[General] Order-Management-Administrator Pdf Exam Dump, Order-Management-Administrator Val
105
General Order-Management-Administrator Pdf Exam Dump, Order-Management-Administrator Val
Posted at 1/18/2026 23:23:45      View161 | Replies4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of DumpsValid Order-Management-Administrator dumps for free: https://drive.google.com/open?id=1vq0EJwAY3Az3Dc0lSP-MnlpYoZwU1iXU
It is evident to all that the Order-Management-Administrator test torrent from our company has a high quality all the time. A lot of people who have bought our products can agree that our Order-Management-Administrator test questions are very useful for them to get the certification. There have been 99 percent people used our Order-Management-Administrator Exam Prep that have passed their exam and get the certification. It means that our Order-Management-Administrator test questions are very useful for all people to achieve their dreams, and the high quality of our Order-Management-Administrator exam prep is one insurmountable problem.
Salesforce Order-Management-Administrator Exam Syllabus Topics:
  • Order Management Basics: In this topic, the Salesforce Order Management Administrator Consultant learns to position Order Management effectively within Salesforce's core architecture. By articulating the extensible platform capabilities, the ability to integrate with third-party systems, and the overall value proposition, this knowledge helps highlight Order Management's seamless adaptability and efficiency. These insights are crucial for demonstrating business value during client engagements.
  • Deployment and Debugging: In this area, aspiring order management administrator consultant demonstrates a deep understanding of deployment options, life cycles, and the configuration of supporting objects. This includes creating processes from scratch, leveraging pre-set data, and validating results in runtime scenarios.
  • Process Automation and Integrations: This section helps the Salesforce Order Management Administrator Consultant demonstrate the capability to deliver business value by integrating Order Management with external systems using clicks rather than code. Mastery of navigation within Order Management processes, connecting nodes, and integrating systems efficiently ensures understanding of how to implement effective solutions.
Order-Management-Administrator Valid Test Voucher & New Order-Management-Administrator Test ForumThe second format of Salesforce Order-Management-Administrator exam preparation material is the web-based Salesforce Order Management Administrator Accredited Professional (Order-Management-Administrator) practice test. It is useful for the ones who prefer to study online. DumpsValid have made this format so that users don't face the hassles of installing software while preparing for the Salesforce Order Management Administrator Accredited Professional (Order-Management-Administrator) certification. The customizable feature of this format allows you to adjust the settings of Salesforce Order Management Administrator Accredited Professional (Order-Management-Administrator) practice exams.
Salesforce Order Management Administrator Accredited Professional Sample Questions (Q104-Q109):NEW QUESTION # 104
An administrator suspects that recent changes to a flow have created a defect. The administrator wants to test the flow with input data that they believe will cause the error. What can the developer do next?
  • A. Open the Flow and selectAttach to Live Session and Provide the Order Number
  • B. Open theFlow and select Attach to Live Session. Provide the Session Id. Select Attach
  • C. Open the Flow, Select Debug with inputs. Provide the input values, select Run
  • D. Open the Flow, Select Debug, Provide the input values, Select Run
NEW QUESTION # 105
What three steps are required when deploying changes via change sets?
  • A. Create the change set in the sandbox org
  • B. Upload the change set to the target org
  • C. Approve the change set in the sandbox org
  • D. Deploy the change set in the target org
  • E. Add the change set to the release schedule in the target org
Answer: A,B,D
Three steps that are required when deploying changes via change sets are:
Create the change set in the sandbox org. This is the first step where the administrator selects the metadata components that they want to deploy and adds them to a change set in the source org, which is usually a sandbox org.
Upload the change set to the target org. This is the second step where the administrator sends the change set from the source org to the destination org, which is usually a production org or another sandbox org. The administrator needs to have a deployment connection with the target org and permission to upload change sets.
Deploy the change set in the target org. This is the final step where the administrator validates and deploys the change set in the destination org. The administrator needs to have permission to deploy change sets and resolve any deployment errors or warnings.
Verified Reference: https://help.salesforce.com/s/ar ... ound.htm&type=5 https://help.salesforce.com/s/ar ... ploy.htm&type=5
NEW QUESTION # 106
Which two practices ate needed for a custom attribute to map into Order Management assuming the attribute has been created on the necessary objects?
  • A. The types must match within reason
  • B. The names must only contain letters and underscores
  • C. The types must be an exact match (i.e. String to String)
  • D. The names must be an exact match
Two practices that are needed for a custom attribute to map into Order Management assuming the attribute has been created on the necessary objects are:
The types must match within reason. The data type of the custom attribute in Order Management must match or be compatible with the data type of the corresponding attribute in the external system, such as B2C Commerce or B2B Commerce. For example, if the attribute is a string in B2C Commerce, it must also be a string in Order Management.
The names must be an exact match. The name of the custom attribute in Order Management must be exactly the same as the name of the corresponding attribute in the external system, including capitalization and punctuation. For example, if the attribute is named "kitItem" in B2C Commerce, it must also be named "kitItem" in Order Management.
Verified Reference: https://documentation.b2c.commer ... stomAttributes.html
NEW QUESTION # 107
What are three tools that can be used to deploy changes to a Salesforce Org?
Choose 3 answers
  • A. Developer Console
  • B. Change Sets
  • C. Salesforce Pull Requests
  • D. Ant Migration Tool
  • E. Release Manager
Answer: A,B,D
NEW QUESTION # 108
Which practice should an admin consider when working with the Ensure Funds Async action?
  • A. The invoice object should be cloned to a custom object before calling the action
  • B. The Invoice ID should be logged before passing it to the Ensure Funds Async action
  • C. The invoice object should be logged and cloned to a custom object before calling the action
  • D. The invoice ID should be assigned somewhere in the flow before calling the action
The Ensure Funds Async action requires the invoice ID as an input parameter. The action checks if there are enough funds available for the invoice and updates the invoice status accordingly. The invoice ID should be assigned somewhere in the flow before calling the action, otherwise the action will fail. Reference: Salesforce Payments and Order Management
NEW QUESTION # 109
DumpsValid provides you with actual Salesforce Order-Management-Administrator dumps in PDF format, Desktop-Based Practice tests, and Web-based Practice exams. These 3 formats of Salesforce Order Management Administrator Accredited Professional exam preparation are easy to use. This is a printable Salesforce Order-Management-Administrator PDF dumps file. The Salesforce Order-Management-Administrator Pdf Dumps enables you to study without any device, as it is a portable and easily shareable format, thus you can study Salesforce Order-Management-Administrator dumps on your preferred smart device such as your smartphone or in hard copy format.
Order-Management-Administrator Valid Test Voucher: https://www.dumpsvalid.com/Order-Management-Administrator-still-valid-exam.html
Posted at 1/19/2026 11:30:08        Only Author  2#
Thank you for the article; it really piqued my interest. Wish me luck as Im getting ready to take the 156-536 formal test exam!
Posted at 1/22/2026 06:19:24        Only Author  3#
Thank you for your brilliant article, it truly left me in awe! Free OGBA-101 reliable exam materials shared for enhancing your IT skills. Wishing you success in your journey!
Posted at 1/23/2026 16:18:43        Only Author  4#
Your article is truly stunning; I appreciate your sharing! I earned a promotion and salary increase using this Test COF-C02 questions pdf. Now, Im sharing it for free. Wishing you success in your career progress!
Posted at 1/27/2026 10:39:19        Only Author  5#
I am still in awe after reading your article, thank you for sharing! F5CAB1 reliable exam camp file test papers shared for freeget them now to boost your career!
