[Hardware] Oracle 1Z0-083 Latest Test Online | 1Z0-083 Valid Exam Materials
49
Hardware Oracle 1Z0-083 Latest Test Online | 1Z0-083 Valid Exam Materials
Posted at 1/19/2026 08:31:16      View211 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest TorrentExam 1Z0-083 PDF Dumps and 1Z0-083 Exam Engine Free Share: https://drive.google.com/open?id=1TtKOxhfb-ntli48eG3dJ-Ew8EQeAb2_I
Where there is life, there is hope. Never abandon yourself. You still have many opportunities to counterattack. If you are lack of knowledge and skills, our 1Z0-083 study materials are willing to offer you some help. Actually, we are glad that our study materials are able to become you top choice. In the past ten years, we always hold the belief that it is dangerous if we feel satisfied with our 1Z0-083 Study Materials and stop renovating. Luckily, we still memorize our initial determination.
Oracle 1Z0-083 certification exam consists of 84 multiple-choice questions that are to be completed in 150 minutes. 1Z0-083 exam is available in the English language and can be taken either online or at a Pearson VUE testing center. 1Z0-083 exam fee is $245, and the passing score is 64%. Candidates who pass the exam earn the Oracle Database Administrator Certified Professional credential, which demonstrates their proficiency in Oracle database administration.
The Oracle 1Z0-083 exam consists of 80 multiple-choice questions and has a time limit of 105 minutes. To pass the test, candidates must score at least 63% or higher. 1Z0-083 Exam covers a wide range of topics, including Oracle database architecture, backup and recovery strategies, database security, and performance tuning techniques. Oracle Database Administration II certification is ideal for professionals who want to demonstrate their expertise in Oracle database administration and advance their careers.
1Z0-083 Valid Exam Materials | Latest 1Z0-083 Test CampThis 1Z0-083 certification assists you to put your career on the right track and helps you to achieve your career goals in a short time period. There are several personal and professional benefits that you can gain after passing the Oracle Database Administration II (1Z0-083) certification exam. The prominent 1Z0-083 certification benefits include validation of skills and knowledge, more career opportunities, instant rise in salary, quick promotion, etc.
Oracle Database Administration II Sample Questions (Q276-Q281):NEW QUESTION # 276
Your container database, CDB1, has an application container, HR_ROOT, with an application PDB, HR_PDB1.
You have the required privilege to clone HR_PDB1to container database CDB2, which does not contain HR_ROOT.
Which two are always true? (Choose two.)
  • A. The HR_PDB1 clone created in CDB2 will be in mount state when cloning ends.
  • B. Cloning HR_ROOT automatically clones HR_PDB1.
  • C. CDB1 and CDB2 must be in shared undo mode.
  • D. A common user must exist in CDB2 with the CREATE PLUGGABLE DATABASE privilege.
  • E. All transactions in HR_PDB1 of CDB1 must commit before the cloning process starts.
After you create the application PDB, it is in mounted mode, and its status is NEW.
https://docs.oracle.com/en/datab ... eating-application- pdb.html#GUID-88E61123-F651-47D7-9977-B589268EBD29
NEW QUESTION # 277
Which three are located by using environment variables? (Choose three.)
  • A. the temporary disk space used by Oracle Installer during installation
  • B. the Optimal Flexible Architecture (OFA) compliant path to store Oracle software and configuration files.
  • C. the location of Oracle Net Services configuration files
  • D. default directories for temporary files used by temporary tablespaces
  • E. the list of a disk group names to be mounted by an Oracle Automatic Storage Management (ASM) instance at startup
  • F. the maximum number of database files that can be opened by a database instance
Answer: C,D,F
NEW QUESTION # 278
Choose two. Which two are true about the automatic execution of operating system scripts when performing silent mode installation starting from Oracle Database 19c?
  • A. The response file can specify the path of the sudo program.
  • B. Silent install always runs operating scripts automatically.
  • C. The installer will prompt for the root or sudo password.
  • D. The response file can specify the root or sudo password.
  • E. The response file must contain the root or sudo password.
NEW QUESTION # 279
Which two are true about data movement between a non-CDB and a PDB using Data Pump?
(Choose two.)
  • A. Oracle attempts to convert conventional database users to local users when moving schemas from a non-CDB to a PDB.
  • B. Oracle attempts to convert common users to conventional users when moving schemas from a PDB to a non-CDB.
  • C. Moving data from a PDB to a non-CDB is only possible by using transportable tablespace export and import.
  • D. Tablespaces are automatically created as neeed while importing full exports in either a non-CDB or a PDB.
  • E. A new PDB is automatically created when importing a non-CDB into a CDB.
  • F. Moving data from a non-CDB to a PDB is only possible by using conventional export and import.
E,F -> Incorrect -> tablespace export/import can be conventional or transportable A,C -> Nothing is created automatically you must create what you need.
NEW QUESTION # 280
Choose the best answer. SQL Performance Analyzer (SPA) has reported several regressed SQL statements for one of your databases. Which action could help in the performance management of these regressed SQL statements?
  • A. Create SQL plan directives for each of the regressed statements.
  • B. Use the SQL Access Advisor for each of the regressed statements.
  • C. Create an adaptive execution plan for each of the regressed statements
  • D. Use The SQL Tuning Advisor for each of the regressed statements.
NEW QUESTION # 281
Our 1Z0-083 exam torrent is famous for instant download, and we will send the downloading link and password to you within ten minutes after purchasing. You can start your learning immediately, and if you dont receive 1Z0-083 exam torrent, just contact us, we will solve this problem for you. Whats more, with the skilled professionals to compile the 1Z0-083 Exam Dumps, quality and accuracy can be guaranteed. Therefore, you can use the 1Z0-083 exam dumps of us with ease. We have online and offline chat service stuff, if any questions bother you, just consult us.
1Z0-083 Valid Exam Materials: https://www.torrentexam.com/1Z0-083-exam-latest-torrent.html
P.S. Free 2026 Oracle 1Z0-083 dumps are available on Google Drive shared by TorrentExam: https://drive.google.com/open?id=1TtKOxhfb-ntli48eG3dJ-Ew8EQeAb2_I
Posted at 2/8/2026 09:03:16        Only Author  2#
I am so grateful for this inspiring article, thank you! Get your hands on the free Valid C1000-182 test pdf exam questions. Wishing you the best of luck!
Posted at 2/20/2026 08:46:19        Only Author  3#
I really appreciate your work, it left a profound impact on me. This is the Reliable exam NCP-MCI-6.10 questions fee exam that played a role in my promotion and pay raise, now shared with you for free today. Best wishes on your career development!
