[Linux] Raspberry PI camera (B) rev2.0 connectivity
29
Linux Raspberry PI camera (B) rev2.0 connectivity
Posted at 6/26/2023 18:50:32      View2907 | Replies7        Print      Only Author   [Copy Link] 1#
Kinda stuck with the raspberry camera module. I've connected camera module using ADP-Tfirefly board and there is no reason to doubt the connection, cuz power levels on the pins of the camera module seems correct and I can see connected device on the 7th bus using i2cdetect command. But my platform can't find /dev/video0 or any device besides /dev/media0. I've alredy tried to start video stream with gst-launch-1.0 command and raspivid command, but both did not work (raspivid indicates that it failed to open the vchiq). Is there anyone with similar problem?
kern.zip
317 Bytes, Down times: 1
Posted at 6/26/2023 21:24:00        Only Author  2#
Ok, so OV5647 is not set in configuration file. Is there any way to connect OV5647 sensor to roc-rk3588s-pc?
Posted at 3/11/2025 15:33:02        Only Author  3#
I have the same sprunki modded question.
Posted at 1/10/2026 04:45:24        Only Author  4#
Your article is truly amazing, I appreciate you sharing it. Im sharing the C_BCBAI_2509 valid study questions pdf questions that helped me achieve my promotion and salary increasefor free!
Posted at 1/11/2026 06:04:18        Only Author  5#
ُISalesforceAP-214WָϾϷգN҂KaoGuTiI춴ĿĵľWվ֮һվṩõƷ|µӖYϣ҂WվṩɵеČWYϼӖY϶ǷϳɱЧģھWվһMOʩ@ЩӖaƷ]Ўͨ^ԇ҂C߀ȫُIMá
Posted at 1/11/2026 23:08:47        Only Author  6#
This article is brilliant, thank you for this incredible share. AE-Adult-Echocardiography valid test online is rich with helpful content, offered free to aid your learning.
Posted at 1/26/2026 09:00:26        Only Author  7#
I appreciate your article, it was so refreshing and insightful. I believe the Reliable AP-207 exam bootcamp content will be helpful, and it's totally free for you.
Posted at 2/6/2026 00:28:01        Only Author  8#
Im amazed by this article, thank you for sharing it. Upgrade your IT skills by downloading free C-S4CS-2508 reliable exam questions answers. Best of luck!
