[General] PL-300 Review Guide, New PL-300 Test Test
81
【General】 PL-300 Review Guide, New PL-300 Test Test
Posted at 1/19/2026 13:40:49      View:156 | Replies:2        Print      Only Author   [Copy Link] 1#
DOWNLOAD the newest ActualVCE PL-300 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1D1l3MKk_qVSfXq2r2wnwqDUQaWf10bKi
Our desktop Microsoft Power BI Data Analyst (PL-300) practice exam software allows you to see your progress report at the end of each attempt. In this way, you find your mistakes and overcome them before the final take. Our desktop software is customizable so you can change the duration and Microsoft questions of PL-300 Practice Tests according to your learning requirements. Since this software requires installation on Windows computers, you can take the Microsoft Power BI Data Analyst (PL-300) practice exam offline.
PL-300 exam dumps will give you enough information that you don't requirement to seek out any other source. ActualVCE can save you valuable time and money, resulting in satisfying results. PL-300 exam dumps will increase your level of preparation in minimum time. It's the perfect time to take the right decision. Download ActualVCE Microsoft PL-300 Exam Dumps now to proceed successfully in your professional career.
Pass Guaranteed Quiz PL-300 - High Hit-Rate Microsoft Power BI Data Analyst Review GuideThere are a lot of experts and professors in our company. All PL-300 study torrent of our company are designed by these excellent experts and professors in different area. We can make sure that our PL-300 test torrent has a higher quality than other study materials. The aim of our design is to improving your learning and helping you gains your PL-300 Certification in the shortest time. If you long to gain the certification, our Microsoft Power BI Data Analyst guide torrent will be your best choice.
Microsoft Power BI Data Analyst Sample Questions (Q363-Q368):NEW QUESTION # 363
You are profiling data by using Power Query Editor.
You have a table named Reports that contains a column named State. The distribution and quality data metrics for the data m State is shown in the following exhibit.
NEW QUESTION # 364
You need to create a solution to meet the notification requirements of the warehouse shipping department.
NOTE: Each correct select is worth one point:
NEW QUESTION # 365
Note: This question is part of a series of questions that use the same scenario. For your convenience, the scenario is repeated in each question. Each question presents a different goal and answer choices, but the text of the scenario is the same in each question in this series.
You have a Microsoft SQL Server database that contains the following tables.
The following columns contain date information:
- Date[Month] in the mmyyyy format
- Date[Date_ID] in the ddmmyyyy format
- Date[Date_name] in the mm/dd/yyyy format
- Monthly_returns[Month_ID] in the mmyyyy format
The Order table contains more than one million rows.
The Store table has a relationship to the Monthly_returns table on the Store_ID column. This is the only relationship between the tables.
You plan to use Power BI Desktop to create an analytics solution for the data.
You are modeling the data in Power BI.
You need to import only a sample of the data from the Order table.
What are two possible ways to achieve the goal? Each correct answer presents a complete solution.
  • A. In the Power BI model, create a calculated table.
  • B. From Query Editor, add a SELECT statement that uses a WHERE clause to the source definition.
  • C. From Query Editor, create a custom column that uses a custom column formula.
  • D. From Query Editor, filter the table by Order_date.
  • E. From Query Editor, create a column by using Column From Examples.
NEW QUESTION # 366
You have a Power BI data model that imports data from a Microsoft Excel spreadsheet.
You use Power Query to load a query that contains both renamed and custom columns.
Later, you attempt to reload the query and receive the following error message.
Expression.Error: The column 'Category' of the table wasn't found.
What are two possible causes of the error? Each correct answer presents a complete solution.
  • A. The column was removed from the source file.
  • B. The file is no longer in the specified location.
  • C. The column was renamed in the source file.
  • D. The data type of the column was changed.
NEW QUESTION # 367
You have the dataset shown in the following exhibit.
You need to ensure that the visual shows only the 10 cities that have the highest sales profit.
What should you do?
  • A. Add a calculated column to the table that returns the city name if the city is in the top 10, otherwise the calculated column will return "Not in Top 10". In the visual, replace Sales Profit with the calculated column.
  • B. Configure the Sales Profit measure to use the RANKX function.
  • C. Add a Top N filter to the visual.
  • D. Add a calculated column to the table that uses the TOPN function. In the visual, replace Sales Profit with the calculated column.
Power BI Top N Filters are useful to display the top performing records, and Bottom N filters are helpful to display the least performing records. For example, we can display top or bottom 10 products by orders or sales.
Note:
* Select the Column you want to display the Top Sales Profit
* Then change the Filter Type of that Column to Top N
* Fill in Top / Bottom number field
* And lastly drag to the By Value filed your Sales Profit
https://www.tutorialgateway.org/power-bi-top-10-filters/
NEW QUESTION # 368
We are committed to designing a kind of scientific PL-300 study material to balance your business and study schedule. With our PL-300 exam guide, all your learning process includes 20-30 hours. As long as you spare one or two hours a day to study with our laTest PL-300 Quiz prep, we assure that you will have a good command of the relevant knowledge before taking the PL-300 exam. What you need to do is to follow the PL-300 exam guide system at the pace you prefer as well as keep learning step by step.
New PL-300 Test Test: https://www.actualvce.com/Microsoft/PL-300-valid-vce-dumps.html
Microsoft PL-300 Review Guide It is more intelligent and pick out the mistakes and request you practice until you are skilled, Improve Your Confidence With Microsoft PL-300 Dumps PDF, So before choosing our PL-300 training vce pdf, please take a look briefly about PL-300 free pdf training with us together, Microsoft PL-300 Review Guide We have successfully collected a satisfied client base of more than 70,000 and the number is counting every day.
In it, Snyder takes beloved L.L.Bean classics and gives PL-300 Review Guide them new relevance, paired with his always-excellent tailoring, The steps are universal for all strategies.
It is more intelligent and pick out the mistakes PL-300 and request you practice until you are skilled, Improve Your Confidence With Microsoft PL-300 Dumps PDF, So before choosing our PL-300 training vce pdf, please take a look briefly about PL-300 free pdf training with us together.
Top PL-300 Review Guide | Professional Microsoft PL-300: Microsoft Power BI Data Analyst 100% PassWe have successfully collected a satisfied client base of more than 70,000 and the number is counting every day, And you can download the trial of our PL-300 training engine for free before your purchase.
What's more, part of that ActualVCE PL-300 dumps now are free: https://drive.google.com/open?id=1D1l3MKk_qVSfXq2r2wnwqDUQaWf10bKi
Posted at 2/5/2026 16:37:04        Only Author  2#
CompTIA인증220-1202시험은 국제적으로 승인해주는 IT인증시험의 한과목입니다. 근 몇년간 IT인사들에게 최고의 인기를 누리고 있는 과목으로서 그 난이도 또한 높습니다. 자격증을 취득하여 직장에서 혹은 IT업계에서 자시만의 위치를 찾으련다면 자격증 취득이 필수입니다. CompTIA인증220-1202시험을 패스하고 싶은 분들은Itcertkr제품으로 가보세요.
Posted at 2/17/2026 02:21:42        Only Author  3#
Just what I needed—liking it now. Free DS0-001 reliable test dumps pdf to improve your IT knowledge. Wishing you all the best!
