[General] JN0-224 Exam Test - Latest JN0-224 Exam Questions
74
General JN0-224 Exam Test - Latest JN0-224 Exam Questions
Posted at 1/19/2026 19:25:56      View193 | Replies4        Print      Only Author   [Copy Link] 1#
Propulsion occurs when using our JN0-224 practice materials. They can even broaden amplitude of your horizon in this line. Of course, knowledge will accrue to you from our JN0-224 practice materials. There is no inextricably problem within our JN0-224 practice materials. Motivated by them downloaded from our website, more than 98 percent of clients conquered the difficulties. So can you.
Prep4sureExam is a trusted platform that has been helping Automation and DevOps, Associate (JNCIA-DevOps) JN0-224 candidates for many years. Over this long time period, countless candidates have passed their Automation and DevOps, Associate (JNCIA-DevOps) JN0-224 Exam and they all got help from Automation and DevOps, Associate (JNCIA-DevOps) practice questions and easily pass the final exam.
Latest JN0-224 Exam Questions & Latest JN0-224 Test OnlinePrep4sureExam offers you a free demo version of the Juniper JN0-224 dumps. This way candidates can easily check the validity and reliability of the JN0-224 exam products without having to spend time. This relieves any sort of anxiety in the candidate's mind before the purchase of Automation and DevOps, Associate (JNCIA-DevOps) certification exam preparation material. This JN0-224 Exam study material is offered to you at a very low price. We also offer up to 1 year of free updates on Juniper JN0-224 dumps after the date of purchase. Going through our Automation and DevOps, Associate (JNCIA-DevOps) exam prep material there remains no chance of failure in the Juniper JN0-224 exam.
Juniper JN0-224 Exam Syllabus Topics:
  • Python
  • PyEZ: This domain examines Python programming with PyEZ library for Junos automation, including JSNAPy, Jinja2 templates, RPC calls, exception handling, and device configuration management.
  • NETCONF
  • XML API: This domain focuses on XML syntax, XPath expressions, NETCONF protocol, and XML API functionality for programmatic device configuration and communication.
  • Rest API: This domain covers Junos REST API implementation, REST API Explorer tool, and cURL usage for HTTP-based device management and configuration.
  • Junos Automation Stack and DevOps Concepts: This domain covers fundamental automation tools, frameworks, APIs, and DevOps culture applicable to Junos platform operations and network management.
Topic 5
  • Data Serialization: This domain addresses YAML and JSON formats used for structured data representation and exchange in network automation workflows.
Juniper Automation and DevOps, Associate (JNCIA-DevOps) Sample Questions (Q39-Q44):NEW QUESTION # 39
Which process is responsible for JET automation requests?
  • A. jsd
  • B. mgd
  • C. jsrpd
  • D. rpd
The jsd (Junos Script Daemon) process is responsible for handling JET (Junos Extension Toolkit) automation requests. The JET framework allows for more programmable interactions with Junos devices, using APIs to manage and automate network functions. The jsd process handles these API requests, executes the relevant scripts, and interacts with the Junos configuration and operational states accordingly.
JET enables developers to write applications that interact with the Junos OS through APIs, providing a powerful tool for network automation, monitoring, and configuration management. The jsd process ensures that all JET-related operations are processed and executed properly.
Why the Other Options Are Incorrect:
A . jsrpd: This is not a process associated with JET automation requests.
B . mgd: The mgd process is responsible for handling management tasks like CLI commands and configuration changes but is not directly responsible for JET automation requests.
C . rpd: The rpd (Routing Protocol Daemon) manages routing protocols like BGP and OSPF but has no involvement in JET automation.
Reference from Juniper Documentation:
Juniper's documentation on JET and the jsd process outlines how this daemon manages script and API request processing for automation tasks.
NEW QUESTION # 40
Which two statements are correct about the Junos REST API Explorer? (Choose two.)
  • A. The REST API Explorer returns data only in XML format.
  • B. The REST API Explorer supports both GET and POST calls.
  • C. The REST API Explorer is enabled by default on all Junos devices.
  • D. The REST API Explorer supports multiple RPC calls.
The Junos REST API Explorer provides an interactive environment to explore and execute REST API calls. The correct statements are:
Supports GET and POST Calls (C): The REST API Explorer allows users to make both GET and POST requests, enabling retrieval and submission of data to the Junos device.
Supports Multiple RPC Calls (D): The REST API Explorer can execute multiple RPC (Remote Procedure Call) commands, allowing a wide range of operations to be performed directly through the interface.
Option A is incorrect because the REST API Explorer is not enabled by default; it must be enabled manually. Option B is incorrect because the REST API Explorer returns data in both XML and JSON formats, not just XML.
Junos REST API Explorer Documentation: Provides details on the supported operations and how to use the Explorer for different types of requests.
Juniper Networks Documentation: Covers the setup and usage of the REST API Explorer.
NEW QUESTION # 41
What is the difference between a list and a tuple in Python?
  • A. Lists are immutable objects that use parentheses, and tuples are immutable objects that use square brackets.
  • B. Lists are immutable objects that use square brackets, and tuples are mutable objects that use parentheses.
  • C. Lists are mutable objects that use square brackets, and tuples are immutable objects that use parentheses.
  • D. Lists are mutable objects that use parentheses, and tuples are immutable objects that use square brackets.
In Python, the distinction between lists and tuples is essential for efficient programming:
Lists:
Mutable (B): This means that once a list is created, its elements can be changed, added, or removed. Lists are versatile and commonly used when the data is expected to change.
Square Brackets: Lists are defined using square brackets [].
Example:
my_list = [1, 2, 3]
my_list[0] = 10 # Modifying the first element
Tuples:
Immutable (B): Once a tuple is created, it cannot be altered. Tuples are used when a fixed collection of items is needed, providing more integrity to the data.
Parentheses: Tuples are defined using parentheses ().
Example:
my_tuple = (1, 2, 3)
# my_tuple[0] = 10 # This would raise an error because tuples are immutable Reference:
Python Official Documentation: The Python Language Reference provides detailed information on data types like lists and tuples, including their mutability and syntax.
Automation Scripts: In the context of automation, understanding when to use mutable or immutable data structures can significantly impact script performance and reliability.
NEW QUESTION # 42
Which two programming languages are used for Junos on-box scripting? (Choose two.)
  • A. SLAX
  • B. Ruby
  • C. Perl
  • D. XSLT
Junos on-box scripting supports the following programming languages:
SLAX (C): SLAX (Structured Language for XML) is a scripting language designed specifically for Junos devices. It allows for easy manipulation of XML data, making it ideal for creating Junos scripts that interact with device configurations.
XSLT (D): XSLT (Extensible Stylesheet Language Transformations) is another language used for transforming XML documents into other formats. It is commonly used in Junos for transforming XML data into different views or outputs.
Options A (Perl) and B (Ruby) are not used for Junos on-box scripting. While these languages are popular in other contexts, Junos scripting relies heavily on XML-based languages like SLAX and XSLT.
Junos XML API and Scripting Guide: Describes the use of SLAX and XSLT for on-box scripting.
Juniper Networks Automation Documentation: Provides examples and best practices for using SLAX and XSLT in Junos scripting.
NEW QUESTION # 43
Which process is responsible for XML automation requests?
  • A. mgd
  • B. jsrpd
  • C. rpd
  • D. jsd
The mgd (Management Daemon) process in Junos is responsible for handling XML automation requests. This daemon manages the configuration and operational commands received via NETCONF, which uses XML for data exchange. The mgd process parses the XML data and applies the necessary configuration or retrieves the requested information.
Option B is correct because mgd is the process that handles XML-based requests in Junos.
Options A (jsrpd), C (rpd), and D (jsd) are incorrect because they are responsible for different functions, such as routing protocols and services, not XML automation.
Supporting Reference:
Juniper Networks Management Daemon (mgd) Documentation: Provides an overview of the responsibilities of the mgd process, including handling XML requests.
NEW QUESTION # 44
As is known to us, the leading status of the knowledge-based economy has been established progressively. It is more and more important for us to keep pace with the changeable world and improve ourselves for the beautiful life. Our company can help you solve the problem and get your certification, because our company has compiled the JN0-224 question torrent that not only have high quality but also have high pass rate. We believe that our JN0-224 exam questions will help you get the certification in the shortest. So hurry to buy our JN0-224 exam torrent, you will like our products.
Latest JN0-224 Exam Questions: https://www.prep4sureexam.com/JN0-224-dumps-torrent.html
Posted at 1/23/2026 13:53:00        Only Author  2#
I really appreciate your article, it made a huge impact on me. The C-P2WAB-2507 new free study guide content is highly informative, and it's offered at no cost.
Posted at 2/1/2026 22:56:07        Only Author  3#
The content of the article is thought-provoking, and Ive learned a lot from it. Free SY0-701 vce test simulator materialsunlock promotions and higher salary potential!
Posted at 2/8/2026 03:09:18        Only Author  4#
Wir wissen, wie bedeutend die Peoplecert MSP-Practitioner Prfung fr die in der IT-Branche angestellte Leute ist. Deshalb entwickeln wir die Prfungssoftware fr Peoplecert MSP-Practitioner, die Ihnen große Hilfe leisten können. Die Prfungsunterlagen, die Sie brauchen, haben unser Team schon gesammelt. Außerdem haben wir die Unterlagen wissenschaftlich analysiert und geordnet. Wir tun dies alles, um Ihr Stress und Belastung der Vorbereitung auf Peoplecert MSP-Practitioner zu erleichtern.
Posted at 2/24/2026 01:58:03        Only Author  5#
``Υץ饤Х`oϡ󥿩`ͥåȕrhΆ}Ǥय`֥Ȥϥ``Υץ饤Х`ߤ؜Ӥ뤿ᡢयُߤʥ֥ȤŤ뤳ȤӤޤC_ARP2P_2508ѧ󥸥C_ARP2P_2508ُ뤹H䤹ҪϤޤäޤ󡣱uФpʤᡢ``Q؜ӤʤȤ^ޤ
