[General] Experience 24/7 Support And Real Fortinet NSE8_812 Exam Questions With Braindump
67
General Experience 24/7 Support And Real Fortinet NSE8_812 Exam Questions With Braindump
Posted at 1/19/2026 12:24:02      View149 | Replies1        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest BraindumpsIT NSE8_812 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=19ra5BJewrxfhQOqeVRzf0t2qZj1-gaaU
We provide NSE8_812 Exam Torrent which are of high quality and can boost high passing rate and hit rate. Our passing rate is 99% and thus you can reassure yourself to buy our product and enjoy the benefits brought by our NSE8_812 exam materials. Our product is efficient and can help you master the Fortinet NSE 8 - Written Exam (NSE8_812) guide torrent in a short time and save your energy. The product we provide is compiled by experts and approved by the professionals who boost profound experiences.
Fortinet NSE8_812, also known as the Fortinet NSE 8 - Written Exam, is a certification exam designed to test the knowledge and skills of experienced network security professionals. NSE8_812 exam is intended for individuals who have a deep understanding of Fortinet's security solutions and are looking to become certified experts in the field. The Fortinet NSE8_812 exam is a rigorous, comprehensive test that covers a wide range of topics related to network security, including advanced threat protection, network design, and security policies.
Fortinet NSE8_812 Exam is intended for experienced network security professionals who have a strong understanding of network security concepts and technologies. Candidates should have at least five years of experience in network security design, implementation, and management, as well as experience with Fortinet's network security solutions.
NSE8_812 Exam Exercise - NSE8_812 Latest Guide FilesYou can also trust BraindumpsIT NSE8_812 exam practice questions and start preparation with complete peace of mind and satisfaction. The NSE8_812 Exam Questions are designed and verified by experienced and renowned Fortinet exam trainers. They work collectively and strive hard to ensure the top quality of NSE8_812 Exam Practice questions all the time.
Fortinet NSE 8 - Written Exam (NSE8_812) Sample Questions (Q72-Q77):NEW QUESTION # 72
A customer wants to use the FortiAuthenticator REST API to retrieve an SSO group called SalesGroup. The following API call is being made with the 'curl' utility:
Which two statements correctly describe the expected behavior of the FortiAuthenticator REST API? (Choose two.)
  • A. The syntax is incorrect because the API calls needs the get method.
  • B. Only users with the "Full permission" role can access the REST API
  • C. If the REST API web service access key is lost, it cannot be retrieved and must be changed.
  • D. This API call will fail because it requires that API version 2
To retrieve an SSO group called SalesGroup using the FortiAuthenticator REST API, the following issues need to be fixed in the API call:
The API version should be v2, not v1, as SSO groups are only supported in version 2 of the REST API.
The HTTP method should be GET, not POST, as GET is used to retrieve information from the server, while POST is used to create or update information on the server. Therefore, a correct API call would look like this: curl -X GET -H "Authorization: Bearer <token>" https://fac.example.com/api/v2/sso/groups/SalesGroup References: https://docs.fortinet.com/docume ... 927310/introduction https://docs.fortinet.com/docume ... e/927311/sso-groups
NEW QUESTION # 73
What is the benefit of using FortiGate NAC LAN Segments?
  • A. It provides support for multiple DHCP servers within the same VLAN.
  • B. It provides support for IGMP snooping between hosts within the same VLAN
  • C. It allows for assignment of dynamic address objects matching NAC policy.
  • D. It provides physical isolation without changing the IP address of hosts.
FortiGate NAC LAN Segments are a feature that allows users to assign different VLANs to different LAN segments without changing the IP address of hosts or bouncing the switch port. This provides physical isolation while maintaining firewall sessions and avoiding DHCP issues. One benefit of using FortiGate NAC LAN Segments is that it allows for assignment of dynamic address objects matching NAC policy. This means that users can create firewall policies based on dynamic address objects that match the NAC policy criteria, such as device type, OS type, MAC address, etc. This simplifies firewall policy management and enhances security by applying different security profiles to different types of devices. References: https://docs.fortinet.com/docume ... -lan-segments-7-0-1
NEW QUESTION # 74
A remote IT Team is in the process of deploying a FortiGate in their lab. The closed environment has been configured to support zero-touch provisioning from the FortiManager, on the same network, via DHCP options. After waiting 15 minutes, they are reporting that the FortiGate received an IP address, but the zero-touch process failed.
The exhibit below shows what the IT Team provided while troubleshooting this issue:
Which statement explains why the FortiGate did not install its configuration from the FortiManager?
  • A. The DHCP server used the incorrect option type for the FortiManager IP address.
  • B. The FortiGate was not configured with the correct pre-shared key to connect to the FortiManager
  • C. The DHCP server was not configured with the FQDN of the FortiManager
  • D. The configuration was modified on the FortiGate prior to connecting to the FortiManager
C is correct because the DHCP server used the incorrect option type for the FortiManager IP address. The option type should be 43 instead of 15, as shown in the FortiManager Administration Guide under Zero-Touch Provisioning > Configuring DHCP options for ZTP. References: https://docs.fortinet.com/docume ... 1/high-availability https://docs.fortinet.com/docume ... figuring-ha-options
NEW QUESTION # 75
An administrator has configured a FortiGate device to authenticate SSL VPN users using digital certificates.
A FortiAuthenticator is the certificate authority (CA) and the Online Certificate Status Protocol (OCSP) server.
Part of the FortiGate configuration is shown below:
Based on this configuration, which two statements are true? (Choose two.)
  • A. If the OCSP server is unreachable, authentication will succeed if the certificate matches the CA.
  • B. The OCSP check of the certificate can be combined with a certificate revocation list.
  • C. OCSP checks will always go to the configured FortiAuthenticator
  • D. OCSP certificate responses are never cached by the FortiGate.
Configuring SSL VPN authentication using digital certificates | FortiGate / FortiOS 7.2.0 - Fortinet Document Library Online Certificate Status Protocol (OCSP) | FortiGate / FortiOS 7.2.0 - Fortinet Document Library Certificate Revocation Lists (CRLs) | FortiGate / FortiOS 7.2.0 - Fortinet Document Library
NEW QUESTION # 76
Refer to the exhibit containing the configuration snippets from the FortiGate. Customer requirements:
* SSLVPN Portal must be accessible on standard HTTPS port (TCP/443)
* Public IP address (129.11.1.100) is assigned to portl
* Datacenter.acmecorp.com resolves to the public IP address assigned to portl The customer has a Let's Encrypt certificate that is going to expire soon and it reports that subsequent attempts to renew that certificate are failing.
Reviewing the requirement and the exhibit, which configuration change below will resolve this issue?
  • A.
  • B.
  • C.
  • D.
https://docs.fortinet.com/docume ... ically-provision-a- certificate
NEW QUESTION # 77
Tens of thousands of our worthy customers have been benefited by our NSE8_812 exam questions. Of course, your gain is definitely not just a NSE8_812 certificate. Our NSE8_812 study materials will change your working style and lifestyle. You will work more efficiently than others. Our NSE8_812 Training Materials can play such a big role. What advantages does it have? You can spend a few minutes free downloading our demos to check it out. And you will be surprised by the high-quality.
NSE8_812 Exam Exercise: https://www.braindumpsit.com/NSE8_812_real-exam.html
P.S. Free 2026 Fortinet NSE8_812 dumps are available on Google Drive shared by BraindumpsIT: https://drive.google.com/open?id=19ra5BJewrxfhQOqeVRzf0t2qZj1-gaaU
Posted at 1/20/2026 07:09:56        Only Author  2#
Thank you for the article, it was a real eye-catching read. With this H19-338-ENU test review system, I got promoted and received a salary raise. Now, its available for free to all. Wishing everyone a speedy promotion!
