[General] Perfect MB-240–100% Free Latest Exam Registration | MB-240 Reliable Braindumps E
84
【General】 Perfect MB-240–100% Free Latest Exam Registration | MB-240 Reliable Braindumps E
Posted at 1/19/2026 08:35:36      View:110 | Replies:0        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of Dumpexams MB-240 dumps from Cloud Storage: https://drive.google.com/open?id=1p40QyLAVV872xpADBPMBBSc6DnWUGx-Y
Our company has authoritative experts and experienced team in related industry. To give the customer the best service, all of our MB-240 exam torrent materials is designed by experienced experts from various field, so our MB-240 Learning materials will help to better absorb the test sites. One of the great advantages of buying our product is that can help you master the core knowledge in the shortest time. At the same time, our MB-240 Valid Study Guide materials discard the most traditional rote memorization methods and impart the key points of the qualifying exam closely.
Skills measured
  • Configure field service applications (15-20%)
  • Schedule and dispatch work orders (25-30%)
  • Implement Connected Field Service (10-15%)
  • Manage field service mobility (10-15%)
  • Manage inventory and purchasing (5-10%)
Dumpexams is A Perfect and Reliable Option for MB-240 Exam QuestionsWe also provide timely and free update for you to get more MB-240 questions torrent and follow the latest trend. The MB-240 exam torrent is compiled by the experienced professionals and of great value. You can master them fast and easily. We provide varied versions for you to choose and you can find the most suitable version of MB-240 Exam Materials. So it is convenient for the learners to master the Microsoft Dynamics 365 questions torrent and pass the exam in a short time.
Microsoft MB-240 Exam is a valuable certification for professionals who want to gain expertise in Dynamics 365 Field Service applications. Microsoft Dynamics 365 Field Service Functional Consultant certification is globally recognized and demonstrates the candidate’s proficiency in the field. Microsoft Dynamics 365 Field Service Functional Consultant certification is also useful for organizations that use Dynamics 365 Field Service applications as it ensures that their consultants have the necessary skills and knowledge to provide quality services. Microsoft Dynamics 365 Field Service Functional Consultant certification can also lead to better career opportunities and higher salaries for professionals in the field.
Microsoft Dynamics 365 Field Service Functional Consultant Sample Questions (Q79-Q84):NEW QUESTION # 79
Note: This question is part of a series of questions that present the same scenario. Each question in the series contains a unique solution that might meet stated goals. Some question sets might have more than one correct solution, while others might not have a correct solution.
You are a Dynamics 365 for Field Service system administrator.
You are configuring a new instance of Dynamics 365 for Field Service. The organization needs to automatically generate work orders based on agreements, and send invoices on a recurring basis by customer.
Solution: You implement the following configuration changes.
1) Create Agreement
2) Define Booking Setup
3) Create Invoice Setup
4) Set Auto Generate Invoice = Yes
5) Populate Generate Agreement Invoices X Days in Advance
Does this meet the goal?
  • A. No
  • B. Yes
Section: Configure field service applications
NEW QUESTION # 80
You need to create a requirement group for a work order.
NEW QUESTION # 81
Dispatchers at Contoso have access to a wide range of information because they often cover for each other within the region. However, for their normal dairy operations, they only need to be able to see resources in their territory.
The dispatcher needs to customize their schedule board to filter resources to their territory. What should the dispatcher do?
  • A. On the Filter & Map View window, select a Resource Type, then select Save Current Filters as Default.
  • B. Add a Booking Requirements tab.
  • C. On the Filter & Map View window, select a Service Territory, then select Save Current Filters as Default.
  • D. In the Scheduler Settings, select one Territory.
Topic 2, Litware, Inc
Company structure and resources
Litware, Inc. is a home improvement retail company with stores around the world. Litware, Inc. also offers various installation and repair services using both employees and subcontractors.
Litware, Inc. has stores located throughout the United States and Canada.
The company has three main types of stores, each offering a different combination of service personnel.
1. DIY Stores are retail and contractor stores with supply items for electrical, lighting, and other home improvement DIY projects.
* Delivery personnel pick up at the local warehouse for each store.
* Installers install major appliances.
2. Pro Stores offer design ideas for major home renovations.
* Designers are assigned to a department based on skills and expertise.
* Installers are assigned to a geographic region.
* Repair Technicians are all subcontractors.
3. Home Improvement Stores offer the convenience of purchasing items available in the DIY stores, but also include the expert design, installation and repair services offered in the Pro Stores.
* Installers are assigned to multiple stores in a geographic region.
* Repair technicians are all subcontractors.
* Dispatchers are assigned to all territories in a region. Dispatchers assign repair and installation work to technicians based on skill.
All internal delivery, repair and installation employees will utilize the Field Service mobile app. Litware, Inc. employees have full-service licenses, while subcontractors do not K Regions Dispatchers can see all work request data for their region, including resources.
The Canadian regions are:
Data management structure
Litware, Inc. store employees can see data within their region. This is to provide better support of customers and stores within the regions. The current data access structure appears as follows:
Field Service difficulties
Typical job assignment is as follows:
* Appliance Delivery & Hookup: 2 resources - subcontracted out
* Landscaping: minimum 2 resources. 1 expert
* Carpeting: 2-3 resources
* Tile Flooring: 2 resources
* Kitchen Cabinets: 3 resources
* Hardwood Flooring: 2 resources
* Repairs: 1-2 resources
A spreadsheet tracks the skills and certifications earned by each internal employee. They are:
The Skill Proficiency Model used at Litware, Inc. is as follows;
1 - Novice
2 - Inexperienced
3 - Moderate Experience
4 - Experienced
5 - Expert/Certified
For each type of job, there must be at least one certified or highly experienced resource on the job. Their current system does not have a way to share technical documents and instructions with the technicians and have them review it while onsite.
All work is printed out and the provided to the resources. Contractors are currently emailed the job details to which they need to confirm availability. Contractors sometimes decline work. In some of these cases, the Litware, Inc. dispatch team does not react quickly to this information and the customer's work or delivery is delayed.
Customer base
Currently, all customer data are held in Dynamics 365 Finance and Operations (D365 F&O).
* Most store employees do not have access to this data as it is currently being implemented for backend features, such as inventory and invoicing.
* Designers and those scheduling can pull up a customer and their pending orders and installations, but they cannot see the payment details and terms.
85% of Litware's customers are households.
15% are construction-based companies that either purchase or hire Litware, Inc. for specific jobs.
* Most of these companies receive a 5-10% discount on supplies and 10% discount on labor.
Planned changes
Litware, Inc. plans to implement Dynamics 365 Field Service. The requirements gathered during analysis are:
Work Orders and Scheduling
* Scheduling based on resource skill, and number of required resources based on job type and duration.
* Preventative Maintenance emergency calls take priority over other types of jobs.
* Schedule resources based on location, maximizing total work hours and then minimizing drive time.
* All HVAC down jobs require a resource to be onsite at the customer location within 2 hours, per contract terms.
* Some high-end HVAC systems can tell the company when the system is experiencing issues. Alert dispatchers when this occurs if this feature is enabled and purchased.
* Set contractually obligated times for HVAC down jobs.
* Set reminders or see critical details to act on for a job.
* Ability to quickly book a job.
* Easily see when a resource is on Paid Time Off on the schedule board.
Service Contracts
* Set up and create a Preventative Maintenance (PM) type of contracts.
* PM contracts are only for HVAC systems. Semi-annual maintenance jobs should be created 30-days before they are to be scheduled.
* Semi-annual inspections Discount on any required parts and additional labor.
* Include 24-hour emergency service calls at no-charge.
Extended Warranties
* Ability to setup and create an Extended Warranty type of contracts.
* Start when Manufacturer warranty ends.
* Can be purchased for 1, 2 or 3 years and include all parts and labor.
Products and Services
* Integration between D365 F&O and D365 Field Service.
* Implement a parts return process for any unused or defective part during an installation job.
* Multiple price lists will be used, based on region and customer type (retail, construction).
Resources
* Implement company holidays for US and Canada
* Implement various pay types based on OT, Weekends/Holidays, Travel and Regular Time.
* Implement Paid Time Off.
* Optimize resource schedules.
* Access to jobs assigned for the day.
* Specialty equipment scheduled on work orders as needed.
Technical Requirements
Invoicing
* Send Work Order details to D365 F&O when a job is completed, and after internal reviews are performed.
* The system must track the price of resources based on holidays and after-hours scenarios at a rate of one and a half times the normal billing rate.
* Travel time is non-billable. Travel time should be captured as normal billing rate.
* A Delivery Fee of S75 is charged for each order.
* Subcontractor travel time is non-billable but is paid to the subcontractor company by Litware, Inc.
Resources
* Contractor technicians require access to work order and customer details once assigned to a booking. They do not have a license.
* Dispatchers need a schedule board for their region(s).
* Resources have access to view their skills, skill level and certification data.
o Certifications set to expire over the next 120 days should show highlighted in Yellow, o Certifications already expired will show in Red.
* Resources will be notified when they enter or leave a job, or are assigned a job for the day.
* Resource booking automatically updated when they enter job site.
* High priority jobs will send an alert to the resources' phone and send them a text message.
* Resources assigned to a job where their skill level = 1 will be assigned to an experienced resource for 3 months.
* Resources on the job can use their smartphone to call and obtain assistance.
* Resources can access documents either online or offline.
* All parts removed from a customer's equipment must be returned to the Main warehouse.
* All parts not used or deemed defective during an installation must be returned to the originating warehouse.
* All appliances and parts will become part of the customer record.
* All products are received into the Main warehouse and then distributed to van stock for delivery or installation.
* All assets that have an expired manufacturer warranty should show a notification.
Work Orders
* The ability to have templates for work orders. Templates will provide guidance for technicians, and recommend products and default services.
* Work Orders created from a PM contract need to have a status = Service Contract.
* Work Orders created from an Extended Warranty contract need to have a status = Extended Title Warranty
* All HVAC down work orders must be set to high priority.
* All emergency, and contractual Work Orders must be created, reviewed and dispatched within 1 hour. A technician must be onsite within 2 hours.
* All Work Orders created from a PM are non-billable.
* All Extended Warranty jobs must include a flat service fee of $75.
Scheduling
* High Priority work orders for HVAC down cannot be moved once scheduled.
* Work Orders scheduled to technician(s) who do not have the desired skill set and level should show a warning.
o If scheduled, it will send an approval record to the manager to approve the assignment. Approved are booked. Rejected are canceled and the dispatcher notified.
* Dispatchers will assign multi-day work orders, such as kitchen cabinets, bathrooms, landscaping, to the same group of resources for the duration of the work.
* All work orders for an existing asset, where the asset does not have an active manufacturer's warranty, or a valid extended warranty should show an alert upon scheduling.
* Resources should be optimized for high priority items, maximize their work hours and then minimize travel time.
Security and access
* Safeguards must be in place for the data on the Field Service mobile app if a technician loses his mobile device.
* Technicians in the field should only see work orders scheduled for today.
* Field Service administrators need the ability to update the defaults for the schedule assistant.
NEW QUESTION # 82
You are managing a Microsoft Dynamics 365 Field Service implementation with model-driven apps for each workstream. Users are reporting that they see all workstream model-driven apps when they log into Dynamics
365, even though only a single workstream is relevant to their work.
You need to configure the model-driven apps to ensure users can only see the single model-driven app relevant to their work.
What should you do?
  • A. Ensure each model-driven app is saved with the workstream security roles applied, and each user is given the system administrator security role.
  • B. Ensure each model-driven app is saved with the workstream security roles applied, each user is only given the security role relevant for their workstream.
  • C. Ensure each model-driven app is saved with the workstream security roles applied, and each user is given the system customizer security role.
  • D. Ensure each model-driven app is saved with all security roles applied, and each user is only given the security role relevant for their workstream.
NEW QUESTION # 83
You are implementing Dynamics 365 Field Service for Contoso Manufacturing.
You need to set up preventive maintenance schedules for the assets they service.
In addition to creating an Agreement Booking, what else must you set up in order to associate the asset to the agreement?
  • A. Auto Generate Work Order set to Yes
  • B. Booking Recurrence
  • C. Agreement Booking Incident
  • D. Asset Functional Location
NEW QUESTION # 84
MB-240 Reliable Braindumps Ebook: https://www.dumpexams.com/MB-240-real-answers.html
What's more, part of that Dumpexams MB-240 dumps now are free: https://drive.google.com/open?id=1p40QyLAVV872xpADBPMBBSc6DnWUGx-Y
