[General] Study Marketing-Cloud-Developer Reference & Marketing-Cloud-Developer Reliab
89
General Study Marketing-Cloud-Developer Reference & Marketing-Cloud-Developer Reliab
Posted at 1/19/2026 17:04:59      View151 | Replies2        Print      Only Author   [Copy Link] 1#
2026 Latest ExamPrepAway Marketing-Cloud-Developer PDF Dumps and Marketing-Cloud-Developer Exam Engine Free Share: https://drive.google.com/open?id=1qySUP_EguPYkzksWr9UlTdbx1RL9M-Cl
We have a special technical customer service staff to solve all kinds of consumers problems on our Marketing-Cloud-Developer exam questions. If you have questions when installing or using our Marketing-Cloud-Developer practice engine, you can always contact our customer service staff via email or online consultation. They will solve your questions about Marketing-Cloud-Developer Preparation materials with enthusiasm and professionalism, giving you a timely response whenever you contact them.
The Salesforce Certified Marketing Cloud Developer Exam (Marketing-Cloud-Developer) product can be easily accessed just after purchasing it from ExamPrepAway. You can receive free Salesforce Dumps updates for up to 1 year after buying material. The 24/7 support system is also available for you, which helps you every time you get stuck somewhere. Many students have studied from the ExamPrepAway Salesforce Marketing-Cloud-Developer practice material and rated it positively because they have passed the Salesforce Certified Marketing Cloud Developer Exam (Marketing-Cloud-Developer) certification exam on the first try.
Marketing-Cloud-Developer Reliable Test Braindumps, Marketing-Cloud-Developer Popular ExamsIf you want to pass Salesforce Marketing-Cloud-Developer exam and get a high paying job in the industry; if you are searching for the perfect Marketing-Cloud-Developer exam prep material to get your dream job, then you must consider using our Salesforce Certified Marketing Cloud Developer Exam exam products to improve your skillset. We have curated new Marketing-Cloud-Developer Questions Answers to help you prepare for the exam. It can be your golden ticket to pass the Salesforce Marketing-Cloud-Developer test on the first attempt. We are providing latest Marketing-Cloud-Developer PDF question answers to help you prepare exam while working in the office to save your time.
Salesforce Certified Marketing Cloud Developer Exam Sample Questions (Q129-Q134):NEW QUESTION # 129
A developer needs to process a payload from an external system in a CloudPage.
What Marketing Cloud Server-Side JavaScript Platform function should be used for converting a string payload in JSON format to a JavaScript object?
  • A. Base64Decode
  • B. Stringify
  • C. CreateObject
  • D. ParseJSON
To convert a string payload in JSON format to a JavaScript object on a CloudPage, the developer should use the ParseJSON (B) function in Marketing Cloud Server-Side JavaScript (SSJS). This function parses a JSON string and returns a corresponding JavaScript object.
Example:
var jsonString = '{"key1":"value1", "key2":"value2"}'; var jsonObject = Platform.Function.ParseJSON (jsonString); References:
Salesforce Marketing Cloud SSJS Guide
SSJS Platform.Function.ParseJSON
NEW QUESTION # 130
Customer data has been imported into a staging data extension andneeds to be normalized before adding into the master data extension. A text field named 'birthday' contains date values in various formats. Some of the values are valid dates, but some are not.
Which SQL keywords and functions could be used to write the query'' Choose 2 answers
  • A. CASE, ISDATE, CONVERT
  • B. CASE, ISDATE, CAST
  • C. WHERE, ISDATE, CONVERT
  • D. UPDATE, ISDATE, CONVERT
To normalize customer data in a staging data extension where a text field named 'birthday' contains date values in various formats, the developer can use the following SQL keywords and functions:
* CASE, ISDATE, CONVERT (A) - These functions can be used to handle different date formats and convert them into a consistent format.
* CASE, ISDATE, CAST (C) - Similar to the above, CAST can be used to convert text to date format if ISDATE returns true.
Example SQL query:
SELECT CASE WHEN ISDATE(birthday) = 1 THEN CONVERT(DATE, birthday) ELSE NULL END AS normalized_birthday FROM StagingDataExtension References:
Salesforce Marketing Cloud SQL Reference
SQL CASE and ISDATE Functions
NEW QUESTION # 131
Certification Aid wants to create a file drop automation with a filename pattern. An import file is placed daily on the Marketing Cloud Enhanced FTP server, and thefile name always starts with the current month and day (e.g. OCT26). How should the filename pattern be defined? Choose 2.
  • A. Ends With operator
  • B. %%MMDD%%
  • C. %%Month%%%%Day%%
  • D. Begins With operator
To define a filename pattern that matches files starting with the current month and day, you can use the
%%MMDD%%pattern and the "Begins With" operator.
* %%MMDD%% Pattern: This pattern represents the month and day in a two-digit format.
* Begins With Operator: This operator ensures that the automation matches filenames that start with the specified pattern.
NEW QUESTION # 132
Certification Aid wants to automate the import of zipped files into a Data Extension. The zip files are placed on the Marketing Cloud Enhanced FTP server every night. Which activity is needed before those files can be imported? Choose 1.
  • A. File Transfer activity
  • B. Data Extract activity
  • C. Data Extension Import activity
  • D. File Import activity
Before importing zipped files into a Data Extension, a File Transfer activity is needed to unzip the files on the Marketing Cloud Enhanced FTP server. This activity moves and decompresses the files to make them available for import.
* File Transfer Activity: This activity is used to move files from one location to another and to unzip compressed files.
1: Salesforce File Transfer Activity
NEW QUESTION # 133
A developer is troubleshooting why an API client Jd and chent_secret are authenticating yet failing to access data from a child business unit.
What should be checked to validate the installed package can access the child business unit data?
  • A. The account id and parent MIDare included in the authorization call
  • B. The Installed Package has full Enterprise access to all available child business units
  • C. The Installed Package has access to the selected child business unit
To ensure that an installed package can access data from a child business unit, verify that the package has been granted access to the specific child business unit. This is configured during the package setup and permissions assignment.
1: Salesforce Installed Packages and Business Unit Access
NEW QUESTION # 134
We have the first-rate information safety guarantee system for the buyers who buy the Marketing-Cloud-Developer questions and answers of our company, we can ensure that the information of your name, email, or product you buy. We respect the private information of every customer, and we wont send the junk information to you to bother. Besides, you will get Marketing-Cloud-Developer Questions and answers downloading link within ten minutes, and our system will send you the update version to your mailbox.
Marketing-Cloud-Developer Reliable Test Braindumps: https://www.examprepaway.com/Salesforce/braindumps.Marketing-Cloud-Developer.ete.file.html
Open our Marketing-Cloud-Developer pdf dumps anywhere and start preparation, These Salesforce Certified Marketing Cloud Developer Exam (Marketing-Cloud-Developer) practice exams create situations that replicate the actual Marketing-Cloud-Developer exam, After using our Marketing-Cloud-Developer study guide materials, users can devote more time and energy to focus on their major and makes themselves more and more prominent in the professional field, There is no doubt that the function can help you pass the Marketing-Cloud-Developer Reliable Test Braindumps - Salesforce Certified Marketing Cloud Developer Exam exam.
The cloud" consists of thousands of computers and servers, all linked and accessible Associate Marketing-Cloud-Developer Level Exam to you via the Internet, It continues by looking at the way the community is organized and the processes by which that organization works.
Valid Marketing-Cloud-Developer test answers & Salesforce Marketing-Cloud-Developer pass test & Marketing-Cloud-Developer lead2pass reviewOpen our Marketing-Cloud-Developer Pdf Dumps anywhere and start preparation, These Salesforce Certified Marketing Cloud Developer Exam (Marketing-Cloud-Developer) practice exams create situations that replicate the actual Marketing-Cloud-Developer exam.
After using our Marketing-Cloud-Developer study guide materials, users can devote more time and energy to focus on their major and makes themselves more and more prominent in the professional field.
There is no doubt that the function can help Marketing-Cloud-Developer you pass the Salesforce Certified Marketing Cloud Developer Exam exam, But you need professional guidance to pass the exam.
Posted at 2/12/2026 02:28:52        Only Author  2#
˽ϤNΰĤʲܤҪȤƤޤJpshiken401¤ΜʂYϤϤʤΤṩޤʱ֪RǤʤČgȤνMߺϤ碌ܛʹäǤޤäơY401ԇY˺ϸ񤹤Ҫޤ401ѧ}ϡ|θߤѧץåȥե`⤿餹ȤǤޤMi_ɤϡԇYǏηʹäƤΤǤС401ƥȲϤxkƤϴ_ˤʤxޤ
Posted at 2/18/2026 09:12:59        Only Author  3#
What a thought-provoking and inspiring read, thank you for sharing! C-BCSPM-2502 accurate test provides a range of useful materials for free, hoping they help you progress.
