已通過驗證有用的Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant認證考試是由Salesfor
84
Posted at 1/19/2026 02:03:51      View:105 | Replies:2        Print      Only Author   [Copy Link] 1#
通過Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant 認證考試的方法有很多種,花大量時間和精力來復習Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant 認證考試相關的專業知識是一種方法,通過少量時間和金錢選擇使用Fast2test的針對性訓練和練習題也是一種方法。
Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant 考試大綱:
主題簡介
主題 1
  • Analytics Dashboard Design: Building upon the design foundation, this section challenges candidates to bring their dashboard designs to life. It covers the technical expertise required to scope, validate, and prioritize dashboard design requirements.
主題 2
  • Einstein Discovery: This section unveils the magic of AI-driven insights and candidates' ability to analyze and choose one of the three types of predictions. It involves leveraging Einstein's advanced analytics capabilities to adjust data parameters, add or remove data and columns for the improvement of the model.
主題 3
  • Admin
  • Configuration: This topic takes Salesforce consultants on a journey through the enablement of CRM Analytics. It tests their ability to design a solution that is suitable for data sync
  • dataflows
  • recipe limits.
主題 4
  • Security: Consultants stepping into this section will showcase their prowess in implementing necessary security settings. It covers critical aspects such as suitable dataset security settings, and the ability to implement app sharing.
Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant真題材料 - CRM-Analytics-and-Einstein-Discovery-Consultant認證題庫想更好更快的通過Salesforce的CRM-Analytics-and-Einstein-Discovery-Consultant考試嗎?快快選擇我們Fast2test吧!它可以迅速的完成你的夢想。我們Fast2test是一個為多種IT認證考試的人,提供準確的考試材料的網站,我們Fast2test是一個可以為很多IT人士提升自己的職業藍圖,我們的力量會讓你難以置信。你可以先嘗試我們Fast2test為你們提供的免費下載關於Salesforce的CRM-Analytics-and-Einstein-Discovery-Consultant考試的部分考題及答案,檢測我們的可靠性。
最新的 Salesforce Consultant CRM-Analytics-and-Einstein-Discovery-Consultant 免費考試真題 (Q94-Q99):問題 #94
What is a benefit of introducing a second local connector?
  • A. Better deployment management between sandboxes and production environment
  • B. Better maintenance by having a connector per recipe
  • C. Better performance by syncing data according to the refresh necessities
答案:C
解題說明:
Introducing a second local connector in CRM Analytics can improve performance by enabling more granular control over data syncs. By having a separate connector, different datasets or recipes can be synchronized independently based on specific refresh needs, reducing load and improving overall performance. This approach helps optimize data flow operations, especially in large-scale deployments with varying data refresh requirements.
問題 #95
Max number of dataflow definitions (with data sync enabled)
  • A. 0
  • B. 1
  • C. 2
  • D. 3
答案:B
問題 #96
Which of the following is true about the Service Analytics Overview dashboard?
  • A. All of the above.
  • B. It's a great place to start your analysis.
  • C. It lets you drill down to more detailed dashboards, like agent performance, channel review, and telephony metrics.
  • D. It's available on desktop and mobile.
  • E. It instantly provides key metrics on open cases, average time to close, first contact resolution, and customer satisfaction.
答案:A
問題 #97
A CRM Analytics consultant has enabled data sync manually in an org that uses dataflows/recipes. The client says that the dataflow/recipe fails each time it starts running.
What is causing the dataflow/recipe to fail?
  • A. Dataflowsysrecipes with computeExpression nodes fail until syne has run for the first time.
  • B. Dataflows/recipes with sfdcDigest nodes fail until sync has run for the first time.
  • C. Dataflows/recipes with Augment nodes fail until sync has run for the first time.
答案:B
問題 #98
Universal Containers has a single dataset that contains the attainment and commission fields for all sales reps.
Each sales rep should be able view the attainment data for each rep in their division. Each repshould only be able to see their own commission data.
Which option should a CRM Analytics consultant use to enforce this requirement?
  • A. Create separate datasets for attainment and commission, and apply security Predicates and/or sharing inheritance.
  • B. Add the sales organization to the attainment dataset access list to be able to view commission data.
  • C. Utilize a single dataset and apply security predicates and/or sharing inheritance.
答案:A
問題 #99
Fast2test提供的培訓工具包含關於Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant認證考試的學習資料及類比訓練題,更重要的是還會給出跟考試很接近的練習題和答案。選擇Fast2test可以保證你可以在短時間內學習及加強IT專業方面的知識,還可以以高分數通過Salesforce CRM-Analytics-and-Einstein-Discovery-Consultant的認證考試。
CRM-Analytics-and-Einstein-Discovery-Consultant真題材料: https://tw.fast2test.com/CRM-Analytics-and-Einstein-Discovery-Consultant-premium-file.html
Posted at 2/10/2026 02:48:21        Only Author  2#
What an outstanding piece of writing, I truly appreciate your sharing. This 200-201 latest dumps book helped me get a promotion and salary increase. Now it’s free to all. Hope you achieve your career goals!
Posted at 2/19/2026 20:08:38        Only Author  3#
What a remarkable piece of writing, thank you for sharing this with us! AZ-400 valid exam duration provides helpful, in-depth content, offered free for your academic needs.
