Avail High Hit Rate SPLK-2002 Passed to Pass SPLK-2002 on the First Attempt
7
Posted at 1/19/2026 11:39:17      View151 | Replies2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest NewPassLeader SPLK-2002 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1J0QQHYATo69BRbuIgud3_q9kySSIiTLb
Our SPLK-2002 study guide boosts both the high passing rate which is about 98%-100% and the high hit rate to have few difficulties to pass the test. Our SPLK-2002 exam simulation is compiled based on the resources from the authorized experts diligent working and the Real SPLK-2002 Exam and confer to the past years exam papers thus they are very practical. The content of the questions and answers of SPLK-2002 exam quiz is refined and focuses on the most important information.
Do you know why you feel pressured to work? That is because your own ability and experience are temporarily unable to adapt to current job requirements. Our SPLK-2002 exam questions can upgrade your skills and experience to the current requirements in order to have the opportunity to make the next breakthrough. Don't doubt about our SPLK-2002 Study Guide! Just look at the warm feedbacks from our loyal customers, they all have became more successful in their career with the help of our SPLK-2002 practice engine.
Exam SPLK-2002 Duration | SPLK-2002 Exam ExperienceNowadays, using electronic materials to prepare for the exam has become more and more popular, so now, you really should not be restricted to paper materials any more, our electronic SPLK-2002 exam torrent will surprise you with their effectiveness and usefulness. I can assure you that you will pass the SPLK-2002 Exam as well as getting the related certification under the guidance of our SPLK-2002 training materials as easy as pie. Just have a try on our SPLK-2002 exam questions, you will love them for sure!
The SPLK-2002: Splunk Enterprise Certified Architect exam is a challenging but rewarding certification for experienced Splunk professionals. It validates their skills and knowledge in designing and managing complex Splunk environments and opens up new career opportunities. If you are a Splunk professional looking to take your career to the next level, the SPLK-2002 Exam is definitely worth considering.
Splunk Enterprise Certified Architect Sample Questions (Q59-Q64):NEW QUESTION # 59
At which default interval does metrics.log generate a periodic report regarding license utilization?
  • A. 30 seconds
  • B. 10 seconds
  • C. 300 seconds
  • D. 60 seconds
The default interval at which metrics.log generates a periodic report regarding license utilization is 60 seconds. This report contains information about the license usage and quota for each Splunk instance, as well as the license pool and stack. The report is generated every 60 seconds by default, but this interval can be changed by modifying the license_usage stanza in the metrics.conf file. The other intervals (10 seconds, 30 seconds, and 300 seconds) are not the default values, but they can be set by the administrator if needed. For more information, see About metrics.log and Configure metrics.log in the Splunk documentation.
NEW QUESTION # 60
To improve Splunk performance, parallelIngestionPipelines setting can be adjusted on which of the following components in the Splunk architecture? (Select all that apply.)
  • A. Indexers
  • B. Search head
  • C. Cluster master
  • D. Forwarders
NEW QUESTION # 61
Splunk Enterprise platform instrumentation refers to data that the Splunk Enterprise deployment logs in the
_introspection index. Which of the following logs are included in this index? (Select all that apply.)
  • A. disk_objects.log
  • B. audit.log
  • C. resource_usage.log
  • D. metrics.log
The following logs are included in the _introspection index, which contains data that the Splunk Enterprise deployment logs for platform instrumentation:
* disk_objects.log. This log contains information about the disk objects that Splunk creates and manages, such as buckets, indexes, and files. This log can help monitor the disk space usage and the bucket lifecycle.
* resource_usage.log. This log contains information about the resource usage of Splunk processes, such as CPU, memory, disk, and network. This log can help monitor the Splunk performance and identify any resource bottlenecks. The following logs are not included in the _introspection index, but rather in the
_internal index, which contains data that Splunk generates for internal logging:
* audit.log. This log contains information about the audit events that Splunk records, such as user actions, configuration changes, and search activity. This log can help audit the Splunk operations and security.
* metrics.log. This log contains information about the performance metrics that Splunk collects, such as data throughput, data latency, search concurrency, and search duration. This log can help measure the Splunk performance and efficiency. For more information, see About Splunk Enterprise logging and
[About the _introspection index] in the Splunk documentation.
NEW QUESTION # 62
Search dashboards in the Monitoring Console indicate that the distributed deployment is approaching its capacity. Which of the following options will provide the most search performance improvement?
  • A. Add more search peers and make sure forwarders distribute data evenly across all indexers.
  • B. Look for slow searches and reschedule them to run during an off-peak time.
  • C. Replace the indexer storage to solid state drives (SSD).
  • D. Add more search heads and redistribute users based on the search type.
Adding more search peers and making sure forwarders distribute data evenly across all indexers will provide the most search performance improvement when the distributed deployment is approaching its capacity.
Adding more search peers will increase the search concurrency and reduce the load on each indexer.
Distributing data evenly across all indexers will ensure that the search workload is balanced and no indexer becomes a bottleneck. Replacing the indexer storage to SSD will improve the search performance, but it is a costly and time-consuming option. Adding more search heads will not improve the search performance if the indexers are the bottleneck. Rescheduling slow searches to run during an off-peak time will reduce the search contention, but it will not improve the search performance for each individual search. For more information, see [Scale your indexer cluster] and [Distribute data across your indexers] in the Splunk documentation.
NEW QUESTION # 63
To expand the search head cluster by adding a new member, node2, what first step is required?
  • A. splunk init shcluster-config -master_uri https://node2:8089 -replication_port 9200 -secret supersecretkey
  • B. splunk bootstrap shcluster-config -mgmt_uri https://node2:8089 -replication_port 9200 -secret supersecretkey
  • C. splunk init shcluster-config -mgmt_uri https://node2:8089 -replication_port 9200 -secret supersecretkey
  • D. splunk add shcluster-member -new_member_uri https://node2:8089 -replication_port 9200 -secret supersecretkey
To expand the search head cluster by adding a new member, node2, the first step is to initialize the cluster configuration on node2 using the splunk init shcluster-config command. This command sets the required parameters for the cluster member, such as the management URI, the replication port, and the shared secret key. The management URI must be unique for each cluster member and must match the URI that the deployer uses to communicate with the member. The replication port must be the same for all cluster members and must be different from the management port. The secret key must be the same for all cluster members and must be encrypted using the splunk _encrypt command. The master_uri parameter is optional and specifies the URI of the cluster captain. If not specified, the cluster member will use the captain election process to determine the captain. Option C shows the correct syntax and parameters for the splunk init shcluster- config command. Option A is incorrect because the splunk bootstrap shcluster-config command is used to bring up the first cluster member as the initial captain, not to add a new member. Option B is incorrect because the master_uri parameter is not required and the mgmt_uri parameter is missing. Option D is incorrect because the splunk add shcluster-member command is used to add an existing search head to the cluster, not to initialize a new member12
1: https://docs.splunk.com/Documentation/Splunk/9.1.2/DistSearch
/SHCdeploymentoverview#Initialize_cluster_members 2: https://docs.splunk.com/Documentation/Splunk/9.
1.2/DistSearch/SHCconfigurationdetails#Configure_the_cluster_members
NEW QUESTION # 64
NewPassLeader experts have also developed Splunk Enterprise Certified Architect (SPLK-2002) test simulation software for you to assess and improve yourself. This is especially useful for intensive preparation and revision. It will provide you with an Splunk Enterprise Certified Architect (SPLK-2002) exam environment and will give you real exam Splunk SPLK-2002 questions.
Exam SPLK-2002 Duration: https://www.newpassleader.com/Splunk/SPLK-2002-exam-preparation-materials.html
P.S. Free & New SPLK-2002 dumps are available on Google Drive shared by NewPassLeader: https://drive.google.com/open?id=1J0QQHYATo69BRbuIgud3_q9kySSIiTLb
Posted at 2/21/2026 08:39:23        Only Author  2#
I took away so much from reading that article. Free New CAPM dumps pdf materials are here. Best of luck in your exams!
Posted at 2/21/2026 17:19:45        Only Author  3#
Your article was incredibly refreshing, thank you. Here are the free Free 250-579 vce dumps materials! Best of luck on your test.
