[Hardware] Valid ED-Con-101 Exam Labs - ED-Con-101 Exam Quick Prep
113
【Hardware】 Valid ED-Con-101 Exam Labs - ED-Con-101 Exam Quick Prep
Posted at 1/19/2026 18:23:56      View:128 | Replies:3        Print      Only Author   [Copy Link] 1#
As for the ED-Con-101 study materials themselves, they boost multiple functions to assist the learners to learn the study materials efficiently from different angles. For example, the function to stimulate the ED-Con-101 exam can help the exam candidates be familiar with the atmosphere and the pace of the Real ED-Con-101 Exam and avoid some unexpected problem occur such as the clients answer the questions in a slow speed and with a very anxious mood which is caused by the reason of lacking confidence.
You can even print the study material and save it in your smart devices to study anywhere and pass the Salesforce Certified Education Cloud Consultant (ED-Con-101) certification exam. The second format, by Actual4Dumps, is a web-based Salesforce Certified Education Cloud Consultant (ED-Con-101) practice exam that can be accessed online through browsers like Firefox, Google Chrome, Safari, and Microsoft Edge. You don't need to download or install any excessive plugins or Software to use the web-based software.
ED-Con-101 Dumps - Salesforce Certified Education Cloud Consultant Exam Questions [2026]Actual4Dumps exam dumps have two version-PDF and SOFT version which will give you convenient. It is very convenient for you to use PDF real questions and answers. And you can download these materials and print it out for study at any time. The SOFT version simulates the real exam which will give you more realistic feeling. When you are faced with the real exam, you can pass Salesforce ED-Con-101 test easily.
Salesforce Certified Education Cloud Consultant Sample Questions (Q148-Q153):NEW QUESTION # 148
A college plans to implement Student Success Hub and wants to configure Pathways to support students in their academic journey.
What should be considered when implementing Pathways?
  • A. There is a limit to the number of Plan Requirement records.
  • B. There are only two levels of Program Plan requirements in Pathways.
  • C. Pathways uses Program Plan and Plan Requirement records.
The college should consider that Pathways uses Program Plan and Plan Requirement records when implementing Pathways to support students in their academic journey. Pathways is a feature in Student Success Hub that allows users to create and manage personalized learning plans for students based on their goals and interests. Pathways uses Program Plan and Plan Requirement records to define the structure and requirements of a learning plan, such as courses, credits, or milestones. The college should consider that Pathways uses Program Plan and Plan Requirement records when implementing Pathways to support students in their academic journey by configuring and customizing these records to match their academic programs and policies. There is a limit to the number of Plan Requirement records or there are only two levels of Program Plan requirements in Pathways are not things that the college should consider when implementing Pathways to support students in their academic journey. Reference:
https://www.salesforce.org/products/student-success-hub/overview/
https://powerofus.force.com/s/article/SSHub-Pathways
NEW QUESTION # 149
The Alumni Association is interested in using Education Cloud to support its operations. The association track alumni interested board networking activities, and manages fundraising.
Which two Education Cloud considerations should the consultant discuss with the Association?
Choose 2 answers.
  • A. Leverage a third-party app to support event management.
  • B. Install Insights Platform to understand alumni data.
  • C. Configure Relationships to track alumni connections.
  • D. Use Grants Management to track alumni scholarships.
The consultant should discuss with the Association how they can configure Relationships to track alumni connections, and leverage a third-party app to support event management, as two Education Cloud considerations. Relationships is a feature that allows the Association to create and manage connections between Contacts in EDA. Relationships can be used to track various types of connections, such as family, friends, mentors, or board members. A third-party app is an application that provides additional features and solutions for Salesforce. There are many third-party apps on the AppExchange that offer event management capabilities, such as registration pages, ticketing, and agenda-building. The consultant can help the Association choose an app that meets their needs and budget. Using Grants Management to track alumni scholarships, or installing Insights Platform to understand alumni data, are not Education Cloud considerations that the consultant should discuss with the Association. Reference:
https://powerofus.force.com/s/article/EDA-Relationships
https://appexchange.salesforce.c ... =event%20management
NEW QUESTION # 150
A university plans to use Salesforce for its recruitment and admissions process and needs to integrate it with the Student Information System (SIS).
Which step should the consultant take initially?
  • A. Disable Trigger Handler records.
  • B. Use the Data Import Wizard.
  • C. Define the process.
The initial step that the consultant should take when planning to integrate Salesforce with the Student Information System (SIS) is B. Define the process1. This means that the consultant should identify the business requirements, use cases, and scenarios that the integration should support, such as data synchronization, data transformation, data validation, error handling, etc. The consultant should also determine the scope, frequency, direction, and volume of the data exchange, as well as the security and performance considerations2.
A . Disable Trigger Handler records and C. Use the Data Import Wizard are not valid steps for the initial integration planning. Disabling Trigger Handler records is a step that may be required when installing the Education Data Architecture (EDA) package in an existing Salesforce org, as it can prevent conflicts with existing triggers and workflows3. However, this is not related to the integration with the SIS. Using the Data Import Wizard is a tool that can be used to import data from external sources into Salesforce, such as accounts, contacts, leads, etc4. However, this is not a step for the initial integration planning, but rather a possible option for the data migration or loading.
NEW QUESTION # 151
The director of retention wants to use Advisor Link to track early alerts, help students schedule appointments with their advisers, and create program plans.
Which two options are required to use Advisor Link?
Choose 2 answers.
  • A. Person Accounts
  • B. Customer Community Plus
  • C. Education Data Architecture
  • D. Lightning Scheduler
Customer Community Plus and Education Data Architecture (EDA) are two options that are required to use Advisor Link. Customer Community Plus is a license type that enables users to access Advisor Link features such as early alerts, appointments, and program plans from a portal. EDA is a data model that provides the foundation for Advisor Link and other education solutions. Person Accounts and Lightning Scheduler are not required to use Advisor Link. Reference:
https://help.salesforce.com/s/ar ... ents.htm&type=5
https://www.salesforce.org/advisor-link/
NEW QUESTION # 152
A consultant needs to migrate international students' contact and address information to a Salesforce Education Data Architecture (EDA) environment with the State and Country Picklist feature enabled.
What should the consultant confirm before migrating the data?
  • A. Contact Multi-Addresses Enabled is checked.
  • B. Every contact has a state and country value.
  • C. All state and country values are ISO-3166 values.
The State and Country Picklist feature in Salesforce allows users to select states and countries from predefined, standardized lists, instead of entering them manually into text fields2. These picklists are based on ISO-3166 standard values, which are internationally recognized codes for identifying countries and their subdivisions. Therefore, before migrating the data, the consultant should confirm that all state and country values in the source data are ISO-3166 values, otherwise they will not match the picklist values in the target environment.
Contact Multi-Addresses Enabled is a setting in EDA that allows users to store multiple addresses for a contact, such as home, work, or mailing address. This setting does not affect the migration of state and country values, as long as they are ISO-3166 values. Every contact having a state and country value is not a requirement for the migration either, as these fields are not mandatory in EDA.
1: Configure State and Country Picklists - Salesforce3
2: ISO 3166 - Wikipedia
3: Enable Contact Multi-Addresses - Salesforce
NEW QUESTION # 153
If you buy and use the ED-Con-101 study materials from our company, you can complete the practice tests in a timed environment, receive grades and review test answers via video tutorials. You just need to download the software version of our ED-Con-101 Study Materials after you buy our study materials. You will have the right to start to try to simulate the real examination. We believe that the ED-Con-101 study materials from our company will not let you down.
ED-Con-101 Exam Quick Prep: https://www.actual4dumps.com/ED-Con-101-study-material.html
Actual4Dumps is famous in their customer as top quality provider preparation material, Salesforce ED-Con-101 exam dumps will boost your knowledge and confidence to enroll and pass your exam in 7 days, Salesforce Valid ED-Con-101 Exam Labs Soft version & APP version have similar functions such as simulating the real exam scene, Salesforce Valid ED-Con-101 Exam Labs If you want to start your IT career, industry certifications are valuable tools to boost your advancement prospects.
Start with the camera on a steady tripod, Excel ED-Con-101 has never, ever been this simple, Actual4Dumps is famous in their customer as top quality provider preparation material, Salesforce ED-Con-101 Exam Dumps will boost your knowledge and confidence to enroll and pass your exam in 7 days.
Top Valid ED-Con-101 Exam Labs | Efficient ED-Con-101: Salesforce Certified Education Cloud Consultant 100% PassSoft version & APP version have similar functions such as simulating Valid ED-Con-101 Exam Labs the real exam scene, If you want to start your IT career, industry certifications are valuable tools to boost your advancement prospects.
How to getting ED-Con-101 certification quickly and effectively become most important thing for you, What our company specializing in ED-Con-101 exam preparatory is helping our customer to pass exam easily.
Posted at 1/20/2026 21:03:31        Only Author  2#
I’m really thankful for your article, it’s truly unforgettable. I’m offering the Valid test AWS-Solutions-Architect-Associate tips test that played a key role in my promotion and salary increase. It's available for free today—good luck with your career journey!
Posted at 2/7/2026 01:50:33        Only Author  3#
This article is truly an outstanding work, and I’ve benefited greatly from it. The MC-101 latest exam dumps.zip content is highly useful, and it's offered free of charge.
Posted at 2/18/2026 18:01:26        Only Author  4#
Thank you for sharing this remarkable article, it truly impressed me. The Valid practice questions PMI-CPMAI pdf content is very helpful, and you don’t need to pay for it.
