[General] Dumps ARA-C01 Reviews, ARA-C01 Official Study Guide
101
General Dumps ARA-C01 Reviews, ARA-C01 Official Study Guide
Posted at 1/19/2026 16:46:28      View203 | Replies4        Print      Only Author   [Copy Link] 1#
BONUS!!! Download part of PassTestking ARA-C01 dumps for free: https://drive.google.com/open?id=1rfDCumygfxewCad0SXWQ_D80lHYUsyhT
Certification is moving these days and is essential to finding a tremendous compensation calling. Different promising beginners stand around inactively and cash due to including an invalid prep material for the Snowflake ARA-C01 exam. To make an open entrance and cash, everybody should gather themselves with the right and built up base on material for ARA-C01 Exam. The top-notch highlights are given to clients to affect the essential undertaking in certification. Every one of you can test your course of action with Snowflake ARA-C01 Dumps by giving the phony test.
Snowflake ARA-C01 Exam covers a wide range of topics, including Snowflake architecture, data loading, performance tuning, security and access control, and data sharing. Candidates are expected to have a deep understanding of Snowflake architecture, including the various components of a Snowflake deployment and how they work together. They must also be able to design and implement Snowflake solutions that meet business requirements and performance expectations.
Snowflake ARA-C01 (SnowPro Advanced Architect Certification) Certification Exam is a highly reputable certification that is recognized globally by businesses and organizations that use Snowflake. SnowPro Advanced Architect Certification certification exam is designed to test the skills and knowledge of individuals who want to become advanced architects in data warehousing and data analytics. SnowPro Advanced Architect Certification certification is a valuable asset for individuals who want to advance their careers in these fields, and there are several resources available to help candidates prepare for the exam.
ARA-C01 study guide material & ARA-C01 sure pass dumps is for your successful passNow passing Snowflake certification ARA-C01 exam is not easy, so choosing a good training tool is a guarantee of success. PassTestking will be the first time to provide you with exam information and exam practice questions and answers to let you be fully prepared to ensure 100% to pass Snowflake Certification ARA-C01 Exam. PassTestking can not only allow you for the first time to participate in the Snowflake certification ARA-C01 exam to pass it successfully, but also help you save a lot of valuable time.
Snowflake SnowPro Advanced Architect Certification Sample Questions (Q97-Q102):NEW QUESTION # 97
An Architect is designing a file ingestion recovery solution. The project will use an internal named stage for file storage. Currently, in the case of an ingestion failure, the Operations team must manually download the failed file and check for errors.
Which downloading method should the Architect recommend that requires the LEAST amount of operational overhead?
  • A. Use the Snowflake API endpoint and download the file.
  • B. Use the get command in Snowsight to retrieve the file.
  • C. Use the Snowflake Connector for Python, connect to remote storage and download the file.
  • D. Use the get command in SnowSQL to retrieve the file.
NEW QUESTION # 98
What is the MOST efficient way to design an environment where data retention is not considered critical, and customization needs are to be kept to a minimum?
  • A. Use a transient table.
  • B. Use a transient schema.
  • C. Use a temporary table.
  • D. Use a transient database.
Transient databases in Snowflake are designed for situations where data retention is not critical, and they do not have the fail-safe period that regular databases have. This means that data in a transient database is not recoverable after the Time Travel retention period. Using a transient database is efficient because it minimizes storage costs while still providing most functionalities of a standard database without the overhead of data protection features that are not needed when data retention is not a concern.
NEW QUESTION # 99
You have a table named JSON_TBL which has a variant column JSON_VAR. The json stored in that table looks as below
"COURSE_DESC": "SNOWFLAKE CERTIFICATION",
"COURSE_ID": 1000,
"DURATION": 2
if you run a query SELECT JSON_VAR:Course_id FROM JSON_TBL; what will it return
  • A. NULL
  • B. 0
  • C. 1
NEW QUESTION # 100
A retail company has over 3000 stores all using the same Point of Sale (POS) system. The company wants to deliver near real-time sales results to category managers. The stores operate in a variety of time zones and exhibit a dynamic range of transactions each minute, with some stores having higher sales volumes than others.
Sales results are provided in a uniform fashion using data engineered fields that will be calculated in a complex data pipeline. Calculations include exceptions, aggregations, and scoring using external functions interfaced to scoring algorithms. The source data for aggregations has over 100M rows.
Every minute, the POS sends all sales transactions files to a cloud storage location with a naming convention that includes store numbers and timestamps to identify the set of transactions contained in the files. The files are typically less than 10MB in size.
How can the near real-time results be provided to the category managers? (Select TWO).
  • A. All files should be concatenated before ingestion into Snowflake to avoid micro-ingestion.
  • B. An external scheduler should examine the contents of the cloud storage location and issue SnowSQL commands to process the data at a frequency that matches the real-time analytics needs.
  • C. The copy into command with a task scheduled to run every second should be used to achieve the near-real time requirement.
  • D. A stream should be created to accumulate the near real-time data and a task should be created that runs at a frequency that matches the real-time analytics needs.
  • E. A Snowpipe should be created and configured with AUTO_INGEST = true. A stream should be created to process INSERTS into a single target table using the stream metadata to inform the store number and timestamps.
Answer: D,E
To provide near real-time sales results to category managers, the Architect can use the following steps:
* Create an external stage that references the cloud storage location where the POS sends the sales transactions files. The external stage should use the file format and encryption settings that match the source files2
* Create a Snowpipe that loads the files from the external stage into a target table in Snowflake. The Snowpipe should be configured with AUTO_INGEST = true, which means that it will automatically detect and ingest new files as they arrive in the external stage. The Snowpipe should also use a copy option to purge the files from the external stage after loading, to avoid duplicate ingestion3
* Create a stream on the target table that captures the INSERTS made by the Snowpipe. The stream should include the metadata columns that provide information about the file name, path, size, and last modified time. The stream should also have a retention period that matches the real-time analytics needs4
* Create a task that runs a query on the stream to process the near real-time data. The query should use the stream metadata to extract the store number and timestamps from the file name and path, and perform the calculations for exceptions, aggregations, and scoring using external functions. The query should also output the results to another table or view that can be accessed by the category managers. The task should be scheduled to run at a frequency that matches the real-time analytics needs, such as every minute or every 5 minutes.
The other options are not optimal or feasible for providing near real-time results:
* All files should be concatenated before ingestion into Snowflake to avoid micro-ingestion. This option is not recommended because it would introduce additional latency and complexity in the data pipeline.
Concatenating files would require an external process or service that monitors the cloud storage location and performs the file merging operation. This would delay the ingestion of new files into Snowflake and increase the risk of data loss or corruption. Moreover, concatenating files would not avoid micro-ingestion, as Snowpipe would still ingest each concatenated file as a separate load.
* An external scheduler should examine the contents of the cloud storage location and issue SnowSQL commands to process the data at a frequency that matches the real-time analytics needs. This option is not necessary because Snowpipe can automatically ingest new files from the external stage without requiring an external trigger or scheduler. Using an external scheduler would add more overhead and dependency to the data pipeline, and it would not guarantee near real-time ingestion, as it would depend on the polling interval and the availability of the external scheduler.
* The copy into command with a task scheduled to run every second should be used to achieve the near-real time requirement. This option is not feasible because tasks cannot be scheduled to run every second in Snowflake. The minimum interval for tasks is one minute, and even that is not guaranteed, as tasks are subject to scheduling delays and concurrency limits. Moreover, using the copy into command with a task would not leverage the benefits of Snowpipe, such as automatic file detection, load balancing, and micro-partition optimization. References:
* 1: SnowPro Advanced: Architect | Study Guide
* 2: Snowflake Documentation | Creating Stages
* 3: Snowflake Documentation | Loading Data Using Snowpipe
* 4: Snowflake Documentation | Using Streams and Tasks for ELT
* : Snowflake Documentation | Creating Tasks
* : Snowflake Documentation | Best Practices for Loading Data
* : Snowflake Documentation | Using the Snowpipe REST API
* : Snowflake Documentation | Scheduling Tasks
* : SnowPro Advanced: Architect | Study Guide
* : Creating Stages
* : Loading Data Using Snowpipe
* : Using Streams and Tasks for ELT
* : [Creating Tasks]
* : [Best Practices for Loading Data]
* : [Using the Snowpipe REST API]
* : [Scheduling Tasks]
NEW QUESTION # 101
Which organization-related tasks can be performed by the ORGADMIN role? (Choose three.)
  • A. Changing the name of the organization
  • B. Deleting an account
  • C. Viewing a list of organization accounts
  • D. Creating an account
  • E. Enabling the replication of a database
  • F. Changing the name of an account
Answer: C,D,E
According to the SnowPro Advanced: Architect documents and learning resources, the organization-related tasks that can be performed by the ORGADMIN role are:
* Creating an account in the organization. A user with the ORGADMIN role can use the CREATE ACCOUNT command to create a new account that belongs to the same organization as the current account1.
* Viewing a list of organization accounts. A user with the ORGADMIN role can use the SHOW ORGANIZATION ACCOUNTS command to view the names and properties of all accounts in the organization2. Alternatively, the user can use the Admin a Accounts page in the web interface to view the organization name and account names3.
* Enabling the replication of a database. A user with the ORGADMIN role can use the SYSTEM$GLOBAL_ACCOUNT_SET_PARAMETER function to enable database replication for an account in the organization. This allows the user to replicate databases across accounts in different regions and cloud platforms for data availability and durability4.
The other options are incorrect because they are not organization-related tasks that can be performed by the ORGADMIN role. Option A is incorrect because changing the name of the organization is not a task that can be performed by the ORGADMIN role. To change the name of an organization, the user must contact Snowflake Support3. Option D is incorrect because changing the name of an account is not a task that can be performed by the ORGADMIN role. To change the name of an account, the user must contact Snowflake Support5. Option E is incorrect because deleting an account is not a task that can be performed by the ORGADMIN role. To delete an account, the user must contact Snowflake Support. References: CREATE ACCOUNT | Snowflake Documentation, SHOW ORGANIZATION ACCOUNTS | Snowflake Documentation, Getting Started with Organizations | Snowflake Documentation, SYSTEM$GLOBAL_ACCOUNT_SET_PARAMETER | Snowflake Documentation, ALTER ACCOUNT | Snowflake Documentation, [DROP ACCOUNT | Snowflake Documentation]
NEW QUESTION # 102
As we know, Snowflake actual test is related to the IT professional knowledge and experience, it is not easy to clear ARA-C01 practice exam. The difficulty of exam and the lack of time reduce your pass rate. And it will be a great loss for you if you got a bad result in the ARA-C01 Exam Tests. So it is urgent for you to choose a study appliance, especially for most people participating ARA-C01 real exam first time.
ARA-C01 Official Study Guide: https://www.passtestking.com/Snowflake/ARA-C01-practice-exam-dumps.html
DOWNLOAD the newest PassTestking ARA-C01 PDF dumps from Cloud Storage for free: https://drive.google.com/open?id=1rfDCumygfxewCad0SXWQ_D80lHYUsyhT
Posted at 1/23/2026 22:57:02        Only Author  2#
Your article is outstanding; thank you for sharing it! The Exam 1Z1-947 reviews test questions are freegood luck with your exam preparations!
Posted at 1/26/2026 10:06:23        Only Author  3#
Your article was remarkable, Im truly thankful for it. We offer you access to the rich content of ACD201 exam questions pdf for free, hoping it benefits you.
Posted at 2/6/2026 18:10:39        Only Author  4#
What a powerful piece, thank you for sharing this inspiring article! I secured a promotion and salary boost with the SPI exam simulator free. Now, its free for all. Wishing you all success and career growth!
Posted at 2/21/2026 11:21:48        Only Author  5#
KoreaDumps 는 완전히 여러분이 인증시험 준비와 안전한 시험패스를 위한 완벽한 덤프제공 사이트입니다.우리 KoreaDumps의 덤프들은 응시자에 따라 ,시험 ,시험방법에 따라 알 맞춤한 퍼펙트한 자료입니다.여러분은 KoreaDumps의 알맞춤 덤프들로 아주 간단하고 편하게 인증시험을 패스할 수 있습니다.많은 HPE2-W12인증관연 응시자들은 우리 KoreaDumps가 제공하는HPE2-W12 문제와 답으로 되어있는 덤프로 자격증을 취득하셨습니다.우리 KoreaDumps 또한 업계에서 아주 좋은 이미지를 가지고 있습니다.
