[General] Pass-sure MB-820 Training Materials - MB-820 Quiz Torrent & MB-820 Exam Boot
98
【General】 Pass-sure MB-820 Training Materials - MB-820 Quiz Torrent & MB-820 Exam Boot
Posted at 1/19/2026 09:29:27      View:157 | Replies:3        Print      Only Author   [Copy Link] 1#
P.S. Free & New MB-820 dumps are available on Google Drive shared by TrainingQuiz: https://drive.google.com/open?id=1cCwIMuMyMqd_clFvQvaFS_4Y7kHaxCG2
Our web-based practice exam software is an online version of the Microsoft MB-820 practice test. It is also quite useful for instances when you have internet access and spare time for study. To study and pass the certification exam on the first attempt, our Microsoft MB-820 Practice Test software is your best option. You will go through Microsoft MB-820 exams and will see for yourself the difference in your preparation.
Microsoft MB-820 Exam Syllabus Topics:
  • Integrate Business Central with other applications: Accessing Representational State Transfer (REST) services is discussed in this topic.  It also explains implementation of APIs.
  • Install, develop, and deploy for Business Central: It delves into the installation and configuration of a Business Central development environment. Moreover, it discusses creating, debugging, and deploying an extension in Business Central.
  • Develop by using AL: How to Customize the UI experience and Use AL for business central extension is discussed here. It also delves into explaining the essential development standards.
  • Work with development tools: Implementing semi-automated test processes and managing and assessing telemetry are its sub-topics.
Topic 5
  • Develop by using AL objects: Building and extending tables and reports is discussed in this topic. It also explains Designing and creating an XMLport. Lastly, it discusses how to work with entitlement and permission set objects.
Exam Questions MB-820 Vce | Valid MB-820 Test RegistrationWe are glad to introduce the MB-820 study materials from our company to you. We believe our study materials will be very useful and helpful for all people who are going to prepare for the MB-820 exam. There are a lot of excellent experts and professors in our company. In the past years, these experts and professors have tried their best to design the MB-820 Study Materials for all customers.
Microsoft Dynamics 365 Business Central Developer Sample Questions (Q91-Q96):NEW QUESTION # 91
A company is setting up a sandbox environment.
You observe the following issues in Visual Studio Code:
* When you open the User Settings window, no AL command is available
* In the Problems tab. the error 'The target page Customer List for the extension object is not found' is displayed.
You need to identify a solution for each issue.
Which solutions should you use? To answer, select the appropriate options in the answer area.
No AL command in User Settings:
The correct solution is to Install the AL Language extension.
* This issue arises when the AL Language extension is not installed in Visual Studio Code, which is required to work with AL projects in Business Central.
Error in the Problems tab:
The correct solution is to Download Symbols.
* This error typically occurs when the symbols (metadata for pages, tables, etc.) are not downloaded, and Visual Studio Code cannot resolve the reference to the Customer List page. Downloading symbols should fix the problem.
NEW QUESTION # 92
You are exporting data from Business Central.
You must export the data in a non-fixed length and width in CSV format.
You need to generate an XMLport to export the data in the required format.
Which Format property value should you use?
  • A. FixedText
  • B. VariableText
  • C. XML
When exporting data from Business Central and the requirement is for the data to be in a non- fixed length and width CSV format, the Format property of the XMLport should be set to VariableText (B). The VariableText format is designed for handling data exports where the fields are separated by a delimiter, such as a comma or tab, which is typical of CSV (Comma- Separated Values) files. This format allows for the flexibility needed when dealing with varying field lengths, as it does not enforce a fixed width for each field, making it ideal for CSV data exports. Setting the Format property to FixedText (C) would enforce a fixed width for each field, which is not suitable for CSV files, while the XML format (A) is used for exporting data in an XML structure, which is different from the CSV format requirements.
NEW QUESTION # 93
A company plans to customize its per tenant extension reports. The company has the following requirements for the customization:
* Child data items must not be displayed on the request page for some master detail reports.
* Selecting key filter fields takes users too much time. The customization must decrease the amount of time to select the fields.
You need to optimize the report request page.
Which actions should you configure? To answer, select the appropriate options in the answer area.
For the given requirements, you should configure the following actions:
* For child data items not to be displayed on the request page for some master-detail reports, set the DataItemLinkReference property to the parent data item.
* To decrease the amount of time to select key filter fields, specify the RequestFilterHeading property.
In Dynamics 365 Business Central, when customizing report request pages, certain properties can be set to control the behavior and display of the report options:
* Hiding Child Data Items:The DataItemLinkReference property is used to link a child data item to a parent data item in the data model of a report. Setting this property correctly will ensure that the child data items are related to the correct parent data item and will be displayed or hidden accordingly on the request page. If the goal is to prevent child data items from being displayed, you need to make sure they are correctly linked and configured to not appear.
* Optimizing Filter Field Selection:The RequestFilterHeading property is used to group filter fields on the request page. By specifying this property, you can create a more organized and user-friendly interface, which can significantly speed up the process of selecting filters. This property allows you to categorize filters into headings, making it quicker and easier for users to find and set the necessary filters for the report.
By adjusting these properties on the report request page as part of the per tenant extension customization, you will address the company's requirements to optimize the user experience when running reports.
NEW QUESTION # 94
You need to handle the removal of the Description field and the Clone procedure without breaking other extensions.
NOTE: More than one order of answer choices is correct. You will receive credit for any of the correct orders you select.
In Business Central, when you need to handle the removal of fields and procedures to ensure that other extensions are not affected by these changes, you typically follow a two-step deprecation process. This allows other developers and users to adapt to the changes before they are fully enforced. Here are the steps to handle the removal:
* Mark as Obsolete: In the first version where the decision to remove the field or procedure is made, you set the ObsoleteState to Pending and provide an ObsoleteReason. This doesn't remove the feature but indicates to users and developers that it will be removed in the future. This step is crucial for backward compatibility.
* Removal: In a subsequent version, after users have had time to adapt to the deprecation warning, you can then remove the field or procedure or set the ObsoleteState to Removed.
Based on these guidelines, here are the three actions you should perform in sequence:
* Set the Description field as ObsoleteState = Pending and ObsoleteReason = 'Not in use' in version
2.0.0.0.
* Set the Clone procedure as ObsoleteState = Pending and ObsoleteReason = 'Not in use' in version
2.0.0.0.
* Remove the Description field from the Issue table in version 2.0.0.1.
These steps will ensure that anyone using the Description field or Clone procedure will receive a warning about the pending deprecation before it is actually removed, thereby minimizing the impact on other extensions and providing a clear path for migration.
When handling the removal of fields and procedures in Microsoft Dynamics 365 Business Central, the process should be carried out in a way that allows other extensions or dependent features to adapt to the changes without causing immediate failures.
* Set Obsolete State and Reason for Description Field (Version 2.0.0.0): The first step involves marking the Description field as obsolete by setting the ObsoleteState to 'Pending'. This is a non-breaking change, signaling to other developers and users that the field is planned for removal in a future version.
An ObsoleteReason should also be provided to explain why the field is being deprecated.
* Set Obsolete State and Reason for Clone Procedure (Version 2.0.0.0): Similarly, the Clone procedure should be marked as obsolete with the ObsoleteState set to 'Pending'. This indicates that the procedure is no longer in use and will be removed in the future. Providing an ObsoleteReason is best practice as it explains the rationale behind the decision.
* Remove the Description Field (Version 2.0.0.1): In the subsequent version, after the developers and users have been given time to adapt to the deprecation notice, the Description field can be safely removed from the Issue table. This is considered a breaking change, hence it is done after the field has been marked as obsolete in a previous version.
The reason for not removing the Description field and Clone procedure immediately in version 2.0.0.0 is to avoid causing runtime errors for any extensions or integrations that may depend on these components. By following this sequence, you provide a clear deprecation path that helps maintain the stability of the overall system while evolving the schema.
NEW QUESTION # 95
You need to create the API page according to the requirements.
How should you complete the code segment? To answer, select the appropriate options in the answer area.
NEW QUESTION # 96
We know deeply that a reliable MB-820 exam material is our company's foothold in this competitive market. High accuracy and high quality are the most important things we always looking for. Compared with the other products in the market, our MB-820 latest questions grasp of the core knowledge and key point of the real exam, the targeted and efficient Microsoft Dynamics 365 Business Central Developer study training dumps guarantee our candidates to pass the test easily. Our MB-820 Latest Questions is one of the most wonderful reviewing Microsoft Dynamics 365 Business Central Developer study training dumps in our industry, so choose us, and together we will make a brighter future.
Exam Questions MB-820 Vce: https://www.trainingquiz.com/MB-820-practice-quiz.html
What's more, part of that TrainingQuiz MB-820 dumps now are free: https://drive.google.com/open?id=1cCwIMuMyMqd_clFvQvaFS_4Y7kHaxCG2
Posted at 1/31/2026 14:07:53        Only Author  2#
This article is incredibly motivating, thank you for sharing it! Here's the 100-160 reliable exam simulator free test that helped me land my promotion and raise. It's free today—good luck with your career progress!
Posted at 2/3/2026 19:44:38        Only Author  3#
This article is truly eye-opening, thank you for sharing. Wishing myself all the best for the Valid test DP-900 tutorial exam!
Posted at 2/7/2026 04:18:18        Only Author  4#
Your article is outstanding, thank you for sharing! I’m sharing the BUS105 latest test blueprint exam materials for free—best of luck!
