[General] Quiz Cisco - The Best 400-007 - Valid Cisco Certified Design Expert (CCDE) Writt
68
General Quiz Cisco - The Best 400-007 - Valid Cisco Certified Design Expert (CCDE) Writt
Posted at 1/19/2026 07:43:57      View139 | Replies0        Print      Only Author   [Copy Link] 1#
P.S. Free 2026 Cisco 400-007 dumps are available on Google Drive shared by TestSimulate: https://drive.google.com/open?id=1bcfDNM0XwJk2DunuZBuP58MAsj3mqIP7
Our 400-007 exam materials have free demos for candidates who want to pass the exam, you are not required to pay any amount or getting registered with us that you can download our dumps. If you want to check the quality of our 400-007 exam materials, you can download the demo from our website free of charge. Our 400-007 exam materials demo will fully show you the characteristics of the actual exam question, therefore, you can judge whether you need it or not. We believe that the unique questions and answers of our 400-007 Exam Materials will certainly impress you. It will help you make decisions what benefit you and help you pass the exam easily. In addition, our expert of TestSimulate will provide candidates with specially designed materials in order to access your understanding of various questions. Choosing our 400-007 exam materials will definitely give you an unexpected results and surprise.
As you know, the low-quality latest 400-007 exam torrent may do harmful influence on you which may causes results past redemption. Whether you have experienced that problem or not was history by now. The exam will be vanquished smoothly this time by the help of valid latest 400-007 exam torrent. Written by meticulous and professional experts in this area, their quality has reached to the highest level compared with others similar 400-007 Test Prep and concord with the syllabus of the exam perfectly. Their questions points provide you with simulation environment to practice. In that case, when you sit in the real 400-007 exam room, you can deal with almost every question with ease.
Certification 400-007 Sample Questions - Test 400-007 PriceOur system will accurately help you analyze the exercises of the 400-007 study materials. So you need not to summarize by yourself. Then you will clearly know where you are good at and where your do badly. Flexible adjustment to your revision of the 400-007 Real Exam is essential to pass the exam. You can make decisions after careful consideration. It is up to you to make a decision. And after you finish the 400-007 exam questions, the scores will show out right away.
Cisco Certified Design Expert (CCDE) Written Exam Sample Questions (Q184-Q189):NEW QUESTION # 184
Drag and drop the multicast protocols from the left onto the current design situation on the right.
NEW QUESTION # 185
Drag and Drop Question
When a detection system for protecting a network from threats sourced from the Internet is designed there are two common deployment methods, where the system is placed differently relative to the perimeter firewall:
- An unfiltered detection system examines the raw Internet data streams before it reaches the firewall
- A screened detection solution which monitors traffic that is allowed
through the firewall
Both have its advantages and disadvantages drag and drop the characteristics on the left to the corresponding category on the right in no particular order.
NEW QUESTION # 186
A company named XYZ needs to apply security policies for end-user browsing by installing a secure web proxy appliance. All the web traffic must be inspected by the appliance, and the remaining traffic must be inspected by an NGFW that has been upgraded with intrusion prevention system functionality. In which two ways must the routing be performed? (Choose two)
  • A. Policy-based routing on the internet edge
  • B. Static routing on the appliance
  • C. Policy-based routing on the collapsed core
  • D. Policy-based routing on firewalls
In this architecture:
* A secure web proxy is introduced to inspect and filter all web (HTTP/HTTPS) traffic.
* Remaining traffic (non-web) must pass through an NGFW with IPS capabilities.
* Both the web proxy and NGFW reside between the collapsed distribution/core and internet edge.
To enforce that all web traffic is directed to the proxy appliance for inspection and non-web traffic follows its usual path to the NGFW:
A). Policy-Based Routing (PBR) on the Collapsed Core
This allows traffic classification based on destination port (e.g., TCP 80/443) and selectively reroutes web traffic to the proxy. Non-web traffic continues toward the NGFW. PBR is essential here because traditional routing (based only on destination IP) would not differentiate between traffic types.
D). Static Routing on the Appliance
The proxy appliance must return the traffic back toward the NGFW for final processing and internet egress.
This is typically achieved using static routes on the proxy device, ensuring the return path sends packets back to the correct firewall interface for consistent inspection.
#B. Policy-based routing on the internet edge: Not applicable here, as rerouting must occur closer to the source (collapsed core), before traffic reaches the internet edge.
#C. Policy-based routing on firewalls: This adds unnecessary complexity. Firewalls should focus on enforcing security policies, not traffic redirection logic in this scenario.
This approach adheres to CCDE v3.1 best practices by separating policy enforcement functions and enabling scalable, deterministic traffic flow through layered security appliances.
NEW QUESTION # 187
A mega store plans to expand its business into the online world, and wants to operate using the highest possible security standards to prove to their customers that they take handling of their payment information seriously. Only TLS v1.3 will be allowed on their websites.
Which type of SSL certificate will emphasize their commitment to enforcing high security standards and minimize risk of spoofing?
  • A. OV SSL certificate
  • B. EV SSL certificate
  • C. PV SSL certificate
  • D. DV SSL certificate
An Extended Validation (EV) SSL certificate provides the highest level of validation, displaying the organization's verified identity in the browser and minimizing the risk of spoofing. This strongly emphasizes the company's commitment to security when handling sensitive data such as payment information.
NEW QUESTION # 188
Your company designed a network to allow server VLANs to span all access switches in a data center. In the design, Layer 3 VLAN interfaces and HSRP are configured on the aggregation switches. Which two features improve STP stability within the network design? (Choose two.)
  • A. edge port on access ports
  • B. root guard on access ports
  • C. BPDU guard on access ports
  • D. access switch pairs explicitly determined to be root and backup root bridges
  • E. root guard on the aggregation switch downlinks toward access switches
  • F. BPDU guard on the aggregation switch downlinks toward access switches
Answer: C,E
* A (BPDU Guard on access ports): Prevents accidental connection of switches or bridging devices on access ports, which could cause unexpected topology changes or loops.
* C (Root Guard on aggregation switch downlinks): Ensures access switches cannot send superior BPDUs to challenge aggregation switch root status, maintaining predictable STP root placement.
* B: Aggregation downlinks are not normally configured with BPDU Guard (since they expect BPDUs from access switches).
* D: Root guard on access ports is unnecessary as those ports should not participate in STP.
* E: Edge port (Rapid STP concept) is good for faster convergence but doesn't address stability.
* F: STP root and backup root election is important but not a specific STP feature - this is a design decision, not a stability feature.
NEW QUESTION # 189
The operation of our 400-007 exam torrent is very flexible and smooth. Once you enter the interface and begin your practice on our windows software. You will easily find there are many useful small buttons to assist your learning. The correct answer of the 400-007 exam torrent is below every question, which helps you check your answers. We have checked all our answers. So you can check the answers breezily. In addition, the small button beside every question can display or hide answers of the 400-007 Test Answers. You can freely choose the two modes. At the same time, there is specific space below every question for you to make notes. So you can quickly record the important points or confusion of the 400-007 exam guides.
Certification 400-007 Sample Questions: https://www.testsimulate.com/400-007-study-materials.html
So with so many advantages we can offer, why not get moving and have a try on our 400-007 training materials, Activation/Registration I cannot activate Certification 400-007 Sample Questions Exam Simulator using E-mail and Password of my TestSimulate Certification 400-007 Sample Questions account, Cisco Valid 400-007 Test Practice How can ensure my credit card information secure at your site, Actually, our 400-007 valid exam guide is really worth for you to rely on.
You can share your collection with anyone, without having it 400-007 leave your virtual) hands, A demo storefront is available for you to peruse for brainstorming before you take the plunge.
So with so many advantages we can offer, why not get moving and have a try on our 400-007 Training Materials, Activation/Registration I cannot activate CCDE v3.0 Exam Simulator using E-mail and Password of my TestSimulate account.
Free PDF Quiz Accurate 400-007 - Valid Cisco Certified Design Expert (CCDE) Written Exam Test PracticeHow can ensure my credit card information secure at your site, Actually, our 400-007 valid exam guide is really worth for you to rely on, We will be with you in every stage of your 400-007 free dumps preparation to give you the most reliable help.
2026 Latest TestSimulate 400-007 PDF Dumps and 400-007 Exam Engine Free Share: https://drive.google.com/open?id=1bcfDNM0XwJk2DunuZBuP58MAsj3mqIP7
