[General] Free PDF Quiz ServiceNow - CIS-Discovery Authoritative Associate Level Exam
75
General Free PDF Quiz ServiceNow - CIS-Discovery Authoritative Associate Level Exam
Posted at 1/19/2026 12:54:18      View161 | Replies0        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest Lead2PassExam CIS-Discovery PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1NAyG8FjG4170Lo4AHo3eT1_7JCOZrnk7
By using the CIS-Discovery desktop practice exam software, you can sit in real exam like scenario. This CIS-Discovery practice exam simulates the complete environment of the actual test so you can overcome your fear about appearing in the ServiceNow CIS-Discovery Exam. Lead2PassExam has designed this software for your Windows laptops and computers.
ServiceNow CIS-Discovery Exam Syllabus Topics:
  • Operationalizing IT (i.e. MID Server and Discovery Dashboards, Benefits)
  • Pattern Designer (i.e. Debug, Steps, Sections)
  • Planning (i.e. MID Server Requirements and Specifications)
  • Syntax (i.e. Variables, Attributes, Regex)
  • Discovery Solution (i.e. Business Value, Definition, Positioning)
  • Discovery Setup (i.e. Behaviors, Clusters, IP Services, Schedules)
  • Application Identification and Connection Sections (Patterns, Identification and Connection Sections, Troubleshooting
Topic 5
  • Discovery Engagement Readiness
  • Discovery Configuration
  • Operations (i.e. Match, Parse variable, Parse file, Parsing strategies)
Topic 6
  • CMDB Identification and Reconciliation (i.e. CI Identifiers, Reconciliation Definitions, Datasource Precedence, CMDB De-duplication)
Topic 7
  • Discovery Process Flow (i.e. PCIE Phases, ECC Queue, Status, Discovered Device
  • Discovery Pattern Design
The CIS-Discovery Certification is intended for ServiceNow administrators who want to demonstrate their knowledge and skills in using the Discovery application. CIS-Discovery exam covers a range of topics, including the installation and configuration of Discovery, the use of probes and sensors to gather data from your IT infrastructure, and the use of ServiceNow's CMDB (Configuration Management Database) to track and manage your IT assets. Certified Implementation Specialist - Discovery certification is a great way to demonstrate your expertise in using ServiceNow's Discovery application and to stand out in a competitive job market.
New CIS-Discovery Test Practice | Reliable CIS-Discovery Test PatternThe ServiceNow CIS-Discovery certification exam is one of the hottest and career-oriented Certified Implementation Specialist - Discovery (CIS-Discovery) exams. With the Certified Implementation Specialist - Discovery (CIS-Discovery) exam you can validate your skills and upgrade your knowledge level. By doing this you can learn new in-demand skills and gain multiple career opportunities. To do this you just need to enroll in the ServiceNow CIS-Discovery Certification Exam and put all your efforts to pass this important ServiceNow CIS-Discovery Exam Questions.
How to Prepare for Certified Implementation Specialist - Discovery (CIS Discovery) ExamPreparation Guide for Certified Implementation Specialist - Discovery (CIS Discovery) Exam
Introduction
The ServiceNow Accredited Application Professional - Discovery CIS Discovery exam test specifies the intent, audience, testing choices, coverage of the substance of the exam, the research framework, and the specifications to become Discovery Certified. The ServiceNow Accredited Deployment Expert - Discovery test certifies that a qualified applicant has the expertise and experience to configure, handle, execute, and retain a Discovery framework on the ServiceNow platform. With preparation and qualification, you can learn how to master the strengths of ServiceNow by hands-on, real-world coaching to help you achieve your objectives. If you take interactive or in-person classes from ServiceNow or one of our Accredited Training Partners or study CIS Discovery exam dumps, you can learn how to be effective with the Now App. Companies are searching for proven practitioners-and companies utilizing trained professionals are looking for faster rollout and effective usage of ServiceNow. Being accredited would improve your career and help you add much further to the performance of your company.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q110-Q115):NEW QUESTION # 110
Device has both SNMP and SSH port open but during first discovery SSH failed am SNMP succeeded, What kind Affinity will be saved for future.
Response:
  • A. Credential Affinity
  • B. IP Service Affinity
NEW QUESTION # 111
Probe to pattern migration is only support for the release and later.
Response:
  • A. london
  • B. new York
  • C. madrid
  • D. probes cannot be migrated to patterns
NEW QUESTION # 112
Which method for deleting specific CIs is not discovered in 30 days?
  • A. Data Policy
  • B. Scheduled Job
  • C. UI Policy
  • D. Service Mapping
NEW QUESTION # 113
A Discovery Schedule contains a /24 subnet IP Range and a Shazzam batch size of 5000. How many times will a Shazzam probe be launched during discovery?
  • A. 0
  • B. 1
  • C. 2
  • D. 3
A /24 subnet IP Range means that there are 256 possible IP addresses in the range, from 0 to 255. A Shazzam batch size of 5000 means that Discovery will send 5000 ICMP packets at a time to scan the IP addresses.
Therefore, Discovery will launch the Shazzam probe once for every 5000 IP addresses in the range, or 256 /
5000 = 0.0512 times. Since the number of times must be an integer, Discovery will round up to 1 and launch the Shazzam probe once. However, since the Shazzam probe is launched for each MID Server that is assigned to the Discovery Schedule, the actual number of times will depend on how many MID Servers are available. If there are N MID Servers, then the Shazzam probe will be launched N times, each sending 5000 ICMP packets to the same IP range. Therefore, the total number of times that the Shazzam probe will be launched during discovery is N * 1 = N.
* Discovery Schedule form
* Shazzam Probe
* Discovery IP range
NEW QUESTION # 114
A discovery runs against a Windows Server returning the following attribute values for the first time:
name = WindowsSN1 serial_number = 12321
A subsequent discovery is ran against a different Windows Server returning the following attribute values:
name = WindowsSN2
With only base system CI Identifiers configured, which of the following is true?
  • A. A Windows Server CI is created, then updated with WindowsSN1 as the name.
  • B. A Windows Server CI is created, then updated with WindowsSN2 as the name.
  • C. Two Windows Sewer CIs are created, with WindowsSN1 AND WindowsSN2 for names.
  • D. Two Windows Server CIs are created, without serial_number values.
According to the ServiceNow Discovery documentation, the base system CI Identifiers for Windows Server class are name and serial_number. These are the attributes that Discovery uses to uniquely identify a Windows Server CI. If both attributes match an existing CI, Discovery updates that CI. If only one attribute matches, Discovery creates a new CI. If neither attribute matches, Discovery also creates a new CI. In this scenario, the serial_number is the same for both Windows Servers, but the name is different. Therefore, Discovery will create two separate CIs, one with WindowsSN1 as the name and one with WindowsSN2 as the name.
Create a Discovery CI classification - Product Documentation: Tokyo - Now Support Portal Identification rules - Product Documentation: Tokyo - Now Support Portal ServiceNow IRE: Identification Rules Explained - Cookdown
NEW QUESTION # 115
New CIS-Discovery Test Practice: https://www.lead2passexam.com/ServiceNow/valid-CIS-Discovery-exam-dumps.html
What's more, part of that Lead2PassExam CIS-Discovery dumps now are free: https://drive.google.com/open?id=1NAyG8FjG4170Lo4AHo3eT1_7JCOZrnk7
