Relevant ServSafe-Manager Answers & ServSafe-Manager Exam Collection Pdf
Posted at 1/19/2026 20:51:25
Nowadays, the ServSafe-Manager certificate is popular among job seekers. After all, the enormous companies attach great importance to your skills. If you can obtain the ServSafe-Manager certificate, you will have the greatest chance to get the job. So you need to improve yourself during your spare time. Maybe you are always worrying that you are too busy to prapare for an exam, but our ServSafe-Manager Training Materials will help you obtain the certification in the lest time for the advantage of high-efficency.
Our brand has marched into the international market and many overseas clients purchase our ServSafe-Manager exam dump online. As the saying goes, Rome is not build in a day. The achievements we get hinge on the constant improvement on the quality of our ServSafe-Manager latest study question and the belief we hold that we should provide the best service for the clients. The great efforts we devote to the ServSafe exam dump and the experiences we accumulate for decades are incalculable. All of these lead to our success of ServSafe-Manager learning file and high prestige.
ServSafe ServSafe-Manager Exam Collection Pdf, Mock ServSafe-Manager ExamBraindumpQuiz is the leading position in this field and famous for high pass rate of the ServSafe-Manager learning guide. If you are headache about your qualification exams, our ServSafe-Manager learning guide materials will be a great savior for you. Now it is your opportunity that we provide the best valid and professional ServSafe-Manager Study Guide materials which have 100% pass rate. If you really want to clear exam and gain success one time, choosing us will be the wise thing for you. If you hesitate about us please pay attention on below about our satisfying service and high-quality ServSafe-Manager guide torrent.
ServSafe Manager Exam Sample Questions (Q46-Q51):NEW QUESTION # 46
The Person in Charge (PIC) notices that a food handler has an infected wound on his or her hand. They must require the food handler to
- A. cover the wound with a waterproof bandage and single-use glove.
- B. apply antibacterial cream to the wound.
- C. work in the office until the wound heals.
- D. get a release from a medical practitioner.
According to the ServSafe Manager curriculum and the FDA Food Code, an infected wound, cut, or boil on a food handler's hand or wrist is a potential source ofStaphylococcus aureus. This pathogen is commonly found on the skin and can easily be transferred to food or food-contact surfaces. To mitigate this risk, the wound must be properly contained. The standard requirement is a "double barrier" system: the wound must first be covered with awaterproof, leak-proof bandage(such as a finger cot or rubber stall), and then asingle- use glovemust be worn over the bandage.
If the wound is on the arm, it must be covered with a waterproof bandage, but a glove is not required as the arm does not typically make direct contact with food. However, for wounds on the hand or wrist, the glove is mandatory. This is a "restriction" protocol. The employee can still work with food as long as the wound is completely covered and the barrier is maintained. If the wound cannot be properly covered (for example, if it is persistently oozing or if the employee cannot wear gloves), the PIC mustrestrictthe employee from working with exposed food, clean equipment, or utensils. This procedure ensures that biological contaminants from the infection do not enter the "Flow of Food." Managers must monitor these barriers throughout the shift to ensure the bandage stays dry and the glove remains intact.
NEW QUESTION # 47
Lighting fixtures in a cooler must have bulbs that are
- A. plastic shielded.
- B. easily removable.
- C. 100 watts.
- D. fluorescent.
Proper lighting is required in all areas of a food service operation to ensure that staff can clean effectively and monitor food quality. However, light bulbs are a significantphysical hazardbecause they are made of glass.
According to ServSafe and the FDA Food Code, lighting fixtures in food-prep, food-storage, and service areas-including walk-in coolers and freezers-must beplastic shieldedor otherwise shatter-resistant.
The purpose of the plastic shield (Option D) or a "shatter-resistant" coating is to contain the glass fragments if the bulb should break. Without this protection, shards of glass could fall into open food containers, onto clean utensils, or onto prep surfaces, where they are nearly impossible to detect. In a cooler, where food is often stored in open or loosely covered bins, this risk is especially high. Managers must ensure that all lighting meets these safety standards during facility inspections. Beyond the physical protection, the Food Code also specifies minimum lighting intensity for different areas: for example, 10 foot-candles (108 lux) in walk-in units and dry-storage, and 50 foot-candles (540 lux) in high-intensity food-prep areas. Ensuring that bulbs are shielded and providing adequate brightness is a dual-purpose strategy that protects the physical integrity of the food while allowing for better overall sanitation and safety monitoring.
NEW QUESTION # 48
During a 12-hour power outage, the temperature of the freezer reached $55
