[General] Reinstall OS onto the board
17
General Reinstall OS onto the board
Posted at 6/23/2023 06:01:31      View3986 | Replies7        Print      Only Author   [Copy Link] 1#
Hi guys,
I am new to the board overall. The board I got had debian installed on it. I am trying to reinstall OS / upgrade firmware.
Upon following the instructions on the fire fly website, I was able to detect my board on RKDevTool on windows. It states that the device is in loader mode. I was able to use "upgrade firmware" tab and the firmware I downloaded from the resouce page. All updated fine, but after that, when I tried to boot up, it would not. I reconnected the device to my PC and see that it is still in loader mode.
Is it not supposed to first try boot into normal mode unless  otherwise? I tried other firmwares downloaded from the resource page with no luck. Also have tried to erase and then upgrade the firmware again, also with no luck.
I then tried to read "dev partition" in RKDevTool and noticed that no matching partition for "Loader", "Parameter", "trsut", "Resource", "Kernel" and "System".
I am trying to find out what firmware and/or image I should use for upgrade. ANY help would be appreciated. Please let me know if more info is required.
Thanks!
Screenshot 2023-06-22 145931.zip
78.53 KB, Down times: 1
super moderator
Rank: 8Rank: 8
Posted at 6/25/2023 11:09:29        Only Author  2#
What firmware is used? Please provide the firmware name. And provide the burn writing steps.
Posted at 5/17/2025 20:31:01        Only Author  3#
Make sure youre using the correct firmware that matches your board version, and double-check that the firmware package includes all necessary components like parameter, trust, boot, system, etc.
Try this:
Use RKDevTool to Erase Flash completely.
Then use the Download Image tab (not just "Upgrade Firmware") with a full .img file if availablethis tends to be more reliable.
If you're using a split image with multiple files (like boot.img, system.img, etc.), make sure the parameter.txt matches the partition layout.  backyard baseball
After flashing, disconnect power completely, wait a few seconds, then reboot.
Posted at 8/7/2025 17:55:44        Only Author  4#
Right? bitlife unblocked is the open-access version of the massively popular life simulation
Posted at 1/12/2026 15:50:12        Only Author  5#
The content of the article is detailed, and Ive learned many useful things. AZ-700 valid test guide files offers rich material, available for free to support your learning goals.
Posted at 1/13/2026 12:27:49        Only Author  6#
This article is absolutely top-tier, thank you for sharing. I hope the Valid ADX261 vce exam simulator content helps you, and it's totally free.
restricted members
Posted at 1/14/2026 19:22:03        Only Author  7#
Japancertä礯FortinetNSE5_SSE_AD-7.6J^ԇY˺ϸ񤵤륵ȤǡFortinetNSE5_SSE_AD-7.6J^ԇYˤĤƤΆ}Јˤɤɤ󜥤ƤޤʤޤT֪Rg^Ƥޤ˲ĤǡJapancertFortinetNSE5_SSE_AD-7.6JԇYˤĤ¤ԇY}ˤäȤƤޤ衣
Posted at 1/29/2026 02:43:48        Only Author  8#
Microsoft GH-900 Unterlagen von ZertSoft sind besser als andere entsprechende Unterlagen fr Microsoft GH-900 Prfung, weil sie einmaligen Erfolg der Prfung gewährleisten. Die hohe Durchlaufrate sind von vielen Kadidaten geprft. Microsoft GH-900 Dumps von ZertSoft sind der erfolgsreiche Weg. Sie können viel Zeit fr die Vorbereitung der GH-900 Prfung sparen und auch mit guter Note die GH-900 Zertifizierungsprfung machen.
