[General] Actual 1Z0-083 Exam Prep 100% Valid Test Questions are The Best Products
92
General Actual 1Z0-083 Exam Prep 100% Valid Test Questions are The Best Products
Posted at 1/19/2026 08:47:33      View158 | Replies3        Print      Only Author   [Copy Link] 1#
BTW, DOWNLOAD part of DumpExam 1Z0-083 dumps from Cloud Storage: https://drive.google.com/open?id=1cgTZHtBUjdbQdgWUkLiuUPJ1TIGD3Rii
We committed to providing you with the best possible Oracle Database Administration II (1Z0-083) practice test material to succeed in the Oracle 1Z0-083 exam. With real Oracle Database Administration II (1Z0-083) exam questions in PDF, customizable Oracle 1Z0-083 practice exams, free demos, and 24/7 support, you can be confident that you are getting the best possible 1Z0-083 Exam Material for the test. Buy today and start your journey to Oracle Database Administration II (1Z0-083) exam success with DumpExam!
Oracle 1Z0-083 (Oracle Database Administration II) Certification Exam is a professional certification offered by Oracle Corporation to test the knowledge and skills of database administrators in managing and maintaining Oracle databases. Oracle Database Administration II certification exam is designed to validate the advanced-level skills and expertise of the candidates in the areas of database architecture, backup and recovery, performance tuning, security, and multi-tenant architecture.
100% Pass 2026 Oracle High-quality 1Z0-083: Oracle Database Administration II Exam SimulatorIt means that our 1Z0-083 test questions are very useful for all people to achieve their dreams, and the high quality of our 1Z0-083 exam prep is one insurmountable problem. If you decide to choice our products as your study tool, you will be easier to pass your exam and get the 1Z0-083 Certification in the shortest time. So do not hesitate and buy our 1Z0-083 test torrent, an unexpected surprise is awaiting you, we believe you will prefer to our 1Z0-083 test questions than other study materials.
Oracle Database Administration II Sample Questions (Q48-Q53):NEW QUESTION # 48
Examine the statements that use flashback technologies:
1. FLASHBACK TABLE customers TO TIMESTAMP TO_TIMESTAMP (2013-02-04 09:30:00, YYYY-MM-DD HH:MI:SS);
2. SELECT * FROM customers AS OF SCN 123456;
3. FLASHBACK TABLE customers TO BEFORE DROP;
4. FLASHBACK DATABASE TO TIMESTAMP TO_TIMESTAMP (2013-02-04 09:30:00, YYYY- MM-DD HH:MI:SS);
5. SELECT * FROM customers VERSIONS BETWEEM SCN 123456 AND 123999;
6. ALTER TABLE customer FLASHBACK ARCHIVE;
Which set of statements depends on the availability of relevant undo data in the undo tablespace?
  • A. 3,4,5
  • B. 1,2,5
  • C. 2,3,5,6
  • D. 1,3,6
NEW QUESTION # 49
Examine this configuration:
1. CDB1 is a container database.
2. COMMON_USER_PREFIX is set to an empty string.
3. PDB1 is a pluggable database in CDB1.
4. APP1_ROOT is an application container in CDB1.
5. APP1_PDB1 is an application PDB in APP1_ROOT.
You execute these commands:
$ sqlplus sys/oracle@localhost:1521/cdb1 as sysdba
SQL> CREATE ROLE role1 CONTAINER=CURRENT;
What is true?
  • A. It will return an error because creation of a local role is not allowed in CDB$ROOT.
  • B. It will return an error because common roles must start with C##.
  • C. ROLE1 will be created in CDB$ROOT, PDB1, APP1_ROOT, and APP1_PDB1.
  • D. ROLE1 will be created only in CDB$ROOT and APP1_ROOT.
  • E. ROLE1 will be created only in CDB$ROOT.
Answer: E
NEW QUESTION # 50
Which two are true about data movement between a non-CDB and a PDB using Data Pump? (Choose two.)
  • A. A new PDB is automatically created when importing a non-CDB into a CDB.
  • B. Tablespaces are automatically created as neeed while importing full exports in either a non-CDB or a PDB.
  • C. Oracle attempts to convert conventional database users to local users when moving schemas from a non- CDB to a PDB.
  • D. Moving data from a PDB to a non-CDB is only possible by using transportable tablespace export and import.
  • E. Moving data from a non-CDB to a PDB is only possible by using conventional export and import.
  • F. Oracle attempts to convert common users to conventional users when moving schemas from a PDB to a non-CDB.
Answer: D,F
NEW QUESTION # 51
Which three actions are mandatory post database upgrade?
  • A. Resetting passwords to enforce case-sensitivity.
  • B. Upgrading user tables that depend on Oracle-maintained abstract data types.
  • C. Migration to unified auditing.
  • D. Setting threshold values for tablespace alerts.
  • E. Updating client scripts with the new Oracle home.
  • F. Run OPatch commands from the new Oracle home.
Answer: B,E,F
NEW QUESTION # 52
While backing up to an SBT channel, you determine that the read phase of your compressed Recovery Manager (RMAN) incremental level 0 backup is a bottleneck.
FORCE LOGGING is enabled for the database.
Which two could improve read performance? (Choose two.)
  • A. Increase the level of RMAN multiplexing.
  • B. Disable FORCE LOGGING for the database.
  • C. Increase the size of tape I/O buffers.
  • D. Increase the size of the database buffer cache.
  • E. Enable asynchronous disk I/O.
Answer: A,E
NEW QUESTION # 53
DumpExam is unlike other exam materials that are available on the market, 1Z0-083 study torrent specially proposed different versions to allow you to learn not only on paper, but also to use mobile phones to learn. You can choose the version of 1Z0-083 training guide according to your interests and habits. And if you buy the value pack, you have all of the three versions, the price is quite preferential and you can enjoy all of the study experiences. This means you can study 1Z0-083 Exam Engine anytime and anyplace for the convenience these three versions bring.
Exam 1Z0-083 Quiz: https://www.dumpexam.com/1Z0-083-valid-torrent.html
P.S. Free 2026 Oracle 1Z0-083 dumps are available on Google Drive shared by DumpExam: https://drive.google.com/open?id=1cgTZHtBUjdbQdgWUkLiuUPJ1TIGD3Rii
Posted at 1/20/2026 02:03:54        Only Author  2#
Thank you for sharing such a memorable article, it really touched me. Free Reliable PCCP exam bootcamp materials test materials are available! Good luck!
Posted at 1/20/2026 12:26:19        Only Author  3#
JapancertC1000-196̲Ĥُ뤷顢ʤһgΟoϥåץǩ`ȥ`ӥȡäޤԇY}¤ȡJapancertֱˤʤΥ`ܥåC1000-196}°ͤޤʤԇY¥Щ`ṩ뤳ȤҪ󤹤뤳ȤǤޤ¤C1000-196ԇY}֪ꤿϡԇY˺ϸ񤷤ȤƤJapancertϟoϤdž}¤Ƥޤ
Posted at 1/29/2026 09:46:50        Only Author  4#
Through this article, I have gained a deep understanding of this topic and benefited immensely. Best of luck! Here are the free Valid Plat-UX-102 test pass4sure materials to help you!
