Quiz 1Z1-182 - Oracle Database 23ai Administration Associate–High Pass-Rate Onli
Posted at 1/19/2026 16:33:22
BTW, DOWNLOAD part of Test4Engine 1Z1-182 dumps from Cloud Storage: https://drive.google.com/open?id=130qgek_5RjRmb9WhTN41KgzSbipYQBWi
If you choose our 1Z1-182 exam questions, then you can have a study on the latest information and techlonogies on the subject and you will definitely get a lot of benefits from it. Of course, the most effective point is that as long as you carefully study the 1Z1-182 Study Guide for twenty to thirty hours, you can go to the exam. To really learn a skill, sometimes it does not take a lot of time. Come to buy our 1Z1-182 practice materials and we teach you how to achieve your goals efficiently.
1Z1-182 real questions in PDF format are vital in enhancing Oracle Oracle Database 23ai Administration Associate exam preparation. With Oracle Database 23ai Administration Associate (1Z1-182) exam dumps PDF, you can easily study via your smartphone, laptop, and tablet. Test4Engine has designed the Oracle Database 23ai Administration Associate (1Z1-182) PDF format for your convenience, so you prepare for the certification exam at any time and anywhere you want. You can also print questions in the Oracle Database 23ai Administration Associate (1Z1-182) dumps PDF format if you want to avoid eye strain.
Reliable Oracle 1Z1-182 Test Book, Test 1Z1-182 DurationTest4Engine have made sure that each Oracle 1Z1-182 exam questions are updated according to the latest Oracle 1Z1-182 exam criteria issued by Oracle. Each Oracle 1Z1-182 exam question gets reviewed by Oracle professionals many times to ensure incomparable accuracy. Test4Engine offer a demo version of the actual Oracle 1Z1-182 Exam Question only for customer satisfaction and the candidates can check the validity of the product before actually buying it.
Oracle Database 23ai Administration Associate Sample Questions (Q87-Q92):NEW QUESTION # 87
You are going to perform a hot remote clone of PDB1 from CDB1 as TESTPDB in CDB2. Which of the following is a necessary prerequisite for the hot remote clone?
- A. PDB1 must be in read-only mode.
- B. TESTPDB must be in read-only mode after the cloning process is complete.
- C. PDB1 must be taken offline before the cloning process begins.
- D. Both CDBs need to be in local undo mode.
C .True. Hot cloning requires the source PDB (PDB1) to be read-only to ensure consistency during the clone. Others are not prerequisites.
NEW QUESTION # 88
Which three statements are true about row chaining and row migration done by Oracle database block space management?
- A. Update statements can result in one or more migrated rows.
- B. A migrated row results in an update to any index on the table to point the row ID in the index to the row's new location.
- C. Update statements can result in one or more chained rows.
- D. Row pieces of a chained row must always reside in different blocks.
- E. Insert statements can result in a migrated row.
Answer: A,B,C
A .True. Migration updates index ROWIDs.
B .True. Updates can migrate rows if space is insufficient.
C .True. Large updates can chain rows across blocks.
D .False. Chained rows may span blocks but aren't required to.
E .False. Inserts don't migrate; they chain if too large initially.
NEW QUESTION # 89
Which two are true about shrinking a segment online?
- A. To shrink a table it must have a UNIQUE KEY constraint.
- B. To shrink a table it must have a PRIMARY KEY constraint.
- C. It must be in a tablespace that uses Automatic Segment Space Management (ASSM).
- D. It is not possible to shrink either indexes or Index Organized Tables (IOTs).
- E. To shrink a table it must have row movement enabled.
Answer: C,E
A .True. ROW MOVEMENT must be enabled for SHRINK SPACE.
B .False. Indexes and IOTs can be shrunk with CASCADE.
C .False. No such constraint requirement.
D .True. ASSM is required for online shrinking.
E .False. No primary key requirement.
NEW QUESTION # 90
Examine this command: ALTER DATABASE MOVE DATAFILE '/u01/sales01.dbf' TO '/u02/sales02.dbf'; Which two statements are true?
- A. Tables with one or more extents in this data file may be queried during the execution of this command.
- B. DML may be performed on tables with one or more extents in this data file during the execution of this command.
- C. Compressed objects in sales01.dbf will be uncompressed in sales02.dbf after the move.
- D. It overwrites any existing file with the name sales02.dbf in /u02 by default.
- E. The "TO" clause containing the new file name must be specified even if Oracle Managed Files (OMF) is used.
The ALTER DATABASE MOVE DATAFILE command relocates a data file to a new location while the database remains online, introduced in Oracle 12c and enhanced in subsequent releases like 23ai. Let's evaluate each option:
A . DML may be performed on tables with one or more extents in this data file during the execution of this command.True. The move operation is online by default in Oracle 23ai, allowing DML (INSERT, UPDATE, DELETE) operations on tables within the data file being moved. The database ensures consistency using redo and undo mechanisms.
B . It overwrites any existing file with the name sales02.dbf in /u02 by default.False. By default, the command does not overwrite an existing file unless the REUSE clause is specified (e.g., ALTER DATABASE MOVE DATAFILE ... REUSE). Without it, the command fails if the target file exists.
C . The "TO" clause containing the new file name must be specified even if Oracle Managed Files (OMF) is used.False. When OMF is enabled (via DB_CREATE_FILE_DEST), the TO clause is optional. If omitted, Oracle automatically generates a file name and places it in the OMF destination.
D . Compressed objects in sales01.dbf will be uncompressed in sales02.dbf after the move.False. The move operation is a physical relocation of the data file; it does not alter the logical structure or compression state of objects within it. Compressed data remains compressed.
E . Tables with one or more extents in this data file may be queried during the execution of this command.True. The online nature of the move allows queries (SELECT statements) to proceed without interruption, leveraging Oracle's multi-version consistency model.
NEW QUESTION # 91
Which two Oracle database space management features require the use of locally managed tablespaces?
- A. Free space management with bitmaps.
- B. Server-generated tablespace space alerts.
- C. Online segment shrink.
- D. Automatic data file extension (AUTOEXTEND).
- E. Oracle Managed Files (OMF).
A .False. Works with DMTs too.
B .True. LMTs use bitmaps, unlike DMT freelists.
C .False. OMF is independent of management type.
D .False. Alerts work with both.
E .True. Shrink requires LMTs with ASSM.
NEW QUESTION # 92
One of the biggest challenges of undertaking a Oracle 1Z1-182 exam is managing your time effectively. This means setting aside enough time to stud. Many students struggle with this challenge because they are not able to set aside enough time to study and end up rushing through the material at the last minute. Our Oracle 1Z1-182 Pdf Dumps offer an alternate way by providing relevant Oracle 1Z1-182 questions and answers to prepare in the shortest possible time.
Reliable 1Z1-182 Test Book: https://www.test4engine.com/1Z1-182_exam-latest-braindumps.html
Oracle 1Z1-182 Online Version Now, you only need to find the "download for free" item in our website, and you will notice that there are three kinds of versions for you to choose, Oracle 1Z1-182 Online Version Previously, the related content was part of an associate-level certification, The Reliable 1Z1-182 Test Book Plus test is open to technical professionals of all backgrounds, but this can be very rewarding for Reliable 1Z1-182 Test Book members or for Reliable 1Z1-182 Test Book (or both), If you choose to prepare the exam by yourself, there will be many difficulties without the help of our 1Z1-182 cert material.
Understand the way Active Directory replication Test 1Z1-182 Duration works and its importance in keeping all domain controllers up to date, The Outlets and Actions are then connected to View subsystem objects Reliable 1Z1-182 Test Book like button and text fields to give the window controller direct access to those objects.
Get the Most Recent Oracle 1Z1-182 Exam Questions for Guaranteed SuccessNow, you only need to find the "download for free" item in our website, and 1Z1-182 Online Version you will notice that there are three kinds of versions for you to choose, Previously, the related content was part of an associate-level certification.
The Oracle Database 23ai Plus test is open to technical professionals 1Z1-182 of all backgrounds, but this can be very rewarding for Oracle Database 23ai members or for Oracle Database 23ai (or both).
If you choose to prepare the exam by yourself, there will be many difficulties without the help of our 1Z1-182 cert material, Our 1Z1-182 exam bootcamp materials are elaborately written from easy to difficult, from simple to complex.
- 1Z1-182 Test Sample Questions 🦟 1Z1-182 Practice Braindumps 🍉 1Z1-182 Study Tool 🐹 Search for { 1Z1-182 } and download it for free on ▷ [url]www.examdiscuss.com ◁ website 👈1Z1-182 Dump File[/url]
- Free PDF Quiz 2026 1Z1-182: High Pass-Rate Oracle Database 23ai Administration Associate Online Version 🦱 Search for ☀ 1Z1-182 ️☀️ on ▷ [url]www.pdfvce.com ◁ immediately to obtain a free download 🥐Online 1Z1-182 Training Materials[/url]
- 1Z1-182 Exam Collection Pdf 😳 1Z1-182 Practice Braindumps 🥻 Online 1Z1-182 Training Materials 🏊 Copy URL ➥ [url]www.examcollectionpass.com 🡄 open and search for 「 1Z1-182 」 to download for free 🔓1Z1-182 Dump File[/url]
- Don't Miss Up to 365 Days of Free Updates - Buy Oracle 1Z1-182 Questions Now 😽 Open ☀ [url]www.pdfvce.com ️☀️ enter ▶ 1Z1-182 ◀ and obtain a free download 🧾1Z1-182 Test Sample Questions[/url]
- 1Z1-182 Valid Test Braindumps 🕷 1Z1-182 Valid Test Online 🚃 Brain Dump 1Z1-182 Free 🐦 Open website 「 [url]www.vceengine.com 」 and search for “ 1Z1-182 ” for free download 📺Reliable 1Z1-182 Test Pattern[/url]
- Online 1Z1-182 Training Materials 🤘 1Z1-182 Latest Braindumps 🏬 Pass 1Z1-182 Test Guide 💛 Search for 《 1Z1-182 》 and easily obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 📮1Z1-182 Practice Braindumps[/url]
- Hot 1Z1-182 Online Version 100% Pass | Efficient Reliable 1Z1-182 Test Book: Oracle Database 23ai Administration Associate 🏎 Open 【 [url]www.practicevce.com 】 and search for ➤ 1Z1-182 ⮘ to download exam materials for free 🔒1Z1-182 Latest Braindumps[/url]
- Don't Miss Up to 365 Days of Free Updates - Buy Oracle 1Z1-182 Questions Now 🐉 Search for ➤ 1Z1-182 ⮘ and easily obtain a free download on ( [url]www.pdfvce.com ) 🦥1Z1-182 Valid Test Online[/url]
- The Benefits of Using Desktop Oracle 1Z1-182 Practice Test Software 🌴 The page for free download of ⇛ 1Z1-182 ⇚ on ➤ [url]www.prepawaypdf.com ⮘ will open immediately 🥦Interactive 1Z1-182 EBook[/url]
- Don't Miss Up to 365 Days of Free Updates - Buy Oracle 1Z1-182 Questions Now 🛣 Enter ✔ [url]www.pdfvce.com ️✔️ and search for ➠ 1Z1-182 🠰 to download for free 🐨1Z1-182 Examcollection Dumps Torrent[/url]
- 1Z1-182 Online Training Materials 🚊 Online 1Z1-182 Training Materials 🙉 Test 1Z1-182 Dumps.zip 🙋 Open website ▶ [url]www.torrentvce.com ◀ and search for 「 1Z1-182 」 for free download 🥉1Z1-182 Valid Test Braindumps[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, digicomtrainingacademy.org, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
2026 Latest Test4Engine 1Z1-182 PDF Dumps and 1Z1-182 Exam Engine Free Share: https://drive.google.com/open?id=130qgek_5RjRmb9WhTN41KgzSbipYQBWi
