最新C-S4EWM-2023考古題,C-S4EWM-2023權威認證
Posted at 1/18/2026 23:02:37
P.S. KaoGuTi在Google Drive上分享了免費的、最新的C-S4EWM-2023考試題庫:https://drive.google.com/open?id=1rML9vqrqy7DAvgg4i6zG3dFb_U1lnUjG
如果你正在為如何通過C-S4EWM-2023考試而煩惱,這是沒有必要,通過最新的考試要點來提供覆蓋率很廣的SAP C-S4EWM-2023擬真試題,幫助考生做好充足的考前準備。KaoGuTi的目的在于如何提供可以確保考生通過認證的高品質題庫,我們的C-S4EWM-2023考試練習題和答案準確性高,問題覆蓋面大,不斷的更新和整編出高通過率的SAP C-S4EWM-2023題庫,這也是我們對所有的考生提供的保障。
SAP C-S4EWM-2023 考試大綱:| 主題 | 簡介 | | 主題 1 | - Inbound Processes (Value Added Services, Cross-docking, Quality Management): This topic includes executing inbound processes with value added services (VAS) or deconsolidation, and setting up deliveries for cross-docking (CD) or quality inspection (QIE).
| | 主題 2 | - Outbound Processes (Wave Management, Cross-docking, Production Integration): This topic covers combining outbound deliveries using wave management, packing and kitting in outbound processes, and staging products for production.
| | 主題 3 | - Warehouse Processing, Warehouse Task and Order Creation, Strategies: This topic includes defining warehouse process types and setting up determination, as well as defining putaway and picking strategies.
| | 主題 4 | - Internal processing (Physical Inventory, Replenishment): This topic involves defining physical inventory processes and setting up and executing replenishment.
| | 主題 5 | - Cross Topics (Labor Management, Exception Handling, Batches, Serial Numbers): This topic includes setting up labor management and exception handling, and working with additional product information.
| | 主題 6 | - System Integration, Master Data and Delivery Document Customizing: This focuses on setting up system integration, distributing master data, and customizing delivery documents.
C-S4EWM-2023權威認證 - C-S4EWM-2023通過考試怎樣才能確保我們的生活可更快的得到改善?你需要通過C-S4EWM-2023認證考試,獲得證書。而KaoGuTi是IT專業人士的最佳選擇,獲得C-S4EWM-2023認證是IT職業發展的有力保證,我們高品質的題庫能幫助你做到這一點。C-S4EWM-2023考試題庫也會不定期的更新,為你提供最有效的學習資料。使用我們的C-S4EWM-2023考試題庫進行考前復習,可以節約你大量的學習時間和費用,這是最適合獲得C-S4EWM-2023認證的所必須的學習資料。
最新的 SAP Certified Associate C-S4EWM-2023 免費考試真題 (Q68-Q73):問題 #68
For which processes can you create a direct outbound delivery order? Note: There are 3 correct answers to this question.
- A. Direct sales
- B. Inventory difference
- C. Scrapping
- D. Replenishment
- E. Issue to cost center
答案:A,C,E
解題說明:
A direct outbound delivery order is created for scenarios where goods are directly moved out of the warehouse without standard intermediate steps. The applicable processes include:
* A. Scrapping:
* Used to dispose of damaged or obsolete stock directly from the warehouse.
* D. Issue to Cost Center:
* Materials issued for internal consumption or to a specific cost center.
* E. Direct Sales:
* Goods sold directly from the warehouse to customers, bypassing typical outbound processing.
Incorrect Options:
* B: Replenishment involves internal movements and does not create outbound delivery orders.
* C: Inventory differences are adjusted during inventory procedures, not via outbound deliveries.
* SAP Help Portal: Direct Outbound Delivery Order Scenarios
* SAP EWM Documentation: Outbound Delivery Order Processing
問題 #69
Which of the following are product warehouse tasks during putaway with process-oriented storage control?
- A. All process steps
- B. The final process step
- C. The first process step
- D. The first and final process steps
答案:D
解題說明:
Comprehensive and Detailed In-Depth Explanation:
In process-oriented storage control (POSC) for putaway, warehouse tasks are created for specific steps.
Option D ("The first and final process steps") is correct because tasks are generated for the initial step (e.g., unloading) and the final step (e.g., putaway to bin), as defined in the storage process configuration in SPRO:
SCM Extended Warehouse Management > Cross-Process Settings > Process-Oriented Storage Control.
Option A (all steps) includes intermediate steps not always task-based, while B and C are too restrictive.
問題 #70
What do you control with the business context for an exception code.?
- A. The internal exception code that is assigned to it
- B. The user groups that can use the exception code
- C. The work environment in which you can use the exception code
- D. The process that can use the exception code
答案:D
問題 #71
Your customer wants to implement the material flow system (MFS) to control conveyors and the automated high rack storage are a. Which standard options do you have to communicate with the programmable logic controllers (PLC)? Note: There are 2 correct answers to this question.
- A. Use an RFC adaptor (e.g., SAP Plant Connectivity)
- B. Send an IDoc through a Post Processing Framework action to the PLC
- C. Directly integrate to the PLC using ABAP Push Channels
- D. Use the ALE interface to send an IDoc to a 3rd party software
答案:A,C
解題說明:
The Material Flow System (MFS) in SAP EWM integrates with PLCs for automation. Option B ("Directly integrate to the PLC using ABAP Push Channels") is correct as it enables real-time communication via WebSockets, configured in SPRO: SCM Extended Warehouse Management > Material Flow System > Communication. Option D ("Use an RFC adaptor (e.g., SAP Plant Connectivity)") is correct because SAP Plant Connectivity (PCo) uses RFC to connect EWM to PLCs. Option A (ALE/IDoc) and option C (PPF/IDoc) are not standard for direct PLC communication; they're more suited for system-to-system data exchange.
問題 #72
Which of the following can you use to explore released APIs?
- A. SAP Business Accelerator Hub
- B. SAP Integration Suite
- C. SAP Application Interface Framework
答案:A
解題說明:
SAP provides tools to explore released APIs, particularly for integration with SAP S/4HANA and EWM.
Option A ("SAP Business Accelerator Hub") is correct because it is the official platform (previously known as SAP API Business Hub) where developers can discover, explore, and test SAP-released APIs, including those for EWM. It provides detailed documentation and sandbox environments, accessible via SAP's public portal. Option B ("SAP Application Interface Framework") is used for monitoring and managing interfaces, not exploring APIs. Option C ("SAP Integration Suite") is a tool for building integrations, not specifically for API exploration.
問題 #73
SAP 的 C-S4EWM-2023 考古題是從Prometric或VUE考試中心取得的最新原始考題,由資深講師和技術專家精心打造的完美產品,保證了 C-S4EWM-2023 產品的高品質和真實性。已經幫助很多考生成功通過考試,擁有了KaoGuTi C-S4EWM-2023 考題您就可以實現理想,適合全球考生都能通用的模擬試題。因為最新的 C-S4EWM-2023 擬真試題可以為你的複習和看書減輕很多的煩惱。
C-S4EWM-2023權威認證: https://www.kaoguti.com/C-S4EWM-2023_exam-pdf.html
- 高質量的最新C-S4EWM-2023考古題,最有效的學習資料幫助妳快速通過C-S4EWM-2023考試 📭 ➡ [url]www.vcesoft.com ️⬅️最新⇛ C-S4EWM-2023 ⇚問題集合C-S4EWM-2023測試[/url]
- 高質量的最新C-S4EWM-2023考古題,免費下載C-S4EWM-2023考試指南得到妳想要的SAP證書 🤚 透過➡ [url]www.newdumpspdf.com ️⬅️輕鬆獲取➥ C-S4EWM-2023 🡄免費下載C-S4EWM-2023考試大綱[/url]
- 100%合格率最新C-S4EWM-2023考古題&資格考試領導者和精心準備的SAP SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management 🔌 ⇛ [url]www.newdumpspdf.com ⇚上的《 C-S4EWM-2023 》免費下載只需搜尋免費下載C-S4EWM-2023考題[/url]
- 高質量的最新C-S4EWM-2023考古題,覆蓋全真SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management C-S4EWM-2023考試考題 🥣 ▷ [url]www.newdumpspdf.com ◁是獲取▷ C-S4EWM-2023 ◁免費下載的最佳網站C-S4EWM-2023在線題庫[/url]
- C-S4EWM-2023測試 👇 C-S4EWM-2023證照考試 🎆 C-S4EWM-2023考題寶典 🛴 立即到{ [url]www.pdfexamdumps.com }上搜索▶ C-S4EWM-2023 ◀以獲取免費下載C-S4EWM-2023證照[/url]
- 覆蓋全面的最新C-S4EWM-2023考古題 |第一次嘗試輕鬆學習並通過考試和最佳的C-S4EWM-2023權威認證 🏵 [ [url]www.newdumpspdf.com ]上的【 C-S4EWM-2023 】免費下載只需搜尋C-S4EWM-2023考古題更新[/url]
- 高質量的最新C-S4EWM-2023考古題,免費下載C-S4EWM-2023考試資料幫助妳通過C-S4EWM-2023考試 🖊 立即在➡ [url]www.newdumpspdf.com ️⬅️上搜尋{ C-S4EWM-2023 }並免費下載C-S4EWM-2023考古題更新[/url]
- C-S4EWM-2023最新試題 🥗 C-S4EWM-2023 PDF題庫 🌕 C-S4EWM-2023考試大綱 😀 在➥ [url]www.newdumpspdf.com 🡄網站下載免費⇛ C-S4EWM-2023 ⇚題庫收集C-S4EWM-2023證照考試[/url]
- SAP 最新C-S4EWM-2023考古題:SAP Certified Associate - SAP S/4HANA Cloud Private Edition, Extended Warehouse Management考試最新發布|更新的C-S4EWM-2023權威認證 🍟 在“ [url]www.vcesoft.com ”上搜索☀ C-S4EWM-2023 ️☀️並獲取免費下載C-S4EWM-2023考試重點[/url]
- C-S4EWM-2023測試引擎 🍘 C-S4EWM-2023信息資訊 📈 免費下載C-S4EWM-2023考題 ☁ 立即到➡ [url]www.newdumpspdf.com ️⬅️上搜索▛ C-S4EWM-2023 ▟以獲取免費下載C-S4EWM-2023認證題庫[/url]
- C-S4EWM-2023考試大綱 🔰 C-S4EWM-2023測試引擎 🧉 C-S4EWM-2023信息資訊 🎸 複製網址{ [url]www.newdumpspdf.com }打開並搜索《 C-S4EWM-2023 》免費下載C-S4EWM-2023認證考試解析[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, github.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
BONUS!!! 免費下載KaoGuTi C-S4EWM-2023考試題庫的完整版:https://drive.google.com/open?id=1rML9vqrqy7DAvgg4i6zG3dFb_U1lnUjG
