Exam Oracle 1z1-076 Collection | 1z1-076 Complete Exam Dumps
Posted at 1/20/2026 00:15:22
View169
Replies2
BONUS!!! Download part of VCEDumps 1z1-076 dumps for free: https://drive.google.com/open?id=1DkZA5rnoTWK3wRAIdTtgDm18BIpPGvkA
It is a common sense that in terms of a kind of Oracle Database 19c: Data Guard Administration test torrent, the pass rate would be the best advertisement, since only the pass rate can be the most powerful evidence to show whether the 1z1-076 Guide Torrent is effective and useful or not. We are so proud to tell you that according to the statistics from the feedback of all of our customers, the pass rate among our customers who prepared for the exam under the guidance of our Oracle Database 19c: Data Guard Administration test torrent has reached as high as 98%to 100%, which definitely marks the highest pass rate in the field. Therefore, you can carry out the targeted training to improve yourself in order to make the best performance in the real exam, most importantly, you can repeat to do the situation test as you like.
As a market leader, our company is able to attract quality staffs, it actively seeks out those who are energetic, persistent, and professional to various 1z1-076 certificate and good communicator. And we strongly believe that the key of our company's success is its people, skills, knowledge and experience. The successful selection, development and 1z1-076 training of personnel are critical to our company's ability to provide a high standard of service to our customers and to respond their needs on our 1z1-076 exam questions.
Valid Exam 1z1-076 Collection - Fantastic & 100% Pass-Rate 1z1-076 Materials Free Download for Oracle 1z1-076 ExamTo save the clients' time, we send the products in the form of mails to the clients in 5-10 minutes after they purchase our 1z1-076 practice guide and we simplify the information to let the client only need dozens of hours to learn and prepare for the test. To help the clients solve the problems which occur in the process of using our 1z1-076 Guide materials, the clients can consult about the issues about our study materials at any time. So we can say that our 1z1-076 training materials are people-oriented and place the clients experiences in the prominent position.
Oracle Database 19c: Data Guard Administration Sample Questions (Q84-Q89):NEW QUESTION # 84
You created the PRODSBY1 physical standby database for the PROD primary database using gql and RMAN.
You are planning to create a Data Guard Broker configuration. You execute the command:
Which three statements are true regarding the execution of the command?
- A. The PRODSBY1 standby database is automatically added to the configuration if DG_BROKER_START is TRUE for PRODSBYl.
- B. The command will execute successfully only if Oracle Net connectivity to the PROD database instance is defined on the primary host.
- C. The command will execute successfully only if Oracle Net connectivity to the PROD and PRODSBYl database instances are defined on the primary host.
- D. The Data Guard Broker configuration files is automatically created in the destinations specified by the DG_BROKER_CONFIG_FILEn initialization parameters on the primary database.
- E. The PRODSBYI standby database is automatically added to the configuration if Oracle Net connectivity to the PRODSBYl database instance is defined on the primary host.
- F. The command will execute successfully only if the DG_BROKER_START initialization parameter is set to TRUE for the PROD database instance.
Answer: B,D,F
The command executed (CREATE CONFIGURATION 'DGConfig' AS PRIMARY DATABASE IS ' PROD' CONNECT IDENTIFIER IS PROD;) is used to create a Data Guard Broker configuration named
'DGConfig'. The successful execution of this command depends on several conditions:
* A: The DG_BROKER_START parameter must be set to TRUE on the primary database to start the Data Guard Broker processes. Without the broker processes running, the configuration cannot be created.
* D: Oracle Net connectivity to the PROD database instance must be established on the primary host. This is because the Data Guard Broker requires network accessibility to communicate with the primary database and manage the configuration.
* E: When the configuration is created, the Data Guard Broker configuration files are indeed automatically created in the locations specified by the DG_BROKER_CONFIG_FILEn parameters on the primary database.
It's important to note that the command will not automatically add the PRODSBY1 standby database to the configuration (thus B and C are not correct), and there is no requirement for the standby database to have Oracle Net connectivity defined on the primary host for the execution of this command (making F incorrect as well).
References: This information can be validated in Oracle's Data Guard Broker documentation, which outlines the requirements for setting up and managing a Data Guard configuration using the Data Guard Broker.
NEW QUESTION # 85
You are licensed to use Oracle Active Data Guard.
Which TWO statements are true after enabling block change tracking on a physical standby database?
- A. It allows fast incremental backups to be offloaded to the physical standby database.
- B. It allows fast incremental backups to be offloaded to a snapshot standby database, when the physical standby database is converted.
- C. It starts the RVWR process on the physical standby database instance.
- D. It allows fast incremental backups to be taken on the primary database.
- E. It starts the CTWR process on the physical standby database instance.
- F. It starts the CTWR process on the primary database instance.
Block change tracking is a feature that enhances the efficiency of incremental backups by recording changed blocks in a tracking file. When used with Oracle Active Data Guard:
* It starts the RVWR process on the physical standby database instance (A): When block change tracking is enabled on a physical standby database, the Recovery Writer (RVWR) process is initiated.
This process is responsible for recording the changes to blocks in the block change tracking file, which is then used to optimize incremental backups.
* It allows fast incremental backups to be offloaded to the physical standby database (E): With block change tracking enabled on the physical standby database, fast incremental backups can be offloaded from the primary database. This reduces the workload on the primary database and utilizes the standby database for backup operations, improving overall system performance and efficiency.References:
* Oracle Database Backup and Recovery User's Guide
* Oracle Active Data Guard documentation
NEW QUESTION # 86
Examine the Data Guard configuration: DGMGRL> show configuration;
Configuration - Animals
Protection Mode: MaxPerformance
Databases:
dogs- Primary database
sheep - Physical standby database
cats- Snapshot standby database
Fast-Start Failover: DISABLED
Configuration Status: SUCCESS
You receive an error while attempting to raise the protection mode to Maximum Protection:
DGMGRL> edit configuration set protection mode as maxprotection;
Error: ORA-16627: operation disallowed since no standby databases would remain to support protection mode Failed.
What can you conclude based on this error?
- A. The redo transport mode is set to async for the standby database Sheep.
- B. Cats is a snapshot standby database.
- C. The redo transport mode is set to asyn: for the standby database Cats.
- D. The redo transport mode is set to async for both standby databases.
Comprehensive Detailed Explanation:
In an Oracle Data Guard environment, the Maximum Protection mode requires that all redo data be transmitted synchronously to at least one standby database, ensuring no data loss even in the event of a primary database failure. However, a snapshot standby database, by its nature, allows read-write access and is temporarily disconnected from the redo stream, which makes it unable to participate in the synchronous redo transport required by Maximum Protection mode. The presence of a snapshot standby database in the Data Guard configuration thus prevents the activation of Maximum Protection mode, as it cannot guarantee zero data loss without a standby database capable of receiving redo data synchronously.
Oracle Data Guard documentation clearly outlines the requirements and restrictions of different protection modes, including the necessity for standby databases to participate in synchronous redo transport to enable Maximum Protection mode. The inability of snapshot standby databases to fulfill this requirement is a key consideration when planning Data Guard configurations and protection levels.
The error indicates that switching the protection mode to Maximum Protection is not possible due to the presence of a snapshot standby database in the Data Guard configuration, which cannot participate in synchronous redo transport required by the Maximum Protection mode. Therefore, the correct answer is:
NEW QUESTION # 87
Which TWO are TRUE about offloading backups to a physical standby database in a Data Guard environment?
- A. The standby database can not be registered in an RMAN catalog if the primary database has not been registered.
- B. The standby database must be registered in an RMAN catalog before the primary database has been registered.
- C. The standby database must be registered in an RMAN catalog after the primary database has been registered.
- D. Backups of the standby control file taken while connected to the catalog where the database is registered, may be used to restore the control file on the primary database.
In a Data Guard environment, offloading backups to a physical standby database has certain requirements:
* A: Once the primary database is registered in an RMAN catalog, the standby database can also be
* registered. This allows RMAN to manage backups coherently across both databases and leverage the standby database for backup purposes without interfering with the primary database's workload.
* C: Backups of the standby control file taken while connected to the catalog where the database is registered can be used to restore the control file on the primary database. This ensures that backup metadata is consistent across the Data Guard configuration.
Options B and D are incorrect because there is no strict requirement for the order in which the primary and standby databases must be registered in an RMAN catalog. However, it is a common practice to register the primary database first.
References: The Oracle Database Backup and Recovery User's Guide provides detailed procedures on how to manage RMAN backups in a Data Guard environment, including offloading backups to a standby database.
NEW QUESTION # 88
You are using Data Guard in conjunction with Global Database Services.
You have a Data Guard Broker configuration called Sales and a GDS pool called Prod.
Which three are true concerning the management of the broker configuration when using GDS?
- A. Adding a database to the Sales configuration with DGMGRL automatically adds the database to the Prod Pool.
- B. DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool.
- C. DGMGRL may be used to add the Sales configuration to the Prod pool in gds.
- D. Adding a database to the Sales configuration with DGMGRL requires that the Sales configuration be disabled first. It must then be enabled after the new database is added to the configuration.
- E. Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services.
Answer: B,C,E
In the context of Oracle Data Guard and Global Database Services (GDS):
* DGMGRL may be used to add the Sales configuration to the Prod pool in gds (A): Data Guard Broker's command-line interface DGMGRL can be utilized to manage configurations with GDS, allowing the addition of Data Guard Broker configurations to GDS pools.
* Performing a role change with DGMGRL automatically notifies GDS which in turn activates the appropriate services (B): When a role change is executed using DGMGRL, GDS is automatically notified, and it then activates the services that are appropriate for the new database roles.
* DGMGRL may be used to add a single database to the Sales configuration even if Sales is a member of the Prod pool (C): DGMGRL provides the capability to manage individual databases within a broker configuration, including adding databases to a configuration that is already part of a GDS pool.References:
* Oracle Data Guard Broker documentation
* Oracle Global Data Services documentation
NEW QUESTION # 89
Currently, if you want to make 1z1-076 exam certification more tied to your status in the IT industry with fierce competition, and make professional competence stronger in the IT industry, you can choose our VCEDumps's 1z1-076 Exam Training materials. With efforts for many years, the passing rate of VCEDumps's 1z1-076 certification exam has reached as high as 100%. Choosing VCEDumps means to choose success.
1z1-076 Complete Exam Dumps: https://www.vcedumps.com/1z1-076-examcollection.html
With 1z1-076 exam questions, you can prepare for your Oracle Database 19c: Data Guard Administration (1z1-076) certification exam, Oracle Exam 1z1-076 Collection i was regretting for not following my mothers advice, We employ forward-looking ways and measures, identify advanced ideas and systems, and develop state-of-the-art technologies and processes that help build one of the world's leading Oracle Database 19c 1z1-076 updated prep exam, We have professional experts editing 1z1-076 valid prep training once the real exam questions changes.
Cisco Voice Mail Port Wizard, You may be constrained by a 1z1-076 number of factors like lack of processional skills, time or money to deal with the practice exam ahead of you.
With 1z1-076 Exam Questions, you can prepare for your Oracle Database 19c: Data Guard Administration (1z1-076) certification exam, i was regretting for not following my mothers advice, We employ forward-looking ways and measures, identify advanced ideas and systems, and develop state-of-the-art technologies and processes that help build one of the world's leading Oracle Database 19c 1z1-076 updated prep exam.
100% Pass Quiz 2026 1z1-076: Oracle Database 19c: Data Guard Administration Accurate Exam CollectionWe have professional experts editing 1z1-076 valid prep training once the real exam questions changes, We guarantee that you can pass the exam at one time even within one week based on practicing our 1z1-076 exam materials regularly.
- Exam 1z1-076 Collection, Oracle 1z1-076 Complete Exam Dumps: Oracle Database 19c: Data Guard Administration Pass for Sure 🍾 Search for ➠ 1z1-076 🠰 and download it for free on ⮆ [url]www.examcollectionpass.com ⮄ website 🐜Test 1z1-076 Dates[/url]
- Examcollection 1z1-076 Vce 🥃 1z1-076 Best Vce ‼ 1z1-076 New Dumps Files ⛺ Search for 1z1-076 and download it for free immediately on [url]www.pdfvce.com 🦹Valid 1z1-076 Test Question[/url]
- Efficient Exam 1z1-076 Collection | Amazing Pass Rate For 1z1-076 Exam | Professional 1z1-076: Oracle Database 19c: Data Guard Administration 🚟 Search for { 1z1-076 } and download exam materials for free through [ [url]www.exam4labs.com ] 🥺Test 1z1-076 Dates[/url]
- Oracle 1z1-076 Exam | Exam 1z1-076 Collection - Try 1z1-076 Complete Exam Dumps Free and Buy Easily 🎁 Search for ▛ 1z1-076 ▟ and easily obtain a free download on ⮆ [url]www.pdfvce.com ⮄ 🐭Exam 1z1-076 Duration[/url]
- Test 1z1-076 Dates ☎ 1z1-076 Online Version 🍍 1z1-076 Valid Vce 🛤 Simply search for 1z1-076 for free download on [ [url]www.vceengine.com ] 😨Valid 1z1-076 Study Guide[/url]
- Exam 1z1-076 Duration 🏹 1z1-076 Online Version 🎅 Examcollection 1z1-076 Vce 💘 Immediately open ▶ [url]www.pdfvce.com ◀ and search for 1z1-076 to obtain a free download 🎦Valid 1z1-076 Study Guide[/url]
- 1z1-076 New Braindumps Pdf ❗ Latest 1z1-076 Test Voucher ↪ Verified 1z1-076 Answers 🍢 Simply search for ➥ 1z1-076 🡄 for free download on ⏩ [url]www.examdiscuss.com ⏪ 👺Test 1z1-076 Dates[/url]
- Latest 1z1-076 Exam Tips ☝ Verified 1z1-076 Answers 📴 Latest 1z1-076 Exam Tips 🚤 Download { 1z1-076 } for free by simply entering [url]www.pdfvce.com website 🐓1z1-076 Best Vce[/url]
- Free PDF 1z1-076 - Oracle Database 19c: Data Guard Administration High Hit-Rate Exam Collection 🍼 Download 1z1-076 for free by simply searching on ➠ [url]www.practicevce.com 🠰 🚀Valid 1z1-076 Test Question[/url]
- Pass Guaranteed Reliable Oracle - 1z1-076 - Exam Oracle Database 19c: Data Guard Administration Collection 😘 Search on [url]www.pdfvce.com for ⏩ 1z1-076 ⏪ to obtain exam materials for free download 🍾Latest 1z1-076 Test Voucher[/url]
- 1z1-076 Trustworthy Exam Content 🍎 1z1-076 Valid Vce 🙀 1z1-076 Pdf Torrent 📇 Search on ⏩ [url]www.practicevce.com ⏪ for 1z1-076 to obtain exam materials for free download 🚦1z1-076 Best Vce[/url]
- www.stes.tyc.edu.tw, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, bbs.t-firefly.com, bbs.t-firefly.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, hillparkpianolessons.nz, Disposable vapes
P.S. Free 2026 Oracle 1z1-076 dumps are available on Google Drive shared by VCEDumps: https://drive.google.com/open?id=1DkZA5rnoTWK3wRAIdTtgDm18BIpPGvkA
