[General] Testking F5CAB5 Exam Questions & Online F5CAB5 Bootcamps
108
【General】 Testking F5CAB5 Exam Questions & Online F5CAB5 Bootcamps
Posted at 1/19/2026 05:45:42      View:107 | Replies:1        Print      Only Author   [Copy Link] 1#
There are rare products which can rival with our products and enjoy the high recognition and trust by the clients like our products. Our products provide the F5CAB5 study materials to clients and help they pass the test F5CAB5 certification which is highly authorized and valuable. Our company is a famous company which bears the world-wide influences and our F5CAB5 Study Materials are recognized as the most representative and advanced study materials among the same kinds of products.
Just the same as the free demo, we have provided three kinds of versions of our F5 F5CAB5 preparation exam, among which the PDF version is the most popular one. It is understandable that many people give their priority to use paper-based F5CAB5 Materials rather than learning on computers, and it is quite clear that the PDF version is convenient for our customers to read and print the contents in our BIG-IP Administration Support and Troubleshooting F5CAB5 study guide.
Online F5CAB5 Bootcamps - Certification F5CAB5 TorrentActual4Dumps experts have also developed BIG-IP Administration Support and Troubleshooting (F5CAB5) test simulation software for you to assess and improve yourself. This is especially useful for intensive preparation and revision. It will provide you with an BIG-IP Administration Support and Troubleshooting (F5CAB5) exam environment and will give you real exam F5 F5CAB5 questions.
F5 BIG-IP Administration Support and Troubleshooting Sample Questions (Q21-Q26):NEW QUESTION # 21
An organization is reporting slow performance accessing their Intranet website, hosted in a public cloud. All employees use a single Proxy Server with the public IP of 104.219.110.168 to connect to the Internet. What should the BIG-IP Administrator of the Intranet website do to fix this issue?
  • A. Change Source Address to 104.219.110.168/32
  • B. Change Load Balancing Method to Least Connection
  • C. Change Fallback Persistence Profile to source_addr
  • D. Change Default Persistence Profile to cookie
This scenario describes a classic network performance issue known as the "Mega-Proxy" problem. When an organization routes all employee traffic through a single proxy server, the BIG-IP sees thousands of unique users as having the exact same source IP address. If the administrator has configured "Source Address Affinity" persistence, the BIG-IP will correctly follow the rule but incorrectly route all users to the same single backend pool member. This creates a severe load imbalance where one server is overwhelmed while others remain idle, leading to poor application response times. To resolve this, the administrator must change the persistence profile to "HTTP Cookie". Cookie-based persistence allows the BIG-IP to place a unique identifier in each user's browser, allowing the system to distinguish between individual sessions even if they share the same source IP. This fix ensures that traffic is distributed evenly across the pool members, restoring4 the expect5ed load balancing functionality and resolving the slow performance reported by users behind the corporate proxy.
NEW QUESTION # 22
A BIG-IP Administrator needs to deploy an application on the BIG-IP system to perform SSL offload and re-encrypt the traffic to pool members. During testing, users are unable to connect to the application.
What must the BIG-IP Administrator do to resolve the issue? (Choose one answer)
  • A. Enable Forward Proxy in the SSL Profile (Client)
  • B. Configure an SSL Profile (Server)
  • C. Remove the configured SSL Profile (Client)
  • D. Configure Protocol Profile (Server) as splitsession-default-tcp
To successfully perform SSL offload and re-encryption on a BIG-IP system, the virtual server must be configured with both a Client SSL profile and a Server SSL profile. The Client SSL profile enables BIG-IP to decrypt inbound HTTPS traffic from clients, while the Server SSL profile is required to re-encrypt traffic before forwarding it to the pool members.
From the exhibit, the virtual server has a Client SSL profile configured, which allows BIG-IP to accept HTTPS connections from clients. However, there is no Server SSL profile attached, meaning BIG-IP attempts to send unencrypted HTTP traffic to pool members listening on HTTPS (port 443). This protocol mismatch causes the server-side SSL handshake to fail, resulting in users being unable to connect to the application.
This behavior is well documented in BIG-IP SSL troubleshooting guides: when backend servers expect HTTPS, a Server SSL profile is mandatory to establish a secure connection from BIG-IP to the pool members.
The other options are incorrect:
Removing the Client SSL profile (Option A) would break client-side HTTPS.
The server-side TCP profile (Option B) is unrelated to SSL encryption.
Forward Proxy (Option C) is only used for outbound SSL inspection scenarios.
Therefore, configuring an SSL Profile (Server) is the correct and required solution.
NEW QUESTION # 23
A BIG-IP Administrator observes the following pool member status message:
Pool /Common/testpool member /Common/10.120.0.5:8090 monitor status down
[/Common/http: up, /Common/http2: down; last error:]
Why is this pool member being marked down? (Choose one answer)
  • A. The pool member is currently only serving HTTPS traffic.
  • B. The pool member is currently only serving UDP traffic.
  • C. The pool member is currently only serving HTTP traffic.
  • D. The pool member is currently only serving TCP traffic.
The pool member is marked DOWN because it is monitored by multiple health monitors, specifically an HTTP monitor and an HTTP/2 monitor. The status message clearly shows that the HTTP monitor is UP, while the HTTP/2 monitor is DOWN. In BIG-IP, when multiple monitors are assigned to a pool member, the default behavior is AND logic, meaning all assigned monitors must succeed for the pool member to be considered healthy.
In this scenario, the server is responding successfully to standard HTTP (likely HTTP/1.1) requests but does not support or respond correctly to HTTP/2 requests. As a result, the HTTP/2 monitor fails, which causes the overall monitor status to be DOWN, even though HTTP traffic itself is working.
This behavior is expected and documented in BIG-IP monitoring logic. Unless the monitor rule is explicitly changed to "at least one of", a single failing monitor will mark the pool member down. Therefore, the correct conclusion is that the pool member is only serving HTTP traffic, not HTTP/2.
The resolution would be to either remove the HTTP/2 monitor, correct the application to support HTTP/2, or adjust the monitor rule to match the intended health-check logic.
NEW QUESTION # 24
A BIG-IP Administrator is informed that traffic on Interface 1.1 is expected to increase over the maximum bandwidth capacity on the link. There is a single VLAN on the Interface. What should the BIG-IP Administrator do to increase the total available bandwidth?
  • A. Increase the MTU on the VLAN using Interface 1.1
  • B. Create a trunk object with two Interfaces
  • C. Assign two Interfaces to the VLAN
  • D. Set the media speed of Interface 1.1 manually
When a physical network link (like Interface 1.1) reaches its maximum capacity, it creates a bottleneck that negatively impacts network-level performance. To overcome the physical limits of a single interface, BIG-IP administrators use "Trunking," which is the F5 term for Link Aggregation (often implemented via LACP). A trunk object bundles multiple physical interfaces into a single logical link. By creating a trunk with two or more interfaces, the BIG-IP can spread the traffic load across all members of the trunk, effectively doubling or tripling the available bandwidth for the associated VLANs. Beyond performance, troubleshooting redundancy often leads to the use of trunks; if one cable in a trunk fails, the others continue to carry traffic, preventing a complete outage. This is a superior solution to simply increasing MTU (which requires end-to-end support) or manually setting media speeds. In a high-availability environment, configuring trunks is a foundational troubleshooting and optimization step to ensure that traffic spikes do not result in packet loss due to link saturation.
NEW QUESTION # 25
Users report that traffic is negatively affected every time a BIG-IP device fails over. The traffic becomes stabilized after a few minutes. What should the BIG-IP Administrator do to reduce the impact of future failovers?
  • A. Set up Failover Method to HA Order
  • B. Enable Failover Multicast Configuration
  • C. Configure a global SNAT Listener
  • D. Configure MAC Masquerade
When traffic "stabilizes after a few minutes" following a failover, it points to a network-level performance issue involving ARP cache on upstream routers and switches. Each BIG-IP interface has a unique hardware MAC address. During failover, the Standby device takes over the floating IP address, but the upstream switch still associates that IP with the MAC of the now-offline device. Traffic is lost until the switch learns the new MAC or its ARP entry expires. "MAC Masquerading" solves this by creating a shared, virtual MAC address for the floating traffic group. This virtual MAC is used by whichever device is currently active. Because the MAC address for the virtual server IP never changes from the perspective of the network, the upstream devices do not need to update their ARP tables. This troubleshooting solution eliminates the delay associated with failover, providing a seamless transition and ensuring that application traffic flow is not disrupted when the BIG-IP HA state changes.
NEW QUESTION # 26
If you are one of such frustrated candidates, don't get panic. Actual4Dumps declares its services in providing the real F5CAB5 PDF Questions. It ensures that you would qualify for the BIG-IP Administration Support and Troubleshooting (F5CAB5) certification exam on the maiden strive with brilliant grades. Actual4Dumps has formulated the BIG-IP Administration Support and Troubleshooting (F5CAB5) product in three versions. You will find their specifications below to understand them better.
Online F5CAB5 Bootcamps: https://www.actual4dumps.com/F5CAB5-study-material.html
In the present competitive market, F5CAB5 exam certification has been as a weapon to accelerate personal promotion, Recently, F5CAB5 test torrent files are thought highly of by more and more people in the area as F5CAB5 certifications have become an important standard to identify someone's capability, The customizable mock tests make an image of a real-based BIG-IP Administration Support and Troubleshooting (F5CAB5) exam which is helpful for you to overcome the pressure of taking the final examination.
It explores how other industries have employed F5CAB5 reuse for decades to improve their processes and the quality of their products, It doesn't have to be, In the present competitive market, F5CAB5 Exam Certification has been as a weapon to accelerate personal promotion.
F5CAB5 Practice Test: BIG-IP Administration Support and Troubleshooting & F5CAB5 Exam Preparation & F5CAB5 Study GuideRecently, F5CAB5 test torrent files are thought highly of by more and more people in the area as F5CAB5 certifications have become an important standard to identify someone's capability.
Enroll in our F5CAB5 APP to access over 1,600 F5CAB5 questions and answers, All F5CAB5 test bootcamp materials you practiced are tested by our professional experts.
Posted at 2/8/2026 03:19:23        Only Author  2#
Absolutely brilliant content, no hesitation to like it. Thanks to the ITIL actual test pdf exam, I got promoted and earned a higher salary. Now, I’m giving it away for free today!
