[General] Arch-303 Valid Exam Preparation | Arch-303 Valid Exam Book
99
General Arch-303 Valid Exam Preparation | Arch-303 Valid Exam Book
Posted at 1/19/2026 21:35:57      View113 | Replies0        Print      Only Author   [Copy Link] 1#
Nowadays, flexible study methods become more and more popular with the development of the electronic products. The latest technologies have been applied to our Arch-303 actual exam as well since we are at the most leading position in this field. You can get a complete new and pleasant study experience with our Arch-303 Study Materials. Besides, you have varied choices for there are three versions of our Arch-303 practice materials. At the same time, you are bound to pass the Arch-303 exam and get your desired certification for the validity and accuracy of our Arch-303 study materials.
Eliminates confusion while taking the Salesforce Arch-303 certification exam. Prepares you for the format of your Arch-303 exam dumps, including multiple-choice questions and fill-in-the-blank answers. Comprehensive, up-to-date coverage of the entire Salesforce Certified B2C Commerce Architect (Arch-303) certification curriculum. Salesforce Arch-303 practice questions are based on recently released Arch-303 exam objectives.
Pass Your Arch-303 Exam With An Excellent ScoreThrough years of marketing, our Arch-303 study materials have won the support of many customers. The most obvious data is that our products are gradually increasing each year, and it is a great effort to achieve such a huge success thanks to our product development. First of all, we have done a very good job in studying the updating of materials. In addition, the quality of our Arch-303 Study Materials is strictly controlled by teachers. So, believe that we are the right choice, if you have any questions about our study materials, you can consult us.
Salesforce Certified B2C Commerce Architect Sample Questions (Q15-Q20):NEW QUESTION # 15
A third party survey provider offers both an API endpoint for individual survey data and an SFTP server endpoint that can accept batch survey data. The initial implementation of the integration includes
1.Marking the order as requiring a survey before order placement
2. On the order confirmation pace, the survey form is displayed for the customer to fill
3. The data is sent to the survey provider API, and the order it marked as not requiring a survey Later it was identified that this solution is not fit for purpose as the following issues and additional requirements were identified:
1. If the API call fails, the corresponding survey data is lost. The Business requires to avoid data loss.
2. Some customers skipped the form. The Business require sending a survey email to such customers.
3. The Order Management System (OMS) uses a non-standard XML parser it did not manage to parse orders with the survey, until the survey attribute was manually removedfrom the xml.
How should the Architect address the issues and requirements described above?
  • A. Create a custom session attribute when the survey is required. Send to the API endpoint in real-time. On failure, capture the survey data in the session and reprocess, use me session attribute to send emails for the cases when survey was skipped.
  • B. Create a custom object when the survey is required Send to the API endpoint in real-time. On success, remove the object. Onfailure, capture the survey data in the custom object and later reprocess with a job. Use the custom object to send emails for the cases when survey was skipped.
  • C. Create a custom object to store the survey data. Send to the API endpoint using a job. On success, remove the custom object. On failure, send the survey data with APIfrom the next execution of the same job. Use the custom object to send emails for the cases when the survey was skipped.
  • D. Send the survey data to the API endpoint in real-time until the survey data is successfullycaptured.Instruct the OMS development team to update their XML parser, use the Order survey attribute to send emails for the cases when the survey was skipped.
This approach addresses all concerns: data retention, reattempt on failure, and follow-up communication. By storing survey data in a custom object, data is preserved even if the API call fails, allowing for reprocessing.
This method also facilitates sending follow-up emails by querying custom objects for surveys that were skipped, ensuring comprehensive coverage and reliability in data handling and customer engagement.
NEW QUESTION # 16
The Client is creating a new Storefront and their requirements include:
* ApplePay support
* Log -n through a standard OAuth2 social media account
* One Okie checkout process
* Ay B testing forpromotions
Which two items require technical documentation for customizing the Storefront Reference Architecture?
Choose 2 answers
  • A. One Click checkout process
  • B. A/B testing forpromotions
  • C. ApplePay support
  • D. log in through a standard OAuth2 social media account
For customizing the Storefront Reference Architecture to meet specific requirements, the following items would require detailed technical documentation:
* Option A (One Click checkout process): Implementing a one-click checkout process involves significant customization to streamline the checkout flow, potentially requiring integration with payment providers and modifications to the user session management.
* Option C (Log in through a standard OAuth2 social media account): Integrating OAuth2 for social media logins involves handling authentication tokens, user sessions, and potentially syncing user data with the B2C Commerce profiles, all of which require detailed security and integration documentation.
These customizations require careful planning and implementation to ensure they work seamlessly with existing Storefront Reference Architecture components and meet security standards.
NEW QUESTION # 17
A client has a single site with multiple domains, locales, and languages. Afterlaunch, there is a need for the client to perform offline maintenance. The client would like to show the same maintenance page for each locale.
Which version of aliases,Json file below will accomplish this task?
  • A.
  • B.
  • C.
  • D.
Option C correctly addresses the requirement for showing the same maintenance page across multiple locales by having each different domain alias ("nto.eu", "nto.at", "nto.de") mapped to the same www domain ("www.
nto.eu"). This setup allows all traffic, regardless of the original locale-specific domain, to be directed to a single, unified maintenance page hosted under the "www.nto.eu" domain. This ensures consistency in the maintenance message presented to all users, irrespective of their regional domain.
NEW QUESTION # 18
The Client is Crowing and decided to migrate its ecommerce website to B2C Commerce. The Client provided the Architect with the f metrics for its existing website over the past 12 months and forecasted into the next year:
Noting these historical metrics and the forecasted growth of 300%, which load test targets meet best practices for testing the new B2C Commerce site?
  • A. 150000 visits per hour, 3000000 page views per hour, and 37500 orders per hour
  • B. 3000 visits per hour, 60000 page views per hour, and 750 orders per hour
  • C. 1500 visits per hour, 30000 page views per hour, and 375 orders per hour
  • D. 15000 visits per hour, 300000 page views per hour, and 3750 orders per hour
Considering the existing metrics and forecasted 300% growth, the appropriate load testing targets for the new B2C Commerce site would be:
* 15000 visits per hour: This figure is calculated by applying the expected growth to the peak visits per hour (1000 visits), resulting in 4000 visits. The choice of 15000 provides a higher buffer to accommodate unforeseen spikes in traffic.
* 300000 page views per hour: Similarly, this is scaled up from the peak page views per hour (20000) considering the growth, ensuring the site can handle high demand and interactions.
* 3750 orders per hour: This target is based on the peak orders per hour (250) with the growth applied, allowing testing of the system's ability to handle transactions under significant load.
These targets ensure that the system is robust enough to handle increased traffic and transactions without performance degradation, crucial for maintaining customer satisfaction and operational stability.
NEW QUESTION # 19
The client provided these business requirements:
* The B2C Commerce storefront will integrate with the client's Order Management System (OMS).
* The storefront will provide reel-time order export of successfully pieced orders The OMS supports both web service export end SFTP batch order export, but the client has expressed concern about the availability of the OMS.
Which two solutions satisfy the requirements and address the OMS reliability concern?
Choose 2 answers
  • A. Implement a live export of orders during checkout vie web service, marking the processed order as exported when the AM returns successfully.
  • B. Implement a Live export of orders during checkout via SFTP, marking the processed order as exported when it has completed successfully.
  • C. implement a batch export of orders via web service, excluding exported orders. This runs as a scheduled Job with an hourly run rate end marksprocessed orders as exported upon success.
  • D. Implement a batch export of orders to SFTP, excluding exported orders. This runs as a scheduled fc>b with a high-frequency run rate end marks processed orders as exported upon success.
Given the concerns about the reliability of the OMS, implementing scheduled batch exports ensures that order data is not lost due to potential OMS downtime and allows for reattempting failed exports. Option B uses SFTP for a high-frequency batch export, which can be scheduled to run multiple times a day, ensuring minimal delay in order synchronization while marking orders as exported upon successful transmission.
Option C provides a similar safeguard but via web service, which can be scheduled to run hourly. Both methods enable tracking of export status and can handle temporary downtimes by reattempting the export until successful, aligning with the need for reliability in integration processes.
NEW QUESTION # 20
Prepare for the Salesforce Arch-303 exam with ease using DumpsMaterials Salesforce Arch-303 exam questions in a convenient PDF format. Our PDF files can be easily downloaded and accessed on various devices, including PCs, laptops, Macs, tablets, and smartphones. With the Salesforce Certified B2C Commerce Architect (Arch-303) PDF questions, you have the flexibility to study anytime and anywhere, eliminating the need for additional classes. Our comprehensive PDF guide contains all the essential information required to pass the Arch-303 in one shot.
Arch-303 Valid Exam Book: https://www.dumpsmaterials.com/Arch-303-real-torrent.html
Salesforce Arch-303 Valid Exam Preparation Our success rates in the past two years have been absolutely impressive, thanks to our happy customers who are now able to propel their careers in the fast lane, In order to be able to better grasp the proposition thesis direction, the Salesforce Certified B2C Commerce Architect study question focus on proposition which one recent theory and published, in all kinds of academic report even if update to find effective thesis points, according to the proposition of preferences and habits, ponder proposition style of topic selection, to update our Arch-303 exam question, to facilitate users of online learning, better fit time development hot spot, Salesforce Arch-303 Valid Exam Preparation How do I submit a bug or request a feature?
However, it may not seem obvious which Apple updates are needed, Our PDF version of the Arch-303 practice materials support printing on papers, Our success rates in the past two years have been absolutely Exam Arch-303 Questions impressive, thanks to our happy customers who are now able to propel their careers in the fast lane.
100% Pass 2026 Newest Salesforce Arch-303 Valid Exam PreparationIn order to be able to better grasp the proposition thesis direction, the Salesforce Certified B2C Commerce Architect Arch-303 Valid Dumps Ebook study question focus on proposition which one recent theory and published, in all kinds of academic report even if update to find effective thesis points, according to the proposition of preferences and habits, ponder proposition style of topic selection, to update our Arch-303 Exam Question, to facilitate users of online learning, better fit time development hot spot.
How do I submit a bug or request a feature, ExamsLead is providing actual study material for the Arch-303 exam and has made things very easier for candidates to get themselves prepare for the Arch-303 exam.
All you need to do is being confident Arch-303 to us and pay some regular time to review them.
