of the raster analysis is a feature layer.
Which ArcGIS Server will host the output feature service?
- A. ArcGIS Raster Analytics Server site
- B. ArcGIS Hosting Server site
- C. ArcGIS Image Hosting Server site
In ArcGIS Enterprise, when performing raster analysis that results in feature data (e.g., vector outputs), the ArcGIS Hosting Serveris responsible for hosting the resulting feature services. The Raster Analytics Server processes the raster data, and the output is then stored in the ArcGIS Data Store associated with the Hosting Server, which subsequently serves the feature layer.
The Image Hosting Server is primarily used for hosting large imagery datasets and does not handle feature services. The Raster Analytics Server conducts the analysis but does not host the output services.
Reference Source:ArcGIS Enterprise documentation on configuring and deploying raster analytics
NEW QUESTION # 58
EAEP2201 Test Collection Pdf: https://www.actual4dumps.com/EAEP2201-study-material.html
- Reliable EAEP2201 Test Tips 🏗 Valid EAEP2201 Exam Format 🔛 Valid EAEP2201 Exam Voucher 🕧 Download ▶ EAEP2201 ◀ for free by simply searching on ( [url]www.torrentvce.com ) 🦹Top EAEP2201 Exam Dumps[/url]
- Demo EAEP2201 Test 🎸 EAEP2201 Free Brain Dumps ⚖ EAEP2201 Pass4sure Dumps Pdf 🍻 Open ➡ [url]www.pdfvce.com ️⬅️ enter 【 EAEP2201 】 and obtain a free download 🧸Demo EAEP2201 Test[/url]
- EAEP2201 Positive Feedback 🚢 EAEP2201 Pass4sure Dumps Pdf 🦐 Technical EAEP2201 Training 🤰 Simply search for { EAEP2201 } for free download on 「 [url]www.examcollectionpass.com 」 🕝Reliable EAEP2201 Test Preparation[/url]
- Top Features of Pdfvce Esri EAEP2201 PDF Dumps File 🥼 Open 【 [url]www.pdfvce.com 】 and search for “ EAEP2201 ” to download exam materials for free ⚡Technical EAEP2201 Training[/url]
- New EAEP2201 Exam Objectives Exam Pass Certify | Esri EAEP2201 Test Collection Pdf 🏖 Copy URL ✔ [url]www.practicevce.com ️✔️ open and search for ▛ EAEP2201 ▟ to download for free 👼Reliable EAEP2201 Test Tips[/url]
- Free PDF Pass-Sure Esri - New EAEP2201 Exam Objectives 💄 Search for 【 EAEP2201 】 and obtain a free download on ▛ [url]www.pdfvce.com ▟ 🌒EAEP2201 Related Certifications[/url]
- EAEP2201 Free Brain Dumps 📊 Demo EAEP2201 Test 🚒 Reliable EAEP2201 Test Tips 🧗 Copy URL ▶ [url]www.testkingpass.com ◀ open and search for ( EAEP2201 ) to download for free 🚌EAEP2201 Exam Answers[/url]
- Esri EAEP2201 PDF Format which has 100% correct answers 🙊 ⮆ [url]www.pdfvce.com ⮄ is best website to obtain 《 EAEP2201 》 for free download 😁EAEP2201 Latest Braindumps[/url]
- Esri New EAEP2201 Exam Objectives - Authorized EAEP2201 Test Collection Pdf and Perfect Instant Enterprise Administration Professional 2201 Download 🚁 Open website 《 [url]www.troytecdumps.com 》 and search for ▷ EAEP2201 ◁ for free download 🏧EAEP2201 Pass4sure Dumps Pdf[/url]
- EAEP2201 Latest Braindumps 👈 EAEP2201 Free Brain Dumps 💍 EAEP2201 Free Brain Dumps 💐 Download ⮆ EAEP2201 ⮄ for free by simply entering ➡ [url]www.pdfvce.com ️⬅️ website 🥣EAEP2201 Related Certifications[/url]
- Pass Guaranteed 2026 Esri Updated New EAEP2201 Exam Objectives 🕚 Immediately open ☀ [url]www.prep4sures.top ️☀️ and search for ➡ EAEP2201 ️⬅️ to obtain a free download 🏊EAEP2201 Guaranteed Success[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, ycs.instructure.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, dl.instructure.com, www.stes.tyc.edu.tw, proborton.org, www.stes.tyc.edu.tw, Disposable vapes
What's more, part of that Actual4Dumps EAEP2201 dumps now are free: https://drive.google.com/open?id=1v-ic4WxhcwgztK7dgji5MSu2-yBvwua3
