DVA-C02 Test Papers | Test DVA-C02 Questions
Posted at 1/19/2026 17:00:39
View212
Replies4
BTW, DOWNLOAD part of ExamcollectionPass DVA-C02 dumps from Cloud Storage: https://drive.google.com/open?id=1tNeRmi9-YWlc77ehNlovHL3TZff3QeqB
With DVA-C02 study engine, you will get rid of the dilemma that you work hard but cannot improve. With our DVA-C02 learning materials, you can spend less time but learn more knowledge than others. DVA-C02 exam questions will help you reach the peak of your career. Just think of that after you get the DVA-C02 Certification, you will have a lot of opportunities of going to biger and better company and getting higher incomes! what a brighter future!
Amazon DVA-C02 Certification is a valuable credential for developers who want to demonstrate their expertise in AWS development. AWS Certified Developer - Associate certification can help professionals advance their careers by demonstrating their skills and knowledge to potential employers. It can also help organizations identify qualified developers who can design and deploy secure and scalable AWS applications that meet their business needs.
Pass Guaranteed Quiz 2026 Accurate DVA-C02: AWS Certified Developer - Associate Test PapersDo you want to pass DVA-C02 exam easily? DVA-C02 exam training materials of ExamcollectionPass is a good choice, which covers all the content and answers about DVA-C02 exam dumps you need to know. Then you can master the difficult points in a limited time, pass the DVA-C02 Exam in one time, improve your professional value and stand more closely to success.
Amazon AWS Certified Developer - Associate Sample Questions (Q154-Q159):NEW QUESTION # 154
A company is planning to use AWS CodeDeploy to deploy an application to Amazon Elastic Container Service (Amazon ECS) During the deployment of a new version of the application, the company initially must expose only 10% of live traffic to the new version of the deployed application. Then, after 15 minutes elapse, the company must route all the remaining live traffic to the new version of the deployed application.
Which CodeDeploy predefined configuration will meet these requirements?
- A. CodeDeployDefault LambdaCanary10Percent5Minutes
- B. CodeDeployDefault LambdaCanary10Percent15Minutes
- C. CodeDeployDefault ECSLinear10PercentEvery1 Minutes
- D. CodeDeployDefault ECSCanary10Percent15Minutes
* CodeDeploy Predefined Configurations: CodeDeploy offers built-in deployment configurations for common scenarios.
* Canary Deployment: Canary deployments gradually shift traffic to a new version, ideal for controlled rollouts like this requirement.
* CodeDeployDefault.ECSCanary10Percent15Minutes: This configuration matches the company's requirements, shifting 10% of traffic initially and then completing the rollout after 15 minutes.
NEW QUESTION # 155
An ecommerce company is using an AWS Lambda function behind Amazon API Gateway as its application tier. To process orders during checkout, the application calls a POST API from the frontend. The POST API invokes the Lambda function asynchronously. In rare situations, the application has not processed orders. The Lambda application logs show no errors or failures.
What should a developer do to solve this problem?
- A. Inspect the Lambda logs in Amazon CloudWatch for possible errors. Fix the errors.
- B. Create and inspect the Lambda dead-letter queue. Troubleshoot the failed functions. Reprocess the events.
- C. Inspect the frontend logs for API failures. Call the POST API manually by using the requests from the log file.
- D. Make sure that caching is disabled for the POST API in API Gateway.
The solution that will solve this problem is to create and inspect the Lambda dead-letter queue. Troubleshoot the failed functions. Reprocess the events. This way, the developer can identify and fix any issues that caused the Lambda function to fail when invoked asynchronously by API Gateway. The developer can also reprocess any orders that were not processed due to failures. The other options either do not address the root cause of the problem, or do not help recover from failures.
NEW QUESTION # 156
A developer is writing an application to analyze the traffic to a fleet of Amazon EC2 instances.
The EC2 instances run behind a public Application Load Balancer (ALB). An HTTP server runs on each of the EC2 instances, logging all requests to a log file.
The developer wants to capture the client public IP addresses. The developer analyzes the log files and notices only the IP address of the ALB.
What must the developer do to capture the client public IP addresses in the log file?
- A. Add an X-Forwarded-For header to the HTTP server log configuration file.
- B. Install the AWS X-Ray daemon on each EC2 instance. Configure the daemon to write to the log file.
- C. Add a Host header to the HTTP server log configuration file.
- D. Install the Amazon CloudWatch Logs agent on each EC2 instance. Configure the agent to write to the log file.
NEW QUESTION # 157
A developer is creating a mobile application that will not require users to log in.
What is the MOST efficient method to grant users access to AWS resources'?
- A. Create credentials using AWS KMS and apply these credentials to users when using the application.
- B. Use an identity provider to securely authenticate with the application.
- C. Use Amazon Cognito to associate unauthenticated users with an IAM role that has limited access to resources.
- D. Create an AWS Lambda function to create an 1AM user when a user accesses the application.
This solution is the most efficient method to grant users access to AWS resources without requiring them to log in. Amazon Cognito is a service that provides user sign-up, sign-in, and access control for web and mobile applications. Amazon Cognito identity pools support both authenticated and unauthenticated users. Unauthenticated users receive access to your AWS resources even if they aren't logged in with any of your identity providers (IdPs). You can use Amazon Cognito to associate unauthenticated users with an IAM role that has limited access to resources, such as Amazon S3 buckets or DynamoDB tables. This degree of access is useful to display content to users before they log in or to allow them to perform certain actions without signing up. Using an identity provider to securely authenticate with the application will require users to log in, which does not meet the requirement. Creating an AWS Lambda function to create an IAM user when a user accesses the application will incur unnecessary costs and complexity, and may pose security risks if not implemented properly. Creating credentials using AWS KMS and applying them to users when using the application will also incur unnecessary costs and complexity, and may not provide fine-grained access control for resources.
NEW QUESTION # 158
A developer wants to use an AWS AppSync API to invoke AWS Lambda functions to return data. Some of the Lambda functions perform long-running processes. The AWS AppSync API needs to return responses immediately.
Which solution will meet these requirements with the LEAST operational overhead?
- A. Configure the Lambda functions to be AWS AppSync data sources. Use Event mode for asynchronous Lambda invocation.
- B. Set up an Amazon SQS queue. Configure AWS AppSync to send messages to the SQS queue.
Configure a Lambda function event source mapping to poll the queue. - C. Enable caching, and increase the duration of the AWS AppSync cache TTL.
- D. Increase the timeout setting for the Lambda functions to accommodate longer processing times.
Step-by-Step Breakdown:
Requirement Summary:
* AWS AppSync API needs toinvoke Lambda functions
* Some Lambda functions arelong-running
* AppSync shouldreturn immediately, minimizingoperational overhead
**Option A: AppSync + Lambda as data source usingEvent Mode
* #Correct: AWS AppSync supportsasynchronous (event) invocationof Lambda data sources using Event Mode.
* Event Mode means:
* AppSync invokes Lambdaasynchronously
* Immediately returns aresponseto the client (typically a predefined payload or null)
* Ideal forfire-and-forgetworkloads or when the response is not immediately needed Option B: Increase Lambda timeout
* #Incorrect: This keeps AppSync waiting.
* Even with increased timeout, synchronous invocations wouldblock AppSync responses.
Option C: SQS queue + polling Lambda
* #Possible but too complex for this use case.
* Requires additional infrastructure: queue + mapping + custom logic.
* Higheroperational overheadcompared to built-in AppSync Event Mode.
Option D: Enable caching in AppSync
* #Irrelevant: AppSync cache is for optimizing repeated read queries,not for async workflows.
* Asynchronous Lambda with AppSync:https://docs.aws.amazon.com/appsync/latest/devguide/resolver- mapping-template-reference-lambda.html#async-lambda-invocation
* Lambda as AppSync Data Source:https://docs.aws.amazon.com/appsync/latest/devguide/tutorial- lambda-resolvers.html
* Event Mode Docs:https://docs.aws.amazon.com/apps ... solvers.html#event- invocation-mode
NEW QUESTION # 159
If you visit our website ExamcollectionPass, then you will find that our Amazon DVA-C02 practice questions are written in three different versions: PDF version, Soft version and APP version. All types of DVA-C02 Training Questions are priced favorably on your wishes. Obtaining our Amazon DVA-C02 study guide in the palm of your hand, you can achieve a higher rate of success.
Test DVA-C02 Questions: https://www.examcollectionpass.com/Amazon/DVA-C02-practice-exam-dumps.html
- Free Updates the Amazon DVA-C02 Exam for 365 Days to Keep You Ahead 🧂 Search for { DVA-C02 } and obtain a free download on ▛ [url]www.pass4test.com ▟ 🍀Test DVA-C02 Questions Pdf[/url]
- DVA-C02 Pass Exam ⏪ DVA-C02 Reliable Test Experience 🏫 DVA-C02 Pass Exam 🥔 Download ⮆ DVA-C02 ⮄ for free by simply searching on ⮆ [url]www.pdfvce.com ⮄ 🏚DVA-C02 Exam Torrent[/url]
- DVA-C02 Latest Real Test 🗺 Training DVA-C02 Material 💖 DVA-C02 Exam Torrent ⬛ Immediately open ▶ [url]www.testkingpass.com ◀ and search for DVA-C02 to obtain a free download 📋Valid DVA-C02 Study Plan[/url]
- Free Updates the Amazon DVA-C02 Exam for 365 Days to Keep You Ahead 😹 Open [url]www.pdfvce.com enter ➠ DVA-C02 🠰 and obtain a free download 🟧Training DVA-C02 Material[/url]
- DVA-C02 Reliable Learning Materials 🤘 Exam DVA-C02 Guide Materials 🕞 DVA-C02 Valid Dumps Files 🚬 Go to website ▛ [url]www.testkingpass.com ▟ open and search for ⇛ DVA-C02 ⇚ to download for free 🐫Latest DVA-C02 Test Guide[/url]
- DVA-C02 Reliable Test Experience 🕠 DVA-C02 Valid Dumps Files 🧽 Reliable DVA-C02 Test Question 🔳 Go to website ➽ [url]www.pdfvce.com 🢪 open and search for { DVA-C02 } to download for free 🤢Test DVA-C02 Questions Pdf[/url]
- Latest DVA-C02 Test Guide 🆎 DVA-C02 Valid Dumps Files 👻 DVA-C02 New Dumps Questions 🐉 Easily obtain free download of DVA-C02 by searching on [url]www.troytecdumps.com 🐂DVA-C02 Online Exam[/url]
- DVA-C02 Exam Torrent 🎁 Valid Test DVA-C02 Tips ⤴ Valid Test DVA-C02 Tips 🥅 Enter ✔ [url]www.pdfvce.com ️✔️ and search for DVA-C02 to download for free 🍠Training DVA-C02 Material[/url]
- DVA-C02 Valid Dumps Files 🍑 Training DVA-C02 Material 🙌 DVA-C02 Online Exam 🏏 The page for free download of ➤ DVA-C02 ⮘ on [url]www.troytecdumps.com will open immediately 🙉DVA-C02 Latest Real Test[/url]
- DVA-C02 New Dumps Questions 📼 Valid DVA-C02 Study Plan 👱 Valid DVA-C02 Learning Materials 🔷 Search for ☀ DVA-C02 ️☀️ on ▶ [url]www.pdfvce.com ◀ immediately to obtain a free download 🏥DVA-C02 Real Testing Environment[/url]
- Prepare Your Amazon DVA-C02 Exam with Reliable DVA-C02 Test Papers: AWS Certified Developer - Associate Efficiently 🍶 Search for [ DVA-C02 ] and download it for free immediately on ⏩ [url]www.practicevce.com ⏪ 🧩Reliable DVA-C02 Test Question[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, cq.x7cq.vip, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, Disposable vapes
P.S. Free 2026 Amazon DVA-C02 dumps are available on Google Drive shared by ExamcollectionPass: https://drive.google.com/open?id=1tNeRmi9-YWlc77ehNlovHL3TZff3QeqB
