DP-600ԇ}죬DP-600}Md
Posted at 1/20/2026 01:00:33
View149
Replies3
ȻŬ@MicrosoftDP-600ԇJC҂Fast2test㌍Fĉ룬Fast2test MicrosoftDP-600ԇӖYƷ|õӖYϣṩһõČWƽ_}Μʂ@ԇԴ_ٷְٳɹǷdzεģmĕrgWǾx҂Fast2test MicrosoftDP-600ԇӖYϣ㌢옷pĜʂ俼ԇ
MicrosoftDP-600ԇĿ֪MicrosoftDP-600ԇDZ^ͨ^ģͨɹıؽ֮·Բòxͨ^IrֵЙͨ^yԇJC҂Fast2testOӋĿԇԇ}𰸰ͬᘌԣwV]κ߄eYϷʽԳԽFast2test^ǎͨ^yԇƿԇԇ}𰸡^˶˵ʹýYCFast2testͨ^ʸ_100%Fast2testΨһmͨ^ԇķʽx춄һõδ
DP-600}MdDP-600JCָFast2testΨһܹoゃȫMicrosoft DP-600 JCԇPYϵľWվFast2testṩYͨ^Microsoft DP-600 JCԇDzɆ}ģԺܸߵķ֔ͨ^ԇõPJC
µ Microsoft Certified DP-600 Mԇ} (Q32-Q37):} #32
Note: This section contains one or more sets of questions with the same scenario and problem. Each question presents a unique solution to the problem. You must determine whether the solution meets the stated goals.
More than one solution in the set might solve the problem. It is also possible that none of the solutions in the set solve the problem.
After you answer a question in this section, you will NOT be able to return. As a result, these questions do not appear on the Review Screen.
Your network contains an on-premises Active Directory Domain Services (AD DS) domain named contoso.
com that syncs with a Microsoft Entra tenant by using Microsoft Entra Connect.
You have a Fabric tenant that contains a semantic model.
You enable dynamic row-level security (RLS) for the model and deploy the model to the Fabric service.
You query a measure that includes the username () function, and the query returns a blank result.
You need to ensure that the measure returns the user principal name (UPN) of a user.
Solution: You create a role in the model.
Does this meet the goal?
𰸣A
}f
Topic 1, Contoso, ltd.
Overview
Contoso, ltd. is a US-based health supplements company, Contoso has two divisions named Sales and Research. The Sales division contains two departments named Online Sales and Retail Sales. The Research division assigns internally developed product lines to individual teams of researchers and analysts.
Identity Environment
Contoso has a Microsoft Entra tenant named contoso.com. The tenant contains two groups named ResearchReviewersGroupi and ReseachReviewefsGfoup2.
Data Environment
Contoso has the following data environment
* The Sales division uses a Microsoft Power B1 Premium capacity.
* The semantic model of the Online Sales department includes a fact table named Orders that uses import mode. In the system of origin, the OrderlD value represents the sequence in which orders are created.
* The Research department uses an on-premises. third-party data warehousing product.
* Fabric is enabled for contoso.com.
* An Azure Data Lake Storage Gen2 storage account named storage1 contains Research division data for a product line named Producthne1. The data is in the delta format.
* A Data Lake Storage Gen2 storage account named storage2 contains Research division data for a product line named Productline2. The data is in the CSV format.
Planned Changes
Contoso plans to make the following changes:
* Enable support for Fabric in the Power Bl Premium capacity used by the Sales division.
* Make all the data for the Sales division and the Research division available in Fabric.
* For the Research division, create two Fabric workspaces named Producttmelws and Productline2ws.
* in Productlinelws. create a lakehouse named LakehouseV
* In Lakehouse1. create a shortcut to storage1 named ResearchProduct.
Data Analytics Requirements
Contoso identifies the following data analytics requirements:
* All the workspaces for the Sales division and the Research division must support all Fabric experiences.
* The Research division workspaces must use a dedicated, on-demand capacity that has per-minute billing.
* The Research division workspaces must be grouped together logically to support OneLake data hub filtering based on the department name.
* For the Research division workspaces, the members of ResearchRevtewersGroupl must be able to read lakehouse and warehouse data and shortcuts by using SQL endpoints.
* For the Research division workspaces, the members of ResearchReviewersGroup2 must be able to read lakehouse data by using Lakehouse explorer.
* All the semantic models and reports for the Research division must use version control that supports branching Data Preparation Requirements Contoso identifies the following data preparation requirements:
* The Research division data for Producthne2 must be retrieved from Lakehouset by using Fabric notebooks.
* All the Research division data in the lakehouses must be presented as managed tables in Lakehouse explorer.
Semantic Model Requirements
Contoso identifies the following requirements for implementing and managing semantic models;
* The number of rows added to the Orders table during refreshes must be minimized.
* The semantic models in the Research division workspaces must use Direct Lake mode.
General Requirements
Contoso identifies the following high-level requirements that must be considered for all solutions:
* Follow the principle of least privilege when applicable
* Minimize implementation and maintenance effort when possible.
} #33
You need to ensure that Contoso can use version control to meet the data analytics requirements and the general requirements. What should you do?
- A. Store all the semantic models and reports in Data Lake Gen2 storage.
- B. Store all the semantic models and reports in Microsoft OneDrive.
- C. Modify the settings of the Research division workspaces to use an Azure Repos repository.
- D. Modify the settings of the Research workspaces to use a GitHub repository.
𰸣C
}f
Requirement: "All the semantic models and reports for the Research division must use version control that supports branching." Fabric supports Git integration (Azure Repos or GitHub) for semantic models and reports.
Storing in Data Lake Gen2 or OneDrive does not provide version control with branching.
The correct action is to integrate workspaces with a Git repository.
The answer: D. Modify the settings of the Research division workspaces to use an Azure Repos repository.
} #34
You have a Fabric tenant that contains a warehouse.
A user discovers that a report that usually takes two minutes to render has been running for 45 minutes and has still not rendered.
You need to identify what is preventing the report query from completing.
Which dynamic management view (DMV) should you use?
- A. sys.dm-exec_requests
- B. sys.dm._exec._connections
- C. sys.dn_.exec._sessions
- D. sys.dm_pdw_exec_requests
𰸣B
}f
The correct DMV to identify what is preventing the report query from completing is sys.
dm_pdw_exec_requests (D). This DMV is specific to Microsoft Analytics Platform System (previously known as SQL Data Warehouse), which is the environment assumed to be used here. It provides information about all queries and load commands currently running or that have recently run. References = You can find more about DMVs in the Microsoft documentation for Analytics Platform System.
} #35
You have a Fabric tenant that contains a warehouse named Warehouse1. Warehouse1 contains three schemas named schemaA, schemaB. and schemaC You need to ensure that a user named User1 can truncate tables in schemaA only.
How should you complete the T-SQL statement? To answer, select the appropriate options in the answer area.
𰸣
}f
* GRANT ALTER ON SCHEMA::schemaA TO User1;
The ALTER permission allows a user to modify the schema of an object, and granting ALTER on a schema will allow the user to perform operations like TRUNCATE TABLE on any object within that schema. It is the correct permission to grant to User1 for truncating tables in schemaA.
References =
* GRANT Schema Permissions
* Permissions That Can Be Granted on a Schema
} #36
You have a Fabric workspace that contains a warehouse named Warehouse!. Warehousel contains the following data.
You need to create a T-SQL statement that will denormalize the tables and include the ContractType and StartDate attributes in the results. The solution must meet the following requirements:
* Include attributes from matching rows in the Contract table.
* Ensure that all the rows from the Employee table are preserved.
* Return the total number of employees per contract type for all the contract types that have more than two employees.
How should you complete the statement? To answer, select the appropriate options in the answer area.
𰸣
}f
} #37
һݚDǧfYĪɔ؎S̹֮Ȼʧ֮Ȼcڄe˵xYHcԼğPhFast2test MicrosoftDP-600ԇӖYόɾx͵ĵһһͨ^˶XDyoȵMicrosoftDP-600ԇJC@@JCͿcğ_ʼµọ́չ᰿裬ɾx
DP-600}Md: https://tw.fast2test.com/DP-600-premium-file.html
҂ṩƵգُFast2testWYϵĿ͑ṩۙգُDP-600WYİ(ȅͨ^ԇĿ͑ṩ)M}WYϵķգͨ^Microsoft DP-600 JCԇՈx҂Fast2testȡúõijɿԣҪFast2testDP-600}Ʒ|ˣͬӔDP-600}һ_ʼҪ50犣҂ҪŬѕrgs̵45犣40犣ȻѾrgɣDP-600}ҪxԣMicrosoft DP-600ԇ} @ΕrgȣֻҪ͑rϵ҂҂̵ĕrgȰµĿ}WYͨ^]lͽo͑, _͑܉µĿԇ֪Rc҂ṩПTJCԇWYϣаPDFӰ汾ܛ汾DP-600}߀APPھ汾֧xʹã㿼xʹá
RҲֱˮl؟Ҽ ]h̎ȥ҂ṩƵգُFast2testWYϵĿ͑ṩۙգُDP-600WYİ(ȅͨ^ԇĿ͑ṩ)M}WYϵķա
ЧDP-600ԇ} |ͨ^ʵĿԇ|ĜʂDP-600}Mdͨ^Microsoft DP-600 JCԇՈx҂Fast2testȡúõijɿԣҪFast2testDP-600}Ʒ|ˣͬӔDP-600}һ_ʼҪ50犣҂ҪŬѕrgs̵45犣40犣ȻѾrgɡ
DP-600}Ҫxԡ
- |DP-600ԇ}YԇеIߺǵMicrosoft Implementing Analytics Solutions Using Microsoft Fabric ⛴ ڡ [url]www.vcesoft.com DP-600 K@ȡMdDP-600JC[/url]
- DP-600C 🧓 DP-600}YԴ 🕝 DP-600ͨ^ԇ 🔫 [url]www.newdumpspdf.com ṩM DP-600 }ռDP-600yԇ[/url]
- _DP-600ԇ}ģM挍ԇhcܛVCE汾IDP-600Implementing Analytics Solutions Using Microsoft Fabric 📠 { [url]www.pdfexamdumps.com }ϵMd✔ DP-600 ️✔️_DP-600C[/url]
- µDP-600ԇ} |ͨ^ʵĿԇ|DP-600}Md 🐴 Md☀ DP-600 ️☀️ֻ[ [url]www.newdumpspdf.com ]DP-600yԇ[/url]
- ʹ挍Microsoft DP-600ԇ}ʂMicrosoft DP-600ԇpͨ^ 🧺 ✔ tw.fast2test.com ️✔️Wվϲҡ DP-600 }DP-600ԇV
- |DP-600ԇ}죬wMicrosoftJCDP-600ԇ֪Rc 🐍 _{ [url]www.newdumpspdf.com }ݔ☀ DP-600 ️☀️K@ȡMdDP-600}[/url]
- DP-600Y 💮 DP-600T} 🚦 DP-600Cտԇ 👛 ▷ [url]www.vcesoft.com ◁WվdM DP-600 }ռDP-600}YԴ[/url]
- DP-600ͨ^ԇ ❓ DP-600} 🍛 DP-600Cտԇ 😍 }uWַ▷ [url]www.newdumpspdf.com ◁_K▶ DP-600 ◀MdDP-600}YԴ[/url]
- DP-600JC} 🦇 DP-600}YԴ 🍸 DP-600CϢ 💮 [url]www.pdfexamdumps.com Wվ➠ DP-600 🠰KMdDP-600}YԴ[/url]
- |DP-600ԇ}죬wMicrosoftJCDP-600ԇ֪Rc 💇 ✔ [url]www.newdumpspdf.com ️✔️✔ DP-600 ️✔️}DP-600T}[/url]
- ʂֵDP-600ԇ}YԇIȲṩ̣ʴ_DP-600}Md 🥴 ▶ [url]www.newdumpspdf.com ◀ DP-600 ԫ@ȡMdDP-600Cտԇ[/url]
- www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.pcsq28.com, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, www.stes.tyc.edu.tw, blogfreely.net, Disposable vapes
