[Hardware] Newest CIS-Discovery Exam Collection - CIS-Discovery Practice Torrent & CIS-
107
【Hardware】 Newest CIS-Discovery Exam Collection - CIS-Discovery Practice Torrent & CIS-
Posted at 1/20/2026 01:54:22      View:170 | Replies:1        Print      Only Author   [Copy Link] 1#
What's more, part of that TestPDF CIS-Discovery dumps now are free: https://drive.google.com/open?id=1GFtfL8FV-94mIkOCL-7wabHsgkeD-0mo
Obtaining a certificate for an exam can have many benefits, and it will build up your competitive force in the job market and help you to enter a big enterprise and so on. CIS-Discovery exam braindumps of us will help you get the certificate successfully. With professional experts to revise the questions and answers, CIS-Discovery Exam Braindumps are of high quality. CIS-Discovery exam dumps contain knowledge points, and it can help you have a good command of the exam. Choose us, it will become more easily for you to pass the exam.
It can be said that all the content of the CIS-Discovery study materials are from the experts in the field of masterpieces, and these are understandable and easy to remember, so users do not have to spend a lot of time to remember and learn. It takes only a little practice on a daily basis to get the desired results. Especially in the face of some difficult problems, the user does not need to worry too much, just learn the CIS-Discovery Study Materials provide questions and answers, you can simply pass the exam. This is a wise choice, and in the near future, after using our CIS-Discovery training materials, you will realize your dream of a promotion and a raise, because your pay is worth the rewards.
ServiceNow CIS-Discovery Latest Exam Notes, Exam CIS-Discovery QuizzesIf you want to pass the exam quickly, CIS-Discovery prep guide is your best choice. We know that many users do not have a large amount of time to learn. In response to this, we have scientifically set the content of the data. You can use your piecemeal time to learn, and every minute will have a good effect. In order for you to really absorb the content of CIS-Discovery Exam Questions, we will tailor a learning plan for you. This study plan may also have a great impact on your work and life. As long as you carefully study the CIS-Discovery study guide for twenty to thirty hours, you can go to the CIS-Discovery exam.
ServiceNow Certified Implementation Specialist - Discovery Sample Questions (Q11-Q16):NEW QUESTION # 11
During the Discovery process, what determines if an Asset record is created?
  • A. Model Product
  • B. Model Category
  • C. ECC Queue
  • D. CMDB
  • E. Configuration Item
During the Discovery process, the Model Category of the Configuration Item (CI) determines if an Asset record is created. A Model Category is a grouping of models that share the same asset tracking strategy and the same CI and Asset tables. The asset tracking strategy defines whether Discovery creates an Asset record for each CI of that Model Category. There are three possible asset tracking strategies: Create Assets, Don't create Assets, and Create Consumable Assets12.
* 1: ServiceNow Discovery Documentation, Model Categories section
* 2: ServiceNow Support Article, Why do Assets get created when inserting a CI that has a Model that is set to Don't create Assets?
NEW QUESTION # 12
What midserver parameter should be configured on the midserver record to disable the use of service credential(if all the configured credentials dont work).
Response:
  • A. mid.windows.management_protocol
  • B. mid.poll.time
  • C. mid.powershell.local_mia_service_crea entialiallback
NEW QUESTION # 13
Which of the following choices may be global variables for steps in horizontal discovery patterns? (Choose two.)
  • A. computer_system
  • B. baseline
  • C. process
  • D. system
Global variables are variables that are automatically available for all steps in horizontal discovery patterns.
They store information about the target CI, such as its IP address, host name, operating system, and credentials. There are two global variables that may be used for steps in horizontal discovery patterns: system and computer_system. The system variable contains the information about the target CI's IP address, host name, and credentials. The computer_system variable contains the information about the target CI's operating system, such as its name, version, and architecture12.
* Patterns and horizontal discovery - Product Documentation: Tokyo - Now Support Portal
* Horizontal Pattern probe - Product Documentation: San Diego - Now Support Portal
NEW QUESTION # 14
Which best describes Discovery schedule of type Configuration Item?
  • A. Verifies Configuration Item data from the scanned IP ranges against the data in the CMDB.
  • B. Directly populates records in the assets table.
  • C. Collects complete information from the scanned IP ranges and sends it to the CMDB.
  • D. Creates only a list of discovered IPs in both IPv4 and IPv6 formats.
A Discovery schedule of type Configuration Item collects complete information from the scanned IP ranges and sends it to the CMDB. This type of schedule runs a series of probes and sensors to identify and classify the devices and applications on the network, and to create or update the corresponding configuration items in the CMDB. A Discovery schedule of type Configuration Item can also run patterns to discover more details and relationships about the configuration items.
ServiceNow Discovery Overview
Create a Discovery schedule
Discovery schedule types
NEW QUESTION # 15
Device has both SNMP and SSH port open but during first discovery SSH failed am SNMP succeeded, What kind Affinity will be saved for future.
Response:
  • A. IP Service Affinity
  • B. Credential Affinity
NEW QUESTION # 16
For candidates who are going to buy the exam dumps for the exam, the quality must be one of the most standards while choosing the exam dumps. CIS-Discovery exam dumps are high quality and accuracy, since we have a professional team to research the first-rate information for the exam. We have reliable channel to ensure that CIS-Discovery Exam Materials you receive is the latest one. We offer you free update for one year, and the update version for CIS-Discovery exam materials will be sent to your automatically. We have online and offline service, and if you have any questions for CIS-Discovery exam dumps, you can consult us.
CIS-Discovery Latest Exam Notes: https://www.testpdf.com/CIS-Discovery-exam-braindumps.html
ServiceNow Exam CIS-Discovery Simulator Online It has been a long time in certified IT industry with well-known position and visibility, Our CIS-Discovery exam questions can help you achieve all of your dreams, ServiceNow Exam CIS-Discovery Simulator Online The only thing you have to do is just to make your choice and study, If you face any problems while using our CIS-Discovery software, you can reach out to use and our technical experts will help you resolve the problems that you are facing, If you buy and use our CIS-Discovery study materials, you will cultivate a good habit in study.
Part I Fundamentals, Prior to founding Designs on Talent, Linda CIS-Discovery spent her professional career leading talent acquisition and talent management teams for Gap, Pepsi/Pizza Hut, and Home Depot.
ServiceNow CIS-Discovery PDF Questions-Turn Your Exam Fear Into ConfidenceIt has been a long time in certified IT industry with well-known position and visibility, Our CIS-Discovery Exam Questions can help you achieve all of your dreams, The only thing you have to do is just to make your choice and study.
If you face any problems while using our CIS-Discovery software, you can reach out to use and our technical experts will help you resolve the problems that you are facing.
BONUS!!! Download part of TestPDF CIS-Discovery dumps for free: https://drive.google.com/open?id=1GFtfL8FV-94mIkOCL-7wabHsgkeD-0mo
Posted at 3/7/2026 21:42:28        Only Author  2#
I’m so thankful for your article, it’s definitely been eye-opening. Exam questions MuleSoft-Integration-Architect-I vce offers great content that I hope helps you, and it's entirely free.
